2 Replies Latest reply on Oct 28, 2015 9:24 AM by resdesign
    IE8 Finds Error in edge.6.0.0.min.js file with "if(b===b.window)"
    Happiest Camper
      I am finishing up the first stage of a large project in Edge Animate and everything is working in current browsers.
      The last phase is to get all the files working in IE8, which unfortunately has to happen.  I used Modernizr to have a fallback for my .SVGs and off I went to test it.
      In IE8 for Windows XP I receive the error, 'window' is null or not an object, and the error refers me to the line in the edge.6.0.0.min.js file...
      if(b===b.window)
      I have no idea what to do from here as this is code written by Edge and I do not know what this references nor understand the code's purpose... any suggestions at all?
      Here is the full code from the .js file if that helps anyone, but I'm horribly stuck with a deadline on Friday so any help will be eternally appreciated, including more information on what this file contains.  Thanks.
      (function(f,r,u){function e(a){return!a||"loaded"==a||"complete"==a||"uninitialized"==a}function p(){var a=c.shift();n=1;a?a.t?s(function(){("c"==a.t?w.injectCss:w.injectJs)(a.s,0,a.a,a.x,a.e,1)},0):(a(),p()):n=0}function h(g,d,m,t,v,f,h){function l(a){if(!z&&e(y.readyState)&&(q.r=z=1,!n&&p(),a)){"img"!=g&&s(function(){k.removeChild(y)},50);for(var b in B[d])if(B[d].hasOwnProperty(b))B[d][b].onload();y.onload=y.onreadystatechange=null}}h=h||w.errorTimeout;var y=r.createElement(g),z=0,A=0,q={t:m,s:d,
      e:v,a:f,x:h};1===B[d]&&(A=1,B[d]=[]);"object"==g?(y.data=d,y.setAttribute("type","text/css")):(y.src=d,y.type=g);y.width=y.height="0";y.onerror=y.onload=y.onreadystatechange=function(){l.call(this,A)};c.splice(t,0,q);"img"!=g&&(A||2===B[d]?(P(),k.insertBefore(y,a?null:b),s(l,h)):B[d].push(y))}function l(a,b,g,d,k){n=0;b=b||"j";z(a)?h("c"==b?y:m,a,b,this.i++,g,d,k):(c.splice(this.i++,0,a),1==c.length&&p());return this}function q(){var a=w;a.loader={load:l,i:0};return a}var x=r.documentElement,s=f.setTimeout,
      b=r.getElementsByTagName("script")[0],d={}.toString,c=[],n=0,v=function(){},t="MozAppearance"in x.style,a=t&&!!r.createRange().compareNode,k=a?x:b.parentNode,g=f.opera&&"[object Opera]"==d.call(f.opera),g=!!r.attachEvent&&!g,x="webkitAppearance"in x.style&&!("async"in r.createElement("script")),m=t?"object":g||x?"script":"img",y=g?"script":x?"img":m,A=Array.isArray||function(a){return"[object Array]"==d.call(a)},z=function(a){return"string"==typeof a},E=function(a){return"[object Function]"==d.call(a)},
      P=function(){b&&b.parentNode||(b=r.getElementsByTagName("script")[0])},Q=[],B={},L={timeout:function(a,b){b.length&&(a.timeout=b[0]);return a}},M,w;w=function(a){function b(a){a=a.split("!");var g=Q.length,c=a.pop(),d=a.length,c={url:c,origUrl:c,prefixes:a},m,k,n;for(k=0;k<d;k++)n=a[k].split("="),(m=L[n.shift()])&&(c=m(c,n));for(k=0;k<g;k++)c=Q[k](c);return c}function g(a){a=a.split("?")[0];return a.substr(a.lastIndexOf(".")+1)}function c(a,d,m,k,n){var t=b(a),e=t.autoCallback;g(t.url);if(!t.bypass){d&&
      (d=E(d)?d:d[a]||d[k]||d[a.split("/").pop().split("?")[0]]);if(t.instead)return t.instead(a,d,m,k,n);B[t.url]&&!0!==t.reexecute?t.noexec=!0:B[t.url]=1;a&&m.load(t.url,t. forceCSS||!t.forceJS&&"css"==g(t.url)?"c":u,t.noexec,t.attrs,t.timeout);(E(d)||E(e))&&m.load(function(){q();d&&d(t.origUrl,n,k);e&&e(t.origUrl,n,k);B[t.url]=2})}}function d(a,b){function g(a,d){if(""!==a&&!a)!d&&e();else if(z(a))d||(n=function(){var a=[].slice.call(arguments);t.apply(this,a);e()}),c(a,n,b,0,k);else if(Object(a)===a)for(h in f=
      function(){var b=0,g;for(g in a)a.hasOwnProperty(g)&&b++;return b}(),a)a.hasOwnProperty(h)&&(d||--f||(E(n)?n=function(){var a=[].slice.call(arguments);t.apply(this,a);e()}:n[h]=function(a){return function(){var b=[].slice.call(arguments);a&&a.apply(this,b);e()}}(t[h])),c(a[h],n,b,h,k))}var k=!!a.test,m=a.load||a.both,n=a.callback||v,t=n,e=a.complete||v,f,h;g(k?a.yep:a.nope,!!m| |!!a.complete);m&&g(m);!m&&a.complete&&g("")}var m,k,n=this.yepnope.loader;if(z(a))c(a,0,n,0);else if(A(a))for(m=0;m<a.length;m++)k=
      a[m],z(k)?c(k,0,n,0):A(k)?w(k):Object(k)===k&&d(k,n);else Object(a)===a&&d(a,n)};w.addPrefix=function(a,b){L[a]=b};w.addFilter=function(a){Q.push(a)};w.errorTimeout=1E4;null==r.readyState&&r.addEventListener&&(r.readyState="loading",r.addEventListener("DOMContentLoaded",M=function(){r.removeEventListener("DOMContentLoaded",M,0);r.readyState="complete"},0));f.yepnope=q();f.yepnope.executeStack=p;f.yepnope.injectJs=function(a,g,c,d,m,k){var n=r.createElement("script"),t,h;d=d||w.errorTimeout;n.src=
      a;for(h in c)n.setAttribute(h,c[h]);g=k?p:g||v;n.onreadystatechange=n.onload=function(){!t&&e(n.readyState)&&(t=1,g(),n.onload=n.onreadystatechange=null)};s(function(){t||(t=1,g(1))},d);P();m?n.onload():b.parentNode.insertBefore(n,b)};f.yepnope.injectCss=function(a,g,c,d,m,k){d=r.createElement("link");var n;g=k?p:g||v;d.href=a;d.rel="stylesheet";d.type="text/css";for(n in c)d.setAttribute(n,c[n]);m||(P(),b.parentNode.insertBefore(d,b),s(g,0))}})(this,document);
      "function"!=typeof Array.prototype.forEach&&(Array.prototype.forEach=function(f){for(var r=0;r<this.length;r++)f.apply(this,[this[r],r,this])});"function"!==typeof String.prototype.trim&&(String.prototype.trim=function(){return this.replace(/^\s+|\s+$/g,"")});var aBootcompsLoaded=[];window.AdobeEdge=window.AdobeEdge||{};
      (function(f){function r(a){return"[object Array]"===Object.prototype.toString.call(a)}function u(a,b){var g;for(g=0;a&&g<a.length;g++)b[b.length++]=a[g]}function e(a,b){var g,c;if(r(a))for(c=a.length,g=0;g<c;g++)b(g,a[g]);else for(g in a)a.hasOwnProperty(g)&&b(g,a[g])}function p(a){var b=V.style,g,c;for(c=0;c<a.length;c++)if(g=a[c],void 0!==b[g])return!0;return!1}function h(a){a=""+a;if(!G.rgba&&0==a.indexOf("rgba")){var b=a.lastIndexOf(",");0<b&&(a="rgb("+a.substring(5,b)+")")}return a}function l(a){var b;
      e(a,function(a,g){null!==g&&(b=!0)});return!b}function q(a,b){e(b,function(b,g){a[b]=g});return a}function x(a){var b={};b.num=parseFloat(a);b.units=String(a).match(/[a-zA-Z%]+$/);r(b.units)&&(b.units=b.un its[0]);return b}function s(a){return a.replace(/^-ms-/,"ms-").replace(/-([a-z]|[0-9])/ig,function(a,b){return String(b).toUpperCase()})}function b(a){var g;AdobeEdge.Notifier.call(this);this.length=0;if(!a)return this;if(a instanceof b)return a;if("string"===typeof a)if(a=a.trim(),/^#([\w\-]+)$/.test(a))(g=
      D.getElementById(a.substring(1)))&&(this[this.length++]=g);else if(/<|&#?\w+;/.test(a)){g=this.length++;var c=a;a=document.createElement("div");var d=(ma.exec(c)||["",""])[1].toLowerCase(),d=da[d]||da._default;a.innerHTML=d[1]+c.replace(na,"<$1></$2>")+d[2];for(c=d[0];c--;)a=a.lastChild;this[g]=a}else u(D.querySelectorAll(a),this);else{g=a;c=g.length;g=null!==g&&g===g.window?!1:1===g.nodeType&&c?!0:r(g)||"function"!==typeof g&&(0===c||"number"===typeof c&&0<c&&c-1 in g);if(g)return u(a,this);a.nodeType?
      this[this.length++]=a:oa.call(this,a)}return this}function d(a){return new b(a)}function c(a){return a.parent().hasClass("center-wrapper")}function n(a){c(a)||a.wrap("<div class='flow-wrapper' style='width:1px'><div class='center-wrapper'></div></div>")}function v(a,b,g,m,k,t){function e(){var k=c(a),n=k?a.parent().parent().parent():a.parent(),h=n.width(),v=n.height(),f=a.width(),l =a.height(),y=d(window).height(),s=1;(n="body"===n[0].nodeName.toLowerCase())&&(v=y);t||(v=d(window).height(),h=d(window).width());
      h=Math.round(h);v=Math.round(v);h/=f;v/=l;"both"===b?s=Math.min(h,v):"height"===b?s=v:"width"===b&&(s=h);void 0!==m&&(s=Math.min(s,m/f));void 0!==g&&(s=Math.max(s,g/f));a.css("-o-transform-origin","0 0");a.css("-ms-transform-origin","0 0");a.css("-webkit-transform-origin","0 0");a.css("-moz-transform-origin","0 0");a.css("-o-transform-origin","0 0");a.css("transform-origin","0 0");v="scale("+s+")";a.css("-o-transform",v);a.css("-ms-transform",v);a.css("-webkit-transform",v);a.css("-moz-transform",
      v);a.css("-o-transform",v);a.css("transform",v);n&&!k||a.parent().height(Math.round(l*s)).width(Math.round(f*s));k&&(k=a.parent().pare nt(),k.height(Math.round(l*s+a.offset().top-k.offset().top)))}k?d.data(a[0],"alreadyWrapped")||(d.data(a[0],"alreadyWrapped",!0),d(window).bind("resize",function(){e()}),W(function(){e()})):c(a)||(n(a),d(window).bind("resize",function(){e()}),e())}function t(a,b){var g=d(a);c(g)&&(g=g.parent());if("both"===b||"horizontal"===b)g.css("position","absolute"),g.css("margin-left",
      "auto"),g.css("margin-right","auto"),g.css("left","0"),g.css("right","0");if("both"===b||"vertical"===b)g.css("position","absolute"),g.css("margin-top","auto"),g.css("margin-bottom","auto"),g.css("top","0"),g.css("bottom","0")}function a(){var a=this.notifier={};a.obs=[];a.lvl=0}function k(a,b,g){if(b){g||(g={});g.methodName=b;var c=a.notifier,d=c.obs,k,m;c.lvl++;for(k=0;k<d.length;k++)if(m=(m=d[k])&&!m.deleted?m.o:void 0)if("function"===typeof m)m(b,a,g);else if(m[b])m[b](a,g);c.lvl--;if(0===c.lvl)for(a=
      d.length,k=a-1;0<=k;k--)d[k].deleted&&d.splice(k,1)}}function g(a,b,g){var c,d,k,m,n=g?"":" ",t=/\S+/g,e=/[\t\r\n\f]/g;if(g?"undefined"===typeof b||"string"===typeof b&&b:"string"===typeof b&&b)c=(b||"").match(t)||[],a.each(function(a,t){if(d=1===t.nodeType&&(t.className?(" "+t.className+" ").replace(e," "):n)){for(m=0;k=c[m++];)if(g)for(;0<=d.indexOf(" "+k+" ");)d=d.replace(" "+k+" "," ");else 0>d.indexOf(" "+k+" ")&&(d+=k+" ");t.className=g?b?d.trim():"":d.trim()}})}function m(a,b){var g,c="#"==
      b[0],d=!c&&"."==b[0],k=c||d?b.slice(1):b,m=/^[\w-]*$/.test(k);return null!=a&&a.nodeType==a.DOCUMENT_NODE&&m&&c?(g=a.getElementById(k))?[g]:[]:1!==a.nodeType&&9!== a.nodeType?[]:Array.prototype.slice.call(m&&!c?d?a.getElementsByClassName(k):a.getElements ByTagName(b):a.querySelectorAll(b))}function y(a,b){b=b.replace(/=#\]/g,'="#"]');var g,c,d=pa.exec(b);d&&d[2]in fa&&(g=fa[d[2]],c=d[3],b=d[1],c&&(d=Number(c),c=isNaN(d)?c.replace(/^["']|["']$/g,""):d));if(!b)return!g||g.call(a,null,c)===a;if(!b||!a||
      1!==a.nodeType)return!1;if(g=a.webkitMatchesSelector||a.mozMatchesSelector||a.oMatchesSelector||a.matchesSelector)return g.call(a,b);c=a.parentNode;(g=!c)&&(c=tempParent).appendChild(a);d=~m(c,b).indexOf(a);g&& tempParent.removeChild(a);return d}function A(a){a=d(a);return!(!a.width()&&!a.height())&&"none"!==a.css("display")}function z(a,b,g){function c(a){g._l[b]=null;l(g._l)&&k(g,"assetsLoaded",{inst:a.target})}if(!AdobeEdge.supported.addEventListener)return b;if(g&&"string"===typeof b&&!g._l[b])switch(a){case "image":a=
      new Image;a.addEventListener("error",c);a.addEventListener("load",c);a.src=b;g._l[b]=a;break;case "audio":a=new Audio;a.addEventListener("error",c);a.addEventListener("canplaythrough",c);a.src=b;g._l[b]=a;break;case "video":a=document.createElement("video"),a.addEventListener("error",c),a.addEventListener("canplaythrough",c),a.src=b,g._l[b]=a}}function E(a,b){var g=q({name:a,conf:b,apply:function(a,b){1===this.conf.a?a.attr(this.name,b):(1===this.conf.cb&&(a.css("-webkit-"+this.name,b),a.css("-ms-"+
      this.name,b),a.css("-moz-"+this.name,b),a.css("-o-"+this.name,b)),a.css(this.name,b))},units:function(a){var b;"auto"!==a&&this.conf.u&&("string"===typeof a&&(b=x(a)),b&&b.units||(a+=this.conf.u));return a},prep:function(a,b,g,c,d,k,m){void 0!==c&&b[g]?(void 0===b[g][c]&&k&&(c=k),void 0!==d&&b[g][c]?a=b[g][c][d]:(a=b[g][c],void 0===a&&(a=this.conf.d))):a=b[g];void 0!==a&&(a=this.units(a),1===this.conf.p&&z(b.type,m._getFullURL(a),m),this.conf.t&&(a=this.conf.t.replace("@@0",a)));return a},render:function(a,
      b,g){var c=this.conf.f||this.name;void 0===b[c]||void 0!==this.conf.o&&this.conf.o!==b.tag||void 0!==this.conf.e&&this.conf.e===b.tag||(c=this.prep(a,b,c,this.conf.i,this.conf.j,this.conf.ii,g),null!==c&&void 0!==c&&this.apply(a,c,b,g))}},E.prototype);E.splitUnits=x;b.x&&(g=q(g,b.x));return g}function P(a){e(a,function(a,b){S[a]=new E(a,b)})}function Q(a,b,g,c,m,n,t,v){var h=d(document.createElement(g.tag||"div")),f=h[0];AdobeEdge.$.data(f,"domDef",g);h.attr("id",g.id);h.css("position","absolute");
      h.css("margin","0px");b&&g.symbolName&&b._applyBaseStyles(h,g.symbolName);e(S,function(b,c){c.render(h,g,a)});h.css("-webkit-tap-highlight-color","rgba(0, 0, 0, 0)");b&&b.register(f,g,b.ele?b.ele.id:"");h.addClass(h.attr("id")+"_id");v||k(AdobeEdge,"beginEle",{sym:b,ele:f,defn:{dom:g,style:c}});n&&h.addClass(n);(c=document.getElementById(f.id))&&( n=d(c).parent())&&n[0]==m&&m.removeChild(c);m.children&&0<=t&&t<m.children.length?m.insert Before(f,m.children[t]):m.appendChild(f);AdobeEdge.$.data(f,"originalId",
      g.id);AdobeEdge.$.data(f,"symParent",b);b&&(m=f.style.webkitTransform,b.gpuAccelerate&&f.style&&("undefined"===typeof m||""===m||"none"===m)?window.edge_authoring_mode&&"BODY"===f.nodeName||(f.style.webkitTransform="translateZ(0)"):!f.style.zIndex&&window.edge_authoring_mode&&(f.style.zIndex=0));b&&(v||k(b,"newEle",{ele:f,defn:g}));return h}function B(a){a.t&&(a.t=a.t.toLowerCase(),a.type=a.t);a.cs&&(a.className=a.cs);for(var b in Y)null!=a[b]&&(a[Y[b]]=a[b],a[b]=null);a.rect||(a.rect=[]);for(;4>
      a.rect.length;)a.rect[a.rect.length]=0;a.transform&&(1>a.transform.length&&(a.transform[0] =[0,0,0]),2>a.transform.length&&(a.transform[1]=[0,0,0]),3>a.transform.length&&(a.transfor m[2]=[0,0,0]),4>a.transform.length&&(a.transform[3]=[1,1,1]));a.children&&(a.c=a.children, e(a.children,function(a,b){B(b)}))}function L(a,b,g,c,m,n,t){if(m||b||b.id)m=m||d("."+b.id)[0],e(g,function(g,d){var e=Q(a,b,d,c,m,n,t++),h={sym:b,ele:e[0],defn:d};d.c&&L(a,b,d.c,void 0,e[0],n,0);k(AdobeEdge,"endEle",h)})}function M(b,
