15 Replies Latest reply on Nov 12, 2015 1:18 PM by Mrinmay Majhi
    Lightroom CC crashes on startup (OS-X)
    LTParis
      Out of the blue, Lightroom CC is crashing in startup. Photoshop CC still works with no issues.
      I've tried renaming ~/Library/Cache/Adobe/Lightroom and trying option and opening the application.
      I've tried signing in and out of Creative Cloud.
      If I sign out, I can log into it in limited functionality mode.
        • 1. Re: Lightroom CC crashes on startup (OS-X)
          Mrinmay Majhi Adobe Employee
          Hi LTParis,
          Which version of Mac are you using?
          Which version of Lightroom are you using?
          Could you please post the error log?
          ~Mrinmay
          • 2. Re: Lightroom CC crashes on startup (OS-X)
            LTParis Level 1
            10.10.3 with Lightroom CC (assuming the latest push release from Adobe)
            Not sure where the dump log is located
            • 3. Re: Lightroom CC crashes on startup (OS-X)
              Please try to launch Lightroom.
              If it crashes, you will get option to report.
              Please copy the details and post in here.
              ~Mrinmay
              • 4. Re: Lightroom CC crashes on startup (OS-X)
                LTParis Level 1
                I actually never get an option to report...
                screen capture - lightroom - YouTube
                • 5. Re: Lightroom CC crashes on startup (OS-X)
                  Please click the link below and follow the steps.
                  Lightroom doesn't launch or closes automatically after splash screen
                  Let me know if this helps.
                  ~Mrinmay
                  • 6. Re: Lightroom CC crashes on startup (OS-X)
                    LTParis Level 1
                    I had already tried option 1. Option 2 mentions SLcache but I do not have that present in my folder structure.
                    • 7. Re: Lightroom CC crashes on startup (OS-X)
                      Please follow the below steps to navigate to the location provided.
                      > Launch Finder
                      > Click on Go > Go To Folder
                      > Type in /Library/Application Support/Adobe
                      > Then follow the steps as provided in the link
                      Hope this helps.
                      ~Mrinmay
                      • 8. Re: Lightroom CC crashes on startup (OS-X)
                        LTParis Level 1
                        Tried that. I got one small step further where it asked for re-registration. But Lightroom crashed again, and crashed on trying to restart.
                        • 9. Re: Lightroom CC crashes on startup (OS-X)
                          Please use the link below : Creative Cloud Help / Troubleshoot install issues with log files | CC
                          ~Mrinmay
                          • 10. Re: Lightroom CC crashes on startup (OS-X)
                            LTParis Level 1
                            Very odd. Out of the blue it's working again. After all the countless reboots, the clearing of caches, the signing out/in. I still have zero explanation of why it was failing.
                            • 11. Re: Lightroom CC crashes on startup (OS-X)
                              ljgeist1
                              I'm having the same issue. OS-X 10.11.1, crash report:
                              Process:               Adobe Lightroom [679]
                              Path:                  /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/MacOS/Adobe Lightroom
                              Identifier:            com.adobe.Lightroom6
                              Version:               Adobe Lightroom [1046594] (6.2.1)
                              Code Type:             X86-64 (Native)
                              Parent Process:        ??? [1]
                              Responsible:           Adobe Lightroom [679]
                              User ID:               501
                              Date/Time:             2015-11-07 15:32:32.271 -0600
                              OS Version:            Mac OS X 10.11.1 (15B42)
                              Report Version:        11
                              Anonymous UUID:        5B27E5CC-EBD3-2B06-5D3B-CDDF233B845F
                              Time Awake Since Boot: 630 seconds
                              System Integrity Protection: enabled
                              Crashed Thread:        5  Dispatch queue: OzUserInfoCacheIndexDefinitions.lua :: /Users/LJG/Library/Caches/Adobe/Lightroom/oz-user-8536b084cdb3d1aedd3ded66f94ca248
                              Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
                              Exception Codes:       KERN_INVALID_ADDRESS at 0x0000000000000010
                              Exception Note:        EXC_CORPSE_NOTIFY
                              • 12. Re: Lightroom CC crashes on startup (OS-X)
                                ljgeist1 Level 1
                                Sorry, here's the entire crash report:
                                User ID:               501
                                Report Version:        11
                                VM Regions Near 0x10:
                                    __TEXT                 000000010f944000-000000010f953000 [   60K] r-x/rwx SM=COW  /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/MacOS/Adobe Lightroom
                                Global Trace Buffer (reverse chronological seconds):
                                0.683804     CFNetwork                 0x00007fff9af4bcdf TCP Conn 0x7ffef0c69210 started
                                1.608956     CFNetwork                 0x00007fff9af4e163 TCP Conn 0x7ffef0c6f360 SSL Handshake DONE
                                1.703607     CFNetwork                 0x00007fff9af4e03f TCP Conn 0x7ffef0c6f360 starting SSL negotiation
                                1.703809     CFNetwork                 0x00007fff9af4ca0f TCP Conn 0x7ffef0c6f360 complete. fd: 9, err: 0
                                1.703877     CFNetwork                 0x00007fff9afdb1ad TCP Conn 0x7ffef0c6f360 event 1. err: 0
                                1.799494     CFNetwork                 0x00007fff9af4bcdf TCP Conn 0x7ffef0c6f360 started
                                1.952264     CFNetwork                 0x00007fff9af4e163 TCP Conn 0x7ffef039e980 SSL Handshake DONE
                                2.167488     CFNetwork                 0x00007fff9af4e03f TCP Conn 0x7ffef039e980 starting SSL negotiation
                                2.167770     CFNetwork                 0x00007fff9af4ca0f TCP Conn 0x7ffef039e980 complete. fd: 119, err: 0
                                2.167931     CFNetwork                 0x00007fff9afdb1ad TCP Conn 0x7ffef039e980 event 1. err: 0
                                2.262126     CFNetwork                 0x00007fff9af4e03f TCP Conn 0x7ffeefc88920 starting SSL negotiation
                                2.262376     CFNetwork                 0x00007fff9af4ca0f TCP Conn 0x7ffeefc88920 complete. fd: 108, err: 0
                                2.262583     CFNetwork                 0x00007fff9afdb1ad TCP Conn 0x7ffeefc88920 event 1. err: 0
                                2.306146     CFNetwork                 0x00007fff9af4bcdf TCP Conn 0x7ffef039e980 started
                                2.369464     CFNetwork                 0x00007fff9af4bcdf TCP Conn 0x7ffeefc88920 started
                                2.458957     CFNetwork                 0x00007fff9af0f89e Creating default cookie storage with process/bundle identifier
                                2.458957     CFNetwork                 0x00007fff9af0f836 Faulting in CFHTTPCookieStorage singleton
                                2.458957     CFNetwork                 0x00007fff9af0f6c5 Faulting in NSHTTPCookieStorage singleton
                                Thread 0:: Dispatch queue: com.apple.main-thread
                                0   com.adobe.ag.kernel           0x000000010f975cb5 0x10f95e000 + 97461
                                1   com.adobe.ag.kernel           0x000000010f9675ea 0x10f95e000 + 38378
                                2   com.adobe.ag.kernel           0x000000010f967fec lua_resume + 112
                                3   com.adobe.ag.kernel           0x000000010f961997 0x10f95e000 + 14743
                                4   com.adobe.ag.kernel           0x000000010f96179b 0x10f95e000 + 14235
                                5   com.adobe.ag.kernel           0x000000010f967c8f 0x10f95e000 + 40079
                                6   com.adobe.ag.kernel           0x000000010f976283 0x10f95e000 + 98947
                                7   com.adobe.ag.kernel           0x000000010f967f4d 0x10f95e000 + 40781
                                8   com.adobe.ag.kernel           0x000000010f9675ea 0x10f95e000 + 38378
                                9   com.adobe.ag.kernel           0x000000010f9681a4 0x10f95e000 + 41380
                                10  com.adobe.ag.kernel           0x000000010f95ffb7 lua_pcall + 100
                                11  com.adobe.ag.substrate         0x000000010fad01ac 0x10fabd000 + 78252
                                12  com.apple.CoreFoundation       0x00007fff8b863c9c __CFNOTIFICATIONCENTER_IS_CALLING_OUT_TO_AN_OBSERVER__ + 12
                                13  com.apple.CoreFoundation       0x00007fff8b863c2f ___CFXRegistrationPost_block_invoke + 63
                                14  com.apple.CoreFoundation       0x00007fff8b863ba7 _CFXRegistrationPost + 407
                                15  com.apple.CoreFoundation       0x00007fff8b863912 ___CFXNotificationPost_block_invoke + 50
                                16  com.apple.CoreFoundation       0x00007fff8b8206d2 -[_CFXNotificationRegistrar find:object:observer:enumerator:] + 1922
                                17  com.apple.CoreFoundation       0x00007fff8b81f925 _CFXNotificationPost + 693
                                18  com.apple.Foundation           0x00007fff990a46fc postQueueNotifications + 782
                                19  com.apple.CoreFoundation       0x00007fff8b86d097 __CFRUNLOOP_IS_CALLING_OUT_TO_AN_OBSERVER_CALLBACK_FUNCTION__ + 23
                                20  com.apple.CoreFoundation       0x00007fff8b86d007 __CFRunLoopDoObservers + 391
                                21  com.apple.CoreFoundation       0x00007fff8b84bfe8 CFRunLoopRunSpecific + 328
                                22  com.apple.HIToolbox           0x00007fff9c9aed55 RunCurrentEventLoopInMode + 235
                                23  com.apple.HIToolbox           0x00007fff9c9aea97 ReceiveNextEventCommon + 184
                                24  com.apple.HIToolbox           0x00007fff9c9ae9cf _BlockUntilNextEventMatchingListInModeWithFilter + 71
                                25  com.apple.AppKit               0x00007fff9cd01d96 _DPSNextEvent + 1067
                                26  com.apple.AppKit               0x00007fff9cd011c5 -[NSApplication _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 454
                                27  com.apple.AppKit               0x00007fff9ccf5d28 -[NSApplication run] + 682
                                28  com.apple.AppKit               0x00007fff9ccbefbe NSApplicationMain + 1176
                                29  com.adobe.Lightroom6           0x000000010f9459a9 main + 953
                                30  libdyld.dylib                 0x00007fff9f69c5ad start + 1
                                Thread 1:
                                0   libsystem_kernel.dylib         0x00007fff98dca78a __workq_kernreturn + 10
                                1   libsystem_pthread.dylib       0x00007fff9ff9358c _pthread_wqthread + 1283
                                2   libsystem_pthread.dylib       0x00007fff9ff91375 start_wqthread + 13
                                Thread 2:: Dispatch queue: com.apple.libdispatch-manager
                                0   libsystem_kernel.dylib         0x00007fff98dcb0a2 kevent_qos + 10
                                1   libdispatch.dylib             0x00007fff9769611d _dispatch_mgr_invoke + 216
                                2   libdispatch.dylib             0x00007fff97695d85 _dispatch_mgr_thread + 52
                                Thread 3:
                                Thread 4:
                                Thread 5 Crashed:: Dispatch queue: OzUserInfoCacheIndexDefinitions.lua :: /Users/LJG/Library/Caches/Adobe/Lightroom/oz-user-8536b084cdb3d1aedd3ded66f94ca248
                                0   com.adobe.ag.kernel           0x000000010f975529 0x10f95e000 + 95529
                                1   com.adobe.ag.kernel           0x000000010f95fcf2 lua_setfield + 83
                                2   com.adobe.wichitafoundation   0x000000010fc4af17 0x10fc42000 + 36631
                                3   com.adobe.wichitafoundation   0x000000010fc545b1 0x10fc42000 + 75185
                                4   libdispatch.dylib             0x00007fff976903c3 _dispatch_client_callout + 8
                                5   libdispatch.dylib             0x00007fff97694ff3 _dispatch_queue_drain + 754
                                6   libdispatch.dylib             0x00007fff9769b6bf _dispatch_queue_invoke + 549
                                7   libdispatch.dylib             0x00007fff97693d0b _dispatch_root_queue_drain + 538
                                8   libdispatch.dylib             0x00007fff97693ab8 _dispatch_worker_thread3 + 91
                                9   libsystem_pthread.dylib       0x00007fff9ff934f2 _pthread_wqthread + 1129
                                10  libsystem_pthread.dylib       0x00007fff9ff91375 start_wqthread + 13
