1 Reply Latest reply on Jul 26, 2006 2:50 PM by Peter Farland
    FDS samples not working.
    bluecrab
      I installed CFMX 7.0.2 developer edition in the multiserver configuration. This created the cfusion instance of JRun. I then installed FDS 2 express following the install instructions from this Tech Note: http://www.adobe.com/cfusion/knowledgebase/index.cfm?id=4f079a4d&pss=rss_flex_4f079a4d
      I merged the web.xml files from CF and Flex following the forum post found here: http://www.adobe.com/cfusion/webforums/forum/messageview.cfm?catid=583&threadid=1168104&en terthread=y
      CF works and the Flex samples will open but they don't do anything. The dashboard sample displays this error: [MessagingError message='Unknown destination 'dashboard_feed_control'.']
      Please help.
        • 1. FDS samples not working.
          Peter Farland Level 3
          The first link says "Combining these two web applications into a single .war file is an unsupported configuration and is not recommended due to known issues and conflicts".
          Do you really need to combine these web applications?
          Can you try to get it to work without combining them?
          This isn't really enough information for me to diagnose the issue, but if the error is raised by the client, then it may not be able to find the services-config.xml. Perhaps ColdFusion doesn't call it this and you'd need to tell the message broker servlet and the webtier compiler (if compiling from a .mxml based URL instead of deploying a precompiled SWF) where to find the correct config file.
