6 Replies Latest reply on Oct 29, 2015 12:44 PM by A.T. Romano
    Trandscoding Error?????
    BuckeyeBry
      When burning a large video, 24 minutes, to a Blueray I get a transcoding error at 77%?  Help...I'm using PE 7
        • 1. Re: Trandscoding Error?????
          What operating system are you on?
          How much free, clean, defragmented space is on your drive(s)?
          What model of camcorder is your video coming from and what format and resolution is it?
          What are your Project Settings, as listed under the program's Edit menu?
          • 2. Re: Trandscoding Error?????
            BuckeyeBry Level 1
            Windows 8.1 Pro
            How do you find "Free, clean, defrag space?
            Cannon Vixia HF20
            Not sure where to find project settings
            • 3. Re: Trandscoding Error?????
              BuckeyeBry Level 1
              64 bit
              • 4. Re: Trandscoding Error?????
                A.T. Romano Level 7
                BuckeyeBry
                It is not going to matter if you have Windows 8.1 Pro 64 bit. The key words are Premiere Elements 7 and AVCHD editing and Blu-ray burn to.
                If you are using Premiere Elements 7 on that computer, Premiere Elements 7 is still going to be a 32 bit application (it runs in the 32 bit compatibility mode of the 64 bit system). In the 32 bit system, maximum supported installed RAM = 4 GB of which 3 GB or less of that are available. This condition creates serious problems when you are trying to edit and process high resource demanding AVCHD format of the Canon HF20. For Windows, Premiere Elements becomes a 64 bit application with related computer resource perks when it is version 10, 11, 12/12.1, 13/13.1, or 14 specifically on Windows 7, 8, 8.1, or 10 64 bit.
                When you are doing this burn to Blu-ray disc format on Blu-ray disc, what are the readings that you see for Space Required and Bitrate (with and without the "Fit Content to Available Space" enabled)?
                Have you been able to do successful burn to Blu-ray with Premiere Elements 7 with a smaller sized project than what you are doing now? If so, please let us know the size of the project at that time.
                There is also the possibility of trying to take the AVCHD to a less resource demanding format, such as HD MPEG2.mpg, and import the HD MPEG2.mpg into the project. Lots of factors to consider.
                Please consider, give more information, and then we can decide troubleshooting strategy.
                Thank you.
                ATR
                • 5. Re: Trandscoding Error?????
                  You can find our how much space you have left on your hard drive(s) by opening My Computer in Windows Explorer.
                  • 6. Re: Trandscoding Error?????
                    A.T. Romano Level 7
                    BuckeyeBry
                    Add On information in case you need it...Referring to your information post 2
                    About your camera specifications, the Canon VIXIA HF20 that you mentioned
                    Canon U.S.A. : Support & Drivers : VIXIA HF20
                    For Premiere Elements 7 project settings see Timeline workspace, Edit Menu/Project Settings/General and the readings for Editing Mode, Timebase, Frame Size, and Pixel Aspect Ratio (even if the fields look grayed out).
                    ATR
