6 Replies Latest reply on Nov 27, 2015 12:01 PM by johnrellis
    Copy develop settings from one photo to another: having problems! photo:getDevelopSettings LrDevelopController.setValue
    roryj2010499 Level 1
      I've also attached the full code at the bottom of this message in case that helps, but, to summarize,
      I have a lua plugin (MIDI2LR by rsjaffe) that receives MIDI messages from an application through a LrSocket. Everything has been working, but I've tried to add copy/paste develop settings without success.
      In the following code, the copy settings is:
      function copySettings()
          local photo = LrApplication.activeCatalog():getTargetPhoto()
          settings = photo:getDevelopSettings()
      end
      and the paste settings is:
      function pasteSettings()
          applySettings(settings)
      end
      function applySettings(set) --still experimental
          if LrApplicationView.getCurrentModuleName() ~= 'develop' then
                  LrApplicationView.switchToModule('develop')
          end
          for x,v in pairs(set) do
      --      SERVER:send(string.format('%s %d\n', x, develop_lerp_to_midi(v)))
      --      PARAM_OBSERVER[x] = v
            LrDevelopController.setValue(x,v)
          end
      end
      The functions do get called, but nothing happens to the target photo. I've also been unable to attach a debugger (tried ZeroBrane studio as described in Debugging Adobe Lightroom plugins with ZeroBrane Studio - ZeroBrane but can't get Lightroom to load mobdebug.lrmodule.
      Can someone point out where I'm going wrong?
      Thanks.
      require 'strict.lua' -- catch some incorrect variable names
      require 'Develop_Params.lua' -- global table of develop params we need to observe
      local LrApplication      = import 'LrApplication'
      local LrApplicationView  = import 'LrApplicationView'
      local LrDevelopController = import 'LrDevelopController'
      local LrFunctionContext  = import 'LrFunctionContext'
      local LrSelection        = import 'LrSelection'
      local LrShell            = import 'LrShell'
      local LrSocket            = import 'LrSocket'
      local LrTasks            = import 'LrTasks'
      local LrUndo              = import 'LrUndo'
      -- File-local consts
      local RECEIVE_PORT = 58763
      local SEND_PORT    = 58764
      local PICKUP_THRESHOLD = 4
      -- File-local vars
      local CopyUUID
      local settings
      local LAST_PARAM = ''
      local PARAM_OBSERVER = {}
      local PICKUP_ENABLED = true
      local SERVER = {}
      --File-local function declarations, advance declared to allow it to be in scope for all calls.
      --When defining pre-declared function, DO NOT USE local KEYWORD again, as it will define yet another local function.
      --These declaration are intended to get around some Lua gotcha's.
      local applySettings
      local copySettings
      local develop_lerp_to_midi
      local midi_lerp_to_develop
      local pasteSettings
      local processMessage
      local sendChangedParams
      local startServer
      local updateParam
      local ACTIONS = {
          ['DecrementLastDevelopParameter'] = function () LrDevelopController.decrement(LAST_PARAM) end,
          ['VirtualCopy']      = function () LrApplication.activeCatalog():createVirtualCopies() end,
          ['ToggleScreenTwo']  = LrApplicationView.toggleSecondaryDisplay,
          ['CopySettings']    = copySettings,
          ['PasteSettings']    = pasteSettings,
      local TOOL_ALIASES = {
          ['Loupe']          = 'loupe',
          ['CropOverlay']    = 'crop',
          ['SpotRemoval']    = 'dust',
          ['RedEye']          = 'redeye',
          ['GraduatedFilter'] = 'gradient',
          ['RadialFilter']    = 'circularGradient',
          ['AdjustmentBrush'] = 'localized',
      local SETTINGS = {
          ['Pickup'] = function(enabled) PICKUP_ENABLED = (enabled == 1) end,
      end
      end
      function midi_lerp_to_develop(param, midi_value)
          -- map midi range to develop parameter range
          local min,max = LrDevelopController.getRange(param)
      --    if(param == 'Temperature') then
      --        min = 3000
      --        max = 9000
      --    end
          local result = midi_value/127 * (max-min) + min
          return result
      end
      function develop_lerp_to_midi(param)
          -- map develop parameter range to midi range
          local min, max = LrDevelopController.getRange(param)
      --        min = 3000
      --        max = 9000
      --    end
          local result = (LrDevelopController.getValue(param)-min)/(max-min) * 127
          return result
      end
      function updateParam(param, midi_value)
          -- this function does a 'pickup' type of check
          -- that is, it will ensure the develop parameter is close
          -- to what the inputted command value is before updating it
          end
          if((not PICKUP_ENABLED) or (math.abs(midi_value - develop_lerp_to_midi(param)) <= PICKUP_THRESHOLD)) then
              PARAM_OBSERVER[param] = midi_lerp_to_develop(param, midi_value)
