4 Replies Latest reply on Oct 30, 2015 4:50 AM by Vinicius Baptista
    Apply overprint only to black objects & texts
    Pete Stan Level 1
      I am trying to write a script that apply Overprinting attribute to all objects & texts on all layers only to K=100.
      I start from unlocking layers...
      var doc = app.activeDocument;
      for (i=0; i<doc.layers.length; i++)
                  doc.layers[i].locked = false;
      By the way, is it possible to 'read' locked/unlocked state of the all layers by Javascript, perform some operations, and then lock back layers and leave unlocked ones as they were before performing the script?
      Pete
        • 1. Re: Apply overprint only to black objects & texts
          Vinicius Baptista Level 2
          Hi Pete,
          Well, answering the question of this post, use this code:
          var totalItens = app.activeDocument.pageItems.length;
          var items = app.activeDocument.pageItems;
          for (i = 0; i < totalItens; i++){
              if(items[i].typename == 'PathItem'){
                  if (items[i].fillColor.cyan == 0 && items[i].fillColor.magenta == 0 && items[i].fillColor.yellow == 0 && items[i].fillColor.black == 100){
                      if (items[i].fillOverprint == false){
                      items[i].fillOverprint = true;
                  if (items[i].strokeColor.cyan == 0 && items[i].strokeColor.magenta == 0 && items[i].strokeColor.yellow == 0 && items[i].strokeColor.black == 100){
                      if (items[i].strokeOverprint == false){
                      items[i].strokeOverprint = true;
              if(items[i].typename == 'TextFrame'){
                  for ( var j = 0; j < items[i].textRanges.length; j++ ) {
                      if (items[i].textRanges[j].fillColor.cyan == 0 && items[i].textRanges[j].fillColor.magenta == 0 && items[i].textRanges[j].fillColor.yellow == 0 && items[i].textRanges[j].fillColor.black == 100){
                          if (items[i].textRanges[j].characterAttributes.overprintFill == false){
                              items[i].textRanges[j].characterAttributes.overprintFill = true;
                      if (items[i].textRanges[j].strokeColor.cyan == 0 && items[i].textRanges[j].strokeColor.magenta == 0 && items[i].textRanges[j].strokeColor.yellow == 0 && items[i].textRanges[j].strokeColor.black == 100){
                          if (items[i].textRanges[j].characterAttributes.overprintStroke == false){
                              items[i].textRanges[j].characterAttributes.overprintStroke = true;
          And, answering the second question: Yes OfCourse, you can unlock the layers, perform some operations and then lock it back. But is better you say what you trying to do, what the purpose of this?
          I hope helped, bests, Vinícius.
          • 2. Re: Apply overprint only to black objects & texts
            Pete Stan Level 1
            Hi Vinícius,
            This works like a charm! Thanks!
            Second question:
            Because I am unable to lock the layers with variable name in it in different files (see sample screenshot):
            It means that every file has different name of the layer Info (there are plenty of combinations but always starts with 'Info')
            Mind that I would sometimes have more layers so won't be able to lock always the layer at the very top:
            Normally I could perform:
            function tryLockLayer(name) {
                    try {
                        lrs.getByName(name).locked = true;
                    } catch(e) {
                        return;
                var lrs = doc.layers;
                tryLockLayer("Information");
                tryLockLayer("Info Layer");
                tryLockLayer("Info");
            But the problem is that I am not able to 'predict' all the names of that layer in incoming files, there are too many combinations.
            I don't think I would be able to use Regex to match the pattern thats starts from info, like \<Inf\w+ hence I do lock the layer manually before running any script
            Peter
            • 3. Re: Apply overprint only to black objects & texts
              Hi, glad to have helped...
              Well, as the question was answered this topic, I suggest you mark as "answered" to help facilitate research forum here, I'm trying to provide the solution to this second answer, if you prefer you can create a new topic with this question.
              And we going ahead...
              See ya!!
              Best regards, Vinícius.
              • 4. Re: Apply overprint only to black objects & texts
                On time, to your second question:
                This loop will lock all the layers with word 'Inf' in your name, Information, Inf, Info, layerInfo, layer 1 Information, whatever.... Note: It's considered the Uppercase and Lowercase.
                var layersLength = app.activeDocument.layers.length;
                for (i=0; i < layersLength; i++){
                    nameLayer = app.activeDocument.layers[i].name;
                    if (nameLayer.indexOf('Inf') != '-1'){
                        app.activeDocument.layers[i].locked = true;
                Hope it works,
                Bests...
                Vinícius
