2 Replies Latest reply on Mar 1, 2016 4:57 AM by BobLevine
    Knockout text not showing when exporting PDF In-Design. Solved!
    robertab10497520
      Hi all,
      So I tried many ways to save out text which was knocked out within a shape and I found two beneficial solutions.
      1. File > Export  > Save > Select PDF/X-1a:2001, under the Adobe PDF preset menu.  This should now export the document with the knockout text/object showing.
      2. Alternatively, you can save out the pages required as a Jpg image and then use www.smallpdf.com to convert the jpg to a pdf. You can then attach that one page to the rest of your pdf document if need be, using the same third party website provided.
