7 Replies Latest reply on Dec 22, 2015 11:02 AM by resdesign
    Trouble with a Countdown Timer
    jmflu Level 1
      So I did search on this topic and that is how I got started from this thread:
      Edge animate countdown
      I am using the sample files provided by user: dharmk
      So here is my project file: Dropbox - simplecountdown.zip
      I started with this sample, but I wanted the countdown to countdown to a specific day, so I switched the variable as suggested to:
      var until = new Date(Date.UTC(2015, 0, 11, 12, 6, 7));
      however this makes the compisition report as: Imgur: The most awesome images on the Internet
      What am I doing wrong here?
        • 1. Re: Trouble with a Countdown Timer
          jmflu Level 1
          I think I figured out that it has to do with I am trying to set it more than one month ahead in time.  How can I get it to say the correct amount of days (I don't really want to have a month counter)
          • 2. Re: Trouble with a Countdown Timer
            resdesign Adobe Community Professional & MVP
            You need to use this format for your target date.
            //Date.UTC(year, month[, day[, hour[, minute[, second[, millisecond]]]]])
            var until = new Date(Date.UTC(2015, 12, 25, 10, 50, 0));
            • 3. Re: Trouble with a Countdown Timer
              jmflu Level 1
              Ok I finally got it working, but now I am having a simple but weird problem.
              In edge, I am trying to change the color to white on the text (which I did and it shows up in Edge), but when I preview it in html the text always goes back to black.  Examples below:
              in edge:
              in preview:
              Any idea why this would keep going back to black?  I could post the code of the js if that helps.
              //Change this as per your requirement
              var until = new Date(Date.UTC(2016, 0, 11, 0, 0, 0));
              var $dd = sym.$("dd");
              var $hh = sym.$("hh");
              var $mm = sym.$("mm");
              var $ss = sym.$("ss");
              function pad(num, size) {
                  var s = num+"";
                  while (s.length < size) s = "0" + s;
                  return s;
              function startCounter() {
                updateCounter();
                setInterval(updateCounter, 1000);
              function updateCounter() {
                var now = new Date();
                var delta = until - now;
                var days  = Math.floor( delta / (86400000) );
                var hours = Math.floor( delta / (3600000) );
                var mins  = Math.floor( delta / (60000) );
                var secs  = Math.floor( delta / 1000 );
                var dd = days;
                var hh = hours - days  * 24;
                var mm = mins - hours * 60;
                var ss = secs - mins  * 60;
                $dd.html(pad(dd,2));
                $hh.html(pad(hh,2));
                $mm.html(pad(mm,2));
                $ss.html(pad(ss,2));
              startCounter();
              • 4. Re: Trouble with a Countdown Timer
                jbird42786
                Can anybody help with my Flash countdown issue?  Below is the script, it works but I want specific spacing between the days/hours/minutes/seconds.  Even though I set the text up with the correct spacing, the exported file doesn't carry it over and it adds the : which I don't want.
                this.onEnterFrame = function() {
                var today:Date = new Date();
                var currentYear = today.getFullYear();
                var currentTime = today.getTime();
                var targetDate:Date = new Date(2016,0,31);
                var targetTime = targetDate.getTime();
                var timeLeft = targetTime - currentTime;
                var sec = Math.floor(timeLeft/1000);
                var min = Math.floor(sec/60);
                var hrs = Math.floor(min/60);
                var days = Math.floor(hrs/24);
                sec = String(sec % 60);
                if (sec.length < 2) {
                  sec = "0" + sec;
                min = String(min % 60);
                if (min.length < 2) {
                  min = "0" + min;
                hrs = String(hrs % 24);
                if (hrs.length < 2) {
                  hrs = "0" + hrs;
                days = String(days);
                var counter:String = days + ":" + hrs + ":" + min + ":" + sec;
                time_txt.text = counter;
                • 5. Re: Trouble with a Countdown Timer
                  Could you ask you question in the Flash forum since you are using Flash (Animate CC) and not Edge Animate?
                  • 6. Re: Trouble with a Countdown Timer
                    jbird42786 Level 1
                    my apologies, thought I was in the Flash forum.  Thank you!
                    • 7. Re: Trouble with a Countdown Timer
                      You are the perfect example of why some of us thought that calling Flash, Animate CC would confuse people!
                      Good luck on your project!