                                Thread 6:
                                Thread 7:: cr_scratch
                                0   libsystem_kernel.dylib         0x00007fff98dc9f5e __psynch_cvwait + 10
                                1   libsystem_pthread.dylib       0x00007fff9ff9473d _pthread_cond_wait + 767
                                2   com.adobe.ag.AgImageIO         0x0000000117d7cd4b 0x117b99000 + 1981771
                                3   com.adobe.ag.AgImageIO         0x0000000117f6354b 0x117b99000 + 3974475
                                4   com.adobe.ag.AgImageIO         0x0000000117d46541 0x117b99000 + 1758529
                                5   libsystem_pthread.dylib       0x00007fff9ff939b1 _pthread_body + 131
                                6   libsystem_pthread.dylib       0x00007fff9ff9392e _pthread_start + 168
                                7   libsystem_pthread.dylib       0x00007fff9ff91385 thread_start + 13
                                Thread 8:: Worker Thread Dispatcher
                                2   com.adobe.ag.kernel           0x000000010f9849d5 AgConditionLock_wait + 37
                                3   com.adobe.ag.kernel           0x000000010f97e478 AgTransitQueue_dequeueToLuaState + 91
                                4   com.adobe.ag.kernel           0x000000010f97f3ae 0x10f95e000 + 136110
                                8   com.adobe.ag.kernel           0x000000010f95ff36 lua_call + 37
                                9   com.adobe.ag.substrate         0x000000010fadd10b AgLua_callWithAutoReleasePool + 85
                                10  com.adobe.ag.kernel           0x000000010f967c8f 0x10f95e000 + 40079
                                11  com.adobe.ag.kernel           0x000000010f976283 0x10f95e000 + 98947
                                12  com.adobe.ag.kernel           0x000000010f967f4d 0x10f95e000 + 40781
                                13  com.adobe.ag.kernel           0x000000010f9675ea 0x10f95e000 + 38378
                                14  com.adobe.ag.kernel           0x000000010f9681a4 0x10f95e000 + 41380
                                15  com.adobe.ag.kernel           0x000000010f95ffb7 lua_pcall + 100
                                16  com.adobe.ag.substrate         0x000000010fad0bf9 0x10fabd000 + 80889
                                17  com.apple.Foundation           0x00007fff98ff8ee4 __NSThread__start__ + 1351
                                18  libsystem_pthread.dylib       0x00007fff9ff939b1 _pthread_body + 131
                                19  libsystem_pthread.dylib       0x00007fff9ff9392e _pthread_start + 168
                                20  libsystem_pthread.dylib       0x00007fff9ff91385 thread_start + 13
                                Thread 9:: Queue Processor - AgPhotoAvailability
                                6   com.adobe.ag.kernel           0x000000010f967f3c 0x10f95e000 + 40764
                                7   com.adobe.ag.kernel           0x000000010f95ff36 lua_call + 37
                                8   com.adobe.ag.substrate         0x000000010fadd10b AgLua_callWithAutoReleasePool + 85
                                9   com.adobe.ag.kernel           0x000000010f967c8f 0x10f95e000 + 40079
                                10  com.adobe.ag.kernel           0x000000010f976283 0x10f95e000 + 98947
                                11  com.adobe.ag.kernel           0x000000010f967f4d 0x10f95e000 + 40781
                                12  com.adobe.ag.kernel           0x000000010f9675ea 0x10f95e000 + 38378
                                13  com.adobe.ag.kernel           0x000000010f9681a4 0x10f95e000 + 41380
                                14  com.adobe.ag.kernel           0x000000010f95ffb7 lua_pcall + 100
                                15  com.adobe.ag.kernel           0x000000010f962166 0x10f95e000 + 16742
                                16  com.adobe.ag.kernel           0x000000010f967c8f 0x10f95e000 + 40079
                                17  com.adobe.ag.kernel           0x000000010f967f3c 0x10f95e000 + 40764
                                18  com.adobe.ag.kernel           0x000000010f95ff36 lua_call + 37
                                19  com.adobe.ag.substrate         0x000000010fadd10b AgLua_callWithAutoReleasePool + 85
                                20  com.adobe.ag.kernel           0x000000010f967c8f 0x10f95e000 + 40079
                                21  com.adobe.ag.kernel           0x000000010f976283 0x10f95e000 + 98947
                                22  com.adobe.ag.kernel           0x000000010f967f4d 0x10f95e000 + 40781
                                23  com.adobe.ag.kernel           0x000000010f9675ea 0x10f95e000 + 38378
                                24  com.adobe.ag.kernel           0x000000010f9681a4 0x10f95e000 + 41380
                                25  com.adobe.ag.kernel           0x000000010f95ffb7 lua_pcall + 100
                                26  com.adobe.ag.substrate         0x000000010fad0bf9 0x10fabd000 + 80889
                                27  com.apple.Foundation           0x00007fff98ff8ee4 __NSThread__start__ + 1351
                                28  libsystem_pthread.dylib       0x00007fff9ff939b1 _pthread_body + 131
                                29  libsystem_pthread.dylib       0x00007fff9ff9392e _pthread_start + 168
                                30  libsystem_pthread.dylib       0x00007fff9ff91385 thread_start + 13
                                Thread 10:: com.apple.NSURLConnectionLoader
                                0   libsystem_kernel.dylib         0x00007fff98dc4c96 mach_msg_trap + 10
                                1   libsystem_kernel.dylib         0x00007fff98dc40d7 mach_msg + 55
                                2   com.apple.CoreFoundation       0x00007fff8b84d2b4 __CFRunLoopServiceMachPort + 212
                                3   com.apple.CoreFoundation       0x00007fff8b84c77c __CFRunLoopRun + 1356
                                4   com.apple.CoreFoundation       0x00007fff8b84bfc8 CFRunLoopRunSpecific + 296
                                5   com.apple.CFNetwork           0x00007fff9af12d6d +[NSURLConnection(Loader) _resourceLoadLoop:] + 412
                                6   com.apple.Foundation           0x00007fff98ff8ee4 __NSThread__start__ + 1351
                                7   libsystem_pthread.dylib       0x00007fff9ff939b1 _pthread_body + 131
                                8   libsystem_pthread.dylib       0x00007fff9ff9392e _pthread_start + 168
                                9   libsystem_pthread.dylib       0x00007fff9ff91385 thread_start + 13
                                Thread 11:: AsyncDataServer
                                2   com.adobe.ag.kernel           0x000000010f984a66 AgConditionLock_wait + 182
                                Thread 12:: com.apple.NSEventThread
                                5   com.apple.AppKit               0x00007fff9ce57d49 _NSEventThread + 149
                                6   libsystem_pthread.dylib       0x00007fff9ff939b1 _pthread_body + 131
                                7   libsystem_pthread.dylib       0x00007fff9ff9392e _pthread_start + 168
                                8   libsystem_pthread.dylib       0x00007fff9ff91385 thread_start + 13
                                Thread 13:: Preview Server
                                Thread 14:: Dispatch queue: WFDocStoreMessageProcessor.lua :: /Users/LJG/Library/Caches/Adobe/Lightroom/oz-user-8536b084cdb3d1aedd3ded66f94ca248
                                0   libsystem_malloc.dylib         0x00007fff9ff9e9c4 szone_free_definite_size + 1590
                                1   com.apple.Foundation           0x00007fff9905621c -[_NSCallStackArray dealloc] + 28
                                2   libobjc.A.dylib               0x00007fff97800224 objc_object::sidetable_release(bool) + 242
                                3   com.apple.CoreFoundation       0x00007fff8b81197d -[__NSDictionaryM dealloc] + 269
                                4   libobjc.A.dylib               0x00007fff97800224 objc_object::sidetable_release(bool) + 242
                                5   com.apple.CoreFoundation       0x00007fff8b8d8009 -[NSException dealloc] + 105
                                6   libobjc.A.dylib               0x00007fff97800224 objc_object::sidetable_release(bool) + 242
                                7   libobjc.A.dylib               0x00007fff977fb094 (anonymous namespace)::AutoreleasePoolPage::pop(void*) + 476
                                8   com.adobe.wichitafoundation   0x000000010fc54786 0x10fc42000 + 75654
                                9   libdispatch.dylib             0x00007fff976903c3 _dispatch_client_callout + 8
                                10  libdispatch.dylib             0x00007fff97694ff3 _dispatch_queue_drain + 754
                                11  libdispatch.dylib             0x00007fff9769b6bf _dispatch_queue_invoke + 549
                                12  libdispatch.dylib             0x00007fff97693d0b _dispatch_root_queue_drain + 538
                                13  libdispatch.dylib             0x00007fff97693ab8 _dispatch_worker_thread3 + 91
                                14  libsystem_pthread.dylib       0x00007fff9ff934f2 _pthread_wqthread + 1129
                                15  libsystem_pthread.dylib       0x00007fff9ff91375 start_wqthread + 13
                                Thread 15:: Queue Processor - PreviewFileStore
                                Thread 16:
                                2   com.adobe.headlights.LogSessionFramework 0x00000001232ea2dc boost::condition_variable::do_wait_until(boost::unique_lock<boost::mutex>&, timespec const&) + 76
                                3   com.adobe.headlights.LogSessionFramework 0x00000001232e8b9e boost::this_thread::hiden::sleep_until(timespec const&) + 78
                                4   com.adobe.headlights.LogSessionFramework 0x0000000123291911 RealTimeProcessor::Sleep(int) + 243
                                5   com.adobe.headlights.LogSessionFramework 0x000000012328fe72 RealTimeProcessor::WorkerThread() + 2370
                                6   com.adobe.headlights.LogSessionFramework 0x00000001232e7bfa boost::(anonymous namespace)::thread_proxy(void*) + 138
                                Thread 17:: Queue Processor - NegativeQueue
                                Thread 18:: Queue Processor - HistogramQueue
                                Thread 19:: Queue Processor - RenderQueue_Render
                                Thread 20:: com.apple.CFSocket.private
                                0   libsystem_kernel.dylib         0x00007fff98dca222 __select + 10
                                1   com.apple.CoreFoundation       0x00007fff8b88a4aa __CFSocketManager + 762
                                2   libsystem_pthread.dylib       0x00007fff9ff939b1 _pthread_body + 131
                                3   libsystem_pthread.dylib       0x00007fff9ff9392e _pthread_start + 168
                                4   libsystem_pthread.dylib       0x00007fff9ff91385 thread_start + 13
                                Thread 21:: Queue Processor - RenderQueue_ReadPreview
                                Thread 22:: Queue Processor - RenderQueue_Video
                                Thread 23:: Queue Processor - RenderQueue_Face
                                Thread 24:: Dispatch queue: AgWFModelsThread.lua
                                0   com.adobe.ag.kernel           0x000000010f969949 0x10f95e000 + 47433
                                1   com.adobe.ag.kernel           0x000000010f9699c9 0x10f95e000 + 47561
                                2   com.adobe.ag.kernel           0x000000010f969fd9 0x10f95e000 + 49113
                                3   com.adobe.ag.kernel           0x000000010f969327 0x10f95e000 + 45863
                                4   com.adobe.ag.kernel           0x000000010f9675ea 0x10f95e000 + 38378
                                5   com.adobe.ag.kernel           0x000000010f9681a4 0x10f95e000 + 41380
                                6   com.adobe.ag.kernel           0x000000010f95ffb7 lua_pcall + 100
                                7   com.adobe.ag.kernel           0x000000010f962166 0x10f95e000 + 16742
                                8   com.adobe.ag.kernel           0x000000010f967c8f 0x10f95e000 + 40079
                                9   com.adobe.ag.kernel           0x000000010f976283 0x10f95e000 + 98947
                                10  com.adobe.ag.kernel           0x000000010f967f4d 0x10f95e000 + 40781
                                11  com.adobe.ag.kernel           0x000000010f9675ea 0x10f95e000 + 38378
                                12  com.adobe.ag.kernel           0x000000010f9681a4 0x10f95e000 + 41380
                                13  com.adobe.ag.kernel           0x000000010f95ffb7 lua_pcall + 100
                                14  com.adobe.ag.kernel           0x000000010f962166 0x10f95e000 + 16742
                                15  com.adobe.ag.kernel           0x000000010f967c8f 0x10f95e000 + 40079
                                16  com.adobe.ag.kernel           0x000000010f976283 0x10f95e000 + 98947
                                17  com.adobe.ag.kernel           0x000000010f967f4d 0x10f95e000 + 40781
                                18  com.adobe.ag.kernel           0x000000010f9675ea 0x10f95e000 + 38378
                                19  com.adobe.ag.kernel           0x000000010f9681a4 0x10f95e000 + 41380
                                20  com.adobe.ag.kernel           0x000000010f95ffb7 lua_pcall + 100
                                21  com.adobe.ag.kernel           0x000000010f962166 0x10f95e000 + 16742
                                22  com.adobe.ag.kernel           0x000000010f967c8f 0x10f95e000 + 40079
