4 Replies Latest reply on Nov 9, 2015 7:38 PM by ksmader
    After update, cannot import, need to restart many times per hour, slow, unresponsive
    ksmader
      After updating to version 6, Lightroom has become a MIND BOGGLINGLY TERRIBLE piece of software. I have NEVER in my life used an application this HORRENDOUS. It crashes or hangs at nearly every use. I have not quit normally once. The import dialog takes ages to open and then after checking photos, does not respond to clicking the button. The program uses 100% of CPU doing nothing ( I had to stop both face recognition and address lookup and it still does not work). It is garbage. Creative Cloud requires re-entering my password almost daily. Lightroom Mobile does not even allow me to login and when I try responds at a rate of 1 new character a minute.
      It is even worse that there is no real support and I have to resort to crappy forums and your facebook page.
        • 1. Re: After update, cannot import, need to restart many times per hour, slow, unresponsive
          Keith_Reeder Level 4
          And that attitude is supposed to encourage us to help you, is it?
          • 2. Re: After update, cannot import, need to restart many times per hour, slow, unresponsive
            deepakg1988 Adobe Employee
            Please let me know if you have already tried below mentioned steps to resolve this issue.
            Go to the preferences of the Lightroom and under the general tab please un check the option which says "Show Add Photo screen"
            In the performance tab uncheck the option which says"Use Gpu Processor"
            • 3. Re: After update, cannot import, need to restart many times per hour, slow, unresponsive
              ksmader Level 1
              Yes, I have already tried those steps, it did not fix the problem. I did not really expect help on the forum, since there is no help to be given. The problem is not my setup or configuration (even GPU is not really the problem), the problem is releasing buggy, poorly-tested software
              • 4. Re: After update, cannot import, need to restart many times per hour, slow, unresponsive
                ksmader Level 1
                And in case this additional jewel is relevant, Lightroom also produces GIGABYTES of log files in ~/Library/Logs with useful names like PDApp 11-10-2015 11-32-41.log and almost as useful contents like
                11/10/15 11:32:42:208 | [INFO] |  | ASU | OPM | IMSLibHelper |  |  | 120593 | OPMWrapper allocation succeeded
                11/10/15 11:32:42:208 | [INFO] |  | ASU | OPM | OPM |  |  | 120593 | _opm_handle_OPDReturnedStatus called with opdStatus as:0
                11/10/15 11:32:42:208 | [INFO] |  | ASU | OPM | OPM |  |  | 120593 | No Record found for the input fields in opm_getValueForKey
                11/10/15 11:32:42:208 | [INFO] |  | ASU | OPM | IMSLib_OPMWrapper |  |  | 120593 | Failed in getting value for key in OPMGetValueForKey domain:OOBE subDomain:ProxyCredentials key:ProxyUsername
                11/10/15 11:32:42:208 | [INFO] |  | ASU | OPM | IMSLibHelper |  |  | 120593 | Failed to get proxy user name from local db in getProxyCredentialsFromLocalStore
                11/10/15 11:32:42:208 | [INFO] |  | ASU | OPM | IMSLib |  |  | 120593 | Failed get proxy credentials from local store while creating IMSLib instance ...
                11/10/15 11:32:42:208 | [INFO] |  | ASU | OPM | IMSLib |  |  | 120593 | Performing fetch accessToken...
                11/10/15 11:32:42:208 | [INFO] |  | ASU | OPM | IMSLib |  |  | 120593 | Invalid argument inLocale while invoking IMS_fetchAccessToken
                11/10/15 11:32:42:208 | [INFO] |  | ASU | OPM | IMSLib |  |  | 120593 | Using environment:https://ims-na1.adobelogin.com
                This is absolutely ABSURD, under no circumstances should my computer be making a log file larger than about 100kb, let alone filling up my hard-drive which such nonsense
