I have a Web App input form and the form has the ability for a file to be uploaded. I am using AJAX to submit the form. The form and attached file submits fine. The problem is I need to be able to return the data of the web app, specifically the file name. I know when a file is uploaded random numbers are added to ensure each file is unique. I need this data returned so I can then take the file name and do something with it.
Here is my code:
$(function() {
$('.upload').click(function(){
var formData = new FormData($('form')[0]);
$.ajax({
url: '/CustomContentProcess.aspx?CCID=35265&OID={module_oid}&OTYPE={module_otype}',
type: 'POST',
xhr: function() {
myXhr = $.ajaxSettings.xhr();
if(myXhr.upload){
myXhr.upload.addEventListener('progress',progressHandlingFunction, false);
return myXhr;
success: function(results){
console.log(results);
data: formData,
cache: false,
contentType: false,
processData: false
function progressHandlingFunction(e){
if(e.lengthComputable){
var progressBar = document.getElementById("progress");
progressBar.max = e.total;
progressBar.value = e.loaded;
Currently, upon success, the data that is displayed is the the HTML code of the web page that has the form.
How do I modify my code to return the submitted web app data, namely the file name as it is upload?
I thought there was a way to render the new items' detail page in the POST
response (relating to the PageID
parameter on the submit action?), but I couldn't find it.
If the app items don't Require Approval, you can use the {module_webapps}
tag in the content of the response to list the latest few items from the app and identify the one just submitted by a unique attribute or token.
A slightly different approach: after submit, run a search on the unique token. I prefer to do it this way because we
...Copy link to clipboard
A slightly different approach: after submit, run a search on the unique token. I prefer to do it this way because we can get back a proper JSON response containing exactly one item, and we need not rely on the presence (and correct collection naming) of the {module_webapps}
tag in the response.
I was incorrect in my original question. It is actually returning the Custom Content Confirmation Layout page. I used your idea of inserting the latest {module_webapps}
and pulling the most recent item. In a quick test it works great.
I will look into doing the unique token idea as that does sound better.
Thank you for the help and ideas!
