13 Replies Latest reply on Nov 18, 2015 6:40 AM by paulk07
    Calculation Problem
    christianw19891362 Level 1
      How to create a formula to calculate integers and dates using formcalc within LiveCylce ? (i.e. Sep 1, 2015 + 1 + 3= Sep 5, 2015)
        • 1. Re: Calculation Problem
          paulk07 Level 3
          use a date field named StartDate.
          Add a text field and add a script written in FormCalc utilizing the calculate function:
          if (StartDate.rawValue==null) then
          $.rawValue = ""
          else
          Num2Date(Date2Num(StartDate.formattedValue, DateFmt(2))  + 1, DateFmt(2))
          endif
          change the + 1 to increase the number of days calculating from the start date
          Date formats can be changed by using DateFMT(1) or DateFMT(2) or DateFMT(3)
          or you can create a custom format
          • 2. Re: Calculation Problem
            The problem I am having is that I want the "Start Date" field and the "+1" "+2" "+3" etc. fields to be input at random.  Each one of the integer fields would be a separate field that the user would enter a number into and it may not be the same number every time.  It may be 1 or it may be 28.  How do I get the form to auto calculate the "start date" plus the two other fields that are changed by the user (ie. "stop days" and "extension days") to get an "Estimated Completion Date"?
            • 3. Re: Calculation Problem
              paulk07 Level 3
              if (Start.rawValue==null) then
              $.rawValue = ""
              else
              Num2Date(Date2Num(Start.formattedValue, DateFmt(2))  + stop + ext, DateFmt(2))
              endif
              2 date fields named Start and Comp
              2 numeric fields:  stop and ext
              The script is FormCalc on the calculate event of the date field named Comp
              • 4. Re: Calculation Problem
                Awesome! I tried it and everything worked perfect!  I have another equation that I need help with that is very similar to the previous one... I want to take a "Days Allowed" - (End Date - Start Date)= "Days Remaining" (I need it to be an integer, not a date).  Thank you so much for your help!
                • 5. Re: Calculation Problem
                  paulk07 Level 3
                  same as above except a new field (call it whatever you want)
                  Add this script to the new field using "calculate":
                  if (Date2Num(EndDate, "YYYY-MM-DD") and Date2Num(StartDate, "YYYY-MM-DD")) then
                                  if (Date2Num(EndDate, "YYYY-MM-DD") < Date2Num(StartDate, "YYYY-MM-DD")) then
                                      xfa.host.messageBox("The second date is earlier then the first date.\u000aThe date fields will reset.", "Information", 3, 1)
                                      StartDate = null
                                      EndDate = null
                                      $ = null
                  xfa.host.setFocus("StartDate")
                      else
                          $ = Date2Num(EndDate, "YYYY-MM-DD") - Date2Num(StartDate, "YYYY-MM-DD") + 1
                                  endif
                              else
                                  $ = null
                              endif
                  • 6. Re: Calculation Problem
                    When you say "same as above" do you mean I can just leave the previous equation I entered and not change anything as far as the field and coding? Also, when I input the new equation you gave me in numeric field called "Days Remaining" it gives me a syntax error for this line: "if (Date2Num(DateField19, "YYYY-MM-DD") < Date2Num(DateField3, "YYYY-MM-DD")) then" saying "syntax error near token "lt""
                    • 7. Re: Calculation Problem
                      paulk07 Level 3
                      You can leave leave all alone and in the new field add the script.
                      Syntax:  Without seeing the form structure it's difficult to diagnose but try changing the date field names to StartDate and EndDate
                      • 8. Re: Calculation Problem
                        it also gives me a syntax error for this line: "  xfa.host.messageBox("The second date is earlier then the first date.\u000aThe date fields will reset.", "Information", 3, 1) " saying there is an error for "xfa"
                        • 9. Re: Calculation Problem
                          This the problem I am still having.
                          • 10. Re: Calculation Problem
                            I clicked "right answer" but I am still having issues.
                            • 11. Re: Calculation Problem
                              paulk07 Level 3
                              Can you send me the form?
                              • 12. Re: Calculation Problem
                                Yes sir. It has been sent.
