1 2 Previous Next 43 Replies Latest reply on Feb 24, 2018 7:51 AM by CritterMel
    LR Mobile always pending
    DanJ50
      I've seen similar comments posted but haven't really found an answer. When I've finished editing pictures (imported from camera roll) on my ipad in the corner it says 'uploading, 7 pending'. But nothing seems to be happening, I noticed on another post that people reinstalled lightroom and then it then worked fine, that solved it for that one time, I'm now left with pending images again. I can't reinstall lightroom every time I use it. I'm wondering if I've missed a trick, should I exit out of lightroom for it to upload? does it only upload at certain times of the day? Or is there an issue and I should wait for an update?
        • 1. Re: LR Mobile always pending
          khatwani Adobe Employee (Admin)
          Hi DanJ,
          Greetings!!!
          Try this :
          "With Lightroom closed go to /Users/intel/Library/Caches/Adobe/Lightroom/Sync Data/ and remove (or rename) the Sync.lrdata folder. Restart Lr and it should try to reconcile your local synced data and the cloud synced data. This can take a while depending on your machine, network connection, and the number of synced images.  Additionally, when it completes it may leave some images in the All Sync Errors collection. These are usually fixable by applying any setting that forces a sync (like an exposure increase), letting it sync, and then reversing it."
          was the cure that I got from Jim to solve my problem. It worked and I have since not looked back. It is syncing flawlessly now and I am over the moon with how neat it is to work with Mobile. Less desk time and more couch/ipad time...
          Here is the source thread of this answer : https://forums.adobe.com/thread/1446467
          Regards
          Jitendra
          • 2. Re: LR Mobile always pending
            DanJ50 Level 1
            Hi Jitendra,
            Thanks for the reply, I tried your solution but its still not syncing. I think it's an issue on the ipad side, the only thing I can think of is that I live in China and how well creative cloud works can be intermittent. But then I can use the creative cloud app on the ipad and download/update desktop software no problem.
            • 3. Re: LR Mobile always pending
              greule Adobe Employee
              Hi Dan, I've just checked the back-end of your account and it looks like that there are still some originals missing to be uploaded from your iPad.
              Could you send us a Lr Mobile diagnostig log.
              The Lr Mobile app log can be triggered when you open up the settings and long press the top left LR Icon a diagnostic log will be generated and attached to your local mail client.
              In addition could you try to re-boot your device and see if that helps.
              Guido
              • 4. Re: LR Mobile always pending
                DanJ50 Level 1
                Thanks for the reply Greule,
                A reboot didn't help, but I just sent the diagnostig log off.
                Dan
                • 5. Re: LR Mobile always pending
                  PeterRHawkes Level 1
                  Was this problem ever resolved as I have iPhone Pending and iPad Pending and no idea how to cure!!??
                  Peter H
                  • 6. Re: LR Mobile always pending
                    HI Peter, I've just send you a private message with some instructions. - Guido
                    • 7. Re: LR Mobile always pending
                      Guido
                      Thanks for the message; I replied but it bounced!!
                      My reply was;
                      Guido
                      I tried removing those videos to no effect.
                      I therefore removed the Lr apps from iPhone & iPad and then deleted the online library from Lr Desktop and started again!
                      All went well and I was fine with a number of images from Camera Roll on my iPhone uploading and syncing to Desktop and iPad and a Collection from Desktop syncing with both iOS devices.
                      I now added 61 more photos from Camera Roll on iPad and 9 have synced but the remainder have not. Now shows on iPad Pending Upload 52 files?
                      Can you see this blockage from your end?
                      Peter H
                      • 8. Re: LR Mobile always pending
                        nargalzius
                        I have the same issue.
                        There's definitely something wrong with the software. Here's what I did.
                        First, it started with 57 photos (pending) - these were imported from the camera roll of my iphone.
                        I did the suggestions above and the only way to remove the pending was to isolate the actual photos being uploaded. So again, after removing these photos (both from LR on my iPhone AND on the web) it was "up to date" (obviously)
                        Then I tried just importing ONE photo. Then it got stuck again at "Uploading... 1 pending.