                                23  com.adobe.ag.kernel           0x000000010f976283 0x10f95e000 + 98947
                                24  com.adobe.ag.kernel           0x000000010f967f4d 0x10f95e000 + 40781
                                25  com.adobe.ag.kernel           0x000000010f9675ea 0x10f95e000 + 38378
                                26  com.adobe.ag.kernel           0x000000010f9681a4 0x10f95e000 + 41380
                                27  com.adobe.ag.kernel           0x000000010f95ffb7 lua_pcall + 100
                                28  com.adobe.ag.kernel           0x000000010f962166 0x10f95e000 + 16742
                                29  com.adobe.ag.kernel           0x000000010f967c8f 0x10f95e000 + 40079
                                30  com.adobe.ag.kernel           0x000000010f976283 0x10f95e000 + 98947
                                31  com.adobe.ag.kernel           0x000000010f967f4d 0x10f95e000 + 40781
                                32  com.adobe.ag.kernel           0x000000010f9675ea 0x10f95e000 + 38378
                                33  com.adobe.ag.kernel           0x000000010f9681a4 0x10f95e000 + 41380
                                34  com.adobe.ag.kernel           0x000000010f95ffb7 lua_pcall + 100
                                35  com.adobe.ag.kernel           0x000000010f962166 0x10f95e000 + 16742
                                36  com.adobe.ag.kernel           0x000000010f967c8f 0x10f95e000 + 40079
                                37  com.adobe.ag.kernel           0x000000010f976283 0x10f95e000 + 98947
                                38  com.adobe.ag.kernel           0x000000010f967f4d 0x10f95e000 + 40781
                                39  com.adobe.ag.kernel           0x000000010f9675ea 0x10f95e000 + 38378
                                40  com.adobe.ag.kernel           0x000000010f9681a4 0x10f95e000 + 41380
                                41  com.adobe.ag.kernel           0x000000010f95ffb7 lua_pcall + 100
                                42  com.adobe.ag.kernel           0x000000010f962166 0x10f95e000 + 16742
                                43  com.adobe.ag.kernel           0x000000010f967c8f 0x10f95e000 + 40079
                                44  com.adobe.ag.kernel           0x000000010f976283 0x10f95e000 + 98947
                                45  com.adobe.ag.kernel           0x000000010f967f4d 0x10f95e000 + 40781
                                46  com.adobe.ag.kernel           0x000000010f9675ea 0x10f95e000 + 38378
                                47  com.adobe.ag.kernel           0x000000010f9681a4 0x10f95e000 + 41380
                                48  com.adobe.ag.kernel           0x000000010f95ffb7 lua_pcall + 100
                                49  com.adobe.ag.kernel           0x000000010f962166 0x10f95e000 + 16742
                                50  com.adobe.ag.kernel           0x000000010f967c8f 0x10f95e000 + 40079
                                51  com.adobe.ag.kernel           0x000000010f976283 0x10f95e000 + 98947
                                52  com.adobe.ag.kernel           0x000000010f967f4d 0x10f95e000 + 40781
                                53  com.adobe.ag.kernel           0x000000010f9675ea 0x10f95e000 + 38378
                                54  com.adobe.ag.kernel           0x000000010f9681a4 0x10f95e000 + 41380
                                55  com.adobe.ag.kernel           0x000000010f95ffb7 lua_pcall + 100
                                56  com.adobe.ag.kernel           0x000000010f962166 0x10f95e000 + 16742
                                57  com.adobe.ag.kernel           0x000000010f967c8f 0x10f95e000 + 40079
                                58  com.adobe.ag.kernel           0x000000010f976283 0x10f95e000 + 98947
                                59  com.adobe.ag.kernel           0x000000010f967f4d 0x10f95e000 + 40781
                                60  com.adobe.ag.kernel           0x000000010f9675ea 0x10f95e000 + 38378
                                61  com.adobe.ag.kernel           0x000000010f9681a4 0x10f95e000 + 41380
                                62  com.adobe.ag.kernel           0x000000010f95ffb7 lua_pcall + 100
                                63  com.adobe.ag.kernel           0x000000010f962166 0x10f95e000 + 16742
                                64  com.adobe.ag.kernel           0x000000010f967c8f 0x10f95e000 + 40079
                                65  com.adobe.ag.kernel           0x000000010f976283 0x10f95e000 + 98947
                                66  com.adobe.ag.kernel           0x000000010f967f4d 0x10f95e000 + 40781
                                67  com.adobe.ag.kernel           0x000000010f9675ea 0x10f95e000 + 38378
                                68  com.adobe.ag.kernel           0x000000010f9681a4 0x10f95e000 + 41380
                                69  com.adobe.ag.kernel           0x000000010f95ffb7 lua_pcall + 100
                                70  com.adobe.ag.kernel           0x000000010f962166 0x10f95e000 + 16742
                                71  com.adobe.ag.kernel           0x000000010f967c8f 0x10f95e000 + 40079
                                72  com.adobe.ag.kernel           0x000000010f976283 0x10f95e000 + 98947
                                73  com.adobe.ag.kernel           0x000000010f967f4d 0x10f95e000 + 40781
                                74  com.adobe.ag.kernel           0x000000010f9675ea 0x10f95e000 + 38378
                                75  com.adobe.ag.kernel           0x000000010f9681a4 0x10f95e000 + 41380
                                76  com.adobe.ag.kernel           0x000000010f95ffb7 lua_pcall + 100
                                77  com.adobe.wichitafoundation   0x000000010fc4ba53 0x10fc42000 + 39507
                                78  com.adobe.ag.kernel           0x000000010f967c8f 0x10f95e000 + 40079
                                79  com.adobe.ag.kernel           0x000000010f967f3c 0x10f95e000 + 40764
                                80  com.adobe.ag.kernel           0x000000010f9675ea 0x10f95e000 + 38378
                                81  com.adobe.ag.kernel           0x000000010f9681a4 0x10f95e000 + 41380
                                82  com.adobe.ag.kernel           0x000000010f95ffb7 lua_pcall + 100
                                83  com.adobe.wichitafoundation   0x000000010fc4b683 0x10fc42000 + 38531
                                84  com.adobe.wichitafoundation   0x000000010fc4b33c 0x10fc42000 + 37692
                                85  com.adobe.wichitafoundation   0x000000010fc54743 0x10fc42000 + 75587
                                86  libdispatch.dylib             0x00007fff976903c3 _dispatch_client_callout + 8
                                87  libdispatch.dylib             0x00007fff97694ff3 _dispatch_queue_drain + 754
                                88  libdispatch.dylib             0x00007fff9769b6bf _dispatch_queue_invoke + 549
                                89  libdispatch.dylib             0x00007fff97693d0b _dispatch_root_queue_drain + 538
                                90  libdispatch.dylib             0x00007fff97693ab8 _dispatch_worker_thread3 + 91
                                91  libsystem_pthread.dylib       0x00007fff9ff934f2 _pthread_wqthread + 1129
                                92  libsystem_pthread.dylib       0x00007fff9ff91375 start_wqthread + 13
                                Thread 25:
                                5   IMSLib.dylib                   0x0000000112a67662 0x112a62000 + 22114
                                6   IMSLib.dylib                   0x0000000112a67f18 0x112a62000 + 24344
                                7   IMSLib.dylib                   0x0000000112a7f9c5 0x112a62000 + 121285
                                8   IMSLib.dylib                   0x0000000112a7ecdd 0x112a62000 + 117981
                                9   IMSLib.dylib                   0x0000000112aa163c 0x112a62000 + 259644
                                10  IMSLib.dylib                   0x0000000112a884ee 0x112a62000 + 156910
                                11  IMSLib.dylib                   0x0000000112a70389 0x112a62000 + 58249
                                12  libsystem_pthread.dylib       0x00007fff9ff939b1 _pthread_body + 131
                                13  libsystem_pthread.dylib       0x00007fff9ff9392e _pthread_start + 168
                                14  libsystem_pthread.dylib       0x00007fff9ff91385 thread_start + 13
                                Thread 5 crashed with X86 Thread State (64-bit):
                                  rax: 0x00007ffeefa63040  rbx: 0x00007ffeefa62dc8  rcx: 0x0000000000000000  rdx: 0x000070000021c8b8
                                  rdi: 0x0000000000000006  rsi: 0x00007ffeefa63040  rbp: 0x000070000021c8a0  rsp: 0x000070000021c860
                                   r8: 0x0000000000000001   r9: 0x00000000fffe0000  r10: 0x00000000234e1ec1  r11: 0x00007ffde0f8ba0f
                                  r12: 0x0000000000000000  r13: 0x00007ffeefa62e40  r14: 0x000000010fe26af9  r15: 0x00007ffeeb8efb90
                                  rip: 0x000000010f975529  rfl: 0x0000000000010206  cr2: 0x0000000000000010
                                Logical CPU:     1
                                Error Code:      0x00000004
                                Trap Number:     14
                                Binary Images:
                                       0x10f944000 -        0x10f952fff +com.adobe.Lightroom6 (Adobe Lightroom [1046594] - 6.2.1) <C6DBCD5E-A85F-3ABF-8A73-72BBCAC34F68> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/MacOS/Adobe Lightroom
                                       0x10f95e000 -        0x10f99ffff +com.adobe.ag.kernel (AgKernel Version 1.0 - 1.0) <D04B5F34-3399-3B56-A293-4DCFE509A4EC> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AgKernel.framework/Versions/A/AgKernel
                                       0x10f9b0000 -        0x10fa73fff +com.adobe.ag.ui (views version 0.0.1d1 - 0) <E62658C1-629F-328E-8D83-658BBB1B11B4> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AgUI.framework/Versions/A/AgUI
                                       0x10fabd000 -        0x10fb05ff7 +com.adobe.ag.substrate (com.adobe.ag.substrate 6.2.1 - 1.0) <8F46D612-9B18-3030-A2F4-C2B0B9CBF054> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AgSubstrate.framework/Versions/A/AgSubstrate
                                       0x10fb2a000 -        0x10fc2bfff +com.adobe.amtlib (9.0.0.21 - 9.0.0.21) <BAE71CEB-B622-38DB-A0A2-796C0BEB4E03> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
                                       0x10fc42000 -        0x10feb8fff +com.adobe.wichitafoundation (com.adobe.wichitafoundation 6.2.1 - 1.0) <982FC864-578F-33BA-BBA1-B78378FCC6D7> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/WichitaFoundation.agtoolkit/Versions/A/WichitaFoundatio n
                                       0x1101cb000 -        0x1101cbfff +com.adobe.lightroom.AdobeCrashReporter (1.0) <6719858E-4C46-3C1E-9469-DA6F130198CD> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/PlugIns/Adobe Crash Reporter.bundle/Contents/MacOS/Adobe Crash Reporter
                                       0x1101f2000 -        0x1101f5fff +com.adobe.AdobeCrashReporter (7.1 - 7.1.4) <A33546D9-3E26-38A2-88FE-C7C46B4CD989> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashRepor ter
                                       0x112a62000 -        0x112b99fe7 +IMSLib.dylib (9.0.1.20 - 9.0.1.20) <DB55B46B-2C4D-38D0-9717-BEB70B164728> /Library/Application Support/Adobe/*/IMSLib.dylib
                                       0x112e15000 -        0x112e55ff7 +com.adobe.AAM.AdobeUpdaterNotificationFramework (UpdaterNotifications 9.0.0.3 - 9.0.0.3) <2F5B40E6-812C-34E0-A8AC-02F55D770D49> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotifi cations
                                       0x115063000 -        0x115063fe7 +cl_kernels (???) <E8AE4B2A-48A7-4779-B273-BA4EE9F94F06> cl_kernels
                                       0x1179ca000 -        0x1179cdfff +com.adobe.ag.headlights (com.adobe.ag.Headlights 6.2.1 - 1.0) <B0F18474-1849-30D7-AA3D-2BE436007811> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/PlugIns/AdobeHeadlights.lrmodule/Contents/MacOS/AdobeHeadlights
                                       0x1179da000 -        0x1179ddff7 +com.adobe.ag.discburning (com.adobe.ag.discburning 6.2.1 - 1.0) <760B8D85-BDD2-3ACC-825B-13A7F37D76BD> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/DiscBurning.agtoolkit/Contents/MacOS/DiscBurning
                                       0x117a59000 -        0x117a93fff +com.adobe.pip (7.3.1.61) <5371E762-F32A-3330-BF9D-D090A074E2F3> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
                                       0x117a9d000 -        0x117ac6fff +libSLCacheWrapper.dylib (1) <AB5FD9B1-D26B-3599-820A-6E1238597C86> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/LogSession.framework/Resources/libSLCacheWrapper.dylib
                                       0x117ad8000 -        0x117adefff +com.adobe.ag.email (com.adobe.ag.email 6.2.1 - 1.0) <81C0AF58-04EB-3909-BDEA-5313E7C493C2> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/PlugIns/Email.lrmodule/Contents/MacOS/Email
                                       0x117b04000 -        0x117b1fff7 +com.adobe.ag.help (com.adobe.ag.help 6.2.1 - 1.0) <93169A61-1187-3985-85AE-3D88C6E3A836> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/PlugIns/AdobeHelpClient.lrmodule/Contents/MacOS/AdobeHelpClient
                                       0x117b29000 -        0x117b4eff7  com.apple.DiscRecordingUI (9.0.1 - 9010.4.3) <9B5A8A13-39F1-3764-8CAF-7D59FE271AF0> /System/Library/Frameworks/DiscRecordingUI.framework/Versions/A/DiscRecordingUI
