Expand my Community achievements bar.
Flex 2.0 WebService woes
Avatar
Former Community Member
I am experiencing problems with the <mx:WebService>
capability within my Flex 2.0 applications. Please find attached a
brief sample that should help to illustrate the problems.
If you compile and run the attached code with the default
input, you should see the web-service call results in a fault
during the decode sequence. However, if you run the same example
with the following web-based soap client (note you must supply the
URL of the corresponding WSDL), you should see that the web-service
works fine.
http://www.soapclient.com/soapclient.com/soaptest.html
http://www.lyricwiki.org/server.php?wsdl
Interestingly enough, the web-service call within the
supplied Flex application does not fail when supplying input that
is not found, such as when modifying the default artist input to
”Beagles”.
I can’t imagine a simpler web-service test within a
Flex 2.0 application, nor can I see any coding mistakes based upon
my understanding after thoroughly reading the supplied Flex 2.0
documentation.
Regards.
<mx:Application xmlns:mx="
http://www.adobe.com/2006/mxml">
<mx:Script>
private function doRequest():void {
lyricsRequest.getSongResult.request.artist = artist.text;
lyricsRequest.getSongResult.request.song = song.text;
lyricsRequest.getSongResult.send();
</mx:Script>
<mx:WebService id="lyricsRequest"
fault="lyrics.text = event.toString() + event.message.body;"
result="lyrics.text = event.result.lyrics;"
wsdl="
http://www.lyricwiki.org/server.php?wsdl">
</mx:WebService>
<mx:Panel>
<mx:Form defaultButton="{ok}">
<mx:FormItem label="Artist">
<mx:TextInput id="artist" text="Eagles" />
</mx:FormItem>
<mx:FormItem label="Song">
<mx:TextInput id="song" text="Hotel California" />
</mx:FormItem>
</mx:Form>
<mx:TextArea id="lyrics" width="400" height="100"
wordWrap="true" />
<mx:ControlBar>
<mx:Button id="ok" click="doRequest();" label="OK" />
</mx:ControlBar>
</mx:Panel>
</mx:Application>
1 Reply
Avatar
Level 2
I submitted a bug report along with this test case.
