10 Replies Latest reply on Oct 30, 2015 6:25 AM by Abureesh
    How to JavaScript?
    Abureesh
      Hi Everybody,
      I would highly appreciate it if anyone could help on this.
      How to make more than one field required in a form by checking one CheckBox?
      Thanks in advance.
        • 1. Re: How to JavaScript?
          Do you know how to do it for one field? If so, then just duplicate that
          command for the other fields as well...
          • 2. Re: How to JavaScript?
            Abureesh Level 1
            Thanks a lot for your reply.
            I used the following script and it works for one field only.
            function makeFieldRequired() {
                var fields = ["Check Box102"];
                var yes = false;
                for (var i in fields) {
                    if (this.getField(fields[i]).value=="Yes") {
                        yes = true;
                        break;
                this.getField("Text103").required = yes;
            makeFieldRequired();
            I tried to do the following with the multi filed, but it doesn't work:
                var fields = ["CCheck BoxCheck Box95"];
                var yes = false;
                        yes = true;
                        break;
                this.getField("Text96", "Text98", "Text99", "J1", "City1", "Country1").required = yes;
            I tried to repeat the script for each filed in the same "Action," but it doesn't work, too.
            All these attempts are in vain.
            • 3. Re: How to JavaScript?
              Bernd Alheit Adobe Community Professional & MVP
              Use something like this:
                  this.getField("Text96").required = yes;
                  this.getField("Text98").required = yes;
              • 4. Re: How to JavaScript?
                Abureesh Level 1
                Thank a bunch Brend,
                I used your recommendation as follows, but again doesn't works. I am not sure what is wrong that is I am doing!
                    var fields = ["Check Box95"];
                    var yes = false;
                            yes = true;
                            break;
                    this.getFields("Text96").required = yes;
                    this.getFields("Text98").required = yes;
                    this.getFields("Text99").required = yes;
                    this.getFields("J1").required = yes;
                • 5. Re: How to JavaScript?
                  What is not working? What is the content of the field "Check Box95" ?
                  • 6. Re: How to JavaScript?
                    You have errors in your code. Check the JS console and you should see some error messages there that will help you solve the problem.
                    • 7. Re: How to JavaScript?
                      Abureesh Level 1
                      Thanks a lot Bernd.
                      Your help is highly appreciated.
                      I discovered the error. The S in the end of getFild.
                      • 8. Re: How to JavaScript?
                        Abureesh Level 1
                        Thanks a lot try67
                        • 9. Re: How to JavaScript?
                          Correct. Does it work now, then?
                          • 10. Re: How to JavaScript?
                            Abureesh Level 1
                            Yes, it works perfectly.
                            Thanks.
