2 Replies Latest reply on Nov 7, 2015 12:04 PM by dvanhoof
    Lightroom keeps loading CR2 files but doesn't actually loads them
    dvanhoof
      Since this week  whenever Lightroom opens a catalogue or even when a new catalogue has been created Lightroom shows "loading" then eventually says " Lightroom encountered a problem with the (new) catalogue  and will check that catalogue when it starts up next" . Then it closes. When I then start Lightroom indeed it checks the catalogue but when click on any CR2 file the same thing happens I ha\ve been importing CR2 files since Lightroom 4 so I don't understand what the problem is, I reinstalled Lightroom, created a new catalogue but the issue remains. any help will be appreciated?
      here is the system info that LR showed me
      Lightroom version: 6.0 [1014445]
      License: Perpetual
      Operating system: Windows 8.1 Business Edition
      Version: 6.3 [9600]
      Application architecture: x64
      System architecture: x64
      Logical processor count: 8
      Processor speed: 3.3 GHz
      Built-in memory: 8150.0 MB
      Real memory available to Lightroom: 8150.0 MB
      Real memory used by Lightroom: 501.0 MB (6.1%)
      Virtual memory used by Lightroom: 451.3 MB
      Memory cache size: 1.6 MB
      Maximum thread count used by Camera Raw: 4
      Camera Raw SIMD optimization: SSE2,AVX
      System DPI setting: 96 DPI
      Desktop composition enabled: Yes
      Displays: 1) 1680x1050
      Input types: Multitouch: No, Integrated touch: No, Integrated pen: No, External touch: No, External pen: No, Keyboard: No
      Graphics Processor Info:
      GeForce GT 430/PCIe/SSE2
      Check OpenGL support: Passed
      Vendor: NVIDIA Corporation
      Version: 3.3.0 NVIDIA 353.62
      Renderer: GeForce GT 430/PCIe/SSE2
      LanguageVersion: 3.30 NVIDIA via Cg compiler
      Application folder: C:\Program Files\Adobe\Adobe Lightroom
      Library Path: L:\1_LR Catalogue\2016_Catalogue\2016_Catalogue.lrcat
      Settings Folder: C:\Users\DV_PC\AppData\Roaming\Adobe\Lightroom
      Installed Plugins:
      1) Behance
      2) Canon Tether Plugin
      3) Facebook
      4) Flickr
      5) Leica Tether Plugin
      6) Merge and Edit in HDR Express 2
      7) Nikon Tether Plugin
      Config.lua flags: None
      Adapter #1: Vendor : 10de
      Device : de1
      Subsystem : 836d1043
      Revision : a1
      Video Memory : 973
      Adapter #2: Vendor : 1414
      Device : 8c
      Subsystem : 0
      Revision : 0
      Video Memory : 0
      AudioDeviceIOBlockSize: 1024
      AudioDeviceName: Speakers (Realtek High Definition Audio)
      AudioDeviceNumberOfChannels: 2
      AudioDeviceSampleRate: 44100
      Build: Uninitialized
      Direct2DEnabled: false
      GPUDevice: not available
      OGLEnabled: true
        • 1. Re: Lightroom keeps loading CR2 files but doesn't actually loads them
          ssprengel Adobe Community Professional & MVP
          Is there a reason you’re still on LR 6.0?  I’d recommend upgrading to LR 6.1.1, not LR 6.2 or higher until LR 6.3 is available.  Links can be found, here, although the scenario on the webpage is about rolling back from LR 6.2, the steps should work to get to 6.1.1:
          http://www.lightroomqueen.com/how-do-i-roll-back-to-lightroom-2015-1-1-or-lightroom-6-1-1/
          As far as what’s actually happening to you, if a new catalog doesn’t help, then maybe your L: drive has issues and creating a catalog your internal C: drive would help diagnose this.  If the photos, themselves, have issues, then moving the catalog won’t help.
          A couple more unrelated things to try:  turn off GPU Acceleration in LR / Edit / Prefs / Performance, and purge your Camera Raw cache in LR Preferences / File Handling.
          • 2. Re: Lightroom keeps loading CR2 files but doesn't actually loads them
            dvanhoof Level 1
            Hi There,
            After exhausting all other options I finally managed to fix  it by first uninstalling Lightroom, Deleting the corrupt catalogue then  completely removing all Lightroom keys from the entire registry. Rebooted my  PC and reinstalled LR6  an now whilst it is importin the pictures again it finally loads cr2 files correctly, only a little slow now as it is still importin photographs (takes about 7 hours)  but I am certain that the problem is fixed,.
            Thank for your support
            Daniel
