3 Replies Latest reply on Apr 17, 2007 7:45 PM by sahil1210
    External XML config file
    MarcoBazza
      I developed and application in Flex that uses a lot of HTTPService, any of them have an url property that I want to set from an XML external file. This beacuse when I install the application to a client a only need to chage the XML external file and the HTTPSerice change as well. The problem is that a flex application seems to be deployed as a SINGLE SWF FILE that contain the XML file. In fact if I make changes to that file the flex application doesn't feel them.
      In the application MXML file I used this syntax to access the XML file
      <mx:XML id="config" source="config/config.xml"/>
      My application structure is like that:
      / -> swf file
      /config -> config.xml
      /images
      What I have to do to deploy an application that is customizeable by changes of an external file ?
      Marco
