2 Replies Latest reply on Dec 1, 2006 3:17 PM by anema75
    SCORM tracking for PPT without quizz ?
    anema75 Level 1
      Hello,
      I published ppt with quizz with SCORM 1.2 tracking and it work perfectly in our Opensource LMS.
      But if I published a ppt without a quizz, tracking in LMS is only time to open 1st slide and status is failed (or incomplete) and there is no score value tracked.
      Is it possible with breeze presenter to track a ppt without quiz ? (If yes how ?!)
      Thanks in advance
      Marc
        • 1. Re: SCORM tracking for PPT without quizz ?
          deepzn
          Marc
          Change the following settings to enable breeze presenter to track a ppt without quiz:
          1.) Click on Breeze Quiz Manager and click on the second tab Reporting
          2.) Check Enable Reporting for this Presentation
          3.) Under Learning Management System , click on SCORM or AICC (depends on your LMS)
          4.) Under Choose Report Data, select Report Slide Views Only
          5.) Under Report Pass or Fail, select Report Complete/Incomplete
          6.) Under Report Score to LMS as, select Percent
          7.) Under Reporting Level, select Only report the score
          8.) Click OK and publish the presentation
          Hope this helps
          Deepak
          • 2. Re: SCORM tracking for PPT without quizz ?
            anema75 Level 1
            Hello Deepak
            THANKS a LOT !
            It Works with SCORM and our LMS Ganesha.
            Marc
