This content has been marked as final.
Show 11 replies
1. Re: Safari not work with dragLayer
Newsgroup_User Oct 4, 2006 2:25 PM (in response to ingramre)I was able to assemble the puzzle in Safari, but it works only of you
let go of the puzzle piece *exactly* where it's supposed to go. If
you're off by a pixel or two, it flies back home. Or almost back home.
(Clue?)But the first time I did it, Safari crashed, so there is
definitely a problem. I'm pretty sure you just can't drag layers in
Opera (or at least you couldn't in earlier versions) but I don't know if
you are supposed to be able to in Safari. Sorry I can't help you. I have
never used this script.
James M. Shook
http://www.jshook.com -
2. Re: Safari not work with dragLayer
Newsgroup_User Oct 4, 2006 2:44 PM (in response to ingramre)Pretty much by accident I ran
http://jigsaw.w3.org/css-validator/validator?profile=css2&warning=2&uri=http%3A%2F%2Fcoe.j mu.edu%2Fmathvidslc%2Fjigsaw%2F
it seems to want a unit. ie 120px. It could be worth checking out. Sorry I
don't have a definitive answer but would really like to know if this helps.
Jo
"ingramre" <webforumsuser@macromedia.com> wrote in message
news:eg0uiu$14u$1@forums.macromedia.com...
> I've created a small puzzle that involves putting some pieces together as
> the
> text for each corresponding piece is displayed. See it at:
> http://coe.jmu.edu/mathvidslc/jigsaw . This works fine in IE on PC; on
> the
> Mac, it works with Firefox but not Safari and Opera. For Safari and
> Opera,
> when you drag a puzzle piece to any locaiton, it jumps back to the
> original
> location as soon as you end MouseOver. Ideas on how to make this
> compatible
> with Safari/Opera on Mac (OSX).
3. Re: Safari not work with dragLayer
ingramre Oct 5, 2006 6:50 AM (in response to Newsgroup_User)Thanks for taking a look James. Like your website. -
4. Re: Safari not work with dragLayer
ingramre Oct 5, 2006 6:55 AM (in response to Newsgroup_User)Thanks for running the validator. I added the unit (px) and now it validates OK. Unfortunately, it still doesn't work. -
5. Re: Safari not work with dragLayer
Newsgroup_User Oct 5, 2006 7:46 AM (in response to Newsgroup_User)ingramre wrote:
A simple google search uncovers this. Please note at the end of the
text, before you start changing any files, that Safari is not compatible
with this behaviour.
http://www.communitymx.com/blog/index.cfm?newsid=285
6. Safari not work with dragLayer
nijocamus Jan 7, 2007 11:07 PM (in response to Newsgroup_User)This is not my experience -- I have gotten the draglayer behavior to work in safari; however, my problem is that what makes this command work in Safari causes it to *not* work in IE(5.2). The general problem with draglayer appears to be that if your layer contains a large image, then half or more of the time you end up selecting and dragging the image rather than the layer. If you accidentally get the image, then, unless you drag it all the way out of the window, in which case it would save to your desktop, it will jump back to the location of the unmoved layer on MouseUp. it's also ugly, cause you see the blue-grey of the highlighted image. What I did that worked *in Safari* was to create an image map on the image that was in my layer, and then, with this image map selected, choose draglayer from the behaviors + box, and (and this is important) change the event to MouseDown. This works pretty well - if you drag where you see the little hand (over the image map), you will consistently select and drag the layer this way. If your image extends out beyond the image map (mine did, cause it has transparent sections), you can still select the image by mistake if you are over the image but not the image map area. The PROBLEM is that this does NOT work in IE -- if you set things up this way, then in IE (I have 5.2 on a mac) when you start dragging the layer, it starts ok, but after a short time/distance (not sure which) all of a sudden your selection will switch on you, and you will be dragging the selected image rather than the layer. If you drag really really really slowly, you can make it work, but what user would put up with that?
I could get drag layer to work pretty well in IE if I select the <body> tag for attaching the behavior to the layer, and then selected use section of layer (I think use entire layer works also)...but this way of coding it causes disasters in Safari.
Anyone have any suggestions????
(I am using an old version of Dreamweaver -- MX from 2002 or 03 -- and I don't know very much about dhtml or javascript) -
7. Re: Safari not work with dragLayer
Newsgroup_User Jan 8, 2007 4:02 AM (in response to Newsgroup_User)If your question is whether you should decide to support Safari or IE5.2,
that answer should be easy, no?
Murray --- ICQ 71997575
Adobe Community Expert
(If you *MUST* email me, don't LAUGH when you do so!)
http://www.dreamweavermx-templates.com - Template Triage!
http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
http://www.dwfaq.com - DW FAQs, Tutorials & Resources
http://www.macromedia.com/support/search/ - Macromedia (MM) Technotes
"nijocamus" <webforumsuser@macromedia.com> wrote in message
news:ensqk1$574$1@forums.macromedia.com...
> in
> appears
> time
> the
> the
> the
> was to
> this is
> drag
> image
> the
> The
> then
> ok,
> selection
> than the
> what
> tag
> layer
8. Re: Safari not work with dragLayer
Newsgroup_User Jan 8, 2007 4:50 AM (in response to Newsgroup_User)nijocamus wrote:
forget about IE5? It's not used anymore -Mac people use Safari (or FireFox or Opera)
seb ( ---@webtrans1.com)
http://webtrans1.com | high-end web design
Downloads: Slide Show, Directory Browser, Mailing List -
9. Safari not work with dragLayer
nijocamus Jan 8, 2007 9:10 AM (in response to ingramre)Actually, perhaps you advise me on which browsers I need to support (I tend to check safari and IE 5.2, cause that's what I have). I'm putting together a portfolio for job hunting in an industry that is really mixed on PC vs mac -- PC because that's what runs autocad and Mac b/c that's what graphic designers tend to prefer. So, my portfolio will need to work on both platforms. It's also an industry with primarily non-profit clients, so people rarely have the 'latest and greatest' upgrades. Given this, what browser or browsers, would you recommend? I know everyone with a mac can get firefox (althoug many jsut use safari) -- what about the PC folks, what version of IE is it recommended that one design for?
Also, for using draglayer and timeline functions, does anyone know whether I would have significantly better results if I bit the bullet and upgraded to a current version of dreamweaver? (I have MX from about 2002)
thanks!
nijocamus -
10. Re: Safari not work with dragLayer
Newsgroup_User Jan 8, 2007 12:22 PM (in response to ingramre)IE and Firefox are the biggies right now.
But you should always design with ALL browsers in mind. If you do your
coding correctly you shouldn't have any problems with any browser.
That being said, you could also run stats on the browser type that visits
the web site to let you know for sure who's using what.
news:enttt9$heh$1@forums.macromedia.com...
> tend to
> a
> mac --
> designers
> It's
> the
> would
> jsut
> recommended
> thanks!
> nijocamus
11. Re: Safari not work with dragLayer
nijocamus Jan 13, 2007 11:09 AM (in response to ingramre)OK - thanks for the heads up on Mac IE5.2 -- didn't realize mac IE was no longer supported, nor how outdated IE5.2 is. My draglayer script that worked in Safari also worked just fine in Firefox on mac and in IE6 on a PC. (Sorry I'm sooooo out of date here...)
