2 Replies Latest reply on Nov 25, 2015 5:51 AM by javier-pex
    transient document API response
    javier-pex
      Hope anyone might shed more light on this issue. When using the API v4 transientDocument operation I got a 200 Response (OK) but a weird response content, instead of a JSON response I got a text/html
      Any help would be more than welcome, many thanks
      URL
      https://api.na1.echosign.com:443/api/rest/v4/transientDocuments
      RESPONSE
      Metadata
      content-type : text/html
      status : 200
      x-request-id : 28c593a8-5999-4f08-99d0-e0bf10b4aac7
      Body
      eyJ0cmFuc2llbnREb2N1bWVudElkIjoiM0FBQUJMYmxxWmhESUluOGV6cHZtZ3NOWDh2TnRlM1JGdVdkNTUzQkhvYm xpTDBVNEFudmwyWjkxdmprcGNYeGVSRFdSMjFtSkluekNTa1poYzFKSjZpcUhGdVR1SndrbE4yYmhBQW9uc1hrMEVm ektrOGFBM01UeUJWOXV2cFZud3h1cS1NY0N6SldjVmk3dF9RbFlMQWFTWXVId005dUhpY3ZaWTcwWTM0aWwyZUg0N1 NzMVNjanAxY3RLelB6RjFhQnJoenA3MzJjY3dUMUxqZmFaS1p6MVQ1cW5uaHhPIn0=
      REQUEST
      Metadata
      cache-control : no-cache
      content-type : multipart/form-data; boundary=MultiPartFileBoundary150dde63685
      connection : keep-alive
      host : api.na1.echosign.com
      access-token : 3AAABLxxxxxx
      original-path : /rest/v4/transientDocuments
      content-length : 2793
      accept : text/html, image/gif, image/jpeg, *; q=.2, */*; q=.2
      method : POST
      user-agent : Java/1.7.0_51
      requestUrl : rest/latest/transientDocuments
      pragma : no-cache
      Body
      Content-Disposition: form-data; name="File-Name"
      MyFileName
      Content-Disposition: form-data; name="Mime-Type"
      application/pdf
      Content-Disposition: form-data; name="File"; File-Name="MyFileName"
      Content-Type: application/pdf
      Content-Transfer-Encoding: binary
      JVBERi0xLjQKJeLjz9MKMyAwIG9iajw8L0JTPDwvVyAwL1MvUz4+L0E8PC9VUkkoaHR0cDovL3d3dy5SZXppQm94Lm NvbSkvUy9VUkk+Pi9TdWJ0eXBlL0xpbmsvUmVjdFs4MC4yMSA1NzIuMSAxMzEuMTggNTgyLjgyXT4+CmVuZG9iago0 IDAgb2JqPDwvQlM8PC9XIDAvUy9TPj4vQTw8L1VSSShodHRwOi8vdHdpdHRlci5jb20vUmV6aWJveCkvUy9VUkk+Pi 9TdWJ0eXBlL0xpbmsvUmVjdFs5MC4zNCA1NjEuMzggMTMyLjc5IDU3Mi4xXT4+CmVuZG9iago1IDAgb2JqPDwvQlss ssssssS9GaWx0ZXIvRmxhdGVEZWNvZGU+PnN0cmVhbQp4nI1VTU/cMBC9+1dMD6itBFM7sfNBLy0CpFaiFSgSh6oH7 66zCeRjyQZoWvW/d+wkm11EWZRD/NZv3jzPeLJ37CRhHCIpMIogWbCzhF2yO8aR+6GCR+bBV9q/YYLDBfvxk8OC+QF EXFl+yZSK0YtGXIzYD5BLgkTdWm5YGbtmFeWIVRAFwFEFPIzozWMpPGiWTHoQcIl9Bt8q9rAYoRIRxh5hYm6vR1rGU rJtH1KjI344F0DSScqE+1WQLwhjhUJAUrJ3OGuMvoU/sNJLc+TA0cykdWOOQRePult/hL/vkxtbn2flKHcYROg7tVO jGzi9+HKQmEpX8w5b+24xzZt1+02X5uBwnxY1RMZO7NpAph8MNGZu8gezgK6+b8hnVxqS3KcjJAah0/nctnqe9fFvi wLSvNrV6jOs9moGUYjUNquZZLq6tSKgScxUN3XXS65b3YFud4qwauqVadoOZ/d5scirJVa2FG/2pfMletKluzJL3Sz WY/GITM/U4BiD7VgVgoqkvRo29qzUeXEMQ2ikkAu3LSVdMhEoih1gsYE+3VCCI/kJHMj2qj1vYCIOHjJTFPWnK/M7P 6l/4bwud4/+jP+Qzj7cgtlknqNnt30MhTXvCxTRiItt7NmxmOhPoGO/YH8gjhas79krfQc+yv7aJY9525pmYz7m6Es ieBjHzryHYTziYhvbWk/sXeS4/7c+EjcuxqLvNa4ovXIh53puZnV9OzmPUQrH8ALn3Hft7XExYYGh/QSN9CdwYL/gf UMcjLzWuv3S9p36ThNYp2k+N0AjV9GoQUZTuQbdGLioqwUNZ1vDeZPT6hBiXVqoVmNf7T/AJfsHsYhvPAplbmRzdHJ lYW0KZW5kb2JqCjEgMCBvYmo8PC9QYXJlbnQgNyAwIFIvQ29udGVudHMgNiAwIxxxxxxx8L1Byb2NTZXQgWy9QREYg L1RleHQgL0ltYWdlQiAvSW1hZ2VDIC9JbWFnZUldL0ZvbnQ8PC9GMSAyIDAgUj4+Pj4vTWVkaWFCb3hbMCAwIDU5NS 4yOCA4NDEuODhdL0Fubm90c1szIDAgUiA0IDAgUiA1IDAgUl0+PgplbmRvYmoKOCAwIG9iaiA8PC9MZW5ndGggMTcy L0ZpbHRlci9GbGF0ZURlY29kZT4+c3RyZWFtCnicdU89C8IwFNzfr7hRl5ikSZuugg6CQyHgIA5iP6TYpJWCf9+kWt FB3vLuvbvjbqC1JQ6jBDMGtqSNpYIG4ownmcaDJHbh35Lg2NPxxFFSksJwHfkdaZ0zaWZ8m3GSMq4CDNSv9cO60oFc sI1zb2KE1VZASNiaxHQVUBKZESzNYTtaXLwbKzfCO4y+h6/Rn5sKcmnbGPmvg1ZTr1+Hl5Qx9lbHwgU9AWiFO3EKZW 5kc3RyZWFtCmVuZG9iago5IDAgb2JqPDwvUGFyZW50IDcgMCBSL0NvbnRlbnRzIDggMCBSL1R5cGUvUGFnZS9SZXNv dXJjZXM8PC9Qcm9jU2V0IFsvUERGIC9UZXh0IC9JbWFnZUIgL0ltYWdlQyAvSW1hZ2VJXS9Gb250PDwvRjEgMiAwIF I+Pj4+L01lZGlhQm94WzAgMCA1OTUuMjggODQxLjg4XT4+CmVuZG9iagoyIDAgb2JqPDwvQmFzZUZvbnQvVGltZXMt Um9tYW4vVHlwZS9Gb250L0VuY29kaW5nL1dpbkFuc2lFbmNvZGluZy9TdWJ0eXBlL1R5cGUxPj4KZW5kb2JqCjcgMC BvYmo8PC9UeXBlL1BhZ2VzL0NvdW50IDIvS2lkc1sxIDAgUiA5IDAgUl0+PgplbmRvYmoKMTAgMCBvYmo8PC9UeXBl L0NhdGFsb2cvUGFnZXMgNyAwIFI+PgplbmRvYmoKMTEgMCBvYmo8PC9Qcm9kdWNlcihpVGV4dCAyLjAuOCBcKGJ5IG xvd2FnaWUuY29tXCkpL01vZERhdGUoRDoyMDE1MTEwNjE3MDIxNlopL0NyZWF0aW9uRGF0ZShEOjIwMTUxMTA2MTcw MjE2Wik+PgplbmRvYmoKeHJlZgoxxxxxxxxOCAwMDAwMCBuIAowMDAwMDAxODYzIDAwMDAwIG4gCnRyYWlsZXIKPDw vUm9vdCAxMCAwIFIvSUQgWzw3Zjk1ZTA4ZGJmMzllMjg3Yzk4NDAzMTE2NTk1M2M1ND48NmRjZmRlMjkxMGY4MTRlN DVlMGU3M2M2MTc3MjFlNmU+XS9JbmZvIDExIDAgUi9TaXplIDEyPj4Kc3RhcnR4cmVmCjE5ODMKJSVFT0YK
      Regards
      Javier
        • 1. Re: transient document API response
          havermeyer Level 1
          Hi Javier,
          I think I was getting the same error. I contacted support and this is what they told me:
          Our Engineering Team believes they have found the resolution, I have received the below information:
          In our latest release 8.0, we started honoring the 'text/html' in the HTTP Accept header. This was done to enable some new integrations that expected a text/html response. The API requests from Snap Finance have the following in the Accept header:
          As such the service is honoring the priority of text/html and returning in the appropriate format. Could you please try replacing the header in the integration with the value:
          Accept : */*
          This will ensure that we can respond correctly to your API requests as well as the requests from other integrators.
          If you have any other questions or concerns, please let us know.
          I've modified my Java code to include the following:
          headers.put(RestApiUtils.HttpHeaderField.ACCEPT.toString(), "*/*");
          • 2. Re: transient document API response
            javier-pex Level 1
            Many thanks havermeyer, that was the solution!
            After playing around with the "accept" header parameter and in order to be more restrictive with the response:
                        // Set the Accept header
                        headers.put(RestApiUtils.HttpHeaderField.ACCEPT.toString(), MimeType.JSON.toString());
            That works too