      g,c,d,m){a.call(this);c._s.push(this);q(this,{name:g,composition:c,data:b,prnt:d,tl:[],variables:m||{}});k(c,"newSymbol",{symbol:this,parent:d});return this}function w(a,b){if(b&&a.ci)for(var g=0;g<a.ci.length;++g){var c=a.ci[g];c&&w(c,b)}g=a._getTimeline()?a._getTimeline().getState():{playing:void 0};void 0==a.autoPlay||a.autoPlay?void 0==g.playing&&a.play(0):void 0==g.playing&&a.stop(-1,!1)}function F(a,b){var g,c;for(g in b)if(b.hasOwnProperty(g)){c=b[g];c.typeName=g;c.v&&(c.version=c.v);c.mv&&
      (c.minimumCompatibleVersion=c.mv);c.b&&(c.build=c.b);c.bS&&(c.baseState=c.bS);c.iS&&(c.ini tialState=c.iS);null!=c.gpu&&(c.gpuAccelerate=c.gpu);null!=c.rI&&(c.resizeInstances=c.rI);c.cn&&(c.content=c.cn);if(c.content){var d=c.content;null!=d.sI&&(d.symbolInstances=c.content.sI);if(d.symbolInstances)for(var m=0;m<d.symbolInstances.length;m++){var k=d.symbolInstances[m];null!=k.sN&&(k.symbolName=k.sN);null!=k.a&&(k.autoPlay=k.a);null!=k.x&&(k.variables=k.x)}}e(c.content.dom,function(a,b){B(b)});for(var n in c.content.style)c.content.style.hasOwnProperty(n)&&
      B(c.content.style[n]);c.cg&&(c.centerStage=c.cg);c.stf&&(c.scaleToFit=c.stf);c.x&&(c.varia bles=c.x);c.tt&&(c.timeline=c.tt);d=c.timeline;if(null!=d)for(null!=d.d&&(d.duration=d.d),null!=d.a&&(d.autoPlay=d.a),d.l&&(d.labels=d.l),c=0;c<d.data.length;c++)d.data[c]&&d.data[c][8 ]&&d.data[c][8].vt&&(d.data[c][8].valueTemplate=d.data[c][8].vt),d.data[c]&&d.data[c][1]&&"tr"===d.data[c][1]&&(d.data[c][1]=Y.tr)}a.sym=b}function I(b,c){a.call(this);this.$=d;q(this,{id:b,opts:q(c||{},aa),_urlRegExp:/^(?:[a-z]+:)?\/\//i,
      _l:{},_d:{},_s:[],loaded:function(a,b,c){this._d[a]=null;l(this._d)&&this.ready()},load:function(a,b){b||(this._d[a]=!0);var c=this;yepnope({load:this._getFullURL(a),callback:function(g,d,m){b?b(a,d,m):c.loaded(a,d,m)}})},define:function(a,b,c,g,d,m){F(this,b);this.fnt=c;this.res=d;this.fx=m;ja(b);this.registerFonts(c);var k=this;g&&0<g.length&&g.forEach(function(a){k.load(a)})},_getFullURL:function(a){return this._urlRegExp.test(a)?a:(this.opts.htmlRoot||"")+a},definePreloader:function(a){this.preloaderDOM=
      a},defineDownLevelStage:function(a){this.downLevelStageDOM=a},getStage:function(){return this.stage},registerFonts:function(a){if(a){var b,c,g,m,k,n,t;f.fonts=f.fonts||{};for(n in a)if(a.hasOwnProperty(n)&&!f.fonts[n]&&(g=a[n])&&""!==g){b=!1;for(t in f.fonts)f.fonts.hasOwnProperty(t)&&f.fonts[t]===g&&(b=!0);if(!b)if(f.fonts[n]=g,b=g.indexOf("//use.typekit.com/"),0>b&&(b=g.indexOf("//use.typekit.net/")),0>b&&(b=g.indexOf("//use.edgefonts.net/"),k=0<b,window._adobewebfontsappname_="Animate"),0<b)c=
      g.indexOf('"',b+1),0<c&&(b=g.substring(b,c),k&&"file:"===window.location.protocol&&(b="http:"+b),g=document.createElement("script"),g.src=this._getFullURL(b),g.type="text/javascript",document.getElementsByTagName("head")[0].appendChild(g),k||(m=function(){try{window.Typekit.load()}catch(a){window.setTimeout(m,100)}},window.setTimeout(m,100)));else if(0>g.indexOf("<script")&&0>g.indexOf("<link"))d("head").append(document.createTextNode(g));else if(0>g.indexOf("<script"))d("head").append(g);else if(b=
      g.indexOf(">"),c=g.indexOf("\x3c/script>"),0<b&&0<c){g=g.substring(b+1,c);try{window.eval(g)}catch(e){}}}}},getSymbols:function(a){if(!a)return this._s;var b=[];e(this._s,function(g,c){c.name===a&&b.push(c)});return b},rC:function(a){return a},rR:function(a){this.stage&&O(this.stage,a)},ready:function(){var a=this;AdobeEdge.ready(function(){a.preloaderDOM&&a.preloaderDOM.script&&(new Function("e",a.preloaderDOM.script.loading))({event:"done",progress:1,reason:"complete"});C.AdobeEdge&&C.AdobeEdge.bootstrapLoading&&
      (c=c||{},c.bootstrapLoading=!0);window.edge_authoring_mode||(c&&c.framework$&&(f.$=c.frame work$),window.jQuery&&(f.$=window.jQuery));AdobeEdge.addTouchSupport();a.bindingFn&&a.bind ingFn(f.$);var b=a.stage=new M(a.sym,"stage",a),g,m="."+a.id,k=d(m);k[0]||(k=d("body").addClass(m));b.init(k[0],"edgeLoad-"+a.id);b._applyBaseStyles(k,"stage");k.css("position","relative");if(!window.edge_authoring_mode||c.sym)if(k=b.data.stage,!k||"height"!==k.scaleToFit&&"width"!==k.scaleToFit&&"both"!==k.scaleToFit||
      n(d(m)),!k||"vertical"!==k.centerStage&&"horizontal"!==k.centerStage&&"both"!==k.centerStage||t(b.ele,k.centerStage),"height"===k.scaleToFit||"width"===k.scaleToFit||"both"===k.scaleToFit){var m=k.content.style["${stage}"]||k.content.style["${Stage}"],e,h,ca=/px|^0$/;m&&m.sizeRange&&(e=m.sizeRange[0],e=ca.test(e)?parseInt(e,10):void 0,h=m.sizeRange[1],h=ca.test(h)?parseInt(h,10):void 0);v(b.$("stage"),k.scaleToFit,e,h,!0,a.opts.bScaleToParent)}g=function(){if(a.launchCalled||a.opts.bootstrapLoading&&
      !f.doPlayWhenReady)f.readyAndWaiting.push(g);else{a.launchCalled=!0;d(".edgePreload-"+a.id).css("display","none");d(".edgeLoad-"+a.id).removeClass("edgeLoad-"+a.id);aBootcompsLoaded.push(a.id);for(var c=window.AdobeEdge.bootstrapListeners.length,k=0;k<c;k++)try{window.AdobeEdge.bootstrapListeners[k](a.id)}catch(m){console.log("bootstrap error "+m)}c=d.Event("compositionReady");c.compId=a.id;d(document).trigger(c);a.readyCalled=!0;window.edge_authoring_mode?b.stopA ll(0):w(b,!0)}};l(a._l)?g():a.addObserver({assetsLoaded:function(a,
      b){g()}})})},getCompId:function(){return this.id}});return this}function N(a){e(H,function(b,g){a=Math.min(g.rC(a),a)});return a}function J(a,b){e(H,function(g,c){var d=c[b];d&&d.call(c,a)})}function O(a,b){if(a.ci)for(var g=0;g<a.ci.length;++g){var c=a.ci[g];c&&O(c,b)}a&&a._getTimeline().tick(b)}function K(a){a({event:"begin"})}function W(a){if(U||"complete"===D.readyState)a();else if(D.addEventListener){var b=!1;D.addEventListener("DOMContentLoaded",function(g){U=!0;b||(a(),b=!0)},!1);D.onreadystatechange=
      function(){"complete"==document.readyState&&(U=!0);D.onreadystatechange=null;b||(a(),b=!0)}}else D.attachEvent&&D.attachEvent("onreadystatechange",function(b){U=!0;a(b)})}function R(a){return a&&"string"===typeof a&&(0<a.indexOf("%")||0<a.indexOf("em")||"auto"===a||"null"===a)?!1:!0}function $(a){if(!a)return 0;if("number"===typeof a)return a;var b=a.indexOf("px").val;return 0<b?(val=a.substring(0,b),parseFloat(val)):parseFloat(a)}function X(a,b,g,c,d){var k,m,n;for(k=0;k<a.length;k++)m=a[k],n="${"+
      m.id+"}",g[n]&&(b[n]=!0,m.rect||(m.rect=m.r,m.r=void 0,m.rect||(m.rect=[0,0,0,0])),m.rect&&(m.transform||(m.transform=m.tf,m.tf=void 0,m.transform||(m.transform=[])),m.transform[0]||(m.transform[0]=[0,0]),R(m.rect[0])&&(m. transform[0][0]=$(m.rect[0]),c[n]=m.transform[0][0],m.rect[0]="0px"),R(m.rect[1])&&(m.transform[0][1]=$(m.rect[1]),d[n]=m.transform[0][1],m.rect[1]="0px"))),m.children?X(m.children,b,g,c,d):m.c&&X(m.c,b,g,c,d)}function ja(a){if(!window.edge_authoring_mode)for(var b in a)if(a.hasOwnProperty(b)){var g=
      a[b],c=void 0,d=void 0,m=void 0,k=void 0,n={},t={},e={},h={};if(g.timeline)for(m=g.timeline,c=0;c<m.data.length;c++)(k=m.data[c])&&("left"==k[1]||"top"==k[1])&&R(k[7])&&(h[k[5]]=!0);g.content&&g.content.dom&&X(g.content.dom,e,h,n,t);if(g.timeline)for(m=g.timeline,c=0;c<m.data.length;c++)(k=m.data[c])&&("left"==k[1]||"top"==k[1])&&R(k[7])&&e[k[5]]&&("left"===k[1]?d="translateX":"top"===k[1]&&(d="translateY"),k[1]=d)}}var D=document,C=window,S={},H={},aa={imagesDir:"images/"},ba,la=Array.prototype.forEach,
      T,U,ka=[],V,oa=[].push,ga={},da={option:[1,"<select multiple='multiple'>","</select>"],thead:[1,"<table>","</table>"],col:[2,"<table><colgroup>","</colgroup></table>"],tr:[2,"<table><tbody>","</tbody></table>"],td:[3,"<table><tbody><tr>","</tr></tbody></table>"],_default:[1,"",""]},ma=/<([\w:]+)/,na=/<(?!area|br|col|embed|hr|img|input|link|meta|param)(([\w:]+)[^>]*)\/ >/gi,G={},Z={};f.doPlayWhenReady=!1;f.readyAndWaiting=[];var qa={columnCount:!0,fillOpacity:!0,fontWeight:!0,lineHeight:!0,opacity:!0,
      order:!0,orphans:!0,widows:!0,zIndex:!0,zoom:!0},ha={letterSpacing:0,fontWeight:400};V=doc ument.createElement("div");ba=p(["transformProperty","WebkitTransform","MozTransform","OTransform","msTransform"]);d.each=e;d.extend=q;d.data=function(a,b,g){var c="an_"+b;2<arguments.length&&(a[c]=g);return a[c]};q(a.prototype,{addObserver:function(a){if(a){var b=this.notifier.obs,g,c;g=b.length;for(c=0;c<g;c++)if(b[c].o===a)return;b[g]={o:a}}},removeObserver:function(a){if(a){var b=this.notifier,g=b.obs,c;
      for(c=0;c<g.length;c++)if(g[c].o===a)if(0===b.lvl){g.splice(c,1);break}else g[c].deleted=!0}},notifyObservers:function(a,b){return k(this,a,b)},removeObservers:function(){var a=this.notifier?this.notifier.obs:null;a&&a.splice(0,a.length)}});b.expr={};var fa=b.expr[":"]={visible:function(){if(A(this))return this},hidden:function(){if(!A(this))return this},selected:function(){if(this.selected)return this},checked:function(){if(this.checked)return this},parent:function(){return this.parentNode},first:function(a){if(0===
      a)return this},last:function(a,b){if(a===b.length-1)return this},eq:function(a,b,c){if(a===c)return this},has:function(a,b,c){if(m(this,c).length)return this}},pa=/(.*):(\w+)(?:\(([^)]+)\))?$\s*/,ra={tabindex:"tabIndex",readonly:"readOnly","for":"htmlFor","class":"className",maxlength:"maxLength",cellspacing:"cellSpacing",cellpadding:"cellPadding",rowspan:"rowSpan",colspan:"colSpan",usemap:"useMap",frameborder:"frameBorder",contenteditable:"contentEditable"};q(b.prototype,{css:function(a,b){if(!(1>
      this.length)){if("string"==typeof a){var c,g=s(a);if(1<arguments.length){isNaN(parseFloat(b))||!isFinite(b)||qa[g]||(b+="px");for(c=0;c<this.length;c++)this[c].style[g]=b;return this}c=C.getComputedStyle?C.getComputedStyle(this[0])[g]||this[0].style[g]:this[0].style[g];"normal"===c&&g in ha&&(c=ha[g]);return c}if(r(a)){var m={},k=this[0];d.each(r(a)?a:[a],function(a,b){var c=s(b);m[b]=k.style[c]||C.computedStyle.getPropertyValue(k)[c]});return m}for(g in a)this.css(g,a[g]);return this}},prop:function(a,
      b){a=ra[a]||a;return 1 in arguments?this.each(function(c,g){this[a]="function"==typeof b?b.call(this,g,this[a]):b}):this[0]&&this[0][a]},addClass:function(a){g(this,a);return this},removeClass:function(a){g(this,a,!0);return this},hasClass:function(a){a=" "+a+" ";for(var b=0,c=this.length,g=/[\t\r\n\f]/g;b<c;b++)if(1===this[b].nodeType&&0<=(" "+this[b].className+" ").replace(g," ").indexOf(a))return!0;return!1},attr:function(a,b){if("string"!==typeof a||!this.length)return null;if(void 0===b)return this[0].getAttribute(a);
      this.each(function(c,g){b?this.setAttribute(a,b):this.removeAttribute(a)});return this},removeAttr:function(a){if("string"!==typeof a||!this.length)return null;this.each(function(b,c){c.removeAttribute(a)});return this},each:function(a){la.call(this,function(b,c){a.call(b,c,b)});return this},get:function(a){if(this.length&&a<this.length)return this[a]},_s:function(a,b){if(this.length){if(void 0===a)return this[0][b];this.each(function(c,g){this[b]=a});return this}},parent:function(){var a=this[0].parentNode;
      return a&&11!==a.nodeType?d(a):null},parents:function(){for(var a=this[0],b=[];(a=a.parentNode)&&9!==a.nodeType;)1===a.nodeType&&b.push(a);return b},text:function(a){return this._s(a,"textContent")},html:function(a){return this._s(a,"innerHTML")},show:function(){return this.each(function(){"none"==this.style.display&&(this.style.display="");if("none"==getComputedStyle(this,"").getPropertyValue("display")){var a=this.style,b=this.nodeName,c,g;Z[b]||(c=document.createElement(b),document.body.appendChild(c),
      g=getComputedStyle(c,"").getPropertyValue("display"),c.parentNode.removeChild(c),"none"==g&&(g="block"),Z[b]=g);a.display=Z[b]}})},hide:function(){return this.css("display","none")},wrap:function(a){var b="function"==typeof a;if(this[0]&&!b)var c=d(a).get(0),g=c.parentNode||1<this.length;return this.each(function(m){d(this).wrapAll(b?a.call(this,m):g?c.cloneNode(!0):c)})},wrapAll:function(a){if(this[0]){for(this[0].parentElement.insertBefore(a,this[0]);a.firstElementChild;)a=a.firstElementChild;d(a).append(this)}return this},
      dimension:function(a){var b=this[0],c=a[0]?a[0].toUpperCase()+a.substr(1):"";if(b===b.window)return b.document.documentElement["client"+c];if(9===b.nodeType)return Math.max(b.body["scroll"+c],D["scroll"+c],b.body["offset"+c],D["offset"+c],D["client"+c]);c=this.css(a)||"";if("auto"!=c&&(c=x(c),!c.units||"px"==c.units))return c.num;b=b.getBoundingClientRect();if("width"===a)return Math.round(b.width);if("height"===a)return Math.round(b.height)},width:function(a){return void 0!=a?this.css("width",a):
      this.dimension("width")},height:function(a){return void 0!=a?this.css("height",a):this.dimension("height")},offset:function(){if(!this.length)return null;var a=this[0].getBoundingClientRect();return{left:a.left+window.pageXOffset,top:a.top+window.pageYOffset,width:Math.round(a.width),hei ght:Math.round(a.height)}},is:function(a){return 0<this.length&&y(this[0],a)}});P({opacity:{},left:{f:"rect",i:0,u:"px"},top:{f:"rect",i:1,u:"px"},width:{f:"rect",i:2,u:"px"},height:{f:"rect",i:3,u:"px"},right:{f:"rect",
      i:4,u:"px"},bottom:{f:"rect",i:5,u:"px"},src:{o:"img",f:"fill",i:1,a:1,p:1,x:{apply:function(a,b,c,g){b=g?g._getFullURL(b):b;a.attr("src",b)}}},poster:{f:"poster",o:"video",a:1},preload:{f:"preload",a:1},medsrc:{e:"img",f:"source",a:1,x:{apply:function(a,b,c,g){var m;a:{m=c.type;var k=c.preload;if(!AdobeEdge.isIOS){var n,t;for(n=0;n<b.length;n++)if(t=b[n].split("."),t=t[t.length-1].toLowerCase(),AdobeEdge.supported[m][t]){t=!1;(t=null===k||""==k?"auto"==("audio"==m?g.opts.gAudioPreloadPreference:
