4 Replies Latest reply on Apr 7, 2009 12:27 AM by Richard_Abbott
    XML Help
    released87 Level 1
      I have an XML file with the following structure:
      <products>
      <product>//Repeating Node
      <id></id>
      <category></category>
      <subcategory></subcategory>
      ....more nodes....
      </product
      </products>
      As you can see, I basically have a product list, which has both category and subcategory elements as siblings. However, I need to build a new XML Object using the category element as the repeating, unique element, and have all subcategories as the child of the category.
      Example:
      <category name="colors">
      <subcategory>blue</subcategory>
      <subcategory>red</subcategory>
      </category>
      <category name="foods">
      <subcategory>Pizza</subcategory>
      <subcategory>Buffalo Wings</subcategory>
      </category>
      This is what I have now. The category nodes work fine and are unique, however I am unable to get the subcategories,
        • 1. Re: XML Help
          funkysoul Level 4
          well you can't have 2 equally named elements inside of a node.
          You need to restructure your XML to fit your needs without using the same element name twice in a single node.
          Maybe you could do something like this:
          <subcategory1>red</subcategory1>
          </category>
          <subcategory1>Buffalo Wings</subcategory1>
          </category>
          • 2. Re: XML Help
            kid electric Level 1
            Really?  I'm not an XML expert, but I think that's not true.  Otherwise, how can you have
            <products>
                 <product> Product 1 </product>
                 <product> Product 2 </product>
            </products>
            Of course you can have multiple elements with the same name!  That's sort of the point of XML.  Then you can do a "for each... in" operation to find every node of the same tag/element label.
            Unless I'm confused about something here... (like I said, I'm not an expert, but I'm pretty sure you can nest multiple elements of the same type)
            • 3. Re: XML Help
              funkysoul Level 4
              Now you confusing me as well
              When you using attributes you can use the same element name so you can loop through them for example:
              <?xml version="1.0"?>
              <menu name="links">
                  <menu name="macromedia">
                      <item name="flash" action="gotoURL" variables="http://www.macromedia.com/software/flash"/>
                      <item name="dreamweaver" action="gotoURL" variables="http://www.macromedia.com/software/dreamweaver"/>
                      <item name="fireworks" action="gotoURL" variables="http://www.macromedia.com/software/fireworks"/>
                  </menu>
                  <menu name="kirupa">
                      <item name="home" action="gotoURL" variables="http://www.kirupa.com"/>
                      <item name="forums" action="gotoURL" variables="http://www.kirupaforum.com/forums/index.php"/>
                      <menu name="tutorials">
                          <item name="actionscript" action="gotoURL" variables="http://www.kirupa.com/developer/actionscript/index.htm"/>
                          <item name="photoshop" action="gotoURL" variables="http://www.kirupa.com/photoshop/index.htm"/>
                          <item name="web" action="gotoURL" variables="http://www.kirupa.com/web/index.htm"/>
                      </menu>
                  </menu>
                  <item name="google" action="gotoURL" variables="http://www.google.com"/>
              </menu>
              Above you have the same element name but the attribute name is different.
              I must admit now that I'm more awake then dead, you could use the same element name but that would be a pain to read that xml in when targeting specific nodes and it's not that quite readable anymore.
              Apart from that you normally and I mean NORMALLY loop through the nodes, not through the children of the node.
              • 4. Re: XML Help
                Richard_Abbott Level 3
                Tiago,
                your XML looks like...
                xml_var =
                <root>
                </category>
                </category>
                </root>
                To get out all subcategories regardless of category you can do
                xml_var.descendants("subcategory");
                which will give you an XMLList with all subcategories regardless of immedaite parent.
                To get out just the colours (sorry, colors!) subcategories you could use
                xml_var.category.(@name=="colors").children();
                which (presupposing I have got the dots in the right place) will give you just the blue and red entries.
                Hope that helps,
                Richard
