5 Replies Latest reply on Oct 30, 2015 3:56 AM by Jump_Over
    Get height of page items using reference point
    aviR Level 1
      Hello all
      Can anyone tell me how to get the geometric bounds of a page item using reference point?
      Please help
      Thank you
        • 1. Re: Get height of page items using reference point
          Jump_Over Level 5
          geometricBounds property is reffered to document.zeroPoint
          Whats your goal?
          Jarek
          • 2. Re: Get height of page items using reference point
            aviR Level 1
            My goal is:
            When i set the reference point in to document to any point ex:- topleftcorner
            then i should get the X and Y value of the selected page item.
            How can I do this?
            • 3. Re: Get height of page items using reference point
              Jump_Over Level 5
              there is no such property like X and Y for object.
              Object.geometricBounds is an array of y,x,Y,X coordinates for object's corners regarding to zeroPoint.
              LeftUp corner is Object.geometricBounds[1] (for x) and Object.geometricBounds[0] (for y).
              However if your goal is to check layoutWindow.transformReferencePoint and read relative object's bound point
                   app.activeDocument.layoutWindows[0].transformReferencePoint will tell you which point is selected
              According to above you need to read some object.geometricBounds or calculate it (in case of center points)
              Jarek
              • 4. Re: Get height of page items using reference point
                aviR Level 1
                What I am doing is:
                setting the reference point like following
                app.ActiveWindow.transformReferencepoint = idAnchorPoint.idTopLeftAnchor
                After this I want to get the X and Y coordinates that is showing at the top of the indesign document below the menu bar.
                Are you getting my query?
                • 5. Re: Get height of page items using reference point
                  Jump_Over Level 5
                  If you set the reference point ==> you can read/calculate object relative values
                  I.e:
                  you set reference to AnchorPoint.TOP_LEFT_ANCHOR
                       so you can
                            read X value as object.geometricBounds[1] and
                            read Y value as object.geometricBounds[0]
                  you set reference to AnchorPoint.RIGHT_CENTER_ANCHOR
                       so you can
                            read X value as object.geometricBounds[3] and
                            calculate Y value as (object.geometricBounds[2] - object.geometricBounds[0] ) / 2
                  Is here something unclear?
                  Jarek
