2 Replies Latest reply on Nov 6, 2015 2:28 AM by try67
    Custom Calculation Script - Allow text field when checkbox is selected
    emilyp70953729
      I have a check box that if not checked, the following section auto populates "N/A"; however, if the check box is checked, I want the user to be able to complete the text fields in the following section.
      Here is the code I'm using to auto populate "N/A":
      var a =""
      if (this.getField("cbGeneralLiability").value != "On")
      a="N/A "
      event.value=a.
      What coding do I use to allow the user to input text if the check box is "On"?
      As the formula stands now, if the check box is checked, and I attempt to insert text in the following text fields, the text does not appear.
