2 Replies Latest reply on Oct 30, 2015 8:37 AM by PROIETTA
    AE / Mac Pro 6,1: Render Error!
      Hello. I found during the render an error that does not allow me to go out with my final file.
      Each 8 seconds rendered, After Effects crashes with this error advice:
      Register rendering v13.5 Macintosh 64 Adobe After Effects for the project "mapping_castello_v018_2015_peraga.aep"
      Rendering started in 10/23/15 at 11:13:33 EDT
      10/23/15 11:13:33 EDT: Starting composition "DEF-1024".
      Render Settings: Settings best
        Quality: High
        Resolution: Full
        Size: 1024 x 768
        Use proxy: Do not use any proxy
        Effects: Settings. current
        Disk cache: Settings. current
        Color depth: 8
        Merger fotogr .: On to pick levels.
        Rendering field: Disable
        Pulldown: Disable
        Effect mov .: On to pick levels.
        Single: Settings. current
        Interval. time: Length comp.
        Start: 0: 00: 00: 00
        End: 0: 07: 45: 03
        Duration: 0: 07: 45: 04
        Freq. frames: 25.00 (composition)
        Guide layers: Settings. current
        Skip existing files: Disable
        Output Module: Without losses
        Output: /Users/proietta/Desktop/castello_peraga_v08/castello_peraga_def_v08.mov
        Format: QuickTime
        Information output: Photo - JPEG
        Information output: Quality space = 100
        Include: Project Link
        Audio Output: 48.000 kHz / 16-bit / Stereo (if the composition contains audio)
        Channels: RGB
        Depth: Millions of Colors
        Color: Premultiplied
        Resize: -
        Crop: -
        Dim. End: 1024 x 768
        Profile: -
        Post-Render Action: None
      After Effects - Error: Can not allocate enough memory to render the current frame (1016 x 800 @ 8 bpc). Reduce the memory requirements for the rendering of this frame, or install more RAM. (12805). For more information, see www.adobe.com/go/learn_ae_mem_it (7 :: 66)
        10/23/15 11:16:47 EDT: term composition "DEF-1024".
      Total elapsed time: 3 min, 14 sec
      Registry closed 23/10/15 at 11:16:47 EDT
      Once the error appears I have to close and restart the software.
      I'm working with a very performing machine and I do not understand how it is possible ...
      Hardware summary:
        Model Name: Mac Pro
        Model Identifier: MacPro6,1
        Processor Name: Quad-Core Intel Xeon E5
        Processor speed: 3.7 GHz
        Number of processors: 1
        Number of Core: 4
        L2 cache (per core): 256 KB
        L3 Cache: 10 MB
        Memory: 20 GB
        Boot ROM Version: MP61.0116.B07
        SMC Version (system): 2.20f18
        Version lighting: 1.4a6
        Hardware UUID: FD4796AB-E6F3-5061-AE65-92A5693DB289
      I set the AE preferences related to memory to 16 GB dedicated and I ticked the box for the reduction of the cache memory if it's almost full.
      What can I do to get more performances from my Mac Pro and get faster render without this kind of mistakes?
      Thanks a lot!
