5 Replies Latest reply on May 14, 2006 6:41 PM by kglad
    Need Help With Syntax Error
    ZEO2K
      Here's my code:
      ["item" + num].gotoAndStop("s2");
      stop ();
      Here's my syntax error:
      **Error** Symbol=sprite 107, layer=Action Layer, frame=1:Line 1: Unexpected '.' encountered
      Total ActionScript Errors: 1 Reported Errors: 1
      Wanted to know if I wrote this syntax wrong and if anyone knows how to solve it.
      Thanx!
        • 1. Re: Need Help With Syntax Error
          Level 7
          Well, as the error message is telling you, no period (.) before the
          gotoAndStop.
          Either write:
          gotoAndStop("s2")
          or use:
          this.gotoAndStop("s2")
          which is a less buggy syntax.
          Also, you probably don't need the "stop();" after the first line...
          you're already leaving the rest of that code behind by going to the
          frame labeled "s2".
          ZEO2K wrote:
          > Here's my code:
          > .gotoAndStop("s2");
          > stop ();
          > '.' encountered
          > .gotoAndStop("s2");
          > it.
          > Thanx!
          • 2. Re: Need Help With Syntax Error
            the syntax is wrong and to resolve the problem we need to know the relative or absolute path from the timeline that contains that code to the object "item"+num. if, for example, the object is on the same timeline as the code, you could use:
            • 3. Re: Need Help With Syntax Error
              ZEO2K Level 1
              Thanks guys for your help. It worked!
              • 4. Re: Need Help With Syntax Error
                Level 7
                Oh... forgot about the square brackets disappearing problem, now that
                I'm reading from the newsgroup. That's REALLY annoying...
                > you could use:
                > this["item" + num].gotoAndStop("s2");
                • 5. Re: Need Help With Syntax Error
                  you're welcome.