                        Then I removed it and once again it stopped importing and returned to "All up to date"
                        But whenever I would do this (delete the photo successfully from phone and get the "up to date" dialog), the LR WEB interface STILL had the photo (showing that cloud lightning icon saying that it was "syncing" - even if I've cancelled it from the phone). So ONCE AGAIN, I remove it from the web as well just to make sure the photo has no traces in both iPhone and web.
                        Then instead of importing a photo (just to eliminate the possiblity of a corrupted photo from the camera roll) I try taking a picture straight from LR. ONCE AGAIN, it gets stuck with "Uploading... 1 pending"
                        I've also tried redoing all mentioned above, but this time uninstalling LR mobile from my phone after I've cleared the web interface as well. And the problem persists.
                        So I'm pretty sure it's the software either from the phone app, or the web app. I don't think there's an issue between the Web and the Desktop client (but I may be wrong) but there definitely is between the mobile app and the web app
                        • 9. Re: LR Mobile always pending
                          Doubtless is a software issue but what!??!
                          Long work round - on my iPad Pro I import photos from SD card (jpeg version as RAW not supported) and they go into Apple Photos. I then connect to my iMac remotely using Parallels Access (sure will work with others) and export photos from Apple Photos on my desktop into a folder already setup in Lr as Auto Import. I then start Lr and create a collection and put the newly imported photos into it. That collection then successfully synchs with Lr Mobile on my iPad and iPhone. The wait is allowing Apple Photos on iOS device to sunchanged to the Desktop version!
                          Rather a long way round and leaves me feeling would I be better just using Apple Photos!!
                          Peter H
                          • 10. Re: LR Mobile always pending
                            Jay6k
                            Add another person with the same issue to the pile! I've tried the "delete all data" option in Lightroom CC preferences, tried deleting the sync.lrdata file in the library cache folder... nothing works. Forever pending....lightroom-screenshot.jpgIMG_6713.PNG
                            • 11. Re: LR Mobile always pending
                              Hi. Could you please send me a LR Desktop diagnostic log  - best as a private message with a downloadable dropbox link.
                              You can trigger the log via LR Desktop preferences -> Lightroom Mobile and when you hold down the alt key you will notice a generate diagnostic log button. - Guido
                              • 12. Re: LR Mobile always pending
                                ianr77322067
                                I have an iPad Air 2 with Lightroom Mobile installed and a Macbook Air with Lightroom installed.
                                I have tried all sorts things  to make two way sync work as we would all like.
                                I have over 3,000 photos stored in Photos on both devices, synced through iCloud. Mostly they are JPGs but in the last few months I have been taking RAW photos with a Sony A7II (ARW files) and a Nikon D750 (NEF files).
                                My Macbook stores the full size photos but my iPad stores photos at a much reduced size, optimised for the iPad.
                                What I have discovered is the following:
                                I can insert an SD card into the card reader for my iPad. Photos opens automatically and I have the option to import all or selected photos. These are stored on the iPad as reduced size images but, as long as my iPad is connected to wifi, the original size RAW files are automatically uploaded to iCloud and then the original size RAW files are synced automatically to Photos on my Macbook.
                                Then to import from the iPad camera roll into Lightroom Mobile, I can only import the Nikon RAW FILES. Sony RAW files are not compatible and can't be imported.
                                Any files imported from the iPad camera roll into Lightroom Mobile will only sync to Lightroom on the website and then to Lightroom on my Macbook if they are miniscule. I mean a few kilobytes rather than anything more. Otherwise the message "Uploading 1 Pending" never changes.
                                However, Lightroom Collections made on the Macbook sync quickly to Lightroom Web and my iPad.
                                Then any edits made on the iPad sync back to the Macbook very quickly.
                                Therefore, the recommendations are:
                                Never try to upload photos into the Lightroom system from an iPad. It does not work.
                                Import them into the iPad with an SD card reader, let them sync through iCloud to Photos on the Mac, export them as unaltered originals to where you store your Lightroom images on your Mac and then create a collection or add them to an existing collection that is synced with the iPad.
                                To cut out a couple of steps, it is better to load the SD card contents direct into the Mac first.