                                       0x117b70000 -        0x117b8ffff +com.adobe.BIB (AdobeBIB 1.2.03.34488 - 1.2.03.34488) <644F8DE0-3E61-374D-B17D-44ED3BD10D60> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
                                       0x117b99000 -        0x11a2bffff +com.adobe.ag.AgImageIO (com.adobe.ag.AgImageIO 6.2.1 - 1.0.0d1) <596CEB21-63B8-3949-8D3C-F9D02592E255> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/CameraRaw.lrtoolkit/CameraRaw
                                       0x11a4f9000 -        0x11a9ebfff  com.apple.driver.AppleIntelHD4000GraphicsGLDriver (10.10.18 - 10.1.0) <C587EC82-9B72-3803-B81D-2B9EA073A28B> /System/Library/Extensions/AppleIntelHD4000GraphicsGLDriver.bundle/Contents/MacOS/AppleIn telHD4000GraphicsGLDriver
                                       0x11b01e000 -        0x11b01ffff +com.adobe.ag.xml (com.adobe.ag.xml 6.2.1 - 1.0) <07C1484D-E641-3807-B089-7907B1D0EB8C> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/XML.agtoolkit/Contents/MacOS/XML
                                       0x11b068000 -        0x11b076fff +com.adobe.ag.video-toolkit (com.adobe.ag.video_toolkit 6.2.1 - 1) <F672E4CE-5CFD-3A4F-A99B-3385FF8B6699> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/video_toolkit.agtoolkit/Contents/MacOS/video_toolkit
                                       0x11b082000 -        0x11b0c2fff  com.apple.glut (3.6.3 - GLUT-3.6.3) <8C08DA42-AE1E-3BE7-B2ED-9EA71D1D36DF> /System/Library/Frameworks/GLUT.framework/Versions/A/GLUT
                                       0x11b13d000 -        0x11b17eff7 +com.adobe.ag.bridgetalk (com.adobe.ag.bridgetalk 6.2.1 - 1.0) <6A6A5E86-0672-32A9-9345-DCF37734085F> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/BridgeTalk.agtoolkit/Contents/MacOS/BridgeTalk
                                       0x11b1b8000 -        0x11b271ff7 +com.adobe.ag.imageanalysis (com.adobe.ag.imageanalysis 6.2.1 - 1.0) <D2E928F8-DB53-36C5-805C-E6EEFC2C300E> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/ImageAnalysis.agtoolkit/Contents/MacOS/ImageAnalysis
                                       0x11b281000 -        0x11b355fff +com.adobe.CIT (2.3.0.33236 - 2.3.0.33236) <5CC0D600-30F2-3A3C-9515-CAF5B3DA4B39> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/CIT.framework/Versions/A/CIT
                                       0x11b365000 -        0x11b369ff7 +com.adobe.CITThreading (2.3.0.33236 - 2.3.0.33236) <2E66E0A3-A60C-388A-8552-C5F3B9755AD7> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/CITThreading.framework/Versions/A/CITThreading
                                       0x11b4ea000 -        0x11b4f1ff7 +com.adobe.lightroom.import (com.adobe.ag.import 6.2.1 - 1.0) <BC62DC92-F760-3907-8ADE-18B0AC999948> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/PlugIns/Import.lrmodule/Contents/MacOS/Import
                                       0x11b561000 -        0x11b56dff7 +com.adobe.boost_signals.framework (8.0.0 - 8.0.0.0) <793F75E6-3CDF-391C-B113-8F71CEE7682B> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
                                       0x11b57b000 -        0x11b57dfff +com.adobe.boost_system.framework (8.0.0 - 8.0.0.0) <1946089C-1981-3861-BC75-B52A78F0917B> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
                                       0x11b584000 -        0x11b58aff7 +com.adobe.boost_date_time.framework (8.0.0 - 8.0.0.0) <70340019-229B-308E-8ACC-E55340413843> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
                                       0x11b597000 -        0x11b5a4fff +com.adobe.boost_threads.framework (8.0.0 - 8.0.0.0) <23EFB96A-5AB7-31B0-9621-B8588B213154> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
                                       0x11b5b4000 -        0x11b5e4ff7 +com.adobe.dvamediatypes.framework (8.0.0 - 8.0.0.0) <6E8F39A9-23A4-32C4-A5AB-4C8369E72FC5> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
                                       0x11b601000 -        0x11b61afff  libexpat.1.dylib (12) <1490D436-163D-3385-B71A-A4F17399626A> /usr/lib/libexpat.1.dylib
                                       0x11b677000 -        0x11b6deff7 +com.adobe.dvatransport.framework (8.0.0 - 8.0.0.0) <81FB7C08-FB0A-3F24-A599-C6CAB041EC32> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/dvatransport.framework/Versions/A/dvatransport
                                       0x11b72c000 -        0x11b752ff7 +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <3318FE3E-8AB8-3821-A1FB-8A8D62C20303> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
                                       0x11bf24000 -        0x11bf4fff7 +com.adobe.dvamarshal.framework (8.0.0 - 8.0.0.0) <30853DE9-6933-3312-A0CE-C03E53B3C071> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/dvamarshal.framework/Versions/A/dvamarshal
                                       0x11bf73000 -        0x11bf97ff7 +com.adobe.dvaunittesting.framework (8.0.0 - 8.0.0.0) <1B0262F7-D9A9-3386-992D-473E96A3AB43> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaunittesting
                                       0x11bfbb000 -        0x11c04dfff +com.adobe.dvaaudiodevice.framework (8.0.0 - 8.0.0.0) <C66E4FE3-E19A-34E8-8861-5BE0CE18C633> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/dvaaudiodevice.framework/Versions/A/dvaaudiodevice
                                       0x11e173000 -        0x11e49afff +com.adobe.mediacoreif.framework (8.0.0 - 8.0.0.0) <A5FD42FC-01A2-3043-833B-E954FCD231A5> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/mediacoreif.framework/mediacoreif
                                       0x11e694000 -        0x11e932fff +com.adobe.dvacore.framework (8.0.0 - 8.0.0.0) <E0935431-3C1F-3548-A918-C13359898E6B> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
                                       0x11ea6a000 -        0x11ecb8fff +com.adobe.dynamiclink.framework (8.0.0 - 8.0.0.0) <2C412369-7A38-3E00-8DD1-7FBA5BFD0AF8> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dynamiclink
                                       0x11ee07000 -        0x11eec3fff +com.adobe.dvaplayer.framework (8.0.0 - 8.0.0.0) <FE0CD49A-065D-3148-BF5B-6BF75FAB8928> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/dvaplayer.framework/Versions/A/dvaplayer
                                       0x11ef83000 -        0x11efc3fff +com.adobe.dvanet.framework (8.0.0 - 8.0.0.0) <DF4215F4-4B39-3876-B8B8-DEF23D4EF530> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/dvanet.framework/Versions/A/dvanet
                                       0x11f222000 -        0x11f26efff +com.adobe.ag.cef-toolkit (com.adobe.ag.cef_toolkit 6.2.1 - 1.0) <F7B192E2-04B0-3481-B657-649EB4E84C57> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/cef_toolkit.agtoolkit/Contents/MacOS/cef_toolkit
                                       0x11f28a000 -        0x122e17f1f +libcef.dylib (31523.6.11) <7E427337-65A2-3B49-AD70-9C9BE02F4C01> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/Chromium Embedded Framework.framework/Versions/A/libcef.dylib
                                       0x1231a7000 -        0x1231ddfff  com.apple.audio.midi.CoreMIDI (1.10 - 88) <2BE3A6B5-98D8-386D-8763-BC057CB644FE> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
                                       0x123206000 -        0x123342fff +com.adobe.headlights.LogSessionFramework (7.3.1.61) <D633CDB7-C235-328A-98E5-11FE46B3D179> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/LogSession.framework/LogSession
                                       0x1233dd000 -        0x12395fff7 +com.adobe.ag.coretech-toolkit (com.adobe.ag.coretech_toolkit 6.2.1 - 1.0) <9D2407F2-A8EF-3207-94BD-F1B35843EA07> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/CoreTechToolkit.agtoolkit/Contents/MacOS/CoreTechToolki t
                                       0x123b7e000 -        0x123ec2ff7 +com.adobe.AGM (AdobeAGM 4.30.51.34488 - 4.30.51.34488) <AAD59EC2-F2F0-37A3-BB93-FE9F3B8DF205> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
                                       0x123f30000 -        0x124255fff +com.adobe.CoolType (AdobeCoolType 5.15.00.34488 - 5.15.00.34488) <83E40C9D-DD09-3FEF-B984-AB834D72C32A> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
                                       0x12429d000 -        0x1243ebff7 +com.adobe.ACE (AdobeACE 2.20.02.34488 - 2.20.02.34488) <DCD064B8-A43A-3D41-B499-15E602F69CDA> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
                                       0x1243ff000 -        0x12452dfff +com.winsoft.wrservices (WRServices 7.0.0 - 7.0.0) <0853A41B-A14A-37B7-B27F-457F87865EAD> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
                                       0x12458a000 -        0x124686fff +com.adobe.AXEDOMCore (AdobeAXEDOMCore 3.8.0.34478 - 3.8.0.34478) <45773819-98F5-33BB-9DA3-50B9909E91C5> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
                                       0x125852000 -        0x125852fff +com.adobe.ag.catalogconverters (com.adobe.ag.catalogconverters 6.2.1 - 1.0) <AC79A82B-AD20-3B10-A701-8A05D6FA61DE> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/CatalogConverters.agtoolkit/Contents/MacOS/CatalogConve rters
                                       0x125899000 -        0x125913fff  com.apple.xquery (1.3.1 - 30) <C822958E-D937-3B07-9731-A5A08142BA6A> /System/Library/PrivateFrameworks/XQuery.framework/XQuery
                                    0x7fff620f0000 -     0x7fff62126f5f  dyld (360.17) <03673B53-B8B7-34D1-ADCE-F449E78E39CC> /usr/lib/dyld
                                    0x7fff8b444000 -     0x7fff8b7bfffb  com.apple.VideoToolbox (1.0 - 1731.15.20) <70FDD7D4-FE98-3154-8B7D-72EDD5E92CDB> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
                                    0x7fff8b7c0000 -     0x7fff8b7c2ffb  libutil.dylib (43) <E37832CF-5EE6-345A-B0EC-FFC8D2B67375> /usr/lib/libutil.dylib
                                    0x7fff8b7c3000 -     0x7fff8bc38ff7  com.apple.CoreFoundation (6.9 - 1255.1) <86B26482-C917-34F2-80D8-02911B6001E0> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                                    0x7fff8bc41000 -     0x7fff8bc43fff  com.apple.OAuth (25 - 25) <DFC11955-75DD-303E-BFCB-0F70A4C541E0> /System/Library/PrivateFrameworks/OAuth.framework/Versions/A/OAuth
                                    0x7fff8bc47000 -     0x7fff8bc8dff7  libauto.dylib (186) <460B0167-C89B-37EC-823C-52F684B31C26> /usr/lib/libauto.dylib
                                    0x7fff8bd0e000 -     0x7fff8bd13fff  com.apple.MediaAccessibility (1.0 - 79) <309526B0-1A18-3C2D-B425-A2BB61EED005> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
                                    0x7fff8bd14000 -     0x7fff8bf81ff7  com.apple.imageKit (2.6 - 930) <8DA4A452-0E28-3A3E-82B6-93D155581002> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
                                    0x7fff8bf82000 -     0x7fff8bf85ff7  com.apple.help (1.3.3 - 46) <AA185754-DEEB-3091-9301-7B23C4D36818> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
                                    0x7fff8bf8a000 -     0x7fff8bf93ff7  com.apple.DisplayServicesFW (3.0 - 378) <69821BC1-66F6-30FE-B706-134F3A9FCAD7> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
                                    0x7fff8c113000 -     0x7fff8c116fff  libCoreVMClient.dylib (119.5) <56187F75-4436-31CA-8D3A-C6BC67F6F2BF> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
                                    0x7fff8c117000 -     0x7fff8c140fff  libxpc.dylib (755.1.19) <3E09C275-A33B-357A-B0AB-A2DDF88EC9D5> /usr/lib/system/libxpc.dylib
                                    0x7fff8c14e000 -     0x7fff8c399fff  com.apple.AddressBook.framework (9.0 - 1679) <87B2D9E4-A042-3A99-BC5F-BA48D6896D12> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
                                    0x7fff8c39a000 -     0x7fff8c858fcf  com.apple.vImage (8.0 - 8.0) <04ADAB75-1588-32BD-96B9-8CEE5543599E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
                                    0x7fff8c859000 -     0x7fff8cd7bfff  com.apple.QuartzComposer (5.1 - 334) <B28D6929-25C0-3F27-9454-EAE22857EF4A> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
                                    0x7fff8cd7c000 -     0x7fff8cdadffb  com.apple.GSS (4.0 - 2.0) <D50CDB44-72E9-3520-9965-93901621F781> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
                                    0x7fff8ce3c000 -     0x7fff8d23efff  libLAPACK.dylib (1159) <BDADCDAE-1FD8-3190-B9DD-DB671495EEE2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
                                    0x7fff8d250000 -     0x7fff8d265fff  com.apple.ToneKit (1.0 - 1) <3722D681-0582-335A-A992-A972D2046163> /System/Library/PrivateFrameworks/ToneKit.framework/Versions/A/ToneKit
                                    0x7fff8d2aa000 -     0x7fff8d2deff7  com.apple.CoreVideo (1.8 - 191.1) <FA99D150-EFCE-3F32-ACDF-5E91AD97F176> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
                                    0x7fff8d2df000 -     0x7fff8d2e1ff7  libRadiance.dylib (1440) <A3E73CE6-7260-3828-BCD9-756DB5167010> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
                                    0x7fff8d2e2000 -     0x7fff8d2edfff  libGPUSupportMercury.dylib (12.0.34.12) <9BB56F2D-D91C-3F65-AE44-404173FD242A> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupport Mercury.dylib
                                    0x7fff8d2ee000 -     0x7fff8d31cff7  com.apple.DictionaryServices (1.2 - 250) <94678AC8-41FF-3D2E-A35E-D83AD18D7A78> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
                                    0x7fff8d31d000 -     0x7fff8d3acff7  libCoreStorage.dylib (517) <1CC0776E-B682-3CC1-8CC2-2305E0FA439D> /usr/lib/libCoreStorage.dylib
