1 Reply Latest reply on Nov 12, 2015 9:56 AM by Rick Gerard
    Pixelated vectors
    judithr46653807
      Hello, please help. Searching very long in the web and in after effects for a solution.
      My imported vectors (.ai) are shown in After Effects pixelated by zoom in (200 percent and higher). Already used the best Quality (layers -> Quality -> best) and the Little * (star/sun-) button for all the layers and also the "/" button is active. I don`t know what to do.
      Pixelated vectors by zoom in - quality: optimum / activating the * (sun or star-)button: nothing happened -> vectors are still pixelated
      thanks.
      Judith
        • 1. Re: Pixelated vectors by zoom in - quality: optimum / activating the * (sun or star-)button: nothing happened -> vectors are still pixelated
          Check the Zoom factor in the comp window. It should be at 100%. Check the scale of your layer. With CR turned on and no rasterizing effects applied to an .ai file you should be able to scale without quality loss. If you have applied raster effects in Illustrator or layer styles then CR will not work.
          If this does not solve your problem then post a screenshot with the comp selected in the Project Panel so we can see the comp properties, the Composition panel set to a zoom factor of 100% and resolution set to Auto, previews set to Final Quality. Also, in the timeline, select the layer that is giving you problems, press the U key twice to reveal all modified properties. Now take a screenshot of the whole thing and drag it into the Reply field on this forum so we can see what's going on.