                                • 13. Re: LR Mobile always pending
                                  wazooteyman
                                  I've also sent y'all my log too!  I'm using an iPad pro and trying to sync some RAW data from there to my iPhone and Macbook.  If it helps - I had unloaded my camera directly to the iPad in lieu of using the desktop since I prefer the mobile workflows and can't easily import from the Photos app on the Mac into Lightroom.
                                  • 14. Re: LR Mobile always pending
                                    Magnus Lewan Level 1
                                    I assume it works for some people, but definitely not for me. Everything is pending, and I lost a certain number of photos I had taken, when I uninstalled and reinstalled the app.
                                    For you Adobe people, don't you have anyone internally with the same problem? If you do, it seems simple to just compare the settings of those people with the settings for someone where it works. My wild guess is that it is something with the account configuration on the server side.
                                    • 15. Re: LR Mobile always pending
                                      davidr31512456
                                      I'm not certain if anyone has noticed this, but the only way that LR mobile will sync for me is if I leave the app open (although I'm guessing you just need the app open, I literally watched the cloud synchronization status to ensure that it completed).  This synchronization does NOT work in the background.  Perhaps Adobe plans to add it in the future, but background synchronization would be a huge plus.  For anyone following this thread, I'd suggest leaving your phone unlocked and the LR mobile app open to see if it begins to upload.  I also noticed that the synchronization does not appear to work at all over a slow internet connection (I was on vacation last week and wasn't able to get anything to sync until I got home).
                                      • 16. Re: LR Mobile always pending
                                        storky666 Level 1
                                        I have this problem as well. The sync is essentially worthless.
                                        It would be good to have an option to get the RAW files from the iPhone directly in the computer without having to rely on the cumbersome sync mechanism
                                        • 17. Re: LR Mobile always pending
                                          fonso22
                                          Hello. Was this problem ever solved? I  can't use Lightroom Mobile: it won't upload any photo to the cloud showing 'pending' constantly. Thank you. Philip
                                          • 18. Re: LR Mobile always pending
                                            Could you send us a Lr Mobile diagnosti loc?
                                            The Lr Mobile app log can be triggered when you  open up the settings via the top left Lr-icon in collection view and when you then   long press the top left LR Icon within the settings panel a diagnostic log will be generated and attached to your local mail client.
                                            In addition it would be great if you can run a speedtest on  your device and send us the results.
                                            Guido
                                            • 19. Re: LR Mobile always pending
                                              fonso22 Level 1
                                              Hi there. Please find the Lr Mobile diagnostic attached.
                                              By speedtest you do mean a connection speed test of my phone, right?
                                              Thanks.
                                              Philip
                                              Identity Lab
                                              Explore and Evolve - - - identitylab.at
                                              Philip Reitsperger, Mag., MA
                                              Design Management, - Strategy and Branding - - - philipreitsperger.com <http://philipreitsperger.com/>
                                              This email and any attachments are intended solely for the addressee and may contain confidential information. If you are not the intended recipient of this email and/or its attachments you must not take any action based upon them and you must not copy or show them to anyone. Please send the email back to us and immediately and permanently delete it and its attachments.
                                              • 20. Re: LR Mobile always pending
                                                Right. connection speed of your phone upload would be helpful. - Guido
                                                • 21. Re: LR Mobile always pending
                                                  fonso22 Level 1
                                                  I attached a screenshot in my last email.
                                                  Please find it in this email again.
                                                  Thank you.
                                                  Identity Lab
                                                  • 22. Re: LR Mobile always pending
                                                    Zoals Hein het Ziet
                                                    Hi Guido,
                                                    I have the same problem. I am wondering if you find a soilution to fixe the problem.
                                                    Hein
                                                    • 23. Re: LR Mobile always pending
                                                      Did I get it right that the upload count is stuck even when you have Lr Mobile running in the foreground for a couple of minutes?
                                                      You could also try this...
                                                      1. De-Activate Auto-Lock (Set Auto-Lock on "never")
                                                      2. Run Lightroom again in Foreground
                                                      3. Lightroom mobile should now upload the picture in a reasonable time
                                                      Hope this helps.