      g.opts.gVideoPreloadPreference):"auto"==k)&&z(m,g._getFullURL(b[n]),g);m=g._getFullURL(b[n]);break a}}m=void 0}if(d.isArray(b)&&1!=b.length)for(m=0;m<b.length;m++)k=document.createElement("source"),d(k).attr("src",g._getFullURL(b[m])),a.get(0).appendChild(k);else m?a.attr("src",m):a.attr("src",d.isArray(b)?g._getFullURL(b[0]):g._getFullURL(b));"audio"==c.tag&&a.attr("controls","block"==c.display)}}},"background-image":{e:"img",f:"fill",i:1,t:"url(@@0)",p:1,x:{prep:function(a,b,c,g,d,m,k){var n;b[c]&&
      (n=b[c][g]);void 0!==n&&(n=k._getFullURL(n),z(b.type,n,k),n=this.conf.t.replace("@@0",n));return n}}},"background-color":{f:"fill",i:0,x:{apply:function(a,b){a.css("background-color",h(b))}}},text:{x:{apply:function(a,b){a.html(b)}}},"min-width":{f:"sizeRange",i:0},"max-width":{f:"sizeRange",i:1},"min-height":{f:"sizeRange",i:2},"max-height":{f:"sizeRange",i:3},overflow:{x:{apply:function(a,b){a.css("overflow",b);"hidden"!==b&&"scroll"!==b||a.css("text-overflow","clip")}}},"background-repeat":{e:"img",
      f:"fill",x:{apply:function(a,b){b&&1!=b.length&&(d.isArray(b[1])||a.css("background-repeat",b[6]||"no-repeat"))}}},"background-attachment":{f:"fill",i:7,x:{apply:function(a,b){"scroll"!==b&&a.css("background-attachment",b)}}},"background-size":{f:"fill",i:4,d:"100% 100%"},autoOrient:{x:{apply:function(a,b){AdobeEdge.$.data(a[0],"doAutoOrient",b)}}},clip:{},display:{},"border-top-left-radius":{f:"borderRadius",i:0},"border-top-right-radius":{f:"borderRadius",i:1,ii:0},"border-bottom-right-radius":{f:"borderRadius",
      i:2,ii:0},"border-bottom-left-radius":{f:"borderRadius",i:3,ii:0},"border-width":{f:"stroke",i:0,d:0,u:"px"},"border-color":{f:"stroke",i:1,d:"rgba(0,0,0,0)"},"border-style":{f:"stroke",i:2,d:"none"},cursor:{f:"cursor"},"transform-origin":{cb:1,f:"transform",i:4,x:{prep:function(a,b,c,g,d,m){if(b.transform&&void 0!=b.transform[4])return 1==b.transform[4].length?b.transform[4][0]+" 50%":b.transform[4][0]+" "+b.transform[4][1]}}},"font-family":{f:"font",i:0},"font-size":{f:"font",i:1,u:"px",x:{prep:function(a,
      b,c,g,d,m,k){if("text"==b.type)return g=this.conf.i,d=0,c=this.conf.f,a=b[c][g][d],b=b[c][g][d+1],b&&""!=b||(b=this.conf.u),a+b}}},"font-weight":{f:"font",i:3},"letter-spacing":{f:"textStyle",i:0},"word-spacing":{f:"textStyle",i:1},"line-height":{f:"textStyle",i:2},"text-indent":{f:"textStyle",i:3},"text-transform":{f:"textStyle",i:4},color:{f:"font",i:2,x:{apply:function(a,b){a.css("color",h(b))}}},"text-decoration":{f:"font",i:4},"font-style":{f:"font",i:5},"word-wrap":{f:"font",i:6},"text-align":{f:"align"},
      "white-space":{f:"rect",x:{prep:function(a,b){if(b.font)return 7<b.font.length?b.font[7]:b.rect},apply:function(a,b){d.isArray(b)?(!b[2]||0>=b[2]||"auto"==b[2])&&(!b[3]||0>=b[3]||"auto"==b[3])&&(a.css("white-space","nowrap"),a.css("wordWrap","break-word")):(a.css("white-space",b),"nowrap"==b&&a.css("wordWrap","break-word"))}}},volume:{f:"volume",x:{apply:function(a,b){a.get(0).volume=b}}},className:{f:"uc",x:{apply:function(a,b){a.addClass(b)}}},controls:{a:1},alt:{a:1},title:{a:1},tabindex:{a:1},
      autoplay:{a:1},loop:{a:1},linkURL:{f:"linkURL",a:1,x:{prep:function(a,b){ga[a[0].id]=b;a[0].onclick=function(){var a=ga[this.id];a.linkTarget?window.open(a.linkURL,a.linkTarget):window.location.href=a.linkURL};a[0] .style.cursor="pointer"}}}});var Y={c:"children",r:"rect",zr:"sizeRange",br:"borderRadius",cl:"clip",al:"alt",tt:"title",ti:"tabindex",cn:"controls",sr:"source",ps:"poster",pr:"preload",cu:"cursor",ap:"autoplay",lp:"loop",n:"font",tf:"transform",sh:"boxShadow",ts:"textStyle",o:"opacity",
      uc:"userClass",s:"stroke",f:"fill",v:"display",fi:"filter",sN:"symbolName",tr:"trigger"};q(M.prototype,a.prototype);q(M.prototype,{init:function(a,b){var c=this.data[this.name];c&&L(this.composition,this,c.content.dom,c.content.style,a,b)},register:function(a,b){},play:function(a){}});q(I.prototype,a.prototype);I._playAuto=w;(function(){var a;T||(a=C.requestAnimationFrame||C.webkitRequestAnimationFrame||C.mozRequestAnimationFram e||C.msRequestAnimationFrame||C.oRequestAnimationFrame||function(a){C.setTimeout(a,
      17)},T=function(){var b;b=N(0);J(b,"rP");J(b,"rR");J(b,"rA");a.call(C,T)},a.call(C,T))})();G.cssTransform=p(["transformProperty","WebkitTransform","MozTransform","OTransform","msTransform"]);G.cssTransform3d=p(["perspectiveProperty","WebkitPerspective","MozPerspective","OPerspective","msPerspective"]);G.audio=function(){var a=document.createElement("audio"),b={};a.canPlayType&&(b.m4a=!!a.canPlayType('audio/mp4; codecs="mp4a.40.2"').replace(/no/,""),b.aac=b.m4a,b.mp3=!!a.canPlayType("audio/mpeg;").replace(/no/,
      ""),b.wav=!!a.canPlayType('audio/wav; codecs="1"').replace(/no/,""),b.ogg=!!a.canPlayType('audio/ogg; codecs="vorbis"').replace(/no/,""),b.oga=b.ogg);return b}();G.video=function(){var a=document.createElement("video"),b={};a.canPlayType&&(b.webm=!!a.canPlayType("video/webm").replace(/no/,""),b.mp4=!!a.canPlayType("video/mp4;").replace(/no/,""),b.ogv=!!a.canPlayType('video/ogg; codecs="theora, vorbis"').replace(/no/,""),b.ogg=!!a.canPlayType('video/ogg; codecs="theora, vorbis"').replace(/no/,""));
      return b}();G.customEvent=function(){if(!window.CustomEvent)return!1;try{return void 0!==new CustomEvent("testCustomEvent",!1,!1)}catch(a){}return!1}();G.addEventListener=void 0!==window.addEventListener;var sa=G,ia;V.style.cssText="background-color:rgba(150,255,150,.5)";ia=0==(""+V.style.backgroundColor).indexOf("rgba")?!0:!1;sa.rgba=ia;q(f,{version:"5.0.0",Composition:I,defaultOpt:aa,$:d,An$:b,renderDOM:L,ready:W,camelize:s,splitUnits:x,loadCom position:function(a,b,c,g,m){function n(a,g){W(function(){var m=
      d("."+b),k=/px|^0$/,n=c.scaleToFit,e=c.centerStage,h=c.minW,f=c.maxW,l=c.width,s=c.height,y=m[0 ]||document.getElementsByTagName("body")[0];"absolute"!=y.style.position&&"relative"!=y.style.position&&(y.style.position="relative");s&&(y.style.height=s);l&&(y.style.width=l);/^height$|^width$|^both$/.test(n)&&(h=k.test( h)?parseInt(h,10):void 0,f=k.test(f)?parseInt(f,10):void 0,v(d(y),n,h,f,!1,c.bScaleToParent));/^vertical$|^horizontal$|^both$/.test(e)&&t(y,e);a&& L(H[b],null,a.dom,a.style,m[0],g+b);m.removeClass("edgeLoad-"+
      b)})}function e(){K(function ea(a){a?ea&&setTimeout(ea,20):a={event:"loading",progress:0};f.preloaderDOM.script&&(new Function("e",f.preloaderDOM.script.loading))(a)});n(f.preloaderDOM,"edgePreload-")}function h(){n(f.downLevelStageDOM,"edgeDownLevel-")}var f=H[b]=AdobeEdge.compositions[b]=new I(b,c);k(AdobeEdge,"newComp",{comp:f});ba?(window.edge_authoring_mode||(g?(f.definePreloader(g),e()):f.load(a+"_edgePreload.js",e)),a&&(c&&c.bootstrapLoading?ka.push(a):window.edge_authoring_mode&&c.sym?f.load(a+
      "_edge.js?symbol="+c.sym):f.load(a+"_edge.js"))):window.edge_authoring_mode||(m?(f.defineDownLevelStage(m),h()):f.load(a+"_edgePreload.js",h))},registerCompositionDefn:function(a,b,c,g,d,m){H[a].define(m,b,c,g,d)},registerEventBinding:function(a,b){H[a].bindingFn=b},getComposition:function(a){return H[a]},defineProps:P,props:S,Symbol:M,Notifier:a,isSupported:p,supported:G,isIOS:function(){var a=navigator.userAgent;return"webkitAppearance"in document.documentElement.style&&(/iPad/.test(a)||/iPod/.test(a)||
      /iPhone/.test(a))}(),isOpera:/Opera/.test(navigator.userAgent),registerFonts:function(a){AdobeEdge.getCurrentComposition().registerFonts(a)},playWhenReady:function(){f.doPlayWhenReady=!0;for(var a=0;a<f.readyAndWaiting.length;a++)f.readyAndWaiting[a]()},_:{c:H,P:E,p:S,rE:Q,nO:k,nDN:B }});q(f,a.prototype);a.call(f)})(window.AdobeEdge);window.AdobeEdge.bootstrapListeners||(w indow.AdobeEdge.bootstrapListeners=[]);
      window.AdobeEdge.bootstrapCallback=function(f){window.AdobeEdge.bootstrapListeners.push(f);if(0<aBootcompsLoaded.length)for(var r=0;r<aBootcompsLoaded.length;r++)f(aBootcompsLoaded[r])};window.AdobeEdge.compositions|| (window.AdobeEdge.compositions=[]);window.AdobeEdge.yepnope=window.yepnope;
      (function(f){function r(){f.Notifier.call(this);this.animationID="animID-"+r.nextID;r.nextID+=1}function u(b,d,c){f.Animation.call(this);"function"===typeof b?this.handler=b:"string"===typeof b&&(this.eventType=b);this.handlerContext=c;this.data=d;this.isTrigger=!0}function e(b,d,c,n,h){f.Notifier.call(this);this.animation=b;this.position=0;this.duration=-1;this.opts={};l.extend(this.opts,h);this.easing="function"===typeof n?n:n&&l.easing[n]?n:e.defaultEasing;void 0!==d&&(this.position=d);void 0!==
      c&&(this.duration=c);this.timeline=null;this.dScale=1;this.dDuration=0;this.done=!1}function p(b){f.Animation.call(this);l.extend(this,f.Timeline.config);l.extend(this,b);this.startPosition=this.timerStart=this.timer=0;this.currentPosition=-1;this.playing=void 0;this.iteration=this.duration=0;this.interval=1E3/this.fps;this.objects=[]}function h(b){return s.test(b[1])}var l=f.$,q={},x={},s=/^(trigger|@)$/;l.isArray=function(b){return"[object Array]"===Object.prototype.toString.call(b)};l.easing=l.easing||
      {};l.extend(l.easing,{linear:function(b,d,c,n){return c+n*b},swing:function(b,d,c,n){return(-Math.cos(b*Math.PI)/2+0.5)*n+c}});r.nextID=1;l.extend(r.prototype,f.Notifier.prototype); l.extend(r.prototype,{constructor:r,setup:function(){},update:function(b,d){},getDuration:function(){return 0}});l.extend(u.prototype,r.prototype);l.extend(u.prototype,{constructor:u,update:function(b){this.fired||(this.fired=!0,this.handler?this.handler.call(this.handlerContext,b,this.data):this.eventType&&this.timeline&&
      this.timeline.notifyObservers(this.eventType,{elapsed:b,data:this.data}))},setup:function(b,d){var c=void 0===b.executeTriggers||null===b.executeTriggers;this.fired=b.startingFromCurrent&&c||!c&&!b.executeTriggers?"reverse"!==b.playDirection?b.currentPosition>=d:b.currentPosition<=d:"reverse"!==b.playDirection?b.currentPosition>d:b.currentPosition<d;this.timeline=b}});e.defaultEasing="linear";l.extend(e.prototype,f.Notifier.prototype);l.extend(e.prototype,{constructor:e,setup:function(b){this.timeline=
      b;var d=this.duration,c=null;this.animation&&this.animation.getDuration&&(c=this.animation.getDuration());this.dScale=-1!==d&&0!==d?c/d:1;this.dDuration=-1!==d?d:c;this.done=!1;this.animation&&this.animation.setup&&this.animation.setup(b,this.position)},update:function(b){if(!this.done){var d=this.dDuration,c;this.animation&&(0===d?c=0<=b?1:0:(b>=d&&(b=d),0>=b&&(b=0),c=l.easing[this.easing](b/d,b,0,1,d)),this.animation.update(b*this.dScale,c));("reverse"===this.timeline.playDirection?0>=b:b>=d)&&
      this.complete()}},complete:function(){this.done=!0;this.timeline&&this.timeline.updateComplete(this)},getPosition:function(){return this.position},setPosition:function(b){this.position=b},getDuration:function(){return-1!==this.duration?this.duration:this.animation&&this.animation.getDuration?this.animation.getDuration():0},setDuration:function(b){this.duration=0<=b?b:-1}});p.config={dropFrames:!0,fps:60,pauseThreshold:250};p.prototype.tick =function(b){this._handleTimer(b)};l.extend(p.prototype,r.prototype);
      l.extend(p.prototype,{constructor:p,play:function(b){b=b||{};this.notifyObservers("play");this.playing=!0;this._stop({});if("undefined"===typeof b.pos||null===b.pos)if("reverse"==b.playDirection)b.pos=this.currentPosition,0>=b.pos&&(b.pos=this.getDuration());else if(0>this.currentPosition||this.currentPosition>=this.getDuration())b.pos=0;l.extend(this,b);this.seek(b.pos,b);this.iteration=0;this.timerStart=(new Date).getTime();this.startPosition=this.currentPosition;this.lastUpdateTime=this.timerStart;
      this.firstUpdate=!0;this._handleTimer();this.firstUpdate=!1;return this},stop:function(b){this.playing=!1;b&&b.bSeek?this.seek(b.pos,b):this._stop(b)},seek:function(b,d){this.notifyObservers("seek");this.sort(d);var c=this.currentPosition;this._stop(d);l.extend(this,d);void 0!==b&&(this.currentPosition=b);this.startingFromCurrent="number"===typeof b&&c!==this.currentPosition?!1:!0;this.setup(this);this.firstUpdate=!0;this.updateSeek(this.currentPosition,1,c);this.firstUpdate=!1;return this},add:function(b,
      d,c,n,h){b=new e(b,d,c,n,h);this.objects.push(b);this.sorted=!1},sort:function(b){var d={width:1,height:2,"-webkit-transform-origin":3,"transform-origin":4,"-moz-transform-origin":5,"-ms-transform-origin":6,left:7,top:8,bottom:9,right:10,motion:11};this.sorted||(this.objects.sort(function(b,c){var a=b.animation,k=c.animation;if(a||k){if(!a)return-1;if(!k)return 1}else return b.position-c.position;if(a.property||k.property){if(!a.property)return-1;if(!k.property)return 1}else return b.position-c.position;
      var g=d[a.property],m=d[k.property];return a.sourceElements!==k.sourceElements?a.sourceElements>k.sourceElements?1:-1:g&&(!m||m<g)?1 :m&&(!g||m>g)?-1:b.position-c.position}),this.sorted=!0);for(b=1;b<this.objects.length;b++){var c=this.objects[b-1],n=this.objects[b];c.animation&&n.animation&&c.animation.property===n.animation.property&&c.anima tion.sourceElements===n.animation.sourceElements?(c.animation._nextObj=n.animation,n.anima tion._prevObj=c.animation):(c.animation&&(c.animation._nextObj=null),
      n.animation&&(n.animation._prevObj=null))}},getDuration:function(){var b=this.duration,d=this.objects,c=this.objects.length,n=Math.max,e,t;for(e=0;e<c;e+=1)t=d[e],b=n(b,t.position+t.getDuration());return b},getCurrentPosition:function(){return this.currentPosition},update:function(b,d){this.sort();this.notifyObservers("preUpdate",{elapsed:b,easingConst:d});var c=this.objects,n=this.triggers,e=c.length,t=n.length,a="reverse"!==this.playDirection,k=!1,g=!0,m=!window.edge_authoring_mode&&this.executeTriggers,
