2 Replies Latest reply on Nov 16, 2006 2:17 PM by Newsgroup_User
    Window component problem
    Level 7
      Flash 8.
      I have created a new movie with a window component in the library.
      A button click as follows:
      on (release) {
      Requires:
      - Window component in library
      import mx.managers.PopUpManager;
      import mx.containers.Window;
      System.security.allowDomain(" http://80.5.54.164");
      var my_win:MovieClip = PopUpManager.createPopUp(this, Window, true,
      {closeButton:true, contentPath:" http://80.5.54.164/swiff/kingnut.swf"});
      var winListener:Object = new Object();
      winListener.click = function(evt_obj:Object) {
      my_win.deletePopUp();
      winListener.complete = function(evt_obj:Object) {
      my_win.setSize(my_win.content._width, my_win.content._height + 25);
      my_win.addEventListener("click", winListener);
      my_win.addEventListener("complete", winListener);
      This workd fine and bring up a window with the movie and I can move the
      window and close the window.
      However when I try to add this to a current. ie add window component to
      libray new button with same code project I am getting the following errors:
      **Error** C:\Documents and Settings\stevew\Local Settings\Application
      Data\Macromedia\Flash
      8\en\Configuration\Classes\mx\managers\PopUpManager.as: Line 123: There is
      no method with the name 'deactivate'.
      SystemManager.deactivate(o);
      Data\Macromedia\Flash 8\en\Configuration\Classes\mx\containers\Window.as:
      Line 348: There is no property with the name 'clickHandler'.
      button_mc.clickHandler = delegateClick;
      8\en\Configuration\Classes\mx\controls\scrollClasses\ScrollBar.as: Line 272:
      There is no property with the name 'height'.
      var y:Number = ((pos-minPos) *
      (scrollTrack_mc.height-scrollThumb_mc._height) / (maxPos - minPos)) +
      scrollTrack_mc.top;
      8\en\Configuration\Classes\mx\controls\scrollClasses\ScrollBar.as: Line 494:
      thumbHeight = pageSize / (maxPos-minPos+pageSize) * o.height;
      8\en\Configuration\Classes\mx\controls\scrollClasses\ScrollBar.as: Line 497:
      if (o.height < st.minHeight)
      **Warning** Scene=Scene 1, layer=Vocalise.MC, frame=1:Line 12: There is no
      class or package with the name 'mx.containers' found in package 'mx'.
      Total ActionScript Errors: 6 Reported Errors: 6
      Both movies are set to publish flash 8.
      Any help appreciated
      SteveW
        • 1. Re: Window component problem
          Level 7
          I have just noticed that when I save my fla then try to run it I get the
          same error. I presume this is to do with paths somewhere but have no idea
          what is happening.
          Cheers
          SteveW
          > Flash 8.
          > on (release) {
          > Requires:
          > errors:
          > 272: There is no property with the name 'height'.
          > scrollTrack_mc.top;
          > 494: There is no property with the name 'height'.
          > 497: There is no property with the name 'height'.
          > SteveW
          • 2. Re: Window component problem
            Level 7
            If I save the movie to another drive the movie runs fine. I have been saving
            to the drive that IIS runs on. IE the the drive that 80.5.54.164 mapps to
            from the internet.
            It makes no difference if I take out any references to the domain.
            Very strange
            SteveW
            >what is happening.
            > Cheers
            > SteveW
            >> Flash 8.
            >> on (release) {
            >> Requires:
            >> errors:
            >> is no method with the name 'deactivate'.
            >> scrollTrack_mc.top;
            >> no class or package with the name 'mx.containers' found in package 'mx'.
            >> SteveW
