I created a catalog with the following structure.
(In truth it is much more complex but I simplified into 2 sections)
In symbol1a I have a video but if I go to symbol1b or symbol2a I keep hearing the sound of the video in symbol1a.
Only with Safari on iPad. With Chrome or Firefox on PC or Android everything is ok.
If I step from symbol1a (with video) to symbol1b (without video) I use this code that I added in symbol1 under the label symbol1b:
sym.getSymbol("symbol1a").$("video")[0].volume = 0.0;
If instead I step from symbol1a (with video) to symbol2a (without video) I use this code that I added in stage under the label symbol2:
sym.getSymbol("symbol1").getSymbol("symbol1a").$("video")[0].volume = 0.0;
And all this works well except for Safari on iPad.
If I move on the timeline of symbol1a with label I can stop the video and audio, also on iPad, but if I leave symbol1a and step to another symbol not working.
How can I stop the video going from one to another symbol on iPad?
___________________________________________________________
Then I have another problem on audio and video, but this time on browser.
I use in this brochure 6 videos and 2 audios in total, one for each section.
When I load the page, while I see the preloader, I hear one or more audio/video starting. After loading is finished and I start to see the homepage of the brochure, all the audios stop.
I tried activating the pre loading of audio and video.
Then I tried disabling the pre loading of audio and video.
Now is active.
I tried also with this code at the beginning of the stage
and this code at the beginning of the symbol1:
and also this code ath the beginning of symbol1a:
sym.$("video")[0].volume = 0.0;
I set at the beginning of layer video on symbol1a:
- pause video
- deactivate video layer
- set volume 0
for all the videos and audios but don't work.
What can I do?
I solved the second problem. I disabled Autoplay on all videos.
But the first problem of the audio on iPad have not been able to solve it.
Any ideas?
You can mute or pause all video.
sym.$("video").prop("muted", true); ==> Mute all the video tracks in the composition. Set muted to false to toggle off.
sym.$("video").prop("paused", true); ==> Pause all the video tracks in the composition. Set paused to false to toggle off.
Edge API: Adobe Edge Animate CC JavaScript API
Live: HTML5 Video
