2 Replies Latest reply on Nov 9, 2015 1:50 AM by rombanks
    ES: run external app
    rombanks Level 1
      Hello fellows,
      I wonder if there is a way in ES to launch an external application (e.g., Acrobat) with a specified path to the PDF file?
      I read about cross-DOM functions in the JS tools guide, but it's not clear where is the shared start up folder where a script with a call to acrobat.open should be put.
      Do you have any input on that?
      Thank you!
        • 1. Re: ES: run external app
          Klaus Göbel Level 3
          Hi rombanks
          have a look at the Javascript tools file (around page 52):
          fileObj.execute ()
          Opens this file using the appropriate application, as if it had been double-clicked in a file browser.
          You can use this method to run scripts, launch applications, and so on.
          Returns true immediately if the application launch was successful.
          This works for me:
          var cFileName = YourPath + "/FM2015_mifref.pdf";
          var cFile = new File (cFileName);
          if (cFile.exists)
               alert ("File not found : " + cFileName);
          • 2. Re: ES: run external app
            rombanks Level 1
            Hi Klaus,
            Thank you very much for your input! I just did not realize that I had to define the file as an object. I thought a variable with the filename/path is enough.
            Thanks for your help!
