4 Replies Latest reply on Nov 9, 2015 11:58 AM by deepakg1988
    Syncing collections edited on macbook to the master catalog on an imac
    pghdad1
      My Macbook Pro has a set images from a recent trip in a folder, from which I also created several collections on the Macbook Pro.  I have copied these "master" images and related collections to my iMac.  The folder structure for the master images on the iMac is in a different location than was on the Macbook Pro.   I have since done some editing of some of the collections on the iMac.
      On a subsequent trip, I took my Macbook Pro with the previous trip still on it, which has been untouched since I had loaded it to my iMac. While on this new trip I edited some of the images in some of the collections that had not been edited on my iMac.
      Now I need to sync these edited collections on the Macbook Pro back to the collection on the iMAC.  How do I do that?
      If I need to delete the collection on the iMAC and then sync the edited collection from the Macbook, I have no problem in deleting the collection on the iMAC since I am not trying to preserve anything from it.  But still - how do I just bring across a single collection (out of many) from the Macbook to the iMAC, and insure that the new collection links to the master images (stored in a different location on the iMac)  without having to move a whole catalog and related master images.  Hope this is clear :-)
        • 1. Re: Syncing collections edited on macbook to the master catalog on an imac
          deepakg1988 Adobe Employee
          The collections are saved inside the catalog that you are using in Lightroom
          You have to physically copy the catalog or export the collection as catalog.
          You can right click on the collection and choose export as catalog.
          then you can import the same catalog in the  imac.
          • 2. Re: Syncing collections edited on macbook to the master catalog on an imac
            Export a collection as a catalog
            You can export a collection of photos as a new catalog. When you create a catalog from a collection of photos, the settings in the photos are exported to the new catalog.
            Note:
            Exporting a smart collection as a catalog adds the photos in the smart collection to the new catalog. It does not export the rules or criteria that constitute the smart collection.
            • Select the collection or smart collection that you want to use to create a catalog.
              Right-click (Windows) or Control-click (Mac OS) the collection name and choose Export This Collection As A Catalog.
              Specify the name, location, and other options for the catalog, and then click Save (Windows) orExport Catalog (Mac OS).
            • 3. Re: Syncing collections edited on macbook to the master catalog on an imac
              Import photos from a different Lightroom catalog
              When you import photos from a different Lightroom catalog into the current catalog, you can specify options to handle new photos and photos that already appear in the current catalog.
              Note:
              Catalogs from earlier versions of Lightroom, including public beta releases, must be opened and updated before they can be imported into another catalog. See Upgrade a catalog from an earlier version of Lightroom.
              • Choose File > Import From Another Catalog.
                Navigate to the catalog you want to import and click Open (Windows) or Choose (Mac OS).
                Specify the photos to import:
                • Under Catalog Contents, make sure the folders containing the photos to import are selected.
                • To select or deselect individual photos, click Show Preview, and click the box in the upper-left corner of any preview image. You can also choose Check All or Uncheck All.
                In the New Photos area, choose an option from the File Handling menu:
                Add New Photos To Catalog Without Moving
                Imports photos at their current location.
                Copy New Photos To A New Location And Import
                Imports photos to a new location. Click Choose and specify the folder.
                Don’t Import New Photos
                Only photos that exist in the current catalog are imported. Lightroom determines a photo is a duplicate (already in the catalog) if it has the same, original filename; the same Exif capture date and time; and the same file size.
                In the Changed Existing Photos area, do any of the following:
                • Replace metadata, Develop settings, and negative files to override all the settings in the current catalog. If you choose this option, you can select the Preserve Old Settings As A Virtual Copy option to keep a backup. You can also select the Replace Non-Raw Files Only option to avoid replacing raw negatives. If changes to raw negative files affect only metadata, selecting this option helps save time.
                • Replace metadata and Develop settings only to leave the negative files (the source photos) unchanged. If you choose this option, you can select the Preserve Old Settings As A Virtual Copy option to keep a backup.
                • Replace nothing to import only new photos.
                • If photos in the current catalog are missing and can be found in the imported catalog, indicate whether you want to update the metadata and Develop settings for these files. Select the Preserve Old Settings As A Virtual Copy option to keep a backup. If the photos missing in the current catalog appear in the imported catalog, specify whether the missing files are copied and where they copied to.
                Click Import.
