0 Replies Latest reply on Oct 29, 2015 3:22 PM by s4tlarson
    ColdFusion 11 JMX Monitoring with SSL/TLS
    s4tlarson
      Would like to monitor our JVM performance in the production network securely by enabling the SSL/TLS options available to JMX.
      Having trouble even after I properly created valid keyStore/trustStore using an internal CA with a .csr for a .p7b.
      However while attempting to poll the CF JVM for JMX I cannot get the secure negotiation to work properly.
      Added these lines to /cfusion/bin/vm.config:
      -Dcom.sun.management.jmxremote=true
      -Dcom.sun.management.jmxremote.port=3333
      -Dcom.sun.management.jmxremote.ssl=true
      -Dcom.sun.management.jmxremote.authenticate=false
      -Dcom.sun.management.jmxremote.ssl.need.client.auth=false
      -Djavax.net.ssl.keyStore=jmxkey.keystore
      -Djavax.net.ssl.keyStorePassword=password
      Also want to enable these flags too for testing:
      -Djavax.sun.management.jmxremote.ssl.enabled.protocols=TLSv1.2
      -Djavax.sun.management.jmxremote.ssl.cipher.suites=TLS_RSA_WITH_AES_128_CBC_SHA
      Everything on my jconsole setting are set up properly, what am I missing for the CF/JVM side?
      Also I would like to see some documentation on this setup, haven't found anything through searching.
      Closest example from IBM and Apache Tomcat.
