7 Replies Latest reply on Jun 15, 2017 7:10 AM by Frank9
    How to Change Flash default bitmap properties
    nickcriscuolo@gmail.com
      I am making a pixel art animation from photoshop files that consist of many layers each. I don't want flash to compress or antialias the assets. As it stands currently I have to go into each layer and change the properties to lossless and turn off antialiasing. It's proving to be a huge time drain, especially when I have to re-import the photoshop file after some changes and do it all over again. Also is there a way to re-enable the feature that used to let you select which layers you want to import into Flash? Currently it seems like it just imports everything visible. It's workable, but not as convenient.
      Am I just missing these settings, or are they really no longer available? If not, then is there a script or add on that could do it?