                                    0x7fff8d4e3000 -     0x7fff8d593fff  com.apple.backup.framework (1.7 - 1.7) <70033C43-855B-3F12-998C-343F2A8A93BA> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
                                    0x7fff8d627000 -     0x7fff8d668ff7  libGLU.dylib (12.0.34.12) <055A2B53-7C59-359A-82CB-1F79160C5C86> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
                                    0x7fff8d669000 -     0x7fff8d66afff  libDiagnosticMessagesClient.dylib (100) <F2D8CFCC-A00A-3675-9C01-EF0C663F2445> /usr/lib/libDiagnosticMessagesClient.dylib
                                    0x7fff8d66b000 -     0x7fff8d66bfff  libmetal_timestamp.dylib (600.0.41.2) <2E74E3DE-B13E-3645-8A32-90D889FE92E1> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
                                    0x7fff8d66c000 -     0x7fff8d66ffff  com.apple.IOSurface (108.0.1 - 108.0.1) <7B05B27A-5CC4-30D4-8A10-ED444A2807A2> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
                                    0x7fff8d670000 -     0x7fff8d673fff  com.apple.Mangrove (1.0 - 1) <7CA6F485-F7A5-301C-9F14-4C667EF8B2F3> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
                                    0x7fff8d674000 -     0x7fff8d6e0ff7  com.apple.contacts.Contacts (1.0 - 2137) <3503806B-F315-3869-88FD-FFF8D5C10973> /System/Library/Frameworks/Contacts.framework/Versions/A/Contacts
                                    0x7fff8d6f3000 -     0x7fff8d6fbfff  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <B0028247-B333-36F5-8098-8EC95E6C2B23> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
                                    0x7fff8e07d000 -     0x7fff8e178ff7  libFontParser.dylib (158.3) <DBFEE35E-60F4-3F51-AA25-D4D7E4E01996> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
                                    0x7fff8e17f000 -     0x7fff8e187fff  libcopyfile.dylib (127) <CA2602AB-E8B7-3CD8-A0C5-D86E35FDA09F> /usr/lib/system/libcopyfile.dylib
                                    0x7fff8e188000 -     0x7fff8e32fffb  com.apple.avfoundation (2.0 - 1046.9.1) <AE9896EC-F23A-3148-A757-D5807E1369EA> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
                                    0x7fff8e330000 -     0x7fff8e333ff7  com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <E4643432-0DF2-3CD3-9F63-3A7665B25838> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
                                    0x7fff8e33a000 -     0x7fff8e33ffff  com.apple.DiskArbitration (2.7 - 2.7) <B391A885-1286-3718-A341-8C84560DDE58> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
                                    0x7fff8e3bb000 -     0x7fff8e3f5fff  com.apple.QD (3.12 - 302) <46969760-B02A-3ED5-B8BC-D6144939B16E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
                                    0x7fff8e3f6000 -     0x7fff8e51bff7  com.apple.LaunchServices (728.4 - 728.4) <A4913361-072C-3A0E-9231-0D9B1DC4ECC5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
                                    0x7fff8e51c000 -     0x7fff8e522fff  com.apple.XPCService (2.0 - 1) <E50F1206-8B6B-3CDB-BC66-E5B70B4B41C7> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
                                    0x7fff8e66b000 -     0x7fff8e676ff7  com.apple.CommerceCore (1.0 - 453.1) <73536ABF-E3F2-349B-94CF-A45AD333BC74> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCor e.framework/Versions/A/CommerceCore
                                    0x7fff8e70b000 -     0x7fff8e723fc7  libcompression.dylib (23) <803C89B9-1E7D-3658-A2CF-2B8371C54638> /usr/lib/libcompression.dylib
                                    0x7fff8e724000 -     0x7fff8e74eff7  GLRendererFloat (12.0.34.12) <EC1AE73B-1E91-383F-9954-F6B81313794C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/G LRendererFloat
                                    0x7fff8e77d000 -     0x7fff8e792ff3  libCGInterfaces.dylib (317.8) <92EA55E8-A12D-3AFC-ADE3-F5AB6B80E638> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/Libraries/libCGInterfaces.dylib
                                    0x7fff8e7dc000 -     0x7fff8e7deff7  com.apple.securityhi (9.0 - 55006) <02F35345-EFDE-3EE6-8526-F64EA74F91EA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
                                    0x7fff8e7df000 -     0x7fff8ec4cffb  com.apple.GeoServices (1.0 - 1151.2.13.1) <8305A6E9-BE86-3AC7-8EAB-6A989CC208C0> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
                                    0x7fff8ec4d000 -     0x7fff8ec76fff  libc++abi.dylib (125) <F5027B46-1801-344D-BD51-2E6D188C8900> /usr/lib/libc++abi.dylib
                                    0x7fff8ec9d000 -     0x7fff8ecc6ffb  libRIP.A.dylib (938) <4D830858-FD2C-32B1-9B29-E88AD815E604> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
                                    0x7fff8f590000 -     0x7fff8f5a9ffb  com.apple.openscripting (1.7 - 169) <6AA25650-8900-33C6-AD49-D0543DB27C16> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
                                    0x7fff8f604000 -     0x7fff8f8e9ff3  com.apple.CoreServices.CarbonCore (1136 - 1136) <9DE930A3-63C0-3E21-965A-132D97D61892> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
                                    0x7fff8f8f1000 -     0x7fff8f8fdfff  com.apple.SpeechRecognitionCore (2.2.7 - 2.2.7) <12117823-8A9E-3C88-A01C-3B25D68535CE> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecogn itionCore
                                    0x7fff8fa7b000 -     0x7fff8fb11ff7  com.apple.ColorSync (4.9.0 - 4.9.0) <1FBEDDC2-4BCD-3148-800E-968814206CB9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
                                    0x7fff8fb12000 -     0x7fff8fb1bfff  com.apple.icloud.FindMyDevice (1.0 - 1) <28CE764F-4C4C-3A75-B7AE-EDBC7A189E82> /System/Library/PrivateFrameworks/FindMyDevice.framework/Versions/A/FindMyDevice
                                    0x7fff90a25000 -     0x7fff90a6aff3  libFontRegistry.dylib (155) <BC1B3AD5-4927-3AB7-94FF-CD93BF895D98> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
                                    0x7fff90ac8000 -     0x7fff90b1dfff  com.apple.AE (701 - 701) <87FDCC5A-82AC-36A2-BFE9-D0B2A3D870F1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
                                    0x7fff90c51000 -     0x7fff90e5dfff  com.apple.CoreImage (11.1.0 - 366.1.1) <BE963C1D-90C2-388A-85F2-D6701DC104C4> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
                                    0x7fff91260000 -     0x7fff91270fff  libSparseBLAS.dylib (1159) <C10D35D2-3D3D-3EB0-8215-527BD1F1F3E0> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libSparseBLAS.dylib
                                    0x7fff91271000 -     0x7fff91273ff7  com.apple.xpc.ServiceManagement (1.0 - 1) <0EA1807B-4F41-317D-A6C2-E6A23F201252> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
                                    0x7fff916ab000 -     0x7fff91733fff  com.apple.CoreSymbolication (3.1 - 58048.1) <7B9BCFD9-3600-3973-841D-6227BEDE5D36> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolicatio n
                                    0x7fff91734000 -     0x7fff91737ffb  libScreenReader.dylib (425.100) <993C7AE7-6CA2-37B5-A13C-F9032857D3AD> /usr/lib/libScreenReader.dylib
                                    0x7fff9178d000 -     0x7fff917b6ff7  libsystem_info.dylib (476) <65D0643A-C8AE-3E8D-9F6E-E4AD823F16B2> /usr/lib/system/libsystem_info.dylib
                                    0x7fff91b4b000 -     0x7fff91b53fff  com.apple.AppleSRP (5.0 - 1) <8DBB11A2-150A-3E70-8B83-DDEDAB15E2C3> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
                                    0x7fff91b57000 -     0x7fff91ba7fff  libcups.2.dylib (435) <FA565876-F9B2-3021-8E89-6D665ED01B3D> /usr/lib/libcups.2.dylib
                                    0x7fff91beb000 -     0x7fff91bebfff  com.apple.ApplicationServices (48 - 48) <B5326BD2-AF17-3880-A8C5-3C990AE4A1C8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
                                    0x7fff91bec000 -     0x7fff91cdbfff  libxml2.2.dylib (29) <0702E13C-D726-3DAF-B0D1-77F7B9EF6A37> /usr/lib/libxml2.2.dylib
                                    0x7fff92ea2000 -     0x7fff92eb6fff  libsystem_coretls.dylib (82) <21EDACF1-D9B3-3086-9821-60EB75E7F965> /usr/lib/system/libsystem_coretls.dylib
                                    0x7fff92f7f000 -     0x7fff92f8afff  com.apple.DirectoryService.Framework (10.11 - 194) <D3F78A43-A04D-31CA-AFF0-52E129CEDB91> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
                                    0x7fff92f8b000 -     0x7fff93099fff  com.apple.desktopservices (1.10 - 1.10) <76AA21FE-0F96-366A-9B43-6188FBC29ABE> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
                                    0x7fff9309a000 -     0x7fff930ebff7  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <73EF4EB0-315C-3064-A991-3DBFF6BDDFE1> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
                                    0x7fff932e6000 -     0x7fff934b4ff7  com.apple.QuartzCore (1.11 - 410.9) <4D3C169D-C579-38C3-AE10-B975E89331E0> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
                                    0x7fff934b5000 -     0x7fff934b5fff  libenergytrace.dylib (10) <64F779D4-2192-37EC-8DB5-EC55BAE50058> /usr/lib/libenergytrace.dylib
                                    0x7fff934b6000 -     0x7fff934c1ff7  libcommonCrypto.dylib (60074) <BD1DCF19-8353-3F6A-AFFA-EBBA29A302A8> /usr/lib/system/libcommonCrypto.dylib
                                    0x7fff93535000 -     0x7fff9357aff7  com.apple.coreservices.SharedFileList (24.4 - 24.4) <3C8665BA-A9CD-377C-BECB-2E933FDB68AE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.fr amework/Versions/A/SharedFileList
                                    0x7fff9357b000 -     0x7fff93585fff  com.apple.NetAuth (6.0 - 6.0) <ABBBE552-26E0-3682-8BFD-C59EC702F347> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
                                    0x7fff9361d000 -     0x7fff936d6ff7  libvMisc.dylib (563.4) <04503007-DE32-34EB-90BB-740C289E3784> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
                                    0x7fff93ef1000 -     0x7fff93ef6fff  com.apple.AssetCacheServices (14 - 14) <8C912A44-6635-33A0-82A3-389585BAC0F1> /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/AssetCacheServi ces
                                    0x7fff93ef7000 -     0x7fff93efaff7  libsystem_sandbox.dylib (459.10.4) <BC781530-CA98-392D-A77A-8CAD2D9C6B2F> /usr/lib/system/libsystem_sandbox.dylib
                                    0x7fff93efb000 -     0x7fff93fe6ff7  com.apple.QuickLookUIFramework (5.0 - 696.1) <921959F6-96C2-3814-8D20-0E761AB51199> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
                                    0x7fff94138000 -     0x7fff94140fff  libsystem_networkextension.dylib (384.1.2) <4736FCC5-9DBA-31F4-AAC8-CD0A177CF502> /usr/lib/system/libsystem_networkextension.dylib
                                    0x7fff94141000 -     0x7fff941b4ffb  com.apple.Heimdal (4.0 - 2.0) <2D358FB4-61BB-3BB6-9EF7-D9868A0B0275> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
                                    0x7fff941b6000 -     0x7fff941c4ff7  libbz2.1.0.dylib (38) <99C5121D-8147-3B51-8D79-66245C863338> /usr/lib/libbz2.1.0.dylib
                                    0x7fff94206000 -     0x7fff94209ff7  libCoreFSCache.dylib (119.5) <5935DEAB-4236-38D2-8C76-5AF9A5700559> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
                                    0x7fff94250000 -     0x7fff942f0fff  com.apple.Metadata (10.7.0 - 972.9) <303B6874-8B16-39A0-BB9D-5B7A59D3B8A2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
                                    0x7fff944bf000 -     0x7fff9451fff7  com.apple.QuickLookFramework (5.0 - 696.1) <727FE6BE-8E92-38A3-BDEB-2410B553BB27> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
                                    0x7fff94526000 -     0x7fff94528fff  com.apple.EFILogin (2.0 - 2) <1FF63331-0B4A-385D-AC44-7AE665947553> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
                                    0x7fff94529000 -     0x7fff9457bfff  com.apple.CloudDocs (1.0 - 382) <F8B381F5-C434-3719-B26B-137D61F8DEBD> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
                                    0x7fff94609000 -     0x7fff9467dff3  com.apple.securityfoundation (6.0 - 55126) <73D2EE6C-E3A2-32FE-89B3-BA8ACEA53F09> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
                                    0x7fff94684000 -     0x7fff94685fff  liblangid.dylib (122) <EAC09BF0-5E88-3060-AA51-EC71B4D26F3C> /usr/lib/liblangid.dylib
                                    0x7fff94686000 -     0x7fff94687ff7  libodfde.dylib (23) <B2194A77-3D29-3CE2-9D96-F8986A198980> /usr/lib/libodfde.dylib
                                    0x7fff94688000 -     0x7fff9472cfff  com.apple.Bluetooth (4.4.2 - 4.4.2f1) <7037778A-6783-3727-9076-6CA9ED130A11> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
                                    0x7fff9472d000 -     0x7fff948edfeb  libBLAS.dylib (1159) <4A01C32E-452C-314C-B878-E301D4998C68> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
                                    0x7fff94912000 -     0x7fff94949ff7  com.apple.LDAPFramework (2.4.28 - 194.5) <207E4A14-E3CC-3658-ABAF-B5CAEC9ED1EB> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
                                    0x7fff9494a000 -     0x7fff94960fff  com.apple.CoreMediaAuthoring (2.2 - 953) <8F5453F5-DC0E-39B8-9CB0-0A89268F6930> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthor ing
                                    0x7fff949ab000 -     0x7fff949adff7  com.apple.SafariServices.framework (11601 - 11601.2.7.2) <CC99200E-E893-3A01-AA8F-AF2856675CF7> /System/Library/PrivateFrameworks/SafariServices.framework/Versions/A/SafariServices
