2 Replies Latest reply on Nov 13, 2015 7:35 AM by Szalam
    AE import window all buggy...
    Brandon Kraemer Level 1
      Using the import command in AE, the resulting window opens crazy slow and often doesn't redraw properly inside the dialog box.  What ever comp image I had up will persist in the import box.  Getting anything to refresh in the finder side bar takes a long time.  Behavior is very very laggy.
      Interestingly enough... export dialog box works fine.  Premiere also works fine.
      Specs:
      OS X 10.10.4, MacPro (Late 2013) 3.5 GHz 6-Core, 32 GB 1866 MHz ECC RAM, AMD FirePro D700 6144 MB (dual).
      AE version: 13.5.1.48
