2 Replies Latest reply on Nov 17, 2015 2:40 PM by jeromiec83223024
    Roll OVER/OUT and Drag, is it a feature or bug?
    Nicolas Siver Level 1
      Hi guys,
      Is it feature, when you finish drag operation of child element, Roll OVER/OUT will be re-dispatched to parent element?
      Reproduce:
      1. Use provided code
      2. Start drag of a small circle until you leave green rectangle (you will see 'out' trace)
      3. Now stop drag operation by releasing mouse button
      4. You can see ('over' event is re-dispatched and every mouse move triggers 'out' once)
      Environment:
      Flash Player: 17.0.0.134, same reproducible in Chrome: 19.0.0.226
      OS X El Capitan, Version 10.11.1
      Example Code:
      package {
          import flash.display.Sprite;
          import flash.events.MouseEvent;
          import flash.geom.Rectangle;
          public class Main extends Sprite {
              private var _drag:Sprite;
              public function Main() {
                  var sensor:Sprite = new Sprite();
                  _drag = new Sprite();
                  sensor.addEventListener(MouseEvent.ROLL_OUT, mouseOut);
                  sensor.addEventListener(MouseEvent.ROLL_OVER, mouseOver);
                  sensor.addEventListener(MouseEvent.MOUSE_DOWN, mouseDown);
                  addChild(sensor);
                  sensor.addChild(_drag);
                  sensor.x = sensor.y = 100;
                  sensor.graphics.beginFill(0x009900);
                  sensor.graphics.drawRect(0, 0, 100, 100);
                  _drag.graphics.beginFill(0x990099);
                  _drag.graphics.drawCircle(0, 0, 5);
                  _drag.x = _drag.y = 10;
              private function mouseDown(e:MouseEvent):void {
                  _drag.startDrag(true, new Rectangle(10, 10, 50, 0));
                  stage.addEventListener(MouseEvent.MOUSE_UP, mouseUp);
              private function mouseOver(e:MouseEvent):void {
                  trace('over');
              private function mouseOut(e:MouseEvent):void {
                  trace('out');
              private function mouseUp(e:MouseEvent):void {
                  _drag.stopDrag();
