3 Replies Latest reply on Oct 28, 2015 10:20 PM by JJMack
    Is it possible to call server URL from photoshop script?
    tvstephen7
      I want to send some data to server URL and get response from photoshop, Is there any option to do this?
        • 1. Re: Is it possible to call server URL from photoshop script?
          37105686 Level 1
          you need photoshop to tell you it sent the information, or your looking to pull that information back into photoshop?
          • 2. Re: Is it possible to call server URL from photoshop script?
            xbytor2 Level 4
            Look into wget or curl. These are command line programs that can be called like this:
               app.system("wget http://comsite.org/images/image.jpg > ~/Desktop/image.jpg");
            This definitely works on OS X and there is probably something similar available for Win.
            • 3. Re: Is it possible to call server URL from photoshop script?
              I have downloaded images from a web server using socket code I found in Adobe sample Photoshop Javascript Socket.jsx. It seem to use Browser HTML Protocol port 80 GET. But I have never tried FTP a file to a web server using port 21. It would be complex and require a login etc.  There is also a HTML Port 80 PUT  command but I would know how to use that. Hypertext Transfer Protocol - Wikipedia, the free encyclopedia
              // Copyright 2007.  Adobe Systems, Incorporated.  All rights reserved.
              // This script demonstrates how to download images from a web server using the Socket object.
              // Note: Socket.read() parameter & behavior
              // Socket.read() will read or time out. It may not read all data from server.
              // Socket.read(999999) will read 999999 bytes, or timeout, or socket will be
              // closed by the server.
              // Settings
              #target photoshop
              app.bringToFront(); // bring top
              if("en_US" == $.locale) { // display only US build
                alert("This sample script shows how to download images from a web server using the Socket object.");
              // Remove header lines from HTTP response
              function removeHeaders(binary)
                var bContinue = true ; // flag for finding end of header
                var line = "";
                var nFirst = 0;
                var count  = 0;
                while (bContinue) {
                line = getLine(binary) ; // each header line
                bContinue = line.length >= 2 ;  // blank header == end of header
                nFirst = line.length + 1 ;
                binary = binary.substr(nFirst) ;
                return binary;
              // Get a response line from the HTML
              function getLine(html)
                var line = "" ;
                for (var i = 0; html.charCodeAt(i) != 10; i++){ // finding line end
                line += html[i] ;
                return line ;
              var socket = new Socket;
              var html = "";
              if (socket.open("www.adobe.com:80")){
                socket.write("GET /index.html HTTP/1.0\n\n");
                html = socket.read(9999999);
                socket.close();
              var aImg = html.match(/src=\"\/images\/(.*?)\"/g);  //  src="/images/~~~"
              if (null != aImg) { // parsed image tags
                for (var i=0; i < aImg.length; i++) {
                try{
                var str = aImg[i];
                var sImg = str.substring(5, str.length-1); // remove "src=" & ["]
                var f = File("~/socket_sample_" + i + sImg.substr(sImg.length-4)); // 4 = .gif or .jpg
                f.encoding  = "binary";  // set binary mode
                f.open("w");
                if (socket.open("www.adobe.com:80", "binary")){
                socket.write("GET " + sImg +" HTTP/1.0\n\n"); // Adobe's site image link starts with "/"
                var binary = socket.read(9999999);
                binary = removeHeaders(binary);
                f.write(binary);
                socket.close();
                f.close();
                app.open(f); // Open files in Photoshop
                f.remove();  // Remove temporary downloaded files
                }catch(e){
