7 Replies Latest reply on Nov 8, 2015 2:34 PM by adamg86737138
    Export multiple groups as PDF
    adamg86737138
      I've posted a similar question in the past and it was sorted (ended up exporting groups but as JPG). However I would like to export them as PDF now that I know it is possible and have a rough idea of how to achieve this thanks to some members of this forum.
      Though I only got a far as the below code. It will resize the page but it looks like to the wrong size - and the group ends up in the pasteboard somewhere.
      Would greatly appreciate if someone could point out where I've gone wrong!
      var doc=app.activeDocument;
      var links=doc.links.everyItem().getElements();
      var fd=new Folder(doc.fullName.parent+'/PDF');
      if(!fd.exists){
        fd.create();
      var f;
      for (var i=0;i<links.length; i++){
        if ((links[i].status==LinkStatus.NORMAL||links[i].status==LinkStatus.LINK_EMBEDDED)&&
        links[i].parent instanceof EPS &&
        links[i].parent.parent.parent instanceof Group){
          //create new document
          app.documents.add();
          //duplicate group to new document
          links[i].parent.parent.parent.duplicate(document.pages.item(0));
          //set bounds of page to bounds of group
          var pg = app.activeDocument.pages.item(0);
          var gBounds = links[i].parent.parent.parent.geometricBounds;
          pg.reframe(CoordinateSpaces.INNER_COORDINATES, [[gBounds[1], gBounds[0]], [gBounds[3], gBounds[2]]]);
          //export as PDF
          f=File(fd.fullName+'/'+links[i].name.replace(/.[^.]+$/,'')+'.pdf');
          app.activeDocument.exportFile(ExportFormat.pdfType, f)
          //exit without saving
          app.activeDocument.close(SaveOptions.NO);
      Adam
        • 1. Re: Export multiple groups as PDF
          Peter Kahrel Adobe Community Professional & MVP
          After resizing the page, you need to move the duplicated group to the top left point of the page:
          app.documents[0].groups[0].move([0,0]);
          Peter
          • 2. Re: Export multiple groups as PDF
            adamg86737138 Level 1
            Thank you, Peter. That solves that issue. However the page is not resizing to the correct size. Seems to be about 4 to 5 times smaller than it needs to be. Any ideas why this would be?
            Adam
            • 3. Re: Export multiple groups as PDF
              Adam,
              It seems more straightforward to create the new document at the correct size so that no resizing is needed. Something like this:
              group = links[i].parent.parent.parent;
              gb = group.geometricBounds;
              app.documents.add ({documentPreferences: {pageWidth: gb[3]-gb[1], pageHeight:gb[2]-gb[0]}});
              duped = group.duplicate(app.documents[0].pages.item(0));
              duped.move([0,0]);
              P.
              • 4. Re: Export multiple groups as PDF
                Jump_Over Level 5
                Hi Adam,
                Watch 2 of activeDoc properties:
                measurmentsUnit and zeroPoint
                reframe method expects POINTS as a unit
                and doc.zeroPoint supposes to be set as [0,0]
                Jarek
                • 5. Re: Export multiple groups as PDF
                  Hi Adam,
                  what version of InDesign are you using?
                  I'm just curious…
                  Uwe
                  • 6. Re: Export multiple groups as PDF
                    Yes, it would seem more straightforward to do it that way had I known it was possible!
                    Thanks, Peter. I'll definitely keep this in mind. Works perfectly now!
                    I've pasted the full code below just incase anyone else has similar trouble.
                    if(!fd.exists){
                      fd.create();
                    var f;
                        duped.move([0,0]);
                        //export as PDF
                    • 7. Re: Export multiple groups as PDF
                      Hi Laubender,
                      I'm using Indesign CC 9.2.2
                      Adam
