1. Re: Start an animation when it's scrolled to?
jhtmk Oct 28, 2015 9:25 PM (in response to zkman11)I'm working on something similar at the moment - I calculate the scroll position and use that position to trigger a symbol to show and then play, then I also get it to reset if the user scrolls back up. It resets so if they scroll back down it will trigger again
I am like you - I use bits and pieces and tweak until the job is done, this works for me so I hope it can be of benefit to you too
You can calculate and inject the scroll position directly onto your page with:
function checkScroll(){
var scrollPos = $(window).scrollTop();
$('p').html('scrollPos = '+scrollPos); }
Once you know your scrollPos you can use the following
//Playing symbols based on scroll position
sym.setVariable("symbolPlayed", false);
var mySymbolObject = sym.getSymbol("yourSymbolToPlay");
//change the number of scroll_pos to whatever you calculated
$(window).scroll(function() {
var y_scroll_pos = window.pageYOffset;
var scroll_pos = 282;
if(y_scroll_pos > scroll_pos) {
var symbolPlayed = sym.getVariable("symbolPlayed");
if (!symbolPlayed) {
sym.$("yourSymboToPlayl").show();
mySymbolObject.play("start");
sym.setVariable("symbolPlayed", true);
} if(y_scroll_pos < scroll_pos){
2. Re: Start an animation when it's scrolled to?
zkman11 Oct 28, 2015 9:49 PM (in response to jhtmk)Hey thanks for the help.
I tried using your code and wasn't able to get it to work yet. I noticed you had a typo "yourSymboToPlayl" - is that where i'm supposed to place my own symbol name? would I just put 'Stage' there?
I get this console error as well: Uncaught TypeError: Cannot read property 'play' of undefined
Also the checkscroll function - that script goes in my actual html page?
3. Re: Start an animation when it's scrolled to?
jhtmk Oct 28, 2015 10:28 PM (in response to zkman11)Yeah sorry that was a typo, For my project I'm doing all of the triggering inside edge in the compositionReady, and I have a seperate js script included in my project, which I use the bootstrapCallback to access the composition - that has the checkscroll function, but I don't see why you can't include it in an html page in script tags - it's only while you are developing to get the number, then you can get rid of it.
I'm really not sure I think 'Stage' may work but if you are not wanting to trigger anything inside your actual edge project like I am via compositionReady, then I think this method should still work but you would have to use bootstrapCallback
eg.
AdobeEdge.bootstrapCallback(function(compId){
var myComposition = AdobeEdge.getComposition('YourCompositionId');
Theres a bit of documentation out there on this - I'm not an expert but basically this allows you access and control of your composition externally
And I could possibly be wrong or there may be a much easier way to achieve what you want - it's just what is working for me
4. Re: Start an animation when it's scrolled to?
jhtmk Oct 28, 2015 11:01 PM (in response to jhtmk)Sorry I've just been copy and pasting the relevant bits from my own project and forgot to include the $(window).on('scroll',function(){
checkScroll();
5. Re: Start an animation when it's scrolled to?
jhtmk Oct 29, 2015 12:09 AM (in response to jhtmk)I'm thinking something like this may work for you, maybe try including the checkScroll function within this if it's not working, or maybe someone with better jquery /javascript experience can fix/ tweak this to suit your project
//Access your edge composition (change to whatever your edge composition class is and the name of symbol to play)
var myAnim = AdobeEdge.getComposition("yourCompositionClass");
//access your symbol
var mySymbol = myAnim.getSymbols("yourSymbol")[0];
var mySymbolObject = mySymbol;
//Add a label "start" on the timeline of your symbol to be played
6. Re: Start an animation when it's scrolled to?
zkman11 Oct 29, 2015 9:13 AM (in response to jhtmk)No luck yet. I just replaced all the "yourSymbol" and "symbolPlayed" with "Stage" which may not work.
Still getting this error too: Uncaught TypeError: Cannot read property 'play' of undefined
7. Re: Start an animation when it's scrolled to?
zkman11 Oct 29, 2015 1:05 PM (in response to zkman11)anybody have a script for this that can just be dropped into the stage actions without modifying any of the code/symbols? i'm not knowledgeable enough yet to piece the right things together.
8. Re: Start an animation when it's scrolled to?
mrgrymm Nov 1, 2015 2:48 PM (in response to zkman11)Read through parts 1-6. http://www.raymondcamden.com/?s=Edge+Animate&submit=Search
It works but my only issue is getting it to work with multiple compositions on 1 page
9. Re: Start an animation when it's scrolled to?
zkman11 Nov 2, 2015 9:05 AM (in response to mrgrymm)Yeah those blog articles were the first I saw addressing this problem but none of the examples have worked for me. I talked with the author and had him check my demo page but even he wasn't able to see the issue and no longer works with edge animate.
10. Re: Start an animation when it's scrolled to?
zkman11 Nov 2, 2015 9:13 AM (in response to zkman11)Wow, nevermind. I had tried pretty much every sample of code in all 6 articles with no luck. Wish I had a better explanation for what the issue was but the article you linked to with the most recently updated code just worked. No idea what I did different'y but thanks for posting and helping me persist with it!
11. Re: Start an animation when it's scrolled to?
mrgrymm Nov 2, 2015 5:43 PM (in response to zkman11)I've re-written the code, place it in compositionReady:
var check = 0;
function checkAnim(){
if(check == 0){
sym.play(0);
check = 1;
return check;
$(window).scroll(function(e) {
var y = $(window).scrollTop();
var h = $(window).height();
if(y+h > sym.getSymbolElement().position().top){
checkAnim();
You can download it here Dropbox - test5.zip
The only issue is if you try to use it with mulitple composions. Maybe you can figure it out? How to resolve javascript error in Edge 6.0.0 resulting from multiple compositions using the same function? (Javascript error in event handler! Event Type = symbol)
12. Re: Start an animation when it's scrolled to?
kevinneal Nov 3, 2015 12:06 PM (in response to zkman11)I have his working with multiple compositions. I have 3 on one page, by placing this code into all 3 of them
(note: I have added a buffer zone because the animation wasn't getting triggered on a small screen
Symbol.bindSymbolAction(compId, symbolName, "creationComplete", function(sym, e) {
function isScrolledIntoView(elem) {
var docViewTop = $(window).scrollTop();
var docViewBottom = docViewTop + $(window).height() + 190; //Adjust this number to match the 2nd one below
var elemTop = $(elem).offset().top - 190; //This number adds a buffer zone of 100px of scroll to trigger the animation. It should be the same number as above.
var elemBottom = elemTop + $(elem).height();
return ((elemBottom >= docViewTop)
&& (elemTop <= docViewBottom)
&& (elemBottom <= docViewBottom)
&& (elemTop >= docViewTop) );
var element=sym.getSymbolElement();
if(isScrolledIntoView(element)){
sym.play(0)
}else{
var handler;
handler=function(e){
console.log('Start me up');
sym.play(0);
$(window).off("scroll",handler);
$(window).on("scroll",handler);
