3 Replies Latest reply on Sep 10, 2008 5:40 AM by Newsgroup_User
    Type not found or was not a compile time constant:MapEvent
    hvswathi
      <mx:Application
      xmlns:mx=" http://www.adobe.com/2006/mxml"
      width="800" height="600"
      backgroundColor="#FFFFFF"
      initialize="init()">
      <mx:Script>
      <![CDATA[
      import com.google.maps.Map;
      import com.google.maps.MapEvent;
      import com.google.maps.MapType;
      import com.google.maps.LatLng;
      private var _map:Map;
      private function init():void
      _map = new Map();
      _map.key = "your key here";
      _map.addEventListener(MapEvent.MAP_READY, onMapReady);
      _map.setSize( new Point (this.width, this.height))
      mapContainer.addChild(_map);
      private function onMapReady(event:MapEvent):void
      _map.setCenter(new LatLng(40.736072,-73.992062), 14, MapType.NORMAL_MAP_TYPE);
      </mx:Script>
      <mx:UIComponent id="mapContainer" width="100%" height="100%"/>
      </mx:Application>
      this is the code which i want to excecute
        • 1. Re: Type not found or was not a compile time constant:MapEvent
          Level 7
          "hvswathi" <webforumsuser@macromedia.com> wrote in message
          news:ga2k9i$2j9$1@forums.macromedia.com...
          > <mx:Application
          > <mx:Script>
          > <![CDATA[
          > _map = new Map();
          > </mx:Script>
          > </mx:Application>
          What line caused the error?
          • 2. Re: Type not found or was not a compile time constant:MapEvent
            hvswathi Level 1
            This line is giving the error saying that "type not found:mapEvent"
            Do i need to add any library.
            • 3. Re: Type not found or was not a compile time constant:MapEvent
              Level 7
              news:ga88pf$7d$1@forums.macromedia.com...
              Is the class for this in the folder where it's supposed to be? And it looks
              like the error has a different case than your code. Is it possible you're
              mistaking which line it's attached to? Is there another line where you
              reference mapEvent instead of MapEvent?