                                    0x7fff949ee000 -     0x7fff949f5ff7  libcompiler_rt.dylib (62) <253B36E5-572D-377D-AE99-A02CE32590E5> /usr/lib/system/libcompiler_rt.dylib
                                    0x7fff949f6000 -     0x7fff94a08fff  libsasl2.2.dylib (209) <D48CE2C5-D0C5-39BD-A7DD-C999E81CF885> /usr/lib/libsasl2.2.dylib
                                    0x7fff94a09000 -     0x7fff94c88fff  com.apple.security (7.0 - 57336.10.29) <FA5D22B9-3253-38CF-81E2-E243F93753DC> /System/Library/Frameworks/Security.framework/Versions/A/Security
                                    0x7fff94c91000 -     0x7fff94c93ff7  libquarantine.dylib (80) <1693C5FE-EA0A-3122-85EB-7950ECC7435A> /usr/lib/system/libquarantine.dylib
                                    0x7fff94c94000 -     0x7fff94d03fff  com.apple.SearchKit (1.4.0 - 1.4.0) <45A716CD-D9E7-3F1F-9EC8-BB37CA9E8C04> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
                                    0x7fff94d04000 -     0x7fff94d46ff7  com.apple.Metal (54.26.3 - 54.26.3) <54544DF5-B1D1-3139-ADE6-E815533313EB> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
                                    0x7fff94d51000 -     0x7fff94eddff7  libGLProgrammability.dylib (12.0.34.12) <42F6BEA9-8680-36D9-B5B2-8B368D4F94DB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
                                    0x7fff951e3000 -     0x7fff95241fff  com.apple.SystemConfiguration (1.14 - 1.14) <E3F5D239-4CBE-3B77-A8D9-F3423702AAB9> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
                                    0x7fff9538a000 -     0x7fff953a1fff  libmarisa.dylib (4) <4D3AE55B-CE77-364F-B8DE-C95CAA48B291> /usr/lib/libmarisa.dylib
                                    0x7fff953a2000 -     0x7fff953aaff7  libcldcpuengine.dylib (2.6.4.1) <D8A9DDA1-35B5-3D6B-85E0-A5542033FA9F> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
                                    0x7fff953ab000 -     0x7fff954bdfef  libvDSP.dylib (563.4) <7036F91A-0951-340C-8818-0AB90FF0B057> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
                                    0x7fff954be000 -     0x7fff9550cfff  libcurl.4.dylib (90) <00662A4C-B89A-3A17-93FF-950C6DE47F99> /usr/lib/libcurl.4.dylib
                                    0x7fff955bd000 -     0x7fff955d7ff3  liblzma.5.dylib (10) <8CD18286-49EA-31E4-8A73-1BF8DECED6C6> /usr/lib/liblzma.5.dylib
                                    0x7fff955d8000 -     0x7fff95783ffb  GLEngine (12.0.34.12) <0D0BD639-B516-3216-A0A5-AC4CDD202689> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
                                    0x7fff9578a000 -     0x7fff95796ff7  com.apple.OpenDirectory (10.11 - 194) <7ECA481B-C265-33F6-835E-2E5B96621E51> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
                                    0x7fff957ac000 -     0x7fff957c8ff3  libresolv.9.dylib (60) <B192EC27-84EC-3D8A-9CBF-0374B5C9B31A> /usr/lib/libresolv.9.dylib
                                    0x7fff957c9000 -     0x7fff957d4fff  com.apple.CrashReporterSupport (10.11 - 716) <9BD908E9-368A-3B17-AFCD-185277FF70BA> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporter Support
                                    0x7fff95832000 -     0x7fff95ad8fff  com.apple.CoreData (120 - 640) <37466A48-AA4C-3DB5-B606-C04841D3F654> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
                                    0x7fff95ad9000 -     0x7fff95b17ff7  libGLImage.dylib (12.0.34.12) <4FC92D21-0834-397E-BE0D-282A73FC16B2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
                                    0x7fff95c82000 -     0x7fff95cadff7  com.apple.AddressBook.ContactsFoundation (8.0 - 2137) <082A84FD-0076-3129-8193-2BCB0EAD15E2> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundat ion
                                    0x7fff95cae000 -     0x7fff96204fff  com.apple.MediaToolbox (1.0 - 1731.15.20) <B7C4E89E-A5D5-35B2-BA8F-36EC2EAB2CFC> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
                                    0x7fff9636d000 -     0x7fff963d4fff  com.apple.framework.CoreWiFi (11.0 - 1101.20) <D5DC3626-3131-3BAA-8552-294B4CE1EFCB> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
                                    0x7fff963d5000 -     0x7fff96553fff  com.apple.UIFoundation (1.0 - 435) <237F281F-7F15-3309-B749-F8DA37822F9F> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
                                    0x7fff9655a000 -     0x7fff96581fff  com.apple.ChunkingLibrary (167 - 167) <C22F5038-7354-330F-8F38-36F187E6A4B1> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
                                    0x7fff96582000 -     0x7fff96727ff3  com.apple.audio.toolbox.AudioToolbox (1.13 - 1.13) <F84A0C1D-86BE-3E59-8EEA-BAE0E8CB834B> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
                                    0x7fff96728000 -     0x7fff9672efff  com.apple.IOAccelerator (203.10 - 203.10) <A9827A1B-1337-31CF-9D96-791868B51A49> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
                                    0x7fff9674d000 -     0x7fff96785fff  com.apple.RemoteViewServices (2.0 - 99) <8BD12AE2-BE91-37CF-955B-62E08551FF83> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServi ces
                                    0x7fff96786000 -     0x7fff96791fff  libkxld.dylib (3247.10.11) <22BBF963-3808-3320-8BDA-5B7A99035F14> /usr/lib/system/libkxld.dylib
                                    0x7fff96792000 -     0x7fff9686afff  com.apple.CoreMedia (1.0 - 1731.15.20) <F30D52A8-5FA9-3BFE-856F-D6EDBC725A80> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
                                    0x7fff9686b000 -     0x7fff96877fff  com.apple.speech.synthesis.framework (5.4.12 - 5.4.12) <8D8F331E-21D2-3B7E-B977-3EB1D9E44D5B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
                                    0x7fff974c4000 -     0x7fff9768dff7  com.apple.ImageIO.framework (3.3.0 - 1440) <C00A0D30-2F60-30F1-9BE5-B7FA33A13DC2> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
                                    0x7fff9768e000 -     0x7fff976bbfff  libdispatch.dylib (500.10.1) <438F4595-0731-34A2-ACAD-60121A76D1FF> /usr/lib/system/libdispatch.dylib
                                    0x7fff976d8000 -     0x7fff977b8ff7  unorm8_rgba.dylib (2.6.4.1) <49FF2837-D97B-3CFF-B139-E57D40700F32> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_rgba .dylib
                                    0x7fff977f0000 -     0x7fff97b5addf  libobjc.A.dylib (680) <CE3C3C78-A7BB-3147-8375-55424032FF5E> /usr/lib/libobjc.A.dylib
                                    0x7fff97baf000 -     0x7fff97ca1ff7  libJP2.dylib (1440) <5540B4E7-CDE5-31B1-937F-E5B209E162F1> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
                                    0x7fff97e5c000 -     0x7fff97e61ff3  libunwind.dylib (35.3) <FDA18078-A775-3BAF-A5A6-8A7B75D6AA99> /usr/lib/system/libunwind.dylib
                                    0x7fff97e62000 -     0x7fff97e6bffb  libsystem_notify.dylib (149) <56ABC155-CB99-30A8-A8B1-C204B5615092> /usr/lib/system/libsystem_notify.dylib
                                    0x7fff97e6c000 -     0x7fff97e77ff7  libChineseTokenizer.dylib (16) <1794A880-9C3D-37B2-8F3E-6CAFFB396089> /usr/lib/libChineseTokenizer.dylib
                                    0x7fff97e7f000 -     0x7fff97edcfff  com.apple.CoreServices.OSServices (728.4 - 728.4) <4E1819C2-F7A9-35FB-8193-FF3DCC35226C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
                                    0x7fff97f41000 -     0x7fff97f4cfff  com.apple.AppSandbox (4.0 - 261.10.2) <9824F3E3-6212-32BB-BC68-13FCAF820FB1> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
                                    0x7fff97f4d000 -     0x7fff97f55ffb  libsystem_dnssd.dylib (624.10.1) <21D63EAB-27BE-3F41-B1D4-604BE7F4C9BA> /usr/lib/system/libsystem_dnssd.dylib
                                    0x7fff982c8000 -     0x7fff982c8ff7  libunc.dylib (29) <D9B0C7B1-8648-3AAC-931C-E7CD362FAA8A> /usr/lib/system/libunc.dylib
                                    0x7fff982ce000 -     0x7fff982f0ff7  com.apple.IconServices (68 - 68) <9F8B9184-8DA8-3B7A-970B-3086DDD1CC6F> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
                                    0x7fff982f1000 -     0x7fff98302fff  libz.1.dylib (60) <43317BEA-ACA2-34C2-AF37-902AA926C83A> /usr/lib/libz.1.dylib
                                    0x7fff98303000 -     0x7fff98336fff  com.apple.MediaKit (16 - 807) <CCE5E5C0-B379-3F2C-AE16-7BB543FF7C09> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
                                    0x7fff9833a000 -     0x7fff985cffff  libmecabra.dylib (696.1) <8FCC4C88-BE6A-3697-B1D3-8E1A2A3B99BA> /usr/lib/libmecabra.dylib
                                    0x7fff985ef000 -     0x7fff987fcfff  libicucore.A.dylib (551.30) <CC6AA367-C6D3-3592-A697-76C0CFFE19DD> /usr/lib/libicucore.A.dylib
                                    0x7fff988a2000 -     0x7fff988bdff7  libCRFSuite.dylib (34) <65E4DC91-A994-3921-B5B0-696123CE0C1E> /usr/lib/libCRFSuite.dylib
                                    0x7fff988f7000 -     0x7fff9890bfff  com.apple.CoreDuetDaemonProtocol (1.0 - 1) <C0619E4A-5CF8-357E-B571-2398239911A1> /System/Library/PrivateFrameworks/CoreDuetDaemonProtocol.framework/Versions/A/CoreDuetDae monProtocol
                                    0x7fff9893d000 -     0x7fff98942ff7  libmacho.dylib (875.1) <A9EC23EC-11A0-3B4F-A8AC-B990C8267A6E> /usr/lib/system/libmacho.dylib
                                    0x7fff98a1f000 -     0x7fff98a3afff  com.apple.aps.framework (4.0 - 4.0) <A3971E50-DD87-3752-B37A-E58557AD5AF2> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
                                    0x7fff98bdb000 -     0x7fff98bdbfff  com.apple.CoreServices (728.4 - 728.4) <14019127-641A-3CB9-8155-86AD35F23597> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
                                    0x7fff98bdc000 -     0x7fff98d20ff7  com.apple.QTKit (7.7.3 - 2937) <C04A69AB-93F9-3BB4-BF56-1CD408183CE7> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
                                    0x7fff98d21000 -     0x7fff98d48ff7  com.apple.ProtectedCloudStorage (1.0 - 1) <403BC9E0-2A4E-3481-BDFE-B3CB372E5051> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedClo udStorage
                                    0x7fff98d49000 -     0x7fff98d95ff7  com.apple.corelocation (1486.17 - 1615.37) <AF201676-FFF5-39E1-8B0A-D670F4129CA8> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
                                    0x7fff98d96000 -     0x7fff98d9cff7  com.apple.speech.recognition.framework (5.1.1 - 5.1.1) <433F8745-874A-39B3-A7C6-2EDA8C2C6B4A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
                                    0x7fff98d9d000 -     0x7fff98db2fff  com.apple.AppContainer (4.0 - 261.10.2) <ABF27707-2925-3A25-916E-370A3E342AF0> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
                                    0x7fff98db3000 -     0x7fff98dd1fff  libsystem_kernel.dylib (3247.10.11) <FA4DCF42-27B0-3878-9158-E148D208B21E> /usr/lib/system/libsystem_kernel.dylib
                                    0x7fff98dd2000 -     0x7fff98e67fff  com.apple.ink.framework (10.9 - 214) <F1B3B6C9-FF8D-3E68-93EB-8CDCEB65171A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
                                    0x7fff98e68000 -     0x7fff98eb6ff7  libstdc++.6.dylib (104.1) <77780A99-22DB-35AA-BD9E-ADB83417E4BD> /usr/lib/libstdc++.6.dylib
                                    0x7fff98eb7000 -     0x7fff98f25ff7  com.apple.ApplicationServices.ATS (377 - 394.1) <E35909E3-83E0-3671-914A-B43845D889B3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
                                    0x7fff98fa4000 -     0x7fff98fa6fff  libCVMSPluginSupport.dylib (12.0.34.12) <F8E1EA87-73ED-3372-8C58-4209942ECD20> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dyl ib
                                    0x7fff98fae000 -     0x7fff98fb6fff  libGFXShared.dylib (12.0.34.12) <F8278F50-25AC-3CEC-9F68-D83785A25F5E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
                                    0x7fff98fc2000 -     0x7fff98fc2fff  com.apple.Accelerate.vecLib (3.10 - vecLib 3.10) <E0D5C411-052F-3B71-9562-C1098FB2F86D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
                                    0x7fff98fc3000 -     0x7fff99317fff  com.apple.Foundation (6.9 - 1255.1) <3AD7B198-3943-3919-B6F2-B0C28DC817B1> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                                    0x7fff9936b000 -     0x7fff993c9fff  libsystem_network.dylib (582.1.4) <C5DC3F04-7011-34D4-9682-E1B31999A89C> /usr/lib/system/libsystem_network.dylib
                                    0x7fff993cc000 -     0x7fff9941efff  com.apple.AppleVAFramework (5.0.31 - 5.0.31) <17D3C8AE-5E48-34CE-B5FB-5F30747EDE91> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
                                    0x7fff9941f000 -     0x7fff99457ff7  com.apple.Accounts (113 - 113) <22DBA9B9-F70A-33CB-B87C-4D11AD66D126> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
                                    0x7fff99458000 -     0x7fff9954aff7  libiconv.2.dylib (44) <82529E3B-0485-344C-8075-83C7725D6A6F> /usr/lib/libiconv.2.dylib
                                    0x7fff99584000 -     0x7fff99594ff3  com.apple.ProtocolBuffer (1 - 242) <B3D0CEE0-1ED1-39BB-8C81-896F36398802> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
                                    0x7fff995c2000 -     0x7fff995fcff7  com.apple.DebugSymbols (132 - 132) <6F5853A1-5DA8-3C42-8E02-2B972F34BCE0> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
                                    0x7fff99a58000 -     0x7fff99a67ffb  com.apple.LangAnalysis (1.7.0 - 1.7.0) <E7D610A1-1445-3CA3-B9A1-EE15D54B75AB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