              LrDevelopController.setValue(param, midi_lerp_to_develop(param, midi_value))
              LAST_PARAM = param
          end
      end
          end
          end
      end
      -- message processor
      function processMessage(message)
          if type(message) == 'string' then
              -- messages are in the format 'param value'
              local _, _, param, value = string.find( message, '(%S+)%s(%d+)' )
              if(ACTIONS[param] ~= nil) then -- perform a one time action
                  if(tonumber(value) == 127) then ACTIONS[param]() end
              elseif(param:find('Reset') == 1) then -- perform a reset other than those explicitly coded in ACTIONS array
                if(tonumber(value) == 127) then LrDevelopController.resetToDefault(param:sub(6)) end
              elseif(param:find('SwToM') == 1) then -- perform a switch to module
                  if(tonumber(value) == 127) then LrApplicationView.switchToModule(param:sub(6)) end
              elseif(param:find('ShoVw') == 1) then -- change application's view mode
                  if(tonumber(value) == 127) then LrApplicationView.showView(param:sub(6)) end
              elseif(param:find('ShoScndVw') == 1) then -- change application's view mode
                  if(tonumber(value) == 127) then LrApplicationView.showSecondaryView(param:sub(10)) end
              elseif(TOOL_ALIASES[param] ~= nil) then -- switch to desired tool
                      if(LrDevelopController.getSelectedTool() == TOOL_ALIASES[param]) then -- toggle between the tool/loupe
                          LrDevelopController.selectTool('loupe')
                      else
                          LrDevelopController.selectTool(TOOL_ALIASES[param])
                      end
                  end
              elseif(SETTINGS[param] ~= nil) then
                  SETTINGS[param](tonumber(value))
              else -- otherwise update a develop parameter
                  updateParam(param, tonumber(value))
              end
          end
      end
      -- send changed parameters to MIDI2LR
      function sendChangedParams( observer )
          for _, param in ipairs(DEVELOP_PARAMS) do
              if(observer[param] ~= LrDevelopController.getValue(param)) then
                  SERVER:send(string.format('%s %d\n', param, develop_lerp_to_midi(param)))
                  observer[param] = LrDevelopController.getValue(param)
                  LAST_PARAM = param
              end
          end
      end
      function startServer(context)
          SERVER = LrSocket.bind {
                functionContext = context,
                plugin = _PLUGIN,
                port = SEND_PORT,
                mode = 'send',
                onClosed = function( socket ) -- this callback never seems to get called...
                  -- MIDI2LR closed connection, allow for reconnection
                  -- socket:reconnect()
                end,
                onError = function( socket, err )
                  socket:reconnect()
                end,
      end
      -- Main task
      LrTasks.startAsyncTask( function()
          LrFunctionContext.callWithContext( 'socket_remote', function( context )
              LrDevelopController.revealAdjustedControls( true ) -- reveal affected parameter in panel track
              -- add an observer for develop param changes
              LrDevelopController.addAdjustmentChangeObserver( context, PARAM_OBSERVER, sendChangedParams )
              local client = LrSocket.bind {
                  plugin = _PLUGIN,
                  port = RECEIVE_PORT,
                  mode = 'receive',
                  onMessage = function(socket, message)
                  end,
                      socket:reconnect()
                      -- calling SERVER:reconnect causes LR to hang for some reason...
                      SERVER:close()
                  end,
                  onError = function(socket, err)
                      if err == 'timeout' then -- reconnect if timed out
                          socket:reconnect()
                      end
                  end
              while true do
                  LrTasks.sleep( 1/2 )
              end
              client:close()
              SERVER:close()
          end )
      end )
          if(WIN_ENV) then
              LrShell.openFilesInApp({_PLUGIN.path..'/Info.lua'}, _PLUGIN.path..'/MIDI2LR.exe')
          else
              LrShell.openFilesInApp({_PLUGIN.path..'/Info.lua'}, _PLUGIN.path..'/MIDI2LR.app') -- On Mac it seems like the files argument has to include an existing file
          end
      end)
        • 1. Re: Copy develop settings from one photo to another: having problems! photo:getDevelopSettings LrDevelopController.setValue
          johnrellis Most Valuable Participant
          Re debugging: You absolutely need a more functional method of debugging than print statements.  See this thread for how someone else got ZeroBrane to work for them: Interactive debugger for Lightroom plugins.
          If that doesn't work, you can use my free Debugging Toolkit for Lightroom SDK. It's not as capable as a full-fledged IDE, but it's much better than print statements.
