4 Replies Latest reply on Nov 16, 2015 7:35 AM by LyndonPatton
    Javascript will not execute if a cfdocument tag is in a document
    LyndonPatton Level 1
      I have a popup form action page that opens by using the form/target="_blank"  attribute.
      The new document does a database insert and then creates a PDF using the <cfdocument> tag.
      I'm trying update some elements on the parent/opener form page as it is common for the client to continue using the parent, make some changes, and generate another PDF. If I comment out the <cfdocument> tag my code works fine, the parent document is updated as I expected.
      I'm not sure how to proceed, help much appreciated!
      thanks, Lyndon
      Javascript I'm trying to run just before the <cfdocument> tag:
      <script>
              window.opener.document.getElementById('photoListTitle').innerHTML='test update';
      </script>
      Tag Attributes:
      <cfdocument
              localUrl="yes"
              format="PDF"
              pageType="custom"
              pageWidth="2.2"
              pageHeight="3.375"
              marginBottom="0"
              marginTop="0"
              marginLeft="0"
              marginRight="0"
              orientation="portrait"
              backgroundVisible="yes"
              fontEmbed ="true"
              filename="PDFs/#Replace(BadgPhotoName,'.jpg','.pdf','All')#"
              overwrite="true">
                html...
      </cfdocument>
        • 1. Re: Javascript will not execute if a cfdocument tag is in a document
          Jamo Level 2
          What happens after the PDF is generated?  Is it automatically downloaded to the browser?  Have you tried using a hidden iFrame and some sort of modal notification to display that the file is being generated?  You could have the iframe page trigger a parent function to update HTML and return the link to the PDF file (so that it isn't automatically downloaded).  Files that are automatically downloaded performs a reset and any anything before the file download is ignored.
          • 2. Re: Javascript will not execute if a cfdocument tag is in a document
            The PDF is the action page from my form. Adobe Reader (or the clients PDF reader) is the opener as the <cfdocument> tag make the server send the client a PDF file.
            It seems once the template with a <cfdocument> tag opens, there is no DOM reference to the opener, since it's not an html file (that's my guess at this point anyhow).
            I've decided I need to work on a solution that uses <cflocation> to get the client to the <cfdocument> tag instead of the <cfinclude> tag I'm using now. That way, hopefully, I can use the form/target CFML template to  insert my database record, update the parent page, and pass the new record ID as a url variable to a third template that contains my <cfdocument> tag. Then I can query the new record to get the information the <cfdocument> needs to do the print job.
            I'll report back.
            • 3. Re: Javascript will not execute if a cfdocument tag is in a document
              Well.... Disappointment.
              <cflocation> has the same behavior???  If I comment out the cflocation tag the parent page updates, execute it and it does not.
              I thought for sure it would work since I'm opening a new template.
              Any ideas?
              • 4. Re: Javascript will not execute if a cfdocument tag is in a document
                Happiness!
                Jamo, you the man! An <Iframe> tag did it.
                Thank you so much.
                Passing the BadgeID as a url variable did not work, but a session var worked fine.
                [code]
                <cfoutput>
                    <script>
                        window.opener.document.getElementById('photoTitle').innerHTML='#BadgeID#';
                    </script>
                </cfoutput>
                <cfset Session.BadgeID=#BadgeID#>
                <cfswitch expression="#Form.CardFormat#">
                    <cfcase value="White">
                        <iframe src="WhiteOccupationalLicense.cfm"></iframe>
                    </cfcase>
                [/code]
