6 Replies Latest reply on Nov 4, 2015 9:07 AM by Vamitul
    relink from different folders
    FlemmingP1234
      Hi there
      Can't get the relink to work within vbscript. It should be simple, but it isn't (for me). Getting this error
      I have two scripts I use:
      One that saves information about my links in a text file. Doing this because I link to many different locations.
      One that needs to read this text file in order to relink to correct files again.
      First script:
      Rem To be used for Dumping all linked file information from InDesign
      Set objFSO = CreateObject("Scripting.FileSystemObject")
      Set myInDesign = CreateObject("InDesign.Application.CC.2015")
      'Get Indesign file name and use that to name txt file
      TextFileName = myInDesign.ActiveDocument.Name
      TextFileName = "C:\" + TextFileName + ".txt"
      Set ts = objFSO.CreateTextFile(TextFileName, True)
      If myInDesign.Documents.Count > 0 Then
      txt = "Saving all links from " & Chr(13) & Chr(10) & myInDesign.ActiveDocument.Name
      If MsgBox(txt, vbOKCancel) = vbOK Then
        For Each link in myInDesign.ActiveDocument.Links
             LinkPath = link.FilePath
             ts.WriteLine (LinkPath)
        Next
        ts.Close
        End If
      Else
        MsgBox "Hallo!?"
      End If
      Second script:
      Rem To be used for relinking files into InDesign
      Set ts = objFSO.OpenTextFile(TextFileName)
            WrongLinkPath = link.FilePath
             RightLinkPath = ts.ReadLine
             Relink(RightLinkPath)  <-------This won't work
      Next
      ts.Close