      h=!window.edge_authoring_mode&&(void 0===this.executeTriggers||null===this.executeTriggers),f,l,s,q,p,r;this.currentDirection=a?"forward":"reverse";for(s=0;s<t;s+=1)if(q=n[a?s:t-s-1],p=q.animation.isTrigger&&!(this.startingFromCurrent&&this.firstUpdate),(h&&p||m||!this.firstUpdate)&&!q.animation.fired&&(a?b>=q.position:b<=q.position+q.duration)){p=this.currentPosition=q.position;r=this.getState();for(k=0;k<e;k+=1)f=c[a?k:e-k-1],(l=a&&!f.opts.reverseOnly||!a&&!f.opts.forwardOnly)&&!f.anima tion.isTrigger&&
      (a?p>=f.position:p<=f.position+f.duration)&&((l=p-f.position)||f.duration||a||(l-=1),f.upd ate(l));k=!0;q.animation.update(p);if(!this.equalState(r)){g=!1;break}}if(!k)for(k=0;k<e;k+=1)f=c[a?k:e-k-1],(l=a&&!f.opts.reverseOnly||!a&&!f.opts.forwardOnly)&&!f.anima tion.isTrigger&&(a?b>=f.position:b<=f.position+f.duration)&&((l=b-f.position)||f.duration| |a||(l-=1),f.update(l));this.notifyObservers("fxUpdate",{elapsed:b});this.notifyObservers("postUpdate",{elapsed:b,easingConst:d});this.notifyObservers("update",
      {elapsed:b,easingConst:d});return g},setLoop:function(b){this.loopCount=b},getState:function(){return{pos:this.currentPosition,dir:this.playDirection,playing:this.playing}},equalState:function(b){var d=!!b.playing,c=!!this.playing;return b.pos===this.currentPosition&&b.dir===this.playDirection&&d===c},_handleTimer:function(b){b=b||(new Date).getTime();var d="reverse"===this.playDirection,c=b-this.timerStart-this.iteration*(d?this.startPosition:this.duration-this.startPosition),d=this.startPosition+
      (d?-c:c);b-this.lastUpdateTime>this.pauseThreshold&&(this.timerStart+=b-this.lastUpdateTime+this.interval,c=b-this.timerStart);if(this.playing){if(this.currentPosition=d=Math.max(0,Math.min(d,this.duration)),this.update(d,1),this.lastUpdateTime=b,b=(d="reverse"===this.playDirection)?0<this.currentPosition:this.currentPosition<this.duration,!b){if(this.loopCount&&(this.iteration+=1,this.notifyObservers("iterationComplete",{elapsed:c,count:this.iteration}),"forever"===this.loopCount||this.iteration<
      this.loopCount)){c=this.objects;b=c.length;for(d=0;d<b;d+=1)c[d].done=!1;this.tick();return}this.stop();this.notifyObservers("complete",{elapsed:c})}}else this.notifyObservers("fxUpdate",{elapsed:c})},setup:function(b){f.Animation.prototype.setup.call(this,b);this.triggers=[];b=this.objects;var d=this.objects.length,c,n;for(c=0;c<d;c+=1)n=b[c],n.done=!1,n.setup(this),n.animation.isTrigger&&this.triggers.push(n);this.duration=this.getDuration()},updateComplete:function(b){b.done=!0},_stop:function(b){b&&
      b.dontNotify||this.notifyObservers("stop");this.timer&&clearTimeout(this.timer);this.timerStart=this.timer=0;return this}});p.prototype.updateSeek=p.prototype.update;f.Animation=r;f.TimelineObject=e;f.Timeline= p;f.Timeline.createTimeline=function(b){return new f.Timeline(b)};f.Timeline.createTween=function(b){var d=q[b];return d?d.func.apply(d.context,Array.prototype.slice.call(arguments,1)):null};f.Timeline.addTweenType=function(b,d,c){q[b]={func:d,context:c}};f.Timeline.addTweenProperty=function(b,
      d){x[b]=d};f.Timeline.getTweenType=function(b){return x[b]||"style"};f.Timeline.createTrigger=function(b,d){return new u(b,d,arguments[arguments.length-1])};f.Timeline.isTrigger=h;f.Timeline.isTween=function(b){return!h(b)};f.Timeline.createTL=function(b,d,c){var n=f.Timeline.createTimeline(),e=b.length,t,a,k,g;k=b.duration?b.duration:0;var m;n.duration=k;c&&c.loop&&n.setLoop(c.loop);for(c=0;c<e;c+=1)t=b[c],a=null,k=-1,h(t)?(g=t.slice(3,5),g.push(d),a=f.Timeline.createTrigger.apply(null,g),g=t[5],
      m="none"):t[1]&&(k=x[t[1]]||"style",g=[k,t[1]].concat(t.slice(5)),a=f.Timeline.createTween.apply(null,g),k=t[3],m=t[4],g=t[8]),a&&(a.id=t[0],n.add(a,t[2],k,m,g));return n}})(window.AdobeEdge);
      (function(f){var r=f.$;r.easing.jswing=r.easing.swing;r.extend(r.easing,{def:"easeOutQuad",swing:function(f,e,p,h,l){return r.easing[r.easing.def](f,e,p,h,l)},easeInQuad:function(f,e,p,h,l){return h*(e/=l)*e+p},easeOutQuad:function(f,e,p,h,l){return-h*(e/=l)*(e-2)+p},easeInOutQuad:function(f,e,p,h,l){return 1>(e/=l/2)?h/2*e*e+p:-h/2*(--e*(e-2)-1)+p},easeInCubic:function(f,e,p,h,l){return h*(e/=l)*e*e+p},easeOutCubic:function(f,e,p,h,l){return h*((e=e/l-1)*e*e+1)+p},easeInOutCubic:function(f,e,p,h,
      l){return 1>(e/=l/2)?h/2*e*e*e+p:h/2*((e-=2)*e*e+2)+p},easeInQuart:function(f,e,p,h,l){return h*(e/=l)*e*e*e+p},easeOutQuart:function(f,e,p,h,l){return-h*((e=e/l-1)*e*e*e-1)+p},easeInOutQuart:function(f,e,p,h,l){return 1>(e/=l/2)?h/2*e*e*e*e+p:-h/2*((e-=2)*e*e*e-2)+p},easeInQuint:function(f,e,p,h,l){return h*(e/=l)*e*e*e*e+p},easeOutQuint:function(f,e,p,h,l){return h*((e=e/l-1)*e*e*e*e+1)+p},easeInOutQuint:function(f,e,p,h,l){return 1>(e/=l/2)?h/2*e*e*e*e*e+p:h/2*((e-=2)*e*e*e*e+2)+p},easeInSine:function(f,
      e,p,h,l){return-h*Math.cos(e/l*(Math.PI/2))+h+p},easeOutSine:function(f,e,p,h,l){return h*Math.sin(e/l*(Math.PI/2))+p},easeInOutSine:function(f,e,p,h,l){return-h/2*(Math.cos(Math.PI*e/l)-1)+p},easeInExpo:function(f,e,p,h,l){return 0==e?p:h*Math.pow(2,10*(e/l-1))+p},easeOutExpo:function(f,e,p,h,l){return e==l?p+h:h*(-Math.pow(2,-10*e/l)+1)+p},easeInOutExpo:function(f,e,p,h,l){return 0==e?p:e==l?p+h:1>(e/=l/2)?h/2*Math.pow(2,10*(e-1))+p:h/2*(-Math.pow(2,-10*--e)+2)+p},eas eInCirc:function(f,e,p,h,l){return-h*
      (Math.sqrt(1-(e/=l)*e)-1)+p},easeOutCirc:function(f,e,p,h,l){return h*Math.sqrt(1-(e=e/l-1)*e)+p},easeInOutCirc:function(f,e,p,h,l){return 1>(e/=l/2)?-h/2*(Math.sqrt(1-e*e)-1)+p:h/2*(Math.sqrt(1-(e-=2)*e)+1)+p},easeInElastic:function(f,e,p,h,l){f=1.70158;var q=0,r=h;if(0==e)return p;if(1==(e/=l))return p+h;q||(q=0.3*l);r<Math.abs(h)?(r=h,f=q/4):f=q/(2*Math.PI)*Math.asin(h/r);return-(r*Math.pow(2,10*(e-=1))*Math.sin(2*(e*l-f)*Math.PI/q))+p},easeOutElastic:function(f,e,p,h,l){f=1.70158;var q=0,r=h;
      if(0==e)return p;if(1==(e/=l))return p+h;q||(q=0.3*l);r<Math.abs(h)?(r=h,f=q/4):f=q/(2*Math.PI)*Math.asin(h/r);return r*Math.pow(2,-10*e)*Math.sin(2*(e*l-f)*Math.PI/q)+h+p},easeInOutElastic:function(f,e,p,h,l){f=1.70158;var q=0,r=h;if(0==e)return p;if(2==(e/=l/2))return p+h;q||(q=0.3*l*1.5);r<Math.abs(h)?(r=h,f=q/4):f=q/(2*Math.PI)*Math.asin(h/r);return 1>e?-0.5*r*Math.pow(2,10*(e-=1))*Math.sin(2*(e*l-f)*Math.PI/q)+p:r*Math.pow(2,-10*(e-=1)) *Math.sin(2*(e*l-f)*Math.PI/q)*0.5+h+p},easeInBack:function(f,
      e,p,h,l,q){void 0==q&&(q=1.70158);return h*(e/=l)*e*((q+1)*e-q)+p},easeOutBack:function(f,e,p,h,l,q){void 0==q&&(q=1.70158);return h*((e=e/l-1)*e*((q+1)*e+q)+1)+p},easeInOutBack:function(f,e,p,h,l,q){void 0==q&&(q=1.70158);return 1>(e/=l/2)?h/2*e*e*(((q*=1.525)+1)*e-q)+p:h/2*((e-=2)*e*(((q*=1.525)+1)*e+q)+2)+p},easeIn Bounce:function(f,e,p,h,l){return h-r.easing.easeOutBounce(f,l-e,0,h,l)+p},easeOutBounce:function(f,e,p,h,l){return(e/=l)<1/2.75?7.5625*h*e*e+p:e<2/2.75?h*(7.5625*(e-=1.5/2.75)*e+0.75)+
      p:e<2.5/2.75?h*(7.5625*(e-=2.25/2.75)*e+0.9375)+p:h*(7.5625*(e-=2.625/2.75)*e+0.984375)+p} ,easeInOutBounce:function(f,e,p,h,l){return e<l/2?0.5*r.easing.easeInBounce(f,2*e,0,h,l)+p:0.5*r.easing.easeOutBounce(f,2*e-l,0,h,l)+ 0.5*h+p}})})(window.AdobeEdge);
      (function(f){function r(a,b){return b?b+"_"+a:a+"_"+k++}function u(a){a.length&&(a=a[0]);return a?a.edgeSymbol:null}function e(a,b){a.length&&(a=a[0]);a&&(a.edgeSymbol=b)}function p(a){var b,c,d,k=a.length;if(n.isArray(a))for(b=[],d=0;d<k;d++)c=a[d],b[d]=null!=c&&"object"===typeof c?p(c):c;else for(d in b={},a)a.hasOwnProperty(d)&&"prototype"!==d&&(c=a[d],b[d]=null!=c&&"object"===typeof c?p(c):c);return b}function h(a){a=a.data[a.name];return a.timeline?a.timeline.data:null}function l(a){a=a.data[a.name];
      return a.timeline?a.timeline.duration:0}function q(a,b,c){function d(a,b){for(k=0;k<a.length;k+=1){if(a[k].id===b)return a[k];if(a[k].children)return d(a[k].children,b)}return null}b=b.replace(/[\{\}\$]/g,"");a=a.data[a.name];var k;if(a=a.content?a.content.dom:null)if(b=d(a,b))if(a=f.props[c])return a.prep(null,b,c,a.i,a.j);return null}function x(a,b,c,d,k){return["generated","location",d,k,"linear",a,[[b.x,b.y,0,0],[c.x,c.y,0,0]]]}function s(b,c){var d,k;c&&(b.tlCached=void 0);var n=h(b);if(!n)return null;
      n.duration=l(b);n.dirty&&b.tlCached&&(d=b.tlCached.currentPosition,k=b.tlCached.notifier.o bs,b.tlCached=void 0);if(!b.tlCached){var e,v=b.data[b.name].timeline,s,p={},r={},u,w,F=n.duration,I;e=b.data[b.name];var N;s=n.length;for(w=n.length-1;0<=w;w--)"injected"===n[w][0]&&n.splice(w,1);s=n.length;"number"!==typeof e.timeline.duration&&(e.timeline.duration=0);for(N=0;N<s;N++)(w=n[N])&&a(w)&&(u=w[5],p[u]||(p[u]=[]),p[u].push(w),u=u+":"+("motion"===w[1]?"location":w[1]),r[u]||(r[u]=[]),r[u].push(w)),
      w&&a(w)&&(I=w[3]||0,F=Math.max(F,w[2]+I));p=Math.max(e.timeline.duration,F);w=function(a,b){return a[2]-b[2]};for(u in r)r.hasOwnProperty(u)&&r[u].sort(w);for(u in r)r.hasOwnProperty(u)&&(w=r[u][0],0<w[2]&&(e=q(b,w[5],w[1]),null==e&&(e=w[6]),"location"===w[1]?(w=r[u][0],s={x:w[6][0][0],y:w[6][0][1]},e=x(w[5],s,s,0,Math.max(0,w[2]-1)),e[0]="injected",n.push(e)):void 0!==e&&(w=f.cloneJSONObject(r[u][0]),w[6]=w[7]=e,w[3]=w[2],w[2]=0,w[0]="injected",w[8]&&""!=w[8].valueTemplate&&"string"==typeof e&&(w[8].valueTemplate=
      ""),n.push(w))),s=r[u].length-1,0<=s&&(w=r[u][s],e=w[2]+w[3],e<F&&("location"===w[1]?(s=w[6].length-1,s={x:w[6][s][0],y:w[6][s][1]},e=x(w[5],s,s,e,p-e),e[0]="injected"):(e=f.cloneJSONObject(r[u][s]),e[6]=w[7],e[2]=p,e[3]=0,e[0]="injected",e[8]=e[8]||{},e[8].reverseOnly=!0),n.push(e))));F<p&&(w=["injected","-an_resting",F,p-F,"linear","${stage}","0","100"],n.push(w));b.tlCached=t.createTL(n,b,{loop:v.loop});n.dirty&&(b.tlCached.currentPosition =d,b.tlCached.notifier.obs=k||b.tlCached.notifier.obs);
      b.tlCached.sort()}}function b(a,b){if("string"===typeof b){var c=a.data?a.data[a.name]:0;return(c=c?c.timeline:0)&&c.labels?c.labels[b]:0}return b}function d(a){var b=a,c;"string"===typeof a&&-1!==a.search(/\$\{/)&&(b=a.search(/\$\{/),c=a.search(/\}/),b=a.slice(b+2,c),"string"===typeof b&&(b=f.trimString(b),b=b.replace(/["']/g,"")));return b}function c(a,b){for(var c=a,k;b&&"string"===typeof c&&-1!==c.search(/\$\{/);)k=d(c),c=void 0===b[k]?void 0:c.replace(/\$\{[^\}]*\}/,b[k]);return c}var n=window.jQuery?
      window.jQuery:f.$,v=f.Symbol,t=f.Timeline,a=t.isTween,k=0;v._makeUniqueID=r;f.symbol=v;v.get=v.getSymbol=u;v.setSymbol=e;f.addObserver({newComp:function(a,b){b.comp.addObserver({newSymbol:function(a,b){b.symbol.addObserver({newEle:function(a,b){var c=n(b.ele),g=b.defn,d=a.composition;g.userClass&&c.addClass(g.userClass);f.$.data(c[0],"defn",g);g.symbolName&&(g=new v(d.sym,g.symbolName,d,a),g.init(c[0]),a.ci=a.ci||[],a.ci.push(g),g.prnt=a)}})}})}});f.cl oneJSONObject=p;v.bldTL=s;v.p2n=b;f.trimString=
      function(a){return a.replace(/^\s+|\s+$/g,"")};v.parseVariableName=d;v.substituteVariables=c;n.extend(v.prototype,{init:function(a,b){var c=this.data[this.name],d=n(a),k=d[0].id,t;this.gpuAccelerate=c.gpuAccelerate;"undefined"===typeof this.gpuAccelerate&&(this.gpuAccelerate=!0);this.gpuAccelerate=this.gpuAccelerate&&f.supported.cssTransform3d;this.variables=this.variables||{};this._variables=this._variables||{};a=a||n("."+b)[0];this.autoPlay=c.timeline?c.timeline.autoPlay:!1;e(a,this);if(this.ele=
      a)k&&""!==k||(k=r("stage"),d[0].id=k),t="#"+k,this._variables[k]=this._variables.stage=t,this._variables.symbolStage=t,this._variables.symbolSelector=t,d.css("position","absolute"),d.css("z-index","0");if(c){f.renderDOM(this.composition,this,c.content.dom,c.content.style,a,b);var c=c.content.style,h,v;for(h in c)if("${symbolSelector}"!=h&&c.hasOwnProperty(h)&&(d=h,k=/^\$\{/,k.test(d)?(d=d.replace(k,""),d=d.replace(/\}/,""),d=this.find$(d)):d=f.$(d),d))for(v in f._.p)f._.p.hasOwnProperty(v)&&f._.p[v].render(d,
      c[h],this.composition)}h={Symbol:this,element:this.ele,performDefaultAction:!0};n.extend(h,void 0);this.notifyObservers("creationComplete",h)},lookupSelector:function(a){if("string"===typeof a)try{return c("${"+a+"}",this._variables)}catch(b){}},getSymbolTypeName:function(){return this.name},getComposition:function(){return this.composition},find$:function(a){a=a.split(" ");var b=this._variables[a[0]];if(2>a.length||!b)return b?f.$(b):null;b=f.$(b);if(!b||!b.length)return null;a.splice(0,1);a=a.join(" ");
      return(b=u(b))?b.find$(a):void 0},$:function(a){var b=a;if("string"===typeof a)try{-1===a.search(/\$\{/)?(b=this.lookupSelector(a),"undefined"===typeof b&&(b=a)):b=c(a,this._variables)}catch(k){}void 0===b&&(b=d(a));return f.$(b)},register:function(a,b,c){var d=b.id;c=r(d,c);this._variables[d]="#"+c;b.oldId=b.id;a.id=c},seek:function(a,b){s(this);this.tlCached.seek(a,b)},play:function(a,c,d){s(this);this.tlCached&&(a=b(this,a),this.tlCached.play({pos:a,variables:this._variables,executeTriggers:c,
      playDirection:d}))},stop:function(a,c){s(this);this.tlCached&&(a=b(this,a),this.tlCached.stop({pos:a,variables:this._variables,executeTriggers:c,bSeek:void 0!=a}))},playReverse:function(a,b){this.play(a,b,"reverse")},isPlaying:function(){var a=this._getTimeline();return a&&!!a.playing},isPlayDirectionReverse:function(){var a=this._getTimeline();return a&&"reverse"===a.currentDirection?!0:!1},getTimelinePosition:function(){return this.getPosition()},getPosition:function(){s(this);return this.tlCached?