                                                      Guido
                                                      • 24. Re: LR Mobile always pending
                                                        Zoals Hein het Ziet Level 1
                                                        Question, where can I find Auto-Lock?
                                                        • 25. Re: LR Mobile always pending
                                                          "Auto_Lock" is listed under iOS settings -> Display&Brightness
                                                          • 26. Re: LR Mobile always pending
                                                            Thanks, it seems that it works now.
                                                            • 27. Re: LR Mobile always pending
                                                              anestisp77721485
                                                              I have the same problem with my ipad.  One image is still pending DSCF6296.png  not sure how to fix it
                                                              • 28. Re: LR Mobile always pending
        Could you copy the DSCF6296.png to an extra collection e.g. named "for debug" so that it's easier for me to have a look at the server-side. Thanks, Guido
        • 29. Re: LR Mobile always pending
        anestisp77721485 Level 1
        I can't find that file.  I only have a JPEG version of it but not a png version.  I rarely  use png format.  I did an indexed search for it in my external hard drives as well.
        Sent from my iPhone
        • 30. Re: LR Mobile always pending
        fabienl80233204
        Has this issue been solved?
        Coming back from holidays today, I have a collection with 160 photos -> raw imported from my android phone while I was inthe hotel room.
        Now, I can see all those photos in the lightrom website (Adobe Photoshop Lightroom)
        But on my windows desktop; lightroom CC (updated to latest version) has just created an empty collection... and all photos syncing status remains on "pending".
        (Note that a few other photos that were directly taken with my phone have been sync'ed without issue)
        Is it related to the size of those raw pictures?
        What does status "pending" mean?
        • 31. Re: LR Mobile always pending
        jsp*1130
        I too am having a syncing problem but it's slightly different. In LR preference/Mobile the window shows 6 pending syncs. This has been showing for over a month. However, there are no images in the cloud, or on my iPhone, that are not already synced. Others taken since those 6 waiting have been synced properly, I just don't know how to get rid of those 6 pending images that aren't really pending. The Syncing 6 Photos shows on my basic LR panel. In the LR mobile preferences panel 6 images show as pending yet it also says ) Downloading 0, 6 pending. How do I get those 6 images out of the pending panel?
        • 32. Re: LR Mobile always pending
        Could you both send me a LR Desktop diagnostic log  - best as a private message with a downloadable dropbox link. Thanks in advance - Guido
        • 33. Re: LR Mobile always pending
        I just deleted the sync data and resync everything and it's all good now.
        Sent from my iPhone
        • 34. Re: LR Mobile always pending
        daerp Level 1
        How did you delete the sync data and then do a re-sync? I would love to try that.
        • 35. Re: LR Mobile always pending
        Michael J. Hoffman Adobe Community Professional
        Hi daerp,
        Youll need to go to Lightroom on your desktop for that, and open Preferences.
        On the Lightroom Mobile preferences tab, you can view more information about your account. You can also delete synced information. Delete All Data deletes all information about your photos from Lightroom for mobile, including previews, metadata, and develop settings. However, it doesn't delete your original photos. They remain on the machine and aren't affected. All the collections are also preserved, but their Lightroom mobile sync settings are reset.
        See this page for more detail:
        How to sync Lightroom desktop and the Lightroom mobile app
        Mike
        • 36. Re: LR Mobile always pending
        daerp Level 1
        Thanks, Mike
        I pressed the Delete all Lightroom Mobile Data. And that's good.
        But then I get a window prompt that says: "Delete Lightroom Catalog". That sounds like I might be deleting my desktop catalog, which of course would be a disaster!!
        Paul
        • 37. Re: LR Mobile always pending
        Rosey-82
        I have the same problem with photos not syncin.
        • 38. Re: LR Mobile always pending
        eddy-4
        Same problem--2 uploads always pending.
        • 39. Re: LR Mobile always pending
        Have you tried the solutions listed in this thread? What steps did you take, and what were the results?
        If you go to lightroom.adobe.com and view your catalog, do you see two images with black thumbnails? Try deleting them and resync.
        Mike
        1 2 Previous Next