                                    0x7fff99a68000 -     0x7fff99b17fff  com.apple.cloudkit.CloudKit (480 - 480) <2507C1D3-733F-394A-9ADC-FF8FAD7D21B9> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
                                    0x7fff9a0fa000 -     0x7fff9a117fff  com.apple.AppleVPAFramework (2.0.15 - 2.0.15) <86BC6DCE-8590-38E3-9C0C-52E97F617B58> /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA
                                    0x7fff9a282000 -     0x7fff9a2d1ff7  com.apple.opencl (2.6.9 - 2.6.9) <CA196FE1-7E95-3CBD-A97F-90747B9F5CBC> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
                                    0x7fff9a2d2000 -     0x7fff9a2eefff  com.apple.GenerationalStorage (2.0 - 239) <05652CAD-E7F5-3225-929D-E13F241FBA41> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalSt orage
                                    0x7fff9a3bf000 -     0x7fff9a3c3fff  com.apple.LoginUICore (3.1 - 3.1) <6DCEED7A-529B-3AFD-8F83-97A40B56E4D9> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore. framework/Versions/A/LoginUICore
                                    0x7fff9a3c4000 -     0x7fff9a3e8fff  com.apple.MultitouchSupport.framework (304.9 - 304.9) <90E9EC0A-57D0-331E-AE0D-FF1A7756A409> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
                                    0x7fff9a3e9000 -     0x7fff9aa8fffb  com.apple.JavaScriptCore (11601 - 11601.2.3) <CAB09947-EC70-3CFC-9C24-101122452A58> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
                                    0x7fff9aa90000 -     0x7fff9aae2fff  com.apple.ImageCaptureCore (7.0 - 7.0) <74BC5DBA-FD63-31B9-A55B-C3C128852F1D> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
                                    0x7fff9adbf000 -     0x7fff9af09fc7  com.apple.coreui (2.1 - 364.1) <4E680853-589C-3BC5-8215-240A07A92C81> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
                                    0x7fff9af0a000 -     0x7fff9b191ff3  com.apple.CFNetwork (760.1.2 - 760.1.2) <D4FD8DF6-8481-3BE6-9E93-A3268B16774E> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
                                    0x7fff9b8dd000 -     0x7fff9b90bff7  com.apple.CoreServicesInternal (248.1 - 248.1) <834B5D98-DB81-36B1-BD2A-640928EDAAF6> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesI nternal
                                    0x7fff9b9cf000 -     0x7fff9b9eeff7  com.apple.framework.Apple80211 (11.0 - 1102.32) <B94B708C-D7E8-3733-B360-0D5A48FBB873> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
                                    0x7fff9b9ef000 -     0x7fff9ba02fff  com.apple.CoreBluetooth (1.0 - 1) <A63B8FB0-F8B3-368D-B482-733FF0373610> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
                                    0x7fff9bd9b000 -     0x7fff9bd9ffff  libGIF.dylib (1440) <062A2A8B-E00A-34A5-9C1C-D85C1761CA70> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
                                    0x7fff9bda0000 -     0x7fff9be0fffb  com.apple.datadetectorscore (7.0 - 460) <117708DA-6E19-3866-AD15-0CE3E3F2211A> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
                                    0x7fff9be10000 -     0x7fff9be1bfff  libcsfde.dylib (517) <C8C9A632-5072-3D24-8EBF-CCDE0BC8BFB5> /usr/lib/libcsfde.dylib
                                    0x7fff9be1c000 -     0x7fff9be33fff  libsystem_asl.dylib (322) <97D794DA-8CE5-3676-AC5E-364F6D172BDA> /usr/lib/system/libsystem_asl.dylib
                                    0x7fff9be34000 -     0x7fff9be45ff7  libsystem_trace.dylib (200) <1D289F35-BFA2-3B9E-BDF9-20F34F9A01D4> /usr/lib/system/libsystem_trace.dylib
                                    0x7fff9be46000 -     0x7fff9be46fff  com.apple.Cocoa (6.11 - 22) <A033F342-1FEC-3DFD-830A-E8EE284DF492> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
                                    0x7fff9be47000 -     0x7fff9be70ff7  libxslt.1.dylib (14) <412A09C9-7C02-351E-A416-2453361EACA9> /usr/lib/libxslt.1.dylib
                                    0x7fff9bec6000 -     0x7fff9bf53fe7  libsystem_c.dylib (1081.1.3) <A60CE86D-1FF3-32AD-A672-C7597F884529> /usr/lib/system/libsystem_c.dylib
                                    0x7fff9bf54000 -     0x7fff9bf59fff  com.apple.TCC (1.0 - 1) <96281C9E-B2DF-325F-BFA4-0A15150165EC> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
                                    0x7fff9c1f6000 -     0x7fff9c1f6fff  libOpenScriptingUtil.dylib (169) <5C4A51D4-09A9-3209-8E57-15F112725CC4> /usr/lib/libOpenScriptingUtil.dylib
                                    0x7fff9c1f7000 -     0x7fff9c1fffff  com.apple.CoreServices.FSEvents (1222.1.1 - 1222.1.1) <79DF16A7-E169-38A5-BF5E-2D45F86DE154> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framewor k/Versions/A/FSEvents
                                    0x7fff9c200000 -     0x7fff9c219fff  com.apple.CFOpenDirectory (10.11 - 194) <86755CDA-B4AA-39EF-8F7B-27F120F9AAC3> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
                                    0x7fff9c252000 -     0x7fff9c25afef  libsystem_platform.dylib (73.1.1) <3F4D2390-E3DE-3C24-A515-95DFAC8671C4> /usr/lib/system/libsystem_platform.dylib
                                    0x7fff9c25b000 -     0x7fff9c341fef  unorm8_bgra.dylib (2.6.4.1) <28F838EA-19E5-3724-99FF-B61132555D09> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra .dylib
                                    0x7fff9c378000 -     0x7fff9c3e2ff7  com.apple.framework.CoreWLAN (11.0 - 1101.20) <BA9EB0BF-7915-3DB0-9ACE-EC52CD07E1A8> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
                                    0x7fff9c3e3000 -     0x7fff9c46cff7  com.apple.PerformanceAnalysis (1.0 - 1) <BE35D3E9-570D-3483-9C78-82F3EFB56D43> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAna lysis
                                    0x7fff9c70e000 -     0x7fff9c761ff7  libc++.1.dylib (120.1) <54190E1B-EE49-3D6D-AC29-2813D7380BA5> /usr/lib/libc++.1.dylib
                                    0x7fff9c762000 -     0x7fff9c81cfff  com.apple.DiscRecording (9.0.1 - 9010.4.3) <7AFCD317-2A1C-30D3-9871-C9C2C4FF05FD> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
                                    0x7fff9c81d000 -     0x7fff9c841ff7  libJPEG.dylib (1440) <B16D0DCA-2EA4-348B-A7EA-30E65B536C28> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
                                    0x7fff9c842000 -     0x7fff9c8b8ff7  com.apple.MMCS (1.3 - 349) <C445C851-09F2-34F8-AA4C-D7135C15945F> /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS
                                    0x7fff9c8b9000 -     0x7fff9c8bbfff  libsystem_coreservices.dylib (19) <692631A0-1923-32CA-9BD5-044B1382FFDE> /usr/lib/system/libsystem_coreservices.dylib
                                    0x7fff9c939000 -     0x7fff9c93affb  libSystem.B.dylib (1225.1.1) <59F79CA0-5D86-359D-A235-4F257409109E> /usr/lib/libSystem.B.dylib
                                    0x7fff9c97e000 -     0x7fff9cc73ff3  com.apple.HIToolbox (2.1.1 - 806) <359FC9DB-B64C-3BC7-B9DA-401D8A5337DC> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                                    0x7fff9ccb8000 -     0x7fff9d8dafff  com.apple.AppKit (6.9 - 1404.13) <9B600863-6A16-31CB-8138-97AC8F43FBC6> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                                    0x7fff9d8db000 -     0x7fff9d8e9fff  com.apple.IntlPreferences (2.0 - 192) <6576CA0C-BFA3-3DD4-8FB8-B2B36137060E> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
                                    0x7fff9d8ea000 -     0x7fff9d8f3ff3  com.apple.CommonAuth (4.0 - 2.0) <6EF43A6E-C071-36A3-8B94-694AC6BEF6D3> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
                                    0x7fff9d8f4000 -     0x7fff9da11fff  libsqlite3.dylib (216.4) <5CF0D77D-CF0A-301C-8003-69A840AC47FD> /usr/lib/libsqlite3.dylib
                                    0x7fff9da12000 -     0x7fff9da85fff  com.apple.framework.IOKit (2.0.2 - 1178.10.1) <6A9D7E11-156A-3FDB-850E-114ECB1AE7FD> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
                                    0x7fff9da86000 -     0x7fff9dad1ff7  com.apple.CoreMediaIO (701.0 - 4790) <EE999B42-E879-346B-829F-6CE9E2806187> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
                                    0x7fff9dad2000 -     0x7fff9daddfff  libGL.dylib (12.0.34.12) <182B925C-7BF6-3EFE-85AF-54760206A6FD> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
                                    0x7fff9dae7000 -     0x7fff9db09ff7  com.apple.framework.familycontrols (4.1 - 410) <941D3CE9-826F-38C9-A553-6F44435ADFF6> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
                                    0x7fff9db0a000 -     0x7fff9db0fff7  libheimdal-asn1.dylib (452.1.1) <6E911973-1E1A-3F80-B955-FA78CF20FBFD> /usr/lib/libheimdal-asn1.dylib
                                    0x7fff9db10000 -     0x7fff9db18fff  libMatch.1.dylib (27) <D8024E9A-795B-30FC-BCE7-DB1E20889AB9> /usr/lib/libMatch.1.dylib
                                    0x7fff9db6c000 -     0x7fff9db82ff7  libLinearAlgebra.dylib (1159) <01BD9187-521F-3F96-B477-24511318AECD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLinearAlgebra.dylib
                                    0x7fff9dbed000 -     0x7fff9dc8dfff  com.apple.ViewBridge (157 - 157) <EA9A214B-6AFA-3543-A4F0-8E67F6ED414F> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
                                    0x7fff9dc8f000 -     0x7fff9dc90fff  libsystem_secinit.dylib (20) <932ED582-E80F-39DA-B0FA-F1BC5F1AD2F8> /usr/lib/system/libsystem_secinit.dylib
                                    0x7fff9dce9000 -     0x7fff9dd19ff3  com.apple.CoreAVCHD (5.8.0 - 5800.4.2) <56AA41E6-2F60-31D8-B506-2D4A5C341C77> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
                                    0x7fff9dd27000 -     0x7fff9de0eff7  libcrypto.0.9.8.dylib (59) <7C4E5457-B66C-39CA-BC0E-15CA6C051FC0> /usr/lib/libcrypto.0.9.8.dylib
                                    0x7fff9de0f000 -     0x7fff9de86fc7  libcorecrypto.dylib (334) <4E1B969F-8449-3B21-9880-51AD58E25AA6> /usr/lib/system/libcorecrypto.dylib
                                    0x7fff9de9c000 -     0x7fff9de9eff7  libsystem_configuration.dylib (801.10.2) <93D5FB9A-CC7C-3672-80D8-7A1C4805204B> /usr/lib/system/libsystem_configuration.dylib
                                    0x7fff9e07f000 -     0x7fff9e0cbffb  com.apple.HIServices (1.22 - 548) <19389B63-C373-31AE-9180-3A11093EAE58> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
                                    0x7fff9e0d0000 -     0x7fff9e4fefff  com.apple.vision.FaceCore (3.3.1 - 3.3.1) <D02FBB03-42A5-3E75-83C1-F563B1E3258F> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
                                    0x7fff9e4ff000 -     0x7fff9e62bfff  com.apple.CoreText (352.0 - 494.5.1) <393F0F48-0226-34BA-9793-66D8455EF894> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
                                    0x7fff9e6bf000 -     0x7fff9e6c3fff  libcache.dylib (75) <4948E2C8-867F-3E9D-AAE7-2F30F0B345C6> /usr/lib/system/libcache.dylib
                                    0x7fff9e6c4000 -     0x7fff9e6c5ff3  com.apple.print.framework.Print (10.0 - 266) <F13A0609-793A-3A43-A961-AAFC81AC8FDA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
                                    0x7fff9effb000 -     0x7fff9f00dfff  com.apple.contacts.ContactsPersistence (1.0 - 2137) <40E67B07-5DC9-3B5E-8266-1A27142268D0> /System/Library/PrivateFrameworks/ContactsPersistence.framework/Versions/A/ContactsPersis tence
                                    0x7fff9f00e000 -     0x7fff9f00efff  com.apple.quartzframework (1.5 - 21) <E37B0DA2-8DEB-3D46-9038-BD91E789A375> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
                                    0x7fff9f00f000 -     0x7fff9f013fff  libpam.2.dylib (20) <7F986CE8-EF74-3BC3-BB7E-5267E24EAFFE> /usr/lib/libpam.2.dylib
                                    0x7fff9f014000 -     0x7fff9f0c9fff  com.apple.CoreDuet (1.0 - 1) <063ADBE1-44D5-30EE-887E-69ACC8EA9AB6> /System/Library/PrivateFrameworks/CoreDuet.framework/Versions/A/CoreDuet
                                    0x7fff9f127000 -     0x7fff9f12ffff  com.apple.NetFS (6.0 - 4.0) <5602F3EB-64F6-3495-BEF0-988F92974234> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
                                    0x7fff9f130000 -     0x7fff9f13efff  libxar.1.dylib (302) <898402AF-0DF3-341D-83EA-4A1B1770E718> /usr/lib/libxar.1.dylib
                                    0x7fff9f13f000 -     0x7fff9f142fff  libspindump.dylib (197) <4DAD2F5F-B719-3DD8-9D7C-135314CE85D0> /usr/lib/libspindump.dylib
                                    0x7fff9f193000 -     0x7fff9f1a4fff  libcmph.dylib (6) <43880250-9C2D-395C-90C7-CCCE109FF1B2> /usr/lib/libcmph.dylib
                                    0x7fff9f1fc000 -     0x7fff9f28bfff  com.apple.CorePDF (4.0 - 4) <023E8BCC-DA79-34EE-8975-45690E97F862> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
                                    0x7fff9f303000 -     0x7fff9f304fff  libsystem_blocks.dylib (65) <1B4F1F10-823E-3781-8162-6884D14DF0D6> /usr/lib/system/libsystem_blocks.dylib
                                    0x7fff9f449000 -     0x7fff9f499ff7  com.apple.Symbolication (1.4 - 58044) <BC1259C8-C671-3014-A9C4-85BC767EA962> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
                                    0x7fff9f4b5000 -     0x7fff9f4b5fff  com.apple.audio.units.AudioUnit (1.13 - 1.13) <CFB91CDC-5BBA-3A8E-BA05-6E972217BD57> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
                                    0x7fff9f4c9000 -     0x7fff9f4caffb  libremovefile.dylib (41) <C7CFF5F2-AFFB-3C8D-BDB4-D66D50E657C0> /usr/lib/system/libremovefile.dylib
