2 Replies Latest reply on May 23, 2006 2:19 AM by hufs240
    Local File Browser
      I am trying to design a file explorer or can I open the file explorer for the local hard disk/networks drives to allow a user to select a local file to upload to the server via flash? If anyone has examples or what code I should be looking for please help..
        • 1. Re: Local File Browser
          Rothrock Level 5
          It is only available under Flash 8 and I think it is called the FileReference class. So look in the help files under that. There should be code examples. And as always when trying a new class it is a good idea to read all the methods, properties, events, etc. And then make a brand new fla and try it out before you try and work it into your current project.
          • 2. Re: Local File Browser
            You can use FileReference object to allow a user to select a local file.
            This example help you.
            but, you cannot get a path of the file a user selected because of Macromedia security policy.
            I was disappointed at the fact.
            If anybody find a solution of this problem, let me know it...
            import flash.net.FileReference;
            var objFile:FileReference = new FileReference();
            but.onPress = function(){
            var fileHandler: Object = new Object();
            fileHandler.onSelect = function(refFile:FileReference){
            box.text = refFile.name + "(" + refFile.size + ")";}
