3 Replies Latest reply on Nov 17, 2006 1:58 PM by GentleG
    mc instance name as variable?
    GentleG
      Hi all
      I know how to create empty movieclips that I name (instance) using the content of an array (with text)
      But I don't know how to refer to them without typing in the name manually.
      array (
      one ,1
      two ,2
      three , 3)
      for i =1 to 3
      createemptymc ( array(i , 0)
      this works
      but if I want later to do something with the mc I cannot do
      array(i,0).alpha=70
      So how would I refer to the created mcs using the same array?
      Thank you
      Cheers
      Geert
        • 1. Re: mc instance name as variable?
          digitellinc Level 1
          I don't know if this would be the correct way to do this, but I have used it in some old projects.
          newTarget = eval("_root." + array[i,0] );
          tellTarget("newTarget"){
          alpha = 70;
          • 2. Re: mc instance name as variable?
            Level 7
            I think you have to refer to it as a property of the object that holds it
            using brackets.
            this[array(i,0)].alpha
            Here is an article that explains how to use variable clip names:
            http://www.darknews.com/?p=34
            I hope that helps, I'm sort of a flash noob myself....
            Timm
            "GentleG" <webforumsuser@macromedia.com> wrote in message
            news:ejl08i$o3b$1@forums.macromedia.com...
            > Hi all
            > content
            > array (
            > one ,1
            > two ,2
            > three , 3)
            > for i =1 to 3
            > this works
            > array(i,0).alpha=70
            > Thank you
            > Cheers
            > Geert
            • 3. Re: mc instance name as variable?
              GentleG Level 1
              thank you very much
              this will save me hundreds of lines of code :)
              Cheers