      this.tlCached.getCurrentPosition():0},getDuration:function(){s(this);if(this.tlCached)return this.tlCached.getDuration()},getLabelPosition:function(a){return b(this,a)},_getTimeline:function(){s(this);return this.tlCached},_rebuild:function(){s(this,!0)},getTimelineData:function(){return h(this)},getTLD:function(){return this.getTimelineData()},_applyBaseStyles:function(a,b){var c=this.data[b];if(c.content&&c.content.style&&c.content.style["${symbolSelector}"]){var c=c.content.style["${symbolSelector}"],
      d;if(a&&a[0])for(d in f._.p)if(f._.p.hasOwnProperty(d)){if("width"==d||"height"==d){var k=a[0].style[d];if(null!=k&&""!=k&&"auto"!=k)continue}f._.p[d].render(a,c,this.composition)}}},getAutoPlay:function(){return this.autoPlay},setAutoPlay:function(a){this.autoPlay=a}})})(window.AdobeEdge);
      (function(f){function r(h,l,q,p,s,b){f.Animation.call(this);this.name="prop tween";this.sourceElements=this.elements=q;this.deferElementResolution=!0;this.tweenType=e[h];this.updateTriggered=!1;this.property=l;this.fromValue=p;this.toValue=s;this.duration=1E3;this.fromValues=this.tokens=this.valueTemplate=null;b&&u.extend(this,b);this.deferElementResolution=this.deferElementResolution||"string"===typeof q&&-1!==q.search(/\$\{[^\{\}]+\}/);this.deferElementResolution||(this.elements=this.resolveElementSelector(q));
      q=this.toValues=[];p=this.parseValue(s);var d;u.isArray(s)||(s=[s]);p&&0!==p.length||(p=s);h=p.length;for(s=0;s<h;s+=1)b=p[s],f.props[l]&&(b=f.props[l].units(b)),d={},"string"===typeof b?(d.value=parseFloat(b.replace(/[a-zA-Z%]+$/,"")),d.unit=b.replace(/^-?[0-9]*(\.[0-9]+)?/,""),isNaN(d.value)&&(d.value=b,d.unit="")):("number"===typeof b&&(b=parseFloat(b)),d.value=b,d.unit=""),q.push(d);if(null!=this.fromValue)for(l=this.fromValues=[],(s=this.parseValue(this.fromValue))&&0<s.length?this.fromValue=
      s:u.isArray(this.fromValue)||(this.fromValue=[this.fromValue]),h=this.fromValue.length,s=0;s<h;s+=1)b=this.fromValue[s],"string"===typeof b?(l[s]=parseFloat(b.replace(/[a-zA-Z%]+$/,"")),isNaN(l[s])&&(l[s]=b)):("number"===typeof b&&(b=parseFloat(b)),l[s]=b);if(this.filter)for(u.isArray(this.filter)||(this.filter=[this.filter]),l=this.filter,h=l.length,s=0;s<h;s+=1)"string"===typeof l[s]&&(l[s]=Math[l[s]]),"function"!==typeof l[s]&&(l[s]=null);this.valueTemplate&&(this.tokens=this.parseTemplate(this.valueTemplate))}
      var u=f.$,e={style:0,attribute:1,property:2},p="webkitAppearance"in document.documentElement.style;f.trimString=function(e){return e.replace(/^\s+|\s+$/g,"")};r.Token=function(e,f){this.value=e;this.isPlaceholder=f};r.parseVariableName=function(e){var l=e,q;"string"===typeof e&&-1!==e.search(/\$\{/)&&(l=e.search(/\$\{/),q=e.search(/\}/),l=e.slice(l+2,q),"string"===typeof l&&(l=f.trimString(l),l=l.replace(/["']/g,"")));return l};r.substituteVariables=function(e,f){for(var q=e,p;f&&"string"===typeof q&&
      -1!==q.search(/\$\{/);)p=r.parseVariableName(q),q=void 0===f[p]?void 0:q.replace(/\$\{[^\}]*\}/,f[p]);return q};u.extend(r.prototype,f.Animation.prototype);u.extend(r.prototype,{constructor:r,setup:function(e){this.updateTriggered=!1;this.timeline=e;this.animData=void 0},update:function(e,f){var q=this.getElementSet(),p=this,s=this.tweenType,b=this.property,d;this.updateTriggered||(this.updateTriggered=!0,this.setupForAnimation());q.each(function(c,n){var v=p.getPropertyTweenData(n,s,b),t,a,k,g,m,
      q,r;if(v.animationID===p.animationID){t=v.fromValues;a=v.toValues;v=v.tokens;k=p.filter;g=t.leng th;m=[];for(d=0;d<g;d+=1)q=t[d],r=a[d],q="string"===typeof q?0===f&&0<p.duration?q:r.value:q+(r.value-q)*f,k&&k[d]&&(q=k[d](q,p,this,b,r.unit,e)),"number"===typeof q&&1>q&&(q=q.toFixed(6)),m.push(q+r.unit);t=p.formatValue(m);if(0<t.length)v=t;else if(v){t=v.length;a=[];for(d=0;d<t;d+=1)k=v[d],k.isPlaceholder?a.push(m[k.value]):a.push(k.value);v=a.join("")}else v=m.join("");p.setValue.call(this,s,b,v);p.notifyObservers("onUpdate",
      {elapsed:e,easingConst:f,property:b,value:v,element:this})}})},setValue:function(e,f,q){switch(e){case 0:e=u(this);e.css(f,q);p&&"background-size"===f?e.css("-webkit-background-size",q):"display"===f&&"AUDIO"==this.nodeName&&e.attr("controls","none"===q?null:"controls");break;case 1:this.setAttribute(f,q);break;case 2:this[f]=q}},getDuration:function(){return this.duration},resolveElementSelector:function(){var e=r.substituteVariables(this.elements,this.timeline.variables);e||(e=this.elements);/^\$\{/.test(e)&&
      (e="bad_selector");return u(e)},getElementSet:function(){var e=this.animationID,f;this.timeline.animData=this.timeline.animData||{};(f=this.timeline.animData[e])||(f=this.timeline.animData[e]=this.deferElementResolution?this.resolveElementSelector():this.elements);return f},getValue:function(e,f){var q;switch(f){case 0:q=u(this).css(e);break;case 1:q=this.getAttribute(e);break;case 2:q=String(this[e])}return q},setupForAnimation:function(){var e=this,f=this.tweenType,q=this.property;this.getElementSet().each(function(p,
      s){var b=e.getPropertyTweenData(s,f,q),d,c,n,v;b.animationID=e.animationID;b.toValues=e.toValues ;b.tokens=e.tokens;if(e.fromValues)b.fromValues=e.fromValues;else if(d=e.getValue.call(this,q,f),void 0===d&&(d="0"),(c=e.parseValue(d))&&0<c.length)for(b=b.fromValues=[],d=c.length,n=0;n<d;n+=1)v=c[n],b[n]="string"===typeof v?parseFloat(v.replace(/[a-zA-Z%]+$/,"")):v,isNaN(b[n])&&(b[n]=v);else b.fromValues=[parseFloat(d.replace(/[a-zA-Z%]+$/,""))]})},parseTemplate:function(e){var f=e.length,q=[],p=0,s=
      /@@[0-9]+@@/g,b=null;for(p<f&&(b=s.exec(e));b;)b.index!==p&&q.push(new r.Token(e.substring(p,b.index),!1)),q.push(new r.Token(parseInt(b[0].replace(/@@/g,""),10),!0)),p=s.lastIndex,b=null,p<f&&(b=s.exec(e));p<f&&q.push(new r.Token(e.substring(p,f),!1));return q},parseValue:function(e){return[]},formatValue:function(e){return""},getPropertyTweenData:function(e,l,q){var p=f.$.data(e,"tweenData");p||(p={},f.$.data(e,"tweenData",p));(e=p[l])||(e=p[l]={});(l=e[q])||(l=e[q]={animationID:-1});return l}});
      f.PropertyTween=r;f.Timeline.addTweenType("style",function(e,f,p,u,s){return new r("style",e,f,p,u,s)});AdobeEdge.Timeline.addTweenType("attribute",function(e,f,p,u,s){return new r("attribute",e,f,p,u,s)});AdobeEdge.Timeline.addTweenType("property",function(e,f,p,u,s){return new r("property",e,f,p,u,s)});f.Timeline.addTweenProperty("volume","property")})(window.AdobeEdge);
      (function(f){var r=f.$,u=function(e){this.handlers={};this.timeline=e};u.Register=function(e,f,h){var l=e.updateFinalizer;"undefined"===typeof l&&(l=new u(e),e.updateFinalizer=l,e.addObserver(l));l.handlers[f]=h};u.unRegister=function(e,f){var h=e.updateFinalizer;"undefined"!==typeof h&&delete h.handlers[f]};r.extend(u.prototype,{_finalizeUpdate:function(e,f){var h={elapsed:e,context:f},l;for(l in this.handlers)if(this.handlers.hasOwnProperty(l)){var q=this.handlers[l];if(q.onFinalUpdate)q.onFinalUpdate(h)}this.handlers=
      {}},postUpdate:function(e,f){this._finalizeUpdate(f.elapsed,f.context)},complete:function(e){this.timeline&&this.timeline.removeObserver(this);this.timeline.updateFinalizer=void 0}});f.UpdateFinalizer=u})(window.AdobeEdge);
      (function(f){function r(b,d,e){var f=l.event.special[d];f&&f.teardown&&f.teardown.call(b,d,e);var f=b.AnListeners=b.AnListeners||{},a,k;a=f[d]=f[d]||[];if(null!=e)for(b.removeEventListener?b.removeEventListener(d,e):b.detachEvent&&b.detachEvent(d,e),k=f.le ngth-1;0<=k;k--)a[k]===e&&f.splice(k,1);else d&&(f[d].forEach(function(a){b.removeEventListener?b.removeEventListener(d,a):b.detachEvent&&b.detachEvent(d,a)}),f [d]=[])}function u(b,d,e,f){function a(a){if(2<=a.length&&"object"===typeof a[0]&&"object"===
      typeof a[1]&&"onError"!==a[1].type){var g;g=l.Event("onError");b&&(g.compId=b.getComposition().compId);g.originalEvent=a[1];document.dispatchEvent(g)}w indow.console.log("Javascript error in event handler! Event Type = "+d)}var k=b[f[0]],g;return"function"===typeof k?("element"===d?g=function(){var d;d=Array.prototype.slice.call(arguments);d.unshift(b);if(2<=d.length&&"object"===typeof d[0]&&"object"===typeof d[1]&&"compositionReady"===d[1].type&&"string"===typeof d[1].compId&&"object"===typeof d[0].composition&&
      d[1].compId!==d[0].composition.id)return null;try{return k.apply(b,d)}catch(g){a(d)}}:"timeline"===d?g=function(g,e){var f,t;t=e&&e.methodName&&/^trig_/.test(e.methodName)?l.Event("trigger"):l.Event(d);e&&l.extend(t,e);t.timeline=g;f=Array.prototype.slice.call(arguments);f.splic e(0,0,t);f.unshift(b);try{return k.apply(b,f)}catch(v){a(f)}}:"symbol"===d&&(g=function(b,c){var g,e,f;e=c&&c.methodName?l.Event(c.methodName):l.Event(d);c&&(l.extend(e,c),c.variableValu e&&(f=c.variableValue));g=Array.prototype.slice.call(arguments);
      g.splice(0,0,e,f);g.unshift(b);try{return k.apply(b,g)}catch(t){a(g)}}),g):null}function e(b,d){var e=d[0],f=s[e[0]],a;f&&(a=u(b,e[0],e[1],d.slice(1)))&&f.apply(b,[a].concat(e.slice(1)))}function p(b,d){d=d||b.data[b.name].actions||{};l.extend(b,d)}function h(b,n,v,t,a,k){var g=f.getComposition(b).sym[n],m=x("binding");v=[[k,v,t],m];var h;if(g&&(g.actions=g.actions||{},g.actions[m]=a,g.bindings=g.bindings||[],g.bindings.push(v),b =f.getComposition(b))&&(b.addObserver(d),b=b.getSymbols()))for(g=b.length,
      k=0;k<g;k++)t=b[k],h=t.name,n===h&&(h={},h[m]=a,p(t,h),e(t,v))}var l=f.$,q=f.Symbol,x=f.Symbol._makeUniqueID,s=f.triggerDict={timeline:function(b,d,e){if(b){d={};var f=this._getTimeline();d[e]=b;f.addObserver(d)}},element:function(b,d,e){if(b)if("document"===d)l(document).bind(e,b);else if("window"===d)l(window).bind(e,b);else{var f=/^\$\{/;f.test(d)&&(d=d.replace(f,""),d=d.replace(/\}/,""));(d=this.find$(d))&&d.bind(e,b)}},symbol:function(b,d,e){b&&(d={},d[e]=b,this.addObserver(d))}},b,d;l.Event=
      function(b){if(f.supported.customEvent)return new CustomEvent(b,{bubbles:!0,cancelable:!0});var d=document.createEvent("Event");d.initEvent(b,!0,!0);return d};l.event={};l.event.special={};l.extend(f.An$.prototype,{bind:function(b,d){this.each(function(e,f){var a=l.event.special[b];a&&a.setup&&a.setup.call(f,b,d);f.addEventListener?f.addEventListener(b,d):f.a ttachEvent&&f.attachEvent(b,d);a=f.AnListeners=f.AnListeners||{};a[b]=a[b]||[];a[b].push(d )});return this},unbind:function(b,d){this.each(function(e,
      f){r(f,b,d)});return this},trigger:function(b){var d=document;this[0]&&(d=this[0]);d.dispatchEvent(b);return this}});b={creationComplete:function(b,d){p(b);var f;f=b.data[b.name].bindings||[];var t=f.length,a,k;for(a=0;a<t;a++)k=f[a],e(b,k)}};d={newSymbol:function(c,d){d.symbol.addObserver(b)}};q.bindElementAction=function(b,d,e,f,a){h(b,d,e,f,a,"element")};q.bindTimelineAction=function(b,d,e,f,a){h(b,d,e,f,a,"timeline")};q.bindTriggerAction=function(b,d,e,t,a){var k=f.getComposition(b).sym[d],g;
      k&&(k=k.timeline?k.timeline.data:null)&&(g=x("trig"),t=[g,"trigger",t,g],k.push(t),k.dirty=!0,h(b,d,e,g,a,"timeline"),k.dirty=!1)};q.bindSymbolAction=function(b,d,e,f){h(b,d,"",e,f,"symbol")};q.bindVariableAction=function(b,d,e,f){h(b,d,"","variableChanged:"+e,f,"symbol")};l.extend(q.prototype,{executeSymbolAction:function(b,d){if(!("object"!==typeof d||3>d.length)){var e=d[0],f=this.$(d[1]),a=d[2];!f||1>f.length||(f=q.getSymbol(f[0]))&&e&&(a&&"object"===typeof a||(a=null),f[e].apply(f,a))}},eSA:function(b,
      d){this.executeSymbolAction(b,d)}})})(window.AdobeEdge);
      (function(f,r,u){document.createEvent&&(f.addTouchSupport=function(){var e=f.$,p=f.An$;e.fn=e.fn||{};e.each("touchstart touchmove touchend swipe swipeleft swiperight ".split(" "),function(b,d){p.prototype[d]=e.fn[d]=function(b){return b?this.bind(d,b):this.trigger(d)};e.attrFn&&(e.attrFn[d]=!0)});var h="ontouchend"in document,l=!h&&r.navigator.msPointerEnabled,q=h?"touchstart":"mousedown",x=h?"touchend":"mouseup",s=h?"touchmove":"mousemove";e.event.special.swipe={scrollSupressionThreshold:30,durationThreshold:1E3,
      horizontalDistanceThreshold:30,verticalDistanceThreshold:75,swipeEvent:e.Event("swipe"),swipeLeftEvent:e.Event("swipeleft"),swipeRightEvent:e.Event("swiperight"),setup:function(){if(!this.setupDone){var b=e(this);l&&b.css("-ms-touch-action","pan-y pinch-zoom double-tap-zoom");b.bind(q,function(d){function c(d){b.unbind(x,c);b.unbind(s,f);t&&a&&a.time-t.time<e.event.special.swipe.durationThreshold&&Math.abs(t.coords[0]-a.coords[0])>e.event.special.swipe.horizontalDistanceThreshold&&Math.abs(t.coords[1]-
      a.coords[1])<e.event.special.swipe.verticalDistanceThreshold&&b.trigger(e.event.special.swipe.swipeEvent).trigger(t.coords[0]>a.coords[0]?e.event.special.swipe.swipeLeftEvent:e.event.special.swipe.swipeRightEvent);t=a=u}function f(b){if(t){var c=b.touches?b.touches[0]:b.originalEvent.touches?b.originalEvent.touches[0]:b;a={time:(new Date).getTime(),coords:[c.pageX,c.pageY]};Math.abs(t.coords[0]-a.coords[0])>e.event.special.swipe.scrollSupressionThreshold&&b.preventDefault()}}var h=d.touches?d.touches[0]:
      d.originalEvent.touches?d.originalEvent.touches[0]:d,t={time:(new Date).getTime(),coords:[h.pageX,h.pageY],origin:e(d.target)},a;b.bind(s,f).bind(x,c)});this.setupDone=!0}}};e.each({swipeleft:"swipe",swiperight:"swipe"},function(b,d){e.event.special[b]={setup:function(){e(this).bind(d,e.noop)},teardown:function(b,f,h){e(b).unbind(d)}}})})})(AdobeEdge,window);
      (function(f){function r(b,c,a,k,g,e){null!==s[c]&&(this.superProperty=s[c].cssProp,b=s[c].type,"color"===b?f.ColorTween&&(p.extend(this,f.ColorTween.prototype),p.extend(this,d),f.ColorTween.call(this,b,c,a,k,g,e)):(p.extend(this,h.prototype),p.extend(this,d),f.PropertyTween.call(this,b,c,a,k,g,e)));this.name="subpropertyTween"}function u(){var b=f.$.data(this.element,this.prop);b&&r.applySubproperty(this.element,b,b.tween)}function e(b,c){var a=b[0],k=this.name,g=f.$.data(a,s[k].cssProp);g||(g=d.buildProp.call({superProperty:s[k].cssProp},
      a),f.$.data(a,s[k].cssProp,g));g[k]=c;g.onFinalUpdate.call({element:a,prop:s[k].cssProp})}var p=f.$,h=f.PropertyTween,l=f.UpdateFinalizer,q,x={"box-shadow":{def:"box-shadow","-webkit-box-shadow":"boxShadow.color boxShadow.offsetH boxShadow.offsetV boxShadow.blur boxShadow.spread boxShadow.inset".split(" "),"-moz-box-shadow":"boxShadow.color boxShadow.offsetH boxShadow.offsetV boxShadow.blur boxShadow.spread boxShadow.inset".split(" "),"box-shadow":"boxShadow.color boxShadow.offsetH boxShadow.offsetV boxShadow.blur boxShadow.spread boxShadow.inset".split(" ")},
      "text-shadow":{def:"text-shadow","text-shadow":["textShadow.color","textShadow.offsetH","textShadow.offsetV","textShadow.blur"]},filter:{def:"-webkit-filter","-webkit-filter":"filter.invert filter.hue-rotate filter.contrast filter.saturate filter.brightness filter.sepia filter.grayscale filter.blur filter.drop-shadow.color filter.drop-shadow.offsetH filter.drop-shadow.offsetV filter.drop-shadow.blur".split(" "),"-moz-filter":"filter.invert filter.hue-rotate filter.contrast filter.saturate filter.brightness filter.sepia filter.grayscale filter.blur filter.drop-shadow.color filter.drop-shadow.offsetH filter.drop-shadow.offsetV filter.drop-shadow.blur".split(" "),
      filter:"filter.invert filter.hue-rotate filter.contrast filter.saturate filter.brightness filter.sepia filter.grayscale filter.blur filter.drop-shadow.color filter.drop-shadow.offsetH filter.drop-shadow.offsetV filter.drop-shadow.blur".split(" ")},"background-size":{def:"background-size","background-size":["background-size.x","background-size.y"]},"background-position":{def:"background-position","background-position":["background-position.x","background-position.y"]}},s={"boxShadow.offsetH":{cssProp:"box-shadow",