          • 2. Re: Copy develop settings from one photo to another: having problems! photo:getDevelopSettings LrDevelopController.setValue
            Re your use of LrDevelopController: I haven't seen much experience posted here yet.  It's not clear from the documentation whether the client needs to call LrDevelopController.startTracking() / stopTracking() around a call to setValue().
            There is also the undocumented photo:applyDevelopSettings().   However, if you are connecting to a MIDI controller for interactive use, LrDevelopController looks more appropriate, with regard to history states and control over interactive updates of the display.
            • 3. Re: Copy develop settings from one photo to another: having problems! photo:getDevelopSettings LrDevelopController.setValue
              StefanKeller42 Level 1
              there are some mistakes:
              1. getDevelopSettings has to be called in an AsyncTask
              2. Values are numbers, booleans and strings.
                 booleans can be changed, but I guess string settings (as ToneCurveName) are no way suported now
              3.some Values with 2012 in the name are not working, at least Exposure
              the SDK says:
              WARNING:The develop settings APIs are considered experimental. You should not depend on the contents of the settings table remaining compatible in future versions of Lightroom. The definitive list is the one shown in the UI.
              my source based on yours:
              you may map the 2012 settings to the correct ones...
              local settings
                LrTasks.startAsyncTask ( function ()
                end )
              end
              end
              function applySettings(set) -- not working eg with 2012 Settings
                    if type (v) == "boolean"
                      then
                        if v then v=1 else v=0 end
                      end
                    if type (v) == "number"
                      then
                      --dbgout (string.format('%s is %d', x, v))
                      end
                    if type (v) == "string"
                      then
                      end
                  end
              end
              • 4. Re: Copy develop settings from one photo to another: having problems! photo:getDevelopSettings LrDevelopController.setValue
                this may be a correct way, it seems to work
                local settings
                  end )
                end
                  if settings ~= nil then
                      catalog = LrApplication.activeCatalog()
                      catalog:withWriteAccessDo( "pasteSettings", function()
                        local photo = catalog:getTargetPhoto()
                        photo:applyDevelopSettings(settings)
                      end )
                    end )
                  end
                end
                • 5. Re: Copy develop settings from one photo to another: having problems! photo:getDevelopSettings LrDevelopController.setValue
                  Thank you very much for your assistance. The final version of the code follows.
                  To find out what was wrong, I put in debug print statements -- that made it clear that problem #1 was Lightroom doesn't completely unload one version of a long-running plugin when you reload a new version! I was making edits and reloading the plugin in LR. However, the main plugin task thread runs continuously in my plugin, and LR doesn't terminate that thread when it reloads a plugin--so I'd either have to, in the main plugin task thread, monitor for plugin termination, or restart LR to test the changes.
                  local function PasteSettings  ()
                        LrApplication.activeCatalog():withWriteAccessDo(
                          'Paste settings',
                          function() LrApplication.activeCatalog():getTargetPhoto():applyDevelopSettings(MIDI2LR.Copied_Settin gs) end,
                          { timeout = 4,
                            callback = function() LrDialogs.showError('Unable to get catalog write access for copy settings') end,
                            asynchronous = true }
                      end )
                  end
                  local function CopySettings ()
                      function () MIDI2LR.Copied_Settings = LrApplication.activeCatalog():getTargetPhoto():getDevelopSettings() end
                  end
                  • 6. Re: Copy develop settings from one photo to another: having problems! photo:getDevelopSettings LrDevelopController.setValue
                    Lightroom doesn't completely unload one version of a long-running plugin when you reload a new version! ...so I'd either have to, in the main plugin task thread, monitor for plugin termination, or restart LR to test the changes.
                    I believe you can also disable and re-enable the plugin, but I'm not 100% sure about that.
                    The technique I use for handling reloads is pretty simple.  The .lua file defining the background task defines a global variable that gets incremented every time the file gets loaded:
                    currentLoadVersion = rawget (_G, "currentLoadVersion") or 0
                        --[[ Incremented every time the module is loaded. Avoid triggering
                        "undeclared variable" from strict.lua.]]
                    The use of "rawget" ensures that strict.lua won't think there's an access to an undeclared variable.  (You should definitely use strict.lua, if you're not.)
                    When it first starts, the background task increments "currentLoadVersion" and then periodically checks for changes to its value, indicating the file has been reloaded:
                    LrTasks.startAsyncTask (Debug.showErrors (function ()
                        currentLoadVersion = currentLoadVersion + 1
                        local loadVersion = currentLoadVersion
                        while (loadVersion == currentLoadVersion) do
                            ...do some work...
                            LrTasks.sleep (...)
                            end
                    Info.lua also lets you define scripts that get invoked when the plugin is reloaded or when LR itself is shutting down.  But they need to communicate with the background task using a similar mechanism, with a global counter that the background task periodically checks.
