Hi there,
we use SCCM to deploy software and configured Reader DC similarly to how we used previous version of reader.
Part of this process is make reader the default pdf handler
When deployed as part of a task sequence, Reader is not the default for any user. (Edge remains the default)
When deployed as an application and installed by 1 user, reader becomes the default for that user, but no other users.
Any ideas on whats needed to resolve this?
Command to install: msiexec /i "AcroRead.msi" /q TRANSFORMS="AcroRead.mst" /L* "%temp%\Acrobat Reader DC install.log"
Install Reader manually without the Wizard/SCCM in the workflow and see if it works.
Logging on as a user and running AcroRead.msi results in the default being set for that user.
future users still have Edge set as the default
Acrobat's support for Windows 10 is relatively new (as is the presence of Edge on enterprise systems) and I suspect that you may be encountering a bug. I'll ping some folks who can test a Win 10 environment.
I doubt this will help, but you could try setting IW_DEFAULT_VERB on the cmd line. Adobe Properties — Enterprise Administration Guide.
Ben
tried that and same result.
Will try with Reader XI and see if it has the same issue, may need to look at using that instead though if its working.
*update* Reader XI has the same issue - default viewer is only changed for the logged on user
Please use parameter "OWNERSHIP_STATE=2" in your command to install . It will set Reader as default PDF handler for all existing users on machine.
New Command to install will be : msiexec /i "AcroRead.msi" /q TRANSFORMS="AcroRead.mst" OWNERSHIP_STATE=2 /L* "%temp%\Acrobat Reader DC install.log".
For existing users on machine ownership will be in effect only when they sign out and sign in again after Installation.
But it looks like an issue from Windows 10 side for new users (Created after installation) .
Yes i tried that as per Custom transform file from Acrobat Wizard not applying to Acrobat DC installation
I agree, it seems to be a windows 10 issue - although the file handler was updated immediately when installed for the current user without requiring logoff/restart
I am experiencing the same issue with Adobe Reader DC in my environment as well. The application will only apply the default PDF handling settings for the logged in user, not all users on the system. Have there been any updates to this issue/has a bug been filed? If my environment can be helpful in isolating the issue, please let me know.
Has there been any improvement to this?
Please see if Setting the Default PDF Viewer (handler) — Enterprise Administration Guide helps.
Will try this out, but this introduces another issue
Users who prefer acrobat to be the default viewer will no longer have this possibility as it is reset every logon.
Has this issue been brought up with Microsoft by adobe? Im sure you have more power here in this regard. Is it the intended design for edge to steal ownership for every user?
You may also try the steps mentioned in this link: https://helpx.adobe.com/acrobat/kb/not-default-pdf-owner.html
Regards,
Tariq Dar.