      type:"style",def:"0px",u:"px",i:1},"boxShadow.offsetV":{cssProp:"box-shadow",type:"style",def:"0px",u:"px",i:2},"boxShadow.blur":{cssProp:"box-shadow",type:"style",def:"0px",u:"px",i:3},"boxShadow.spread":{cssProp:"box-shadow",type:"style",def:"0px",u:"px",i:4},"boxShadow.color":{cssProp:"box-shadow",type:"color",def:"rgba(0,0,0,0)",i:5},"boxShadow.inset":{cssProp:"box-shadow",def:"",i:0},"textShadow.offsetH":{cssProp:"text-shadow",type:"style",def:"0px",u:"px",i:1},"textShadow.offsetV":{cssProp:"text-shadow",
      type:"style",def:"0px",u:"px",i:2},"textShadow.blur":{cssProp:"text-shadow",type:"style",def:"0px",u:"px",i:3},"textShadow.color":{cssProp:"text-shadow",type:"color",def:"rgba(0,0,0,0)",i:0},"filter.drop-shadow.color":{cssProp:"filter",type:"color",def:"rgba(0,0,0,0)",strReplace:"drop-shadow(%1",combinedNum:4,i:8},"filter.drop-shadow.offsetH":{cssProp:"filter",type:"style",def:"0px",u:"px",i:9},"filter.drop-shadow.offsetV":{cssProp:"filter",type:"style",def:"0px",u:"px",i:10},"filter.drop-shadow.blur":{cssProp:"filter",
      type:"style",def:"0px",strReplace:"%1)",u:"px",i:11},"filter.grayscale":{cssProp:"filter",type:"style",def:"0",strReplace:"grayscale(%1)",i:6},"filter.sepia":{cssProp:"filter",type:"style",def:"0",strReplace:"sepia(%1)",i:5},"filter.saturate":{cssProp:"filter",type:"style",def:"1",strReplace:"saturate(%1)",i:3},"filter.hue-rotate":{cssProp:"filter",type:"style",def:"0deg",strReplace:"hue-rotate(%1)",u:"deg",i:1},"filter.invert":{cssProp:"filter",type:"style",def:"0",strReplace:"invert(%1)",i:0},"filter.brightness":{cssProp:"filter",
      type:"style",def:"0",strReplace:"brightness(%1)",i:4},"filter.contrast":{cssProp:"filter",type:"style",def:"1",strReplace:"contrast(%1)",i:2},"filter.blur":{cssProp:"filter",type:"style",def:"0px",strReplace:"blur(%1)",u:"px",i:7},"background-position.x":{cssProp:"background-position",type:"style",def:"0px",u:"px",i:2,domProp:"fill"},"background-position.y":{cssProp:"background-position",type:"style",def:"0px",u:"px",i:3,domProp:"fill"},"background-size.x":{cssProp:"background-size",type:"style",
      def:"100%",u:"%",i:4,domProp:"fill"},"background-size.y":{cssProp:"background-size",type:"style",def:"100%",u:"%",i:5,domProp:"fill"}},b=1,d={setValue:function(b,c,a){f.$.data(this,s[c].cssProp)[c]=a},getValue:function(b,c){f.$.data(this,s[b].cssProp)},setupForAnimation:function(){var b=this;this.getElementSet().each(function(){var c=f.$.data(this,b.superProperty);c||(c=b.buildProp(this),f.$.data(this,b.superProperty,c))});h.prototype.setupForAnimation.call(this)},buildProp:function(c){var d,a={},
      k=this.superProperty,g=f.getSubProps(c,k);for(d in g)g.hasOwnProperty(d)&&(a[d]=g[d]);a.id=this.superProperty+b;b+=1;a.element=c;a.prop=k;a.onFinalUpdate=u;return a},update:function(b,c){h.prototype.update.call(this,b,c);var a=this.getElementSet(),d=this,g=this.property,e=this.tweenType;a.each(function(){if(d.getPropertyTweenData(this,e,g).animationID===d.animationID){var a=f.$.data(this,d.superProperty);a.timeline=d.timeline;a.tween=d;l.Register(d.timeline,a.id,a)}})}};r.pro totype.constructor=r;
      f.getSubProps=function(b,c){var a=p(b),d,g;for(g in x[c])if(x[c].hasOwnProperty(g)&&(d=a.css(g))&&""!==d&&"none"!==d){if("filter"==c){g=x[c][g];d=d.replace(/,\s*/g,",");var a=[],e=void 0;a["filter.invert"]=(e=d.match(/invert\((.*?)\)/))?e[1]:null;a["filter.hue-rotate"]=(e=d.match(/hue-rotate\((.*?)\)/))?e[1]:null;a["filter.contrast"]=(e=d.match(/contrast\((.*?)\)/))?e[1]:null;a["filter.saturate"]=(e=d.match(/saturate\((.*?)\)/))?e[1]:null;a["filter.brightness"]=(e=d.match(/brightness\((.*?)\)/))?
      e[1]:null;a["filter.sepia"]=(e=d.match(/sepia\((.*?)\)/))?e[1]:null;a["filter.grayscale"]=(e=d.match(/grayscale\((.*?)\)/))?e[1]:null;a["filter.blur"]=(e=d.match(/blur\((.*?)\)/))?e[1]:null;d=(e=d.match(/drop-shadow\((.*?\)\s*.*?)\)/))?e[1].split(" "):[null,null,null,null];a["filter.drop-shadow.color"]=d[0];a["filter.drop-shadow.offsetH"]=d[1];a["filter.drop-shadow.offsetV"]=d[2];a["filter.drop-shadow.blur"]=d[3];d=[];e=void 0;for(e=0;e<g.length;e+=1)d[g[e]]=a[g[e]]||s[g[e]].def;return d}a=d;g=x[c][g];
      a=a.replace(/,\s*/g,",");a=a.split(" ");d=[];e=void 0;for(e=0;e<g.length;e+=1)d[g[e]]=a[e]||s[g[e]].def;return d}return[]};r.getSubType=function(b){return s[b]?s[b].type:void 0};r.getStyle=function(b){return s[b]?s[b].cssProp:void 0};r.applySubproperty=function(b,c,a){var d,g,e,f=p(b);for(g in x[c.prop])if("def"!==g&&x[c.prop].hasOwnProperty(g)){d="";var n=!0;for(b=0;b<x[c.prop][g].length;b+=1){e=c[x[c.prop][g][b]];void 0===e&&(e=s[x[c.prop][g][b]].def);if("combinedNum"in s[x[c.prop][g][b]])for(var n=
      !0,h=b;h<b+s[x[c.prop][g][b]].combinedNum;h++)void 0!==c[x[c.prop][g][h]]&&c[x[c.prop][g][h]]!=s[x[c.prop][g][h]].def&&(n=!1);x[c.prop][g][b ].match(/^filter./)&&e==s[x[c.prop][g][b]].def&&n||("strReplace"in s[x[c.prop][g][b]]&&(e=s[x[c.prop][g][b]].strReplace.replace("%1",e)),d+=e,b!==x[c.prop][g].length-1&&(d+=" "))}(window.edge_authoring_mode&&g===x[c.prop].def||!window.edge_authoring_mode)&&f.css(g,d )}a&&a.notifier.obs.length&&a.notifyObservers("onUpdate",{elapsed:0,easingConst:0,property:g,value:d,
      element:f[0]})};f.SubpropertyTween=r;f.Timeline.addTweenType("subproperty",function(b,c,a,d,g){return new r("subproperty",b,c,a,d,g)});var c,n;for(q in s)c={},s.hasOwnProperty(q)&&(f.Timeline.addTweenProperty(q,"subproperty"),n=s[q],c[q]={f:n.domProp||f.camelize(n.cssProp),i:n.i,j:n.j,def:n.def},s[q].u&&(c[q].u=s [q].u),f.defineProps(c),f._.p[q].apply=e)})(window.AdobeEdge);
      (function(f){function r(b,a,c,d,e,n){f.PropertyTween.call(this,b,a,c,d,e,n);this.name="transformTween"}function u(b){var a=0;"string"===typeof b?a=parseFloat(b.replace(/[a-zA-Z%]+$/,"")):"number"===typeof b&&(a=b);return a}function e(b,a,c){if(void 0===a)return c;if(void 0===c)return a;var d=u(a),e=u(c),n;if(!d)return c;if(!e)return a;a=f.splitUnits(a).units;c=f.splitUnits(c).units;n=a;a!==c&&("%"===a&&(n=c,d=d/100*b),"%"===c&&(e=e/100*b));return d+e+n}function p(){}var h=f.$,l=f.PropertyTween,q=
      f.UpdateFinalizer,x=Math.cos,s=Math.PI/180,b,d="translateX translateY translateZ scaleX scaleY rotateX rotateY rotateZ skewX skewY".split(" ");b=f.supported=f.supported||{};var c=1,n={translate3d:0,translate:0,translateX:0,translateY:0,translateZ:0,rotate:1,rotateZ: 1,rotateX:1,rotateY:1,rotate3d:1,skew:2,skewX:2,skewY:2,scale3d:3,scale:3,scaleX:3,scaleY: 3,scaleZ:3,perspective:4},v="webkitAppearance"in document.documentElement.style;b.cssTransform=f.isSupported(["transformProperty","WebkitTransform",
      "MozTransform","OTransform","msTransform"]);b.cssTransform3d=f.isSupported(["perspectiveProperty","WebkitPerspective","MozPerspective","OPerspective","msPerspective"]);f.An$.prototype.hasClass=f.An$.prototype.hasClass||function(b){if(this[0]){var a=(this[0].className||"").split(/\s+/),c;for(c=0;c<a.length;c+=1)if(b===a[c])return!0}return!1};r.removeData=function(b){var a=f.$.data(b,r.dataName);a&&(a.timeline&&q.unRegister(a.timeline,a.id),f.$.data(b,r.dataN ame,void 0))};r.getNumber=u;r.splitUnits=
      f.splitUnits;r.applyTransform=function(b,a,c,d){void 0!==f.applyCount&&(f.applyCount+=1);b=h(b);var m,n=!0,l,p;d&&(n=!d.dontForceZ);m=e(1,a.translateX,a.motionTranslateX);l=e(1,a.translateY ,a.motionTranslateY);d=e(1,a.rotateZ,a.motionRotateZ);p=f.supported.cssTransform3d;v?(m="translate("+m+","+l+")",l=u(a.translateZ),(0!==l||n)&&p&&(m+=" translateZ("+a.translateZ+")"),m+=" rotate("+d+") ",p&&(l=u(a.rotateY),0!==l&&(m+=" rotateY("+a.rotateY+")"),l=u(a.rotateX),0!==l&&(m+=" rotateX("+a.rotateX+")")),
      a.skewX&&"0deg"!==a.skewX&&(m+=" skewX("+a.skewX+") "),a.skewY&&"0deg"!==a.skewY&&(m+=" skewY("+a.skewY+") "),m+=" scale("+a.scaleX+","+a.scaleY+") ",l=u(a.scaleZ),1!==l&&p&&(m+=" scaleZ("+a.scaleZ+")"),!window.edge_authoring_mode&&p&&b.css("-webkit-transform-style","preserve-3d"),b.css("-webkit-transform",m)):(p=u(a.rotateX),n=u(a.rotateY),n=a.scaleX*x(s*n),p=a.scaleY*x(s*p),m="translate("+m+","+l+")"+(" rotate("+d+")"),a.skewX&&"0deg"!==a.skewX&&(m+=" skewX("+a.skewX+") "),a.skewY&&"0deg"!==a.skewY&&
      (m+=" skewY("+a.skewY+") "),m+=" scale("+n+","+p+")",b.css("-moz-transform",m),b.css("-o-transform",m),b.css("-ms-transform",m),b.css("msTransform",m));c&&c.notifier.obs.length&&c.notifyObservers("onUpdate",{elapsed:0,easingConst:0,property:"transform",value:m,element:b[0]});b.css("transform",m)};r.dataName="EdgeTransformData";h.extend(r.prototype,l.prototype);h.extend(r.prototype,{constructor:r,setup:function(b){this.timeline=b;this.updateTriggered=!1},setValue:function(b,a,c){f.$.data(this,r.dataName)[a]=
      c},getValue:function(b,a){f.$.data(this,r.dataName)},setupForAnimation:function(){var b=this,a;this.getElementSet().each(function(){a=f.$.data(this,r.dataName);a||(a=b.buildTransformData(this),f.$.data(this,r.dataName,a))});l.prototype.setupForAnimation.call(this)},update:function(b,a){l.prototype.update.call(this,b,a);var c=this.getElementSet(),d=this,e=this.property,n=this.tweenType;c.each(function(){var a;d.getPropertyTweenData(this,n,e).animationID===d.animationID&&(a=f.$.data(this,r.dataName),
      a.timeline=d.timeline,a.tween=d,q.Register(d.timeline,a.id,a))})},buildTransformData:function(b){var a=f.parseCanonicalTransform(b);a||(a={translateX:"0px",translateY:"0px",translateZ:"0px",scaleX:1,scaleY:1,scaleZ:1,rotateX:"0deg",rotateY:"0deg",rotateZ:"0deg",skewXZ:0,skewXY:0,skewYZ:0,skewX:"0deg",skewY:"0deg"},a.matrix&&delete a.matrix);null===a&&(a={});a.id="transform_"+c;c+=1;a.element=b;a.onFinalUpdate=q.prototype.applyTransform;return a},buildDefaultTransformData:function(b){var a={translateX:"0px",
      translateY:"0px",translateZ:"0px",scaleX:1,scaleY:1,scaleZ:1,rotateX:"0deg",rotateY:"0deg",rotateZ:"0deg",skewXZ:0,skewXY:0,skewYZ:0,skewX:"0deg",skewY:"0deg"};a.id="transform_"+c;c+=1;a.element=b;a.onFinalUpdate=q.prototype.applyTransform;return a}});f.getTransform=function(b){b=h(b);var a=b[0].style,c;v&&((c=b[0].style.webkitTransform)||(c=b.css("-webkit-transform")));if(c)return c;(c=b[0].style.msTransform)||(c=b.css("-ms-transform"));c||(c=b.css("msTransform"));c||(c=a.MozTransform);c||(c=a["-moz-transform"]);
      c||(c=b.css("-moz-transform"));c||(c=a.oTransform);c||(c=b.css("-o-transform"));c||(c=a.transform);c||(c=b.css("transform"));return c||""};f.parseCanonicalTransform=function(b,a){var c=("string"===typeof a?a:f.getTransform(b)).match(/(\w+\s*\([^\)]*\))/g),d={},e={},h,s,l;if(!c)return null;e.translateX="0px";e.translateY="0px";e.translateZ="0px";e.scaleX=1;e.scaleY=1;e.scaleZ=1;e.rotateX="0deg";e.rotateY="0deg";e.rotateZ="0deg";e.skewXZ=0;e.skewXY=0;e.skewYZ=0;e.skewX="0deg";e.skewY="0deg";for(h=0;h<
      c.length;h+=1){s=c[h].match(/\w+/);if(d[s[0]]||0>n[s[0]])return null;l=c[h].match(/\([^\)]*\)/);l=l[0].replace(/[\(\)]/g,"");l=l.split(",");switch(s[0]){case "matrix":return null;case "translate3d":e.translateX=l[0];e.translateY=1<l.length?l[1]:"0px";e.translateZ=2<l.length?l[2]:"0px";d.translate3d=d.translate=d.translateX=d.translateY=d.translateZ=!0;break;case "translate":e.translateX=l[0];e.translateY=1<l.length?l[1]:"0px";d.translate3d=d.translate=d.translateX=d.translateY=!0;break;case "translateX":e.translateX=
      l[0];d.translate3d=d.translate=d.translateX=!0;break;case "translateY":e.translateY=l[0];d.translate3d=d.translate=d.translateY=!0;break;case "translateZ":e.translateZ=l[0];d.translate3d=d.translateZ=!0;break;case "rotate3d":return d.rotate3d=d.rotate=d.rotateX=d.rotateY=d.rotateZ=!0,null;case "rotateX":e.rotateX=l[0];d.rotate3d=d.rotateX=!0;break;case "rotateY":e.rotateY=l[0];d.rotate3d=d.rotateY=!0;break;case "rotateZ":case "rotate":e.rotateZ=l[0];d.rotate3d=d.rotate=d.rotateZ=!0;break;case "skew":e.skewX=
      l[0];e.skewY=1<l.length?l[1]:"0px";d.skew=d.skewX=d.skewY=!0;break;case "skewX":e.skewX=l[0];d.skew=d.skewX=!0;break;case "skewY":e.skewY=l[0];d.skew=d.skewY=!0;break;case "scale3d":e.scaleX=l[0];e.scaleY=1<l.length?l[1]:1;e.scaleZ=2<l.length?l[2]:1;d.scale3d=d.scale=d.s caleX=d.scaleY=d.scaleZ=!0;break;case "scale":e.scaleX=l[0];e.scaleY=1<l.length?l[1]:l[0];d.scale=d.scaleX=d.scaleY=!0;break;case "scaleX":e.scaleX=l[0];d.scale3d=d.scale=d.scaleX=!0;break;case "scaleY":e.scaleY=l[0];d.scale3d=d.scale=
      d.scaleY=!0;break;case "scaleZ":e.scaleZ=l[0];d.scale3d=d.scaleZ=!0;break;case "perspective":d.perspective=!0}}return e};f.TransformTween=r;h.extend(q.prototype,{applyTransform:function(b){var a=f.$.data(this.element,r.dataName);a&&b&&r.applyTransform(this.element,a,a.tween,b.context)}});p.applySubprop=function(b,a){var c=b[0],d=this.name,e=r.prototype.buildTransformData(c);e[d]=a;r.applyTransform(c,e,null,{})};f.Timeline.addTweenType("transform",function(b,a,c,d,e){return new r("transform",b,a,c,
      d,e)});for(b=0;b<d.length;b+=1)f.Timeline.addTweenProperty(d[b],"transform");f.defineProps({translateX:{f:"transform",i:0,j:0,u:"px"},translateY:{f:"transform",i:0,j:1,u:"px"},translateZ:{f:"transform",i:0,j:2,u:"px"},rotateZ:{f:"transform",i:1,j:0,u:"deg"},rotateX:{f:"transform",i:1,j:1,u:"deg"},rotateY:{f:"transform",i:1,j:2,u:"deg"},skewX:{f:"transform",i:2,j:0,u:"deg"},skewY:{f:"transform",i:2,j:1,u:"deg"},scaleX:{f:"transform",i:3,j:0},scaleY:{f:"transform",i:3,j:1},scaleZ:{f:"transform",i:3,
      j:2}});for(b=0;b<d.length;b+=1)f._.p[d[b]].apply=p.applySubprop})(window.AdobeEdge);
      (function(f){function r(){if(!x){var a=document.createElement("div"),a=h(a),e,g;a.css("background-color","transparent");g=a.css("background-color");a.css("background-color","rgb(100, 100, 100)");e=a.css("background-color");s=e!==g;a.css("background-color","transparent");a.css("background-color","hsl(100, 100%, 100%)");e=a.css("background-color");b=e!==g;a.css("background-color","transparent");a.css("background-color","rgba(100, 100, 100,.5)");e=a.css("background-color");d=e!==g;a.css("background-color",
      "transparent");a.css("background-color","hsla(100, 100%, 100%, .5)");e=a.css("background-color");c=e!==g;x=!0}}function u(a,b,c,d,e,n){f.PropertyTween.call(this,a,b,c,d,e,n);this.name="colorTween";r()}function e(a){return 0>a?a+1:1<a?a-1:a}function p(a,b,c,d){return d<v?a+c*d:0.5>d?b:d<t?a+c*(t-d):a}var h=f.$,l=["color","background-color","border-color"],q,x=!1,s=!1,b=!1,d=!1,c=!1,n=1/3,v=1/6,t=2/3;h.extend(u.prototype,f.PropertyTween.protot ype);h.extend(u.prototype,{constructor:u,getValue:function(a,
      b){return h(this).css(a)},setValue:function(a,b,c){h(this).css(b,c)},parseValue:function(a){var b=f.parseColorValue(a),c=/rgb/gi,d=/hsl/gi;if(b&&b.colorFunction&&b.values){a=b.values;b=b.colorFunction;if(b.match(c))if(this.animationColorSpace&&"HSL"===this.animationColorSpace)c={r:a[0],g:a[1],b:a[2]},(c=f.rgbToHSL(c))?3<a.length?(a=a[3],a=[c.h, c.s,c.l,a]):a=[c.h,c.s,c.l]:a=[];else if(!this.animationColorSpace)this.animationColorSpace="RGB";else{if("RGB"!==this.animationColorSpace)return a}else if(b.match(d))if(this.animationColorSpace&&
      "RGB"===this.animationColorSpace)c={h:a[0],s:a[1],l:a[2]},(c=f.hslToRGB(c))?3<a.length?(a=a[3],a=[c.r, c.g,c.b,a]):a=[c.r,c.g,c.b]:a=[];else if(!this.animationColorSpace)this.animationColorSpace="HSL";else if("HSL"!==this.animationColorSpace)return a;3===a.length&&(a[3]=1);return a}},formatValue:function(a){r();if(a){var b,e,n;"HSL"===this.animationColorSpace&&c?(b="hsl",a=4===a.length&&c?b+"a("+a[0]+","+a[1]+"%,"+a[2]+"%,"+a[3]+")":b+"("+a[0]+","+a[1]+"%,"+a[2]+"%)"):d?(b="rgb",a=4===a.length&&d?
