5 Replies Latest reply on Nov 25, 2015 12:47 PM by Per Berntsen
    Script to delete all images, text frames and page numbers on a layer
    Per Berntsen Adobe Community Professional
      I have a 364 page book with 322 illustrations, mainly photographs, for offset printing.
      The photographs will be overprinted with varnish on a fifth plate, and I set this up as follows:
      On a new layer, (duplicate of Layer 1) all the photos are deleted, but not their frames.
      The frames are then filled with 100% black.
      All text frames and page numbers will also have to be deleted.
      I realise I could have made this job easier if I had placed all images on their own layer to begin with, but unfortunately I didn't.
      And I don't do scripting myself, so I was wondering if someone has a script that will do this ...
      Using CC 2015.1 on Windows 7.
        • 1. Re: Script to delete all images, text frames and page numbers on a layer
          LeoMari Level 2
          Today I did not have time to finish, which gave time to do so far is this:
            var myDocuments = app.documents.everyItem();
              var myLayers = myDocuments.layers.everyItem();
              var myStories = app.activeDocument.stories.everyItem().getElements();
              var myLayer = "palette"; //Add your layer name here
              var NewLayer = myDoc.layers.item(myLayer).duplicate();
              myDocuments.pageItems.everyItem().locked = false;
              myLayers.locked = false;
              myDoc.layers.item(myLayer).visible = false;
              NewLayer.name = "SampleNew";    //Add your new layer name here
                          re();
                          function re(){
                              var link, image;
                              var openDocs = app.documents;
                              var openDocsLen = openDocs.length;
                              for (var d = 0; d < openDocsLen; d ++){
                              currDoc = openDocs[d],
                              links = currDoc.links,
                              counter = 0;
                              myLayer.locked = true;
                              myDocuments.layers.item(myLayer).locked = true;
                                  for (var i = links.length-1; i >= 0; i--) {
                                      if (links[i].hasOwnProperty('relink')) {
                                          try {
                                              link = links[i];
                                              image = link.parent;
                                              image.remove();
                                              counter++;
                                          catch (err) {
                                              $.writeln(i + " - " + err);
                  for (i = myStories.length - 1; i >= 0; i--){
                      var myTextFrames = myStories[i].textContainers;
                      for (j = myTextFrames.length - 1; j >= 0; j--){
                      myTextFrames[j].remove();
          If no one finished the second finalized.
          Hug!
          • 2. Re: Script to delete all images, text frames and page numbers on a layer
            Thank you!
            This seems to work, except that it does not fill the image frames with 100% black.
            Is that possible to implement?
            • 3. Re: Script to delete all images, text frames and page numbers on a layer
              The script has been a great help. Filling the frames manually wasn't too much work.
              Thanks again!
              • 4. Re: Script to delete all images, text frames and page numbers on a layer
                LeoMari Level 2
                I'm glad to be helpful ..
                Try this:
                #target indesign
                                re();
                                function re(){
                                    var link, image;
                                    counter = 0;
                                                try {
                                                    link = links[i];
                                                    image.remove();
                                                    counter++;
                                                catch (err) {
                                    app.findObjectPreferences = app.changeObjectPreferences = null;
                                    app.findObjectPreferences.fillColor = "None";
                                    app.changeObjectPreferences.fillColor = "Black";
                                    app.changeObject();
                Hug.
                Leonardo
                • 5. Re: Script to delete all images, text frames and page numbers on a layer
                  This worked perfectly. Thanks again!
