2 Replies Latest reply on Nov 5, 2015 11:56 PM by Rick Gerard
    Can't fade in text
    henryb1046977
      I have set two points for the opacity, but the text won't fade in. It just appears with no fade. I can see the opacity level changing, but can't visually see it.
        • 1. Re: Can't fade in text
          Nobody can tell you anything without some serious info. You have not provided anything useful, beginning with your version of AE and a screenshot of the timeline.
          Mylenium
          • 2. Re: Can't fade in text
            Which opacity did you animate. If you used a text animator then that is a different discussion. To figure out what is going on with the text layer select it and press the U key twice to show all modified properties. That should point you in the right direction. If it doesn't please post a screenshot and a detailed description of your workflow.