      b+"a("+a[0]+"%,"+a[1]+"%,"+a[2]+"%,"+a[3]+")":b+"("+a[0]+"%,"+a[1]+"%,"+a[2]+"%)"):(b=a[0],e=a[1],n=a[2],"HSL"===this.animationColorSpace&&(a=f.hslToRGB({h:a[0],g:a[1],b:a[2]}),b=a.r,e=a.g,n=a.b),a=65536*Mat h.floor(2.55*b)+256*Math.floor(2.55*e)+Math.floor(2.55*n),a="#"+a.toString(16));return a}}});f.ColorTween=u;f.Color={formatValue:u.prototype.formatValue,parseValue:u.prototype. parseValue};f.parseColorValue=function(a){if(a){var b=[],c,d,e=/^\s*#([a-fA-F0-9])([a-fA-F0-9])([a-fA-F0-9])\s*$/,f=/rgb/gi,
      n=/hsl/gi;(d=/^\s*#([a-fA-F0-9]{2})([a-fA-F0-9]{2})([a-fA-F0-9]{2})\s*$/.exec(a))?(b=[pars eInt(d[1],16)/255*100,parseInt(d[2],16)/255*100,parseInt(d[3],16)/255*100],c="rgb"):(d=e.exec(a))?(b=[parseInt(d[1]+d[1],16)/255*100,parseInt(d[2]+d[2],16)/255*100,parseInt (d[3]+d[3],16)/255*100],c="rgb"):"transparent"===a&&(b=[0,0,0,0],c="rgb");c||(c=a.toString().match(/\w+/),h.isArray(c)?c=c[0]:c||(c=""),(d=a.toString().match(/\([\d%,\.\s]*\)/))&&0<d.length&&(d=d[0].replace(/[\(\)]/g,"")));if(0===b.length)if(c.match(f))if((e=
      /^\s*([0-9]{1,3})\s*,\s*([0-9]{1,3})\s*,\s*([0-9]{1,3})\s*(?:,\s*([0-9](?:\.[0-9]+)?)\s*)? $/.exec(d))&&4<=e.length){for(a=0;3>a;a+=1)b[a]=e[a+1]/255*100;4<e.length&&(e[4]||(e[4]=1),b[3]=e[4])}else{if((d=/^\s*([0-9]{1,3}(?:\.[0-9]+)?)\s*%\s*,\s*([0-9]{1,3}(?:\.[0-9]+)?)\s*%\s*,\s*([0-9]{1, 3}(?:\.[0-9]+)?)\s*%\s*(?:,\s*([0-9](?:\.[0-9]+)?)\s*)?$/.exec(d))&&4<=d.length)for(5<=d.length&&(d.length=5,d[4]||(d[4]=1)),a=0;a<d.length-1;a+=1)b[a]=d[a+1]}else if(c.match(n)&&(d=/^\s*([0-9]{1,3}(?:\.[0-9]+)?)\s*,\s*([0-9]{1,3}(?:\.[0-9]+)?)\s*%\s*,\s*( [0-9]{1,3}(?:\.[0-9]+)?)\s*%\s*(?:,\s*([0-9](?:\.[0-9]+)?)\s*)?$/.exec(d))&&
      4<=d.length)for(5<=d.length&&(d.length=5,d[4]||(d[4]=1)),a=0;a<d.length-1;a+=1)b[a]=d[a+1];if(b)for(a=0;a<b.length;a+=1)b[a]=Math.round(1E4*b[a])/1E4;return{colorFunction:c,values:b}}};f.hslToRGB=function(a){if(null===a||0>a.s||100<a.s||0>a.l||100<a.l)return null;for(;360<a.h;)a.h-=360;for(;0>a.h;)a.h=360+a.h;var b={},c=a.h/360,d=a.s/100;a=a.l/100;var f,h,l;0===d?b.r=b.g=b.b=a:(d=0.5>=a?a*(1+d):a+d-a*d,a=2*a-d,f=e(c+n),h=e(c),c=e(c-n),l=6* (d-a),b.r=p(a,d,l,f),b.g=p(a,d,l,h),b.b=p(a,d,l,c));b.r=Math.min(100*
      b.r,100);b.g=Math.min(100*b.g,100);b.b=Math.min(100*b.b,100);b.r=Math.round(1E4*b.r)/1E4;b .g=Math.round(1E4*b.g)/1E4;b.b=Math.round(1E4*b.b)/1E4;return b};f.rgbToHSL=function(a){if(null===a||0>a.r||100<a.r||0>a.g||100<a.g||0>a.b||100<a.b)return null;var b={h:0,s:0,l:0},c=a.r/100,d=a.g/100;a=a.b/100;var e=Math.max(c,d,a),f=Math.min(c,d,a),n;b.l=(e+f)/2;e>f&&0<b.l&&(n=e-f,b.s=0.5>=b.l?n/(e+f) :n/(2-e-f),b.h=e===a?4+(c-d)/n:e===d?2+(a-c)/n:(d-a)/n,b.h*=60,360<b.h?b.h-=360:0>b.h&&(b. h=360+b.h));b.s=Math.min(100*
      b.s,100);b.l=Math.min(100*b.l,100);b.h=Math.round(1E4*b.h)/1E4;b.s=Math.round(1E4*b.s)/1E4 ;b.l=Math.round(1E4*b.l)/1E4;return b};f.colorToSupported=function(a){r();if(!d&&/rgba/.test(a)||!s&&/rgb/.test(a)||!c&&/hsla/.test(a)||!b&&/hsl/.test(a)){var e=f.parseColorValue(a).values,g,n,h;if(4<=e.length&&0.5>e[3])return"transparent";g=e[0];n=e[1];h=e[2];/hsl/.test(a)&&(a=f.hslToRGB({h:e[0],g:e[1],b:e[2]}),g=a.r,n=a.g,h=a .b);g=Math.floor(2.55*g);n=Math.floor(2.55*n);h=Math.floor(2.55*h);g=(15<g?"":"0")+
      g.toString(16);n=(15<n?"":"0")+n.toString(16);h=(15<h?"":"0")+h.toString(16);a="#"+g+n+h}return a};f.Timeline.addTweenType("color",function(a,b,c,d,e){return new u("color",a,b,c,d,e)});for(q=0;q<l.length;q+=1)f.Timeline.addTweenProperty(l[q],"color")})(window.AdobeEdge);
      (function(f){function r(b){if(document.documentElement.style.hasOwnProperty("webkitAppearance")){var d=e(b).css("-webkit-transform");d.match(/translateZ/)||d.match(/matrix3d/)||e(b).css("-webkit-transform",d+" translateZ(0)")}}function u(b,d,c,n,l,s){var a=null,k,g;2<=l.length&&e.isArray(l[1])&&2<=n.length&&e.isArray(n[1])?a=1:2<=l.length&&e.isArray (l[4])&&2<=n.length&&e.isArray(n[4])&&(a=4);if(a)for(k=n[a].length<l[a].length?n[a]:l[a],g=k===l[a]?n[a]:l[a],a=k.length;a<g.length;a+=1)k[a]= k[a-1];f.PropertyTween.call(this,
      b,d,c,n,l,s);this.name="GradientTween";this.tweenType=h[b]}var e=f.$,p=f.PropertyTween,h={gradient:0},l={"background-image":{cssProp:"background-image",def:"0px",u:"px",i:1}},q,x=f._.p["background-image"].apply,s=f._.p["background-image"].prep;f.forceGPU=r;e.extend(u.prototype,p.prototype);e.extend(u.prototype,{constructor:u, setupForAnimation:function(){this.getElementSet().each(function(){r(this)});p.prototype.setupForAnimation.call(this)},getValue:function(b,d){return e(this).css(b)},setValuePre:function(b,
      d,c){e(this).css(d,"-webkit-"+c);e(this).css(d,"-moz-"+c);e(this).css(d,"-ms-"+c);e(this).css(d,"-o-"+c)},setValue:function(b,d,c){e(this).css(d,c)},update:function(b,d){var c=this.getElementSet(),e=this,f=this.tweenType,h,a,k,g,m,s;q=l[this.property].cssProp;this.updateTriggered||(this.updateTriggered=!0,this.setupForAnimation());c.each(function(){var c=e.getPropertyTweenData(this,f,e.property),l;if(c.animationID===e.animationID){a=c.fromValues;k=c.toValues;g=e.filter;m=a.length;s=[];for(h=0;h<m;h+=
      1)l=a[h],c=k[h],l="string"===typeof l?0===d&&0<e.duration?l:c.value:l+(c.value-l)*d,g&&g[h]&&(l=g[h](l,e,this,q,c.unit,b)),"number"===typeof l&&1>l&&(l=l.toFixed(6)),s.push(l+c.unit);c=e.formatValuePre(s);l=e.formatValue(s);e.setV aluePre.call(this,f,q,c);e.setValue.call(this,f,q,l);e.notifyObservers("onUpdate",{elapsed:b,easingConst:d,property:q,value:l,element:this})}})},parseValue:function(b){function d(a,b){if(1<a[b].length)return a[b][1];var c;c=0===b?0:b===a.length-1?100:(d(a,b-1)+d(a,b+1))/
      2;a[b].push(c);return c}if(b&&!(2>b.length)){"string"===typeof b&&(b=JSON.parse(b));var c=null,n=null,h=null,l=null,a=null,k=[],g=!1,m=[],s;e.isArray(b[1])?(c=b[0],n=b[1],b[2]&&(g=b[2])):(h=[b[0],b[1]],l=b[2],a=b [3],n=b[4],b[5]&&(g=b[5]));for(b=0;b<n.length;b+=1)if(s=f.Color.parseValue(n[b][0],b))k=k.concat(s),k.push(d(n,b));if((c={angle:c,colorstops:k,centerPoint:h,ellipse:l,extent:a,repeating:g})&&c.colorstops)return null!==c.angle?m=m.concat(c.angle):c.centerPoint&&(m=m.concat(c.centerPoint),m=
      m.concat([c.ellipse,c.extent])),m=m.concat(c.colorstops),m.concat(c.repeating)}},formatVal ue:function(b){return f.formatGradient(b,!1)},formatValuePre:function(b){return f.formatGradient(b,!0)}});f.GradientTween=u;f.Gradient={parseValue:u.prototype.parseValue };f.formatGradient=function(b,d){if(b){var c="",e=null,h,l,a;2===b.length%5?(e=1,c=c+"linear-gradient("+((d?b[0]:(450-b[0])%360)+"deg,")):(e=4,c+="radial-gradient(",c=d?c+(b[0]+"% "+b[1]+"%,"+(1==b[2]?"ellipse":"circle")+" "+b[3]+","):c+(b[3]+
      " "+(1==b[2]?"ellipse":"circle")+" at "+b[0]+"% "+b[1]+"%,"));1==b[b.length-1]&&(c="repeating-"+c);if(!(12>b.length||0!==(b.length-e-1)%5)){a=Math.floor((b.length-e-1)/5);for(h=0;h<a;h+=1)l=5*h+e,c+=f.Color.formatValue(b.slice(l,l+4)),-1!==b[l+4]&&(c+=" "+b[l+4]+"%"),h!==a-1&&(c+=",");return c+=")"}}};f.Timeline.addTweenType("gradient",function(b,d,c,e,f){return new u("gradient",b,d,c,e,f)});f._.p["background-image"].apply=function(b,d){var c,e;if("string"===typeof d)return x.call(f._.p["background-image"],
      b,d);c=f.Gradient.parseValue(d);e=f.formatGradient(c,!1);c=f.formatGradient(c,!0);b.css("background-image","-webkit-"+c);b.css("background-image","-moz-"+c);b.css("background-image","-ms-"+c);b.css("background-image","-o-"+c);b.css("background-image",e)};f._.p["background-image"].prep=function(b,d,c,e,h,l,a){return void 0==d[c]||"string"===typeof d[c][e]?s.call(f._.p["background-image"],b,d,c,e,h,l,a):d[c][e]};for(q in l)l.hasOwnProperty(q)&&f.Timeline.addTweenProperty(q,"gradient")})(window.AdobeEdge);
      (function(f){function r(b,d,c,e,f,h){x.call(this,b,"motion",c,void 0,void 0,h);this.name="motionTween";(this.path=e)&&1<e.length&&6>e[0].length&&(e[0][4]=e[0][5]=0,e[e.length-1].splice(2,0,0,0));this.keyframes=[];b=document.createElement("div");c=q(b);null!==document.body&&document.body.appendChild(b);c.css("left","-9999px").css("width","100px");c.css("transform-origin","50% 50%").css("-webkit-transform-origin","50% 50%").css("-moz-transform-origin","50% 50%").css("-ms-transform-origin","50% 50%").css("-o-transform-origin",
      "50% 50%");d=c.css("transform-origin")||c.css("-webkit-transform-origin")||c.css("-moz-transform-origin")||c.css("-ms-transform-origin")||c.css("-o-transform-origin");c.css("border-width","10px").css("border-style","solid");c=c.css("transform-origin")||c.css("-webkit-transform-origin")||c.css("-moz-transform-origin")||c.css("-ms-transform-origin")||c.css("-o-transform-origin");null!==b.parentNode&&b.parentNode.removeChild(b);this.originIncludesBorders=d!==c}function u(b,d,c){try{if(b[0]===d[0]&&b[1]===
      d[1])return{x:d[0],y:d[1]}}catch(e){}var f={},h=c*c,a=h*c,k=2*a-3*h+1;c=a-2*h+c;var g=-2*a+3*h,h=a-h;f.x=k*b[0]+c*b[2]+g*d[0]+h*d[4];f.y=k*b[1]+c*b[3]+g*d[1]+h*d[5];return f}function e(b,d,c){if(b[0]===d[0]&&b[1]===d[1])return{dx:0,dy:0};var e={},f=c*c,h=6*f-6*c,a=3*f-4*c+1,k=-6*f+6*c;c=3*f-2*c;var f=b[3],g=d[5];e.dx=h*b[0]+a*b[2]+k*d[0]+c*d[4];e.dy=h*b[1]+a*f+k*d[1]+c*g;return e}function p(b,d){var c=b.x-d.x,e=b.y-d.y;return Math.sqrt(c*c+e*e)}function h(b,d,c,e,f){var l=Math.floor(c[e].b),a=(c[e].b+
      c[e+1].b)/2-l,k=u(b,d,a),g=0;p({x:(c[e].x+c[e+1].x)/2,y:(c[e].y+c[e+1].y)/2},k)>f&&(k.b=a+ l,c.splice(e+1,0,k),g=h(b,d,c,e+1,f),g=g+h(b,d,c,e,f)+1);return g}function l(b){var d,c,e,f,l,a,k,g;for(d=0;d<b.length-1;d++){f=[0,0,3*b[d].upper.x,3*b[d].upper.y,3*b[d].lower.x,3*b[d].lower.y] ;l=[1,1,3*b[d+1].upper.x,3*b[d+1].upper.y,3*(1-b[d+1].lower.x),3*(1-b[d+1].lower.y)];a=[];for(c=0;5>c;c++)e=c/4,k={b:e},g=u(f,l,e),k.x=g.x,k.y=g.y,k.b=e,a[c]=k;a:{c=a;e=p(c[c.length-1 ],c[0]);var m=k=void 0,s=m=void 0;g=
      c[c.length-1].x-c[0].x;var q=c[c.length-1].y-c[0].y;for(k=1;k<c.length-1;k++)if(m={x:c[k].x-c[0].x,y:c[k].y-c[0].y},m=m.x*g+m.y*q,s=e*p(c[k],c[0]),0.005<Math.abs(Math.ac os(m/s))){c=!1;break a}c=!0}if(c)a.splice(1,3);else for(c=0;4>c;c++)e=3-c,h(f,l,a,e,0.01);f=b[d];l=1;s=m=q=g=k=e=c=void 0;for(c=0;c<a.length-1;c++)0<a[c+1].x-a[c].x&&(l=Math.min(l,a[c+1].x-a[c].x));k=Math.ceil(1/l); g=1/k;q=[];m=0;q[0]={t:0,e:0};for(c=0;c<k;c++){for(e=c*g;e>a[m+1].x&&m<a.length-2;)m++;s=a[m+1].y;0<a[m+1].x-a[m].x&&
      (s=a[m].y+(e-a[m].x)*(a[m+1].y-a[m].y)/(a[m+1].x-a[m].x));q[c]={t:e,e:s}}1>q[q.length-1].t &&(q[q.length]={t:1,e:1});f.easingTable=q}}var q=f.$,x=f.TransformTween,s=f.UpdateFinalizer;q.extend(r.prototype,x.prototype);q.extend(r .prototype,{constructor:r,getValue:function(b,d){},setupForAnimation:function(){x.prototype.setupForAnimation.call(this);this.points||(this.setUpPoints(),this.setUpLen2bMap(),l(this.keyframes));this.deltas||window.edge_authoring_mode||(this.getElementSet().each(function(){var b=
