1 Reply Latest reply on Nov 6, 2015 9:44 PM by Rick Gerard
    I'm not getting Key-frames ;-;
    impulse.
      When I select "Time Remapping" on the footage I would like to edit, no Key-frames show up. I'm not totally sure if that's what is supposed to happen, but that's what I've learn't should happen when that setting is selected.
        • 1. Re: I'm not getting Key-frames ;-;
          Time remapping only works on video or nested composition layers. Select a layer and enable time remapping and you will get to keyframes.  If it is a still or text later or there is animation in the layer you won't get anything because the workflow is not correct.
          To learn more type "time remapping" in the search help field at the top right corner of the app and study up on the links provided.
