2 Replies Latest reply on Nov 2, 2015 9:46 AM by macian2
    How to add new pages to a document on the left-hand side.
    macian2
      How is it possible to add a specified number of pages, to an existing document, where the new pages will fall on a “left-hand” side (even-numbered pages)?
      My example: I have a four-page document; I want to add an additional 4 pages, using a specific master page, to the document. But, I require the new pages to be placed as left-handed pages (even-number pages).
      I currently have a applescript, that I built & use, to add the four (4) new pages. Unfortunately, the new pages fall at the end of the current document. I cannot figure out how to get them to place properly. I currently do the manual move of the pages.
      Please be nice … my applescritping skill level is just below intermediate. Any suggestions would be greatly appreciated.
      (* INSERT • Display Ad pages.applescript *)
      set myFirst_Pagenumber to 1
      --LIST FOR MY COMMON USE
      --set myMasterChoice to "ADs-Display ad pages"
      --set myMasterChoice to "ADs-Display Ad pages"
      --set myMasterChoice to "ADs-Display Ad Pages"
      --set myMasterChoice to "ADs-Display ads"
      --set myMasterChoice to "ADs-Display Ads"
      --set myMasterChoice to "Ads-Display ads"
      tell application "Adobe InDesign CC 2014"
          activate
          set theDoc to document 1
          set originalPgCount to get count of pages of theDoc
          tell theDoc
              --DETERMINE WHAT THE DISPLAY AD MASTER NAME IS
              try
                  if master spread "ADs-Display ad pages" exists then
                  else if master spread "ADs-Display Ad pages" exists then
                  else if master spread "ADs-Display Ad Pages" exists then
                  else if master spread "ADs-Display ads" exists then
                  else if master spread "ADs-Display Ads" exists then
                  else if master spread "Ads-Display ads" exists then
                  end if
              on error
                  tell current application to beep 3
                  display dialog "Your \"display ad\" master page was not found !" buttons {"Gee Thanks!"} default button 1 with icon 1 giving up after 2
                  return
              end try
          end tell --theDoc
          -- SET PAGE NUMBERING TO START AT 1
          tell theDoc
              set continue numbering of section 1 to false
              set page number start of section 1 to myFirst_Pagenumber
              set continue numbering of section 1 to true
          end tell
          -- INSERT NEW "DISPLAY AD" PAGES
          tell theDoc
              repeat originalPgCount times
                  --make new page at end of theDoc --okay this works
                  try
                      make new page at end of theDoc with properties {applied master:master spread myMasterChoice, allow page shuffle:true}
                  on error
                      return
                  end try
              end repeat
              --SET GUIDES TO TOP
              set properties of the guide preferences to {guides in back:false, guides locked:false, guides shown:true, guides snapto:true, ruler guides color:cyan, ruler guides view threshold:5.0}
          end tell --theDoc
      end tell --application
      tell current application to beep 2
        • 1. Re: How to add new pages to a document on the left-hand side.
          Peter Kahrel Adobe Community Professional & MVP
          When you add a page you can specify where the page is added. Without specification, new pages go to the end of the document. I don't know AppleScript, but in JavaScript you'd do something like
          app.activeDocument.pages.add (LocationOptions.BEFORE, app.activeDocument.pages[-1])
          to add a page before the document's last page. Try and find the AppleScript equivalent of LocationOptions.before.
          Peter
          • 2. Re: How to add new pages to a document on the left-hand side.
            macian2 Level 1
            Thank you pkahrel. Though your suggestion was not exactly what I needed, it was the catalyst to my solution. By identifying the page ID of each existing page of the active document, I could then place my new page exactly where I wanted it. I have attached below the New and Revised applescript that solved my dilemma.
                activate
                tell theDoc
                    --DETERMINE WHAT THE DISPLAY AD MASTER PAGE NAME IS
                    repeat with eachItem in {"ADs-Display ad pages", "ADs-Display Ad pages", "ADs-Display Ad Pages", "ADs-Display ads", "ADs-Display Ads", "Ads-Display ads"}
                        if master spread eachItem exists then
                            set myMasterChoice to eachItem
                        end if
                    end repeat
                end tell --theDoc
                tell theDoc
                end tell --theDoc
                tell theDoc
                    set originalPgCount to count of pages
                    set myPageNames to get id of every page as list
                    repeat with eachItem in myPageNames
                        make new page at after page id eachItem with properties {applied master:master spread myMasterChoice, allow page shuffle:true}
                    end repeat
                    --SET GUIDES TO TOP
                end tell --theDoc