      q(this),c=f.$.data(this,"p_x")||"left",e=f.$.data(this,"p_y")||"top",h=q(this.parentElement),l=+parseFloat(b.css(c))||0,a=+parseFloat(b.css(e))||0;"%"===f.$.data(this,"u_x")&&(l=l/100*+h.width());"%"===f.$.data(this,"u_y")&&(a=a/100*+h.height());f.$.data(this,"deltaX",l);f.$.data(this,"deltaY",a);b.css(c,"0px").css(e,"0px")}),this.deltas=!0);for(var b=this;b._prevObj&&(2!=b._prevObj.path.length||b._prevObj.path[0][0]!==b._prevObj.path[1][0]||b. _prevObj.path[0][1]!==b._prevObj.path[1][1]);)b=b._prevObj;
      b=e(b.path[0],b.path[1],1E-6);this.deltaRotate=180*Math.atan2(b.dx,b.dy)/Math.PI},computeEasing:function(b){var d=this.keyframes;b/=this.getDuration();var c=0,e,f,h;for(e=0;e<d.length-1&&!(c=e,b<=d[e+1].t);e++);e=d[c].easingTable;f=d[c+1].l-d[c].l;b=(b-d[c]. t)/(d[c+1].t-d[c].t);h=Math.floor(b/(e[1].t-e[0].t));h=Math.min(e.length-2,Math.max(h,0));return d[c].l+(e[h].e+(b-e[h].t)*(e[h+1].e-e[h].e)/(e[h+1].t-e[h].t))*f},originInPx:function(b){var d,c={},e=b.width(),h=b.height(),l,a;d=(b.css("transform-origin")||
      b.css("-webkit-transform-origin")||b.css("-moz-transform-origin")||b.css("-ms-transform-origin")||b.css("-o-transform-origin")||"50% 50%").split(" ");0<d[0].indexOf("%")?(l=parseFloat(d[0].substring(0,d[0].length-1))/100,a=parseFloat(d[1].substring(0,d[1].le ngth-1))/100,c.x=e*l,c.y=h*a):(c.x=parseFloat(d[0].substring(0,d[0].length-2)),c.y=parseFl oat(d[1].substring(0,d[1].length-2)));this.originIncludesBorders||(l=l||c.x/e,a=a||c.y/h,d=f.splitUnits(b.css("border-left-width")).num+f.splitUnits(b.css("border-right-width")).num||
      0,d*=l,b=f.splitUnits(b.css("border-top-width")).num+f.splitUnits(b.css("border-bottom-width")).num||0,c.x+=d,c.y+=b*a);return c},update:function(b,d,c){this.updateTriggered||(this.updateTriggered=!0,this.setupForAnimation(c));c=this.getElementSet(c);var h=this,l=this.property,p=this.tweenType,a=this.findSegment(d),k=this.path,g=this.easeToB(d),m=this.points[this.points.length-1].l,r,g=Math.min(1,Math.max(0,g-a));r=Math.max(1E-6,Math.min(0.999999,g));var A=u(k[a],k[a+1],g),a=e(k[a],k[a+1],r),g=180*
      Math.atan2(a.dx,a.dy)/Math.PI,z,E;this._prevObj&&2===k.length&&k[0][0]===k[1][0]&&k[0][1]===k[1][1]?(E=!0,z=0):z=this.deltaRotate-g;if(0>d||1<d)k=Math.atan2(a.dy,a.dx),a=1<d?d-1:d,A.x+=Math.cos(k)*m*a,A.y+=Math.sin(k)*m*a;c. each(function(){var a=q(this),c=h.getPropertyTweenData(this,p,l),e=f.$.data(this,x.dataName),g=this.parentElement,k;e.tween=h;if(c.animationID===h.animationID){var a=h.originInPx(a),c=f.$.data(this,"p_x")||"left",m=f.$.data(this,"p_y")||"top",r=A.x,u=A.y,y=f.$.data(this,"u_x")||
      "px",J=f.$.data(this,"u_y")||"px",O=!window.edge_authoring_mode,K=f.$.data(this,"doAutoOrient"),K="true"===K?!0:"false"===K?!1:K;O&&(k=q(g),g=k.width(),k=k.height(),"%"===y&&(r=r/100*g),"%"===J&&(u=u/100*k));r+="right"===c?a.x:-1*a.x;u+="bottom"===m?a.y:-1*a.y;O&&(r+=0,u+=0);r=0!==r&&1E-6>Math.abs(r)?r.toFixed(6):r.toString();u=0!==u &&1E-6>Math.abs(u)?u.toFixed(6):u.toString();E||(K||(z=0),z=0.01<Math.abs(z)?z:0,f.$.data(this,"motionRotateZ",z+"deg"),h.setValue.call(this,void 0,"motionRotateZ",z+
      "deg"),s.Register(h.timeline,e.id,e));O?(h.setValue.call(this,void 0,"motionTranslateX",r+"px"),h.setValue.call(this,void 0,"motionTranslateY",u+"px"),s.Register(h.timeline,e.id,e)):(q(this).css(c,r+y),h.notifyObservers("onUpdate",{elapsed:b,easingConst:d,property:c,value:r+y,element:e.tween}),q(this).css(m,u+J),h.notifyObservers("onUpdate",{elapsed:b,easingConst:d,property:m,value:u+J,element:this}))}})},findSegment:function(b){b=this.len2b(b*this.points[this.points.length-1].l);b=Math.floor(b);
      return Math.min(Math.max(b,0),this.path.length-2)},easeToB:function(b){return this.len2b(b*this.points[this.points.length-1].l)},setUpLen2bMap:function(){var b=0,d,c,e=60*this.getDuration()/1E3,f=this.len2bMap=[],h=this.points,a;for(d=0;d<h.length-1;d++)h[d].l=b,b+=p(h[d],h[d+1]);c=h[h.length-1].l=b;this.len2bStep=e=c/e;d=b=0;if(0<c){for(;b<=c;){for(;d<h.length-1&&b>h[d+1].l;)d+=1;if(d>=h.length-1)break;a=h[d].b+(b-h[d].l)*(h[d+1].b-h[d].b)/(h[d+1].l-h[d].l);f.push({l:b,b:a});b+=e}f[f.length -1].b<
      h[h.length-1].b&&f.push({l:h[h.length-1].l,b:h[h.length-1].b})}else f.push({l:0,b:h[0].b})},setUpPoints:function(){var b=this.path,d,c,e,f;this.points=[];for(d=0;d<b.length-1;d++)for(c=0;5>c;c++)if(4>c||d===b.length-2)f=c/4,e={b:d+f},f=u(b[d],b[d+1],f),e.x=f.x,e.y=f.y,this.points.push(e);for(d=1;d<b.length;d++)for(f=b.length-d-1,c=0;4>c;c++)e=3-c+4*f,h(b[f],b[f+1],this.points,e,2);return this.points},len2b:function(b){this.len2bMap||this.setUpLen2bMap();var d=this.len2bMap,c=Math.min(Math.max(0,Math.floor(b/
      this.len2bStep)),this.len2bMap.length-2);return 0===d.length?0:1===d.length?d[0].b:(b-d[c].l)*(d[c+1].b-d[c].b)/(d[c+1].l-d[c].l)+d[c].b} });f.MotionTween=r;f.Timeline.addTweenType("motion",function(b,d,c,e,f,h){return new r("motion",b,d,c,e,f,h)});f.Timeline.addTweenProperty("motion","motion");f.Timeline.addTweenProperty("location","motion")})(window.AdobeEdge);
      (function(f){function r(e,b,d,c,f,l){if(d&&c&&e&&e._s&&e.sym&&e.sym[d]){var p=[],a;"object"==typeof c?a=c:(a=b.find$(c))||(a=b.$(c));a.each(function(){var a=h(this),b=document.createElement("div"),c=a._children(),r={},u,x;x=q.getParentSymbol(this,!0);if(u=new q(e.sym,d,e,x,l))(f||0===f)&&a._children().eq(f)[0]?0>f?c.get(f).insertAfter(b):c.get(f).insertBefore(b):a.append(b),u.opts=u.opts||{},h.extend(u.opts,r),u.init(b),u._applyBas eStyles(h(b),d),(x.ci=x.ci||[]).push(u),p.push(u)});e.readyCalled&&
      p.forEach(function(a){x._playAuto(a,!0);a.getSymbolElement().css("position","relative")});return p}}function u(e,b){var d,c=b.getSymbolElementNode().id;for(d=e.length-1;0<=d;d--)e[d].getSymbolElementNode().id===c&&e.splice(d,1)}function e(f,b){b=b||[];var d=f.parentNode;f&&1===f.nodeType&&(b.push(d),e(d,b));return b}function p(e,b){b=b||{};var d=e.composition?e.composition._s:null,c={},f=h.Event("beforeDeletion");h.extend(f,{Symbol:e,element:e.ele,performDefaultAction:!0});c&&h.extend(f,c);c=e.ci;
      if(d&&(e.notifyObservers("beforeDeletion",f),f.performDefaultAction)){e.stop(0);if(c)for(;0<c.length;)p(c[0],b);e.prnt&&e.prnt.ci&&u(e.prnt.ci,e);u(e.composition._s,e);e.composit ion=void 0;e.prnt=void 0;d=e.ele;q.setSymbol(h(d)[0],void 0);b._keepElement?h(d).empty():h(d).remove();e.tlCached=null;e.ele=null;e.removeObservers()}}var h=f.$,l=f.An$,q=f.Symbol,x=f.Composition;h.extend(l.prototype,{_parents:function(){var f=[];this.each(function(b,d){e(d,f)});return h(f)},_children:function(){var e=[];
      this.each(function(b,d){for(var c=e,c=c||[],f=d.firstElementChild;f;)c.push(f),f=f.nextElementSibling});return h(e)},eq:function(e){return h(this[e])},append:function(e){var b=this;h(e).each(function(d,c){b.each(function(b,d){d.appendChild(c)})})}});q.getParentSymbol=function(e,b){var d=h(e),c=d._parents(),f=c.length,l;if((l=q.getSymbol(d[0]))&&b)return l;for(d=0;d<f;d++)if(l=q.getSymbol(c[d]))return l;return null};h.extend(l.prototype,{empty:function(){var e;this.each(function(b,d){for(e=d.firstChild;e;)d.removeChild(e),
      e=d.firstChild})},remove:function(){var e;this.empty();this.each(function(b,d){(e=d.parentNode)&&e.removeChild(d)})}});h.extend(q.prototype,{deleteSymbol:function(e){return p(this,e)},createChildSymbol:function(e,b,d,c){if(e&&b){var f;"object"==typeof b?f=b:(f=this.find$(b))||(f=this.$(b));if(f&&f[0]&&(e=r(this.composition,this,e,b,d,c)))return e.forEach(function(b){}),e[0]}},getVariable:function(e){return this.variables[e]},setVariable:function(e,b){this.variables[e]=b;window.edge_authoring_mode&&
      (this._variables[e]=b);if(e){var d=this.getVariable(e),c="variableChanged:"+e,d={variableValue:d},f=h.Event(c);h.extend(f,{Symbol:this,element:this.ele,performDefaultAction:!0});h.extend(f,d);this.notifyObservers(c,f)}return this},getSymbol:function(e){e=this.$(e);return q.getSymbol(e)},getParentSymbol:function(){return q.getParentSymbol(this.ele,!1)},getChildSymbols:function(){return this.ci?this.ci.slice(0):[]},playAll:function(){this.play();for(var e=this.getChildSymbols(),b=0;b<e.length;b++)e[b].playAll()},
      stopAll:function(e,b){this.stop(e,b);for(var d=this.getChildSymbols(),c=0;c<d.length;c++)d[c].stopAll(e,b)},getSymbolElementNode:function(){return this.ele},getSymbolElement:function(){return f.$(this.ele)},_executeMediaAction:function(e,b){if(!("object"!==typeof b||3>b.length)){var d=b[0],c=this.$(b[1])[0];if(c&&d){var f=b[2];f&&"object"===typeof f||(f=null);"play"===d?(f&&0<f.length&&"number"===typeof f[0]&&(c.currentTime=f[0]),c.play()):"pause"===d&&c.pause()}}},_executeSymbolAction:function(e,
      b){if(!("object"!==typeof b||3>b.length)){var d=b[0],c=f.Symbol.get(this.$(b[1]));if(c&&d){var h=b[2];h&&"object"===typeof h||(h=null);c[d].apply(c,h)}}},eMA:function(e,b){this._executeMediaAction(e,b)}});q.prototype.getParameter=q.prototype.getVariable;q.prototype. setParameter=q.prototype.setVariable;h.extend(x.prototype,{createSymbolChild:function(e,b,d,c){return r(this,this.stage,e,b,d,c)},removeSymbol:function(e,b){if(this.symbolInstances){var d=q.get(e);d&&d.deleteSymbol(b)}}})})(window.AdobeEdge);
        • 1. Re: IE8 Finds Error in edge.6.0.0.min.js file with "if(b===b.window)"
          Happiest Camper Level 1
          OK... as usual I got no help here, but if anyone else runs into this problem, the solution was that the window command was causing the error because IE8 doesn't recognize responsiveness.  The trick was this piece of code added to the top of the script inside the index.html file...
          //this detects all versions of IE, particularly helpful as IE 10 and later weren't called by numbers anymore
          function detectIE() {
              var ua = window.navigator.userAgent;
              var msie = ua.indexOf('MSIE ');
              if (msie > 0) {
                  // IE 10 or older => return version number
                  return parseInt(ua.substring(msie + 5, ua.indexOf('.', msie)), 10);
              var trident = ua.indexOf('Trident/');
              if (trident > 0) {
                  // IE 11 => return version number
                  var rv = ua.indexOf('rv:');
                  return parseInt(ua.substring(rv + 3, ua.indexOf('.', rv)), 10);
              var edge = ua.indexOf('Edge/');
              if (edge > 0) {
                 // IE 12 => return version number
                 return parseInt(ua.substring(edge + 5, ua.indexOf('.', edge)), 10);
              // other browser
              return false;
              var scaleString = "width";
              if(detectIE()==8){
                 //alert("this is IE8");
              scaleString = "none";
               else{
          The variable scaleString then goes into the code already present in the index file replacing "width" (in my case, it could also be used for height and both).
          scaleToFit: scaleString,
          • 2. Re: IE8 Finds Error in edge.6.0.0.min.js file with "if(b===b.window)"
            resdesign Adobe Community Professional & MVP
            Very nice contribution! ☺
            On Wed, Oct 28, 2015 at 11:23 AM, Happiest Camper <forums_noreply@adobe.com>
