2 Replies Latest reply on Nov 11, 2015 11:20 AM by Karl Heinz Kremer
    error: doc.saveAs is not a function
    michel jv71650061
      Acrobat DC
      File: MyTrustedSaveAs.js
      contents of this file:
      myGetPath = app.trustPropagatorFunction(function(v1,v2){
      app.beginPriv();
      return app.getPath(v1,v2);
      app.endPriv();
      myTrustedGetPath = app.trustedFunction(function(v1,v2) {
      app.beginPriv();
      return myGetPath(v1,v2);
      app.endPriv();
      safeSaveAs = app.trustPropagatorFunction(function(doc,vPath){
      app.beginPriv();
      doc.saveAs({cPath:vPath});
      app.endPriv();
      myTrustedSaveAs = app.trustedFunction(function(doc,vPath){
      app.beginPriv();
      safeSaveAs(doc,vPath);
      app.endPriv();
      call from a mouse-up in a form:
      var d = getField("DATE").valueAsString;
      var f = getField("Name").valueAsString;
      // Specify the folder
      var fldr = "/c:/presort/";
      // Determine the full path
      var fp = fldr + d + f;
      // Save the file
      myTrustedSaveAs(fp);
      I receive the error:
      help...
        • 1. Re: error: doc.saveAs is not a function
          Bernd Alheit Adobe Community Professional & MVP
          This is correct. The function saveAs is not defined for a string.
          You must use the parameter doc and vPath.
          • 2. Re: error: doc.saveAs is not a function
            Karl Heinz Kremer Adobe Community Professional
            This is basic Javascript, and has nothing to do with how JavaScript is implemented in Acrobat. You may want to get a good tutorial about the core JavaScript language and read up on how functions need to be called. When you look at how the function myTrustedSaveAs() is defined, you will find this:
            This shows that you need two parameters: One called "doc", and one called "vPath" - you are only providing one (the path). So, change your function call to this, and it should work:
            myTrustedSaveAs(this, fp);
            "this" - in the context of a button event handler - will refer to the current document.