                                    0x7fff9f4cb000 -     0x7fff9f4d2ff7  com.apple.phonenumbers (1.1.1 - 105) <49696A1F-83FC-3BE8-A7E8-F0F4EAA326BB> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
                                    0x7fff9f4dc000 -     0x7fff9f569dd7  com.apple.AppleJPEG (1.0 - 1) <6230F3A0-C89D-3A35-A896-A17B3513E8DB> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
                                    0x7fff9f5cc000 -     0x7fff9f673fff  com.apple.LanguageModeling (1.0 - 1) <C405E993-F0DF-39E4-9B74-FE310E63DD8E> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
                                    0x7fff9f674000 -     0x7fff9f698fff  com.apple.quartzfilters (1.10.0 - 1.10.0) <B25F42F6-2548-39A8-9A9E-35331FD813EB> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
                                    0x7fff9f699000 -     0x7fff9f69cffb  libdyld.dylib (360.17) <99396189-E53A-3A78-BC49-449236DA7CFF> /usr/lib/system/libdyld.dylib
                                    0x7fff9f69d000 -     0x7fff9f6c9fff  com.apple.framework.SystemAdministration (1.0 - 1.0) <6DFACF58-D982-34E7-88A7-B6CC68D2169A> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdminis tration
                                    0x7fff9f6ca000 -     0x7fff9f6cafff  com.apple.Carbon (154 - 157) <DF95E7EB-1CFC-3C83-B114-60FFEEAE166E> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
                                    0x7fff9f6cb000 -     0x7fff9f6eaff7  com.apple.contacts.vCard (1.0 - 2137) <74FA0133-CFBB-3055-B429-AF2D13B24D7D> /System/Library/PrivateFrameworks/vCard.framework/Versions/A/vCard
                                    0x7fff9f6eb000 -     0x7fff9f979ff3  com.apple.RawCamera.bundle (6.17 - 825) <EFF00605-B354-3F94-B4D0-1A14B08482FE> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
                                    0x7fff9f97a000 -     0x7fff9f97afff  com.apple.Accelerate (1.10 - Accelerate 1.10) <84DA0CD4-9670-343A-B243-D03A2A6A14E2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
                                    0x7fff9f985000 -     0x7fff9f9b4fff  com.apple.securityinterface (10.0 - 55065.10.2) <1D6DB9F4-6EB4-39E0-8E99-C09EEA78BB16> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
                                    0x7fff9f9b8000 -     0x7fff9f9b9fff  com.apple.TrustEvaluationAgent (2.0 - 25) <BC19A1D1-805B-3FC5-BF0B-1EF6FB36FE74> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
                                    0x7fff9f9ba000 -     0x7fff9f9baff7  liblaunch.dylib (755.1.19) <7EC0F297-43CC-3D11-B46B-7E72E372648A> /usr/lib/system/liblaunch.dylib
                                    0x7fff9f9bb000 -     0x7fff9f9dcfff  com.apple.Sharing (438.0.1 - 438.0.1) <679D40D7-3C04-3D2C-962B-E8A959E5889E> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
                                    0x7fff9f9dd000 -     0x7fff9f9dffff  com.apple.loginsupport (1.0 - 1) <09F245DC-8342-358E-A881-DAE88BF0EC1D> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.fram ework/Versions/A/loginsupport
                                    0x7fff9fb3c000 -     0x7fff9fb6bfc3  libsystem_m.dylib (3105) <07D50372-30ED-3B03-9FA0-0662BF8F0098> /usr/lib/system/libsystem_m.dylib
                                    0x7fff9fb6c000 -     0x7fff9ff44fef  com.apple.CoreAUC (214.0.0 - 214.0.0) <36675355-FEF4-3DC0-9734-AE6F125883C2> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
                                    0x7fff9ff45000 -     0x7fff9ff6aff7  libPng.dylib (1440) <D60133FC-EA26-3DD4-8F5F-AE854244A648> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
                                    0x7fff9ff90000 -     0x7fff9ff99ff7  libsystem_pthread.dylib (137.1.1) <1373D0F1-C6CA-364E-A6BA-8BDBD0D34670> /usr/lib/system/libsystem_pthread.dylib
                                    0x7fff9ff9a000 -     0x7fff9ffb6ff7  libsystem_malloc.dylib (67) <1B57A614-3D60-3F87-876F-7DB4AF38120F> /usr/lib/system/libsystem_malloc.dylib
                                    0x7fffa01d2000 -     0x7fffa01fdffb  libarchive.2.dylib (32.10.1) <88036C67-C2C8-3ADF-A4C7-6BBF94B80F15> /usr/lib/libarchive.2.dylib
                                    0x7fffa01fe000 -     0x7fffa0200fff  libCGXType.A.dylib (938) <91E0A256-B45F-3728-B68A-250E4E74A838> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
                                    0x7fffa0220000 -     0x7fffa023cff7  libextension.dylib (78) <3A674BC1-8D7E-3A62-80EF-F950B02CB0FF> /usr/lib/libextension.dylib
                                    0x7fffa023d000 -     0x7fffa023ffff  com.apple.CoreDuetDebugLogging (1.0 - 1) <B390CD9A-A04F-3A9E-A40C-CB317F40AFE5> /System/Library/PrivateFrameworks/CoreDuetDebugLogging.framework/Versions/A/CoreDuetDebug Logging
                                    0x7fffa0240000 -     0x7fffa0244fff  com.apple.CommonPanels (1.2.6 - 96) <1D76DDD3-D45A-3679-8B72-5EECE6C1ACAC> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
                                    0x7fffa0245000 -     0x7fffa031bff7  com.apple.DiskImagesFramework (10.11.1 - 415) <F3C0F696-A10D-3A4B-9391-AAD695D29831> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
                                    0x7fffa031c000 -     0x7fffa032afff  com.apple.ToneLibrary (1.0 - 1) <E8B44453-4E70-393C-AECF-988D0A8284A6> /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/ToneLibrary
                                    0x7fffa0367000 -     0x7fffa0572fff  libFosl_dynamic.dylib (16.24) <28CD6965-696D-32D0-B76F-4EA21DC1984A> /usr/lib/libFosl_dynamic.dylib
                                    0x7fffa077e000 -     0x7fffa0780fff  com.apple.SecCodeWrapper (4.0 - 261.10.2) <54B4F790-1FD5-3DFB-8F1F-3BEE312238DC> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
                                    0x7fffa07aa000 -     0x7fffa0805ff7  libTIFF.dylib (1440) <53EB5B1D-0080-367C-ADB6-5A57D1B423ED> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
                                    0x7fffa0806000 -     0x7fffa08b1fff  com.apple.PDFKit (3.1 - 3.1) <CDEADFD1-493E-37A8-B2D4-42AE8F72C5FE> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
                                    0x7fffa08b2000 -     0x7fffa08e2ff7  libsandbox.1.dylib (459.10.4) <78F4D125-DEF0-3BEA-9D7F-E5BE5C06C8DA> /usr/lib/libsandbox.1.dylib
                                    0x7fffa08e3000 -     0x7fffa08f3fff  libbsm.0.dylib (34) <F1E41935-5C5D-3704-AE9D-AEA1F2BCF8B1> /usr/lib/libbsm.0.dylib
                                    0x7fffa08f4000 -     0x7fffa093fffb  com.apple.print.framework.PrintCore (11.0 - 472) <34EA102A-D482-37FF-9C9B-E4FE4275913B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
                                    0x7fffa0940000 -     0x7fffa1babff7  com.apple.CoreGraphics (1.600.0 - 938) <1BB01FAB-B403-3389-8D9F-44A04E9D8ADC> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
                                    0x7fffa1c05000 -     0x7fffa1c1ffff  com.apple.Kerberos (3.0 - 1) <D2F0BF94-8656-3FBF-81AC-43D417B661F1> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
                                    0x7fffa1c20000 -     0x7fffa1c20ff7  libkeymgr.dylib (28) <47080280-8B57-3D75-8A20-9E100864DE27> /usr/lib/system/libkeymgr.dylib
                                    0x7fffa1c24000 -     0x7fffa1c87ff3  libAVFAudio.dylib (161) <1E0384CE-FF8D-36EE-8A28-50CD673D3109> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Resources/libAVFAudio.dylib
                                    0x7fffa1c88000 -     0x7fffa1c96fff  com.apple.opengl (12.0.34 - 12.0.34) <31C23ABB-8F75-3201-8CD1-447B3052B434> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
                                    0x7fffa1c97000 -     0x7fffa1c9cfff  com.apple.ImageCapture (9.0 - 9.0) <E53CC0B8-9D36-3636-B602-8AB4CEB4C313> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
                                External Modification Summary:
                                  Calls made by other processes targeting this process:
                                    task_for_pid: 1
                                    thread_create: 0
                                    thread_set_state: 0
                                  Calls made by this process:
                                    task_for_pid: 0
                                    thread_create: 0
                                    thread_set_state: 0
                                  Calls made by all processes on this machine:
                                    task_for_pid: 537
                                    thread_create: 0
                                    thread_set_state: 0
                                VM Region Summary:
                                ReadOnly portion of Libraries: Total=426.2M resident=0K(0%) swapped_out_or_unallocated=426.2M(100%)
                                Writable regions: Total=290.4M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=290.4M(100%)
        VIRTUAL   REGION
                                REGION TYPE                        SIZE    COUNT (non-coalesced)
                                Accelerate.framework               128K        2
                                Activity Tracing                  2048K        2
                                CG backing stores                 34.6M        8
                                CG image                            28K        4
                                CG shared images                   400K       10
                                CoreAnimation                       28K        4
                                CoreUI image data                  604K        8
                                CoreUI image file                  320K        5
                                Dispatch continuations            8192K        2
                                Image IO                          7664K       10
                                Kernel Alloc Once                    8K        3
                                MALLOC                           196.0M       56
                                MALLOC guard page                   32K        7
                                Memory Tag 242                      12K        2
                                OpenCL                               8K        2
                                Process Corpse Info               2048K        2
                                STACK GUARD                       56.1M       27
                                Stack                             20.3M       27
                                VM_ALLOCATE                        996K       13
                                __DATA                            33.6M      346
                                __GLSLBUILTINS                    2588K        2
                                __IMAGE                            528K        2
                                __LINKEDIT                       104.4M       60
                                __TEXT                           321.7M      334
                                __UNICODE                          552K        2
                                mapped file                       63.5M       47
                                shared memory                     16.3M       11
                                TOTAL                            872.1M      971
                                Model: MacBookPro10,2, BootROM MBP102.0106.B0A, 2 processors, Intel Core i5, 2.6 GHz, 8 GB, SMC 2.6f59
                                Graphics: Intel HD Graphics 4000, Intel HD Graphics 4000, Built-In
                                Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1600 MHz, 0x80AD, 0x484D5434314753364D465238432D50422020
                                Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1600 MHz, 0x80AD, 0x484D5434314753364D465238432D50422020
                                AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x10F), Broadcom BCM43xx 1.0 (7.21.94.29.1a4)
                                Bluetooth: Version 4.4.2f1 16391, 3 services, 27 devices, 1 incoming serial ports
                                Network Service: Wi-Fi, AirPort, en0
                                Serial ATA Device: APPLE SSD SM256E, 251 GB
                                USB Device: USB 2.0 Bus
                                USB Device: Hub
                                USB Device: Hub
                                USB Device: Apple Internal Keyboard / Trackpad
                                USB Device: BRCM20702 Hub
                                USB Device: Bluetooth USB Host Controller
                                USB Device: Hub
                                USB Device: FaceTime HD Camera (Built-in)
                                USB Device: USB 3.0 Bus
                                USB Device: My Passport 0829
                                Thunderbolt Bus: MacBook Pro, Apple Inc., 23.4
                                • 13. Re: Lightroom CC crashes on startup (OS-X)
                                  Mrinmay Majhi Adobe Employee
                                  Hi ljgeist,
                                  Please navigate to the location :  /Users/<User Name>/Library/Caches/Adobe/ (~/Library/Caches/Adobe)
                                  Rename the Lightroom folder.
                                  Hope this helps.
                                  ~Mrinmay
                                  • 14. Re: Lightroom CC crashes on startup (OS-X)
                                    ljgeist1 Level 1
                                    That did the trick. Thanks!
                                    • 15. Re: Lightroom CC crashes on startup (OS-X)
                                      I am happy to hear that the issue is resolved.
                                      Let me know if you have any further queries.
                                      ~Mrinmay
