1 Reply Latest reply on Nov 11, 2015 3:21 AM by Rick Gerard
    AE CC15 crashes while motiontracking!!!
    V4GmbH
      Please, just anyone. Can you give me a reasonable answer and solution for my issue?
      I just want to motiontrack my footage. Everytime I want to track, AE crashes. Tried this with two Macs. On both Macs it crashes.
      Nobody from the support can give me an answer.
      1st Mac:
      iMac 2012
      3,4 GHz Intel Core i7
      16 GB 1600 MHz DDR3
      NVIDIA GeForce GTX 680MX 2048 MB
      OS X 10.9.4 (13E28)
      2nd Mac:
      iMac 2010
      2,93 GHz Intel Core i7
      8 GB 1333 MHz DDR3
      ATI Radeon HD 5750 1024 MB
      OS X 10.10.3 (14D136)
      I motiontrack MXF files from a Sony PXW-FS7 with AE CC2015 (Version 13.5.0.347) via imported Premiere Sequence from CC2014.
      Actually I need to coulor grade my footage too which I do in SpeedGrade.
      But look how funny it is. If I grade with Premiere/SpeedGrade CC 2015 via dynamic link I would loose my correction after I switch between these two programs because of a bug in SpeedGrade CC15 that is not fixed yet, and Adobe support says, NOT to use it.
      So I didn't have problems in any other area of working with AE CC15 linked with Premiere CC14 while I can work with SpeedGrade CC14.
      The grading workflow with dynamic link with Premiere CC15 and SpeedGrade CC15 is not working, more it's a bug from the beginning of the release and nobody tells you.
      Only after long researches you'll find such infromation.
      In CC14 it does work. That's why I used Premiere CC14 and imported a CC14 sequence to AE CC15.
      Unfortunately for me is that mxf files do open and are able to motion track.
      It crashes when I try to motion track the Premiere sequence.
      I track with pauses so if the tracker makes mistakes I can correct them. That's the moment of crashing. When I'm tracking the hole "scene" it does not automatically crash but it has also mistakes in it so that I have to correct the keyframes afterwards.
      It's AGAIN a bug that I just cannot accept when I'm paying for it!...
      Btw, sometimes AE does not import your sequence in your composition which is also a bug since the release of CC15 and isn't fixed since then!
        • 1. Re: AE CC15 crashes while motiontracking!!!
          Seems like I have answered this before. Double post?  Your AE is not the latest version.
          You say you just want to motion track and you are using Sony footage. I just completed using AE's tracker to Stabilize (not warp stabilize), track, and do corner pin track several shots using Sony footage imported with the appropriate Sony Utility for the footage. I had no problems with CC 2015 build 13.5.1.48 on a Mac running OS X 10.11.1 (reported as the latest update on my system). I did not use Dynamic link to import the files, but I did trim them to length inside AE using the Footage panel before making comps out of them and doing the tracking. I also warp stabilized a few of the clips and Camera Tracked three of the shots with no problems.
          If after updating AE you still are having problems I would try tracking some footage in another format or try creating a DI (digital intermediate) of one of your clips using a production format or an image sequence and see if that will track. If updating AE did not fix the problem t would try using the appropriate Sony Utility to make the clips you are working with more compatible.
          BTW, I got the footage from a client so I'm not sure what  utility they used but I found them here: Software for Sony Equipment
