Hi Brad, Flex is intended to create Front-Ends UI, so if you need to write data back to a DB you need to use a backend server tecnology such as CF, PHP, .NET or any other and then you can communicate Flex back with your server using webservices, remoteojbects or httpservices. Hope this helps.
