3 Replies Latest reply on Nov 17, 2006 9:17 AM by jsevlie
    Setting up RemoteObjects
    jsevlie
      I have a question about how to set up a simple RemoteObject call in Flex 2 (with CF 7.0.2). It seems like the examples inside the documentation never do a good enough job of actually telling you where your source files are supposed to be located in reference to everything else.
      So, my question is, does someone have some very quick and dirty sample code of how I can set up a simple RemoteObject call in Flex?
      I need:
      - Source code for your Flex app (with the <mx:RemoteObject> call).
      - Changes you had to make to your services-config.xml file
      - Location of your files (MXML code and your CFCs that the destination ties to)
      The Flex help always give a source like this:
      <source>samples.restaurant.RestaurantService</source>
      But then never actually tells you where in the world that object exists. Obviously there's some CFC called "RestaurantService", but where does it exist (full path)?
      The application that I built already uses Web services, but I'd like to switch over to remote objects (since they are binary and should be quicker than the doggy SOAP wrappers). Implementing web service calls was a snap, but the Remote Objects seems quite a bit more lengthy.
      Any help is greatly appreciated. Thanks!
        • 1. Re: Setting up RemoteObjects
          Well, I can give you an example of how we do it using JBoss instead of ColdFusion. Maybe it would help...
          Assuming you have FDS instead on your Java Application Server and your Java class has a public method you are trying to access. A simple one:
          package com.simple.example;
          public class AJavaClass {
          public AJavaClass() {}
          public String addExclamationPoint(String aString) { return aString + "!"; }
          You then to add configuration to your web.xml so that FDS can access your Java Class. Let's hope the markup will show:
          • 2. Re: Setting up RemoteObjects
            Level 1
            OK, let us continue this: the web.xml
            <context-param>
            <param-name>flex.class.path</param-name>
            <param-value>/WEB-INF/flex/hotfixes,/WEB-INF/flex/jars</param-value>
            </context-param>
            <!-- Http Flex Session attribute and binding listener support -->
            <listener>
            <listener-class>flex.messaging.HttpFlexSession</listener-class>
            </listener>
            <!-- MessageBroker Servlet -->
            <servlet>
            <servlet-name>MessageBrokerServlet</servlet-name>
            <display-name>MessageBrokerServlet</display-name>
            <servlet-class>flex.messaging.MessageBrokerServlet</servlet-class>
            <init-param>
            <param-name>services.configuration.file</param-name>
            <param-value>/WEB-INF/flex/services-config.xml</param-value>
            </init-param>
            <init-param>
            <param-name>flex.write.path</param-name>
            <param-value>/WEB-INF/flex</param-value>
            </init-param>
            <load-on-startup>1</load-on-startup>
            </servlet>
            <servlet>
            <servlet-name>FlexMxmlServlet</servlet-name>
            <display-name>MXML Processor</display-name>
            <description>Servlet wrapper for the Mxml Compiler</description>
            <servlet-class>flex.bootstrap.BootstrapServlet</servlet-class>
            <init-param>
            <param-name>servlet.class</param-name>
            <param-value>flex2.server.j2ee.MxmlServlet</param-value>
            </init-param>
            <init-param>
            <param-name>webtier.configuration.file</param-name>
            <param-value>/WEB-INF/flex/flex-webtier-config.xml</param-value>
            </init-param>
            </servlet>
            <servlet>
            <servlet-name>FlexSwfServlet</servlet-name>
            <display-name>SWF Retriever</display-name>
            <init-param>
            <param-value>flex2.server.j2ee.SwfServlet</param-value>
            </init-param>
            <!-- SwfServlet must be initialized after MxmlServlet -->
            <load-on-startup>2</load-on-startup>
            </servlet>
            <servlet>
            <servlet-name>FlexForbiddenServlet</servlet-name>
            <display-name>Prevents access to *.as/*.swc files</display-name>
            <init-param>
            <param-value>flex.server.j2ee.ForbiddenServlet</param-value>
            </init-param>
            </servlet>
            <servlet>
            <servlet-name>FlexInternalServlet</servlet-name>
            <init-param>
            <param-value>flex.server.j2ee.filemanager.FileManagerServlet</param-value>
            </init-param>
            <load-on-startup>10</load-on-startup>
            </servlet>
            <servlet-mapping>
            <url-pattern>/messagebroker/*</url-pattern>
            </servlet-mapping>
            <servlet-mapping>
            <url-pattern>*.mxml</url-pattern>
            </servlet-mapping>
            <servlet-mapping>
            <url-pattern>*.swf</url-pattern>
            </servlet-mapping>
            <servlet-mapping>
            <url-pattern>*.as</url-pattern>
            </servlet-mapping>
            <servlet-mapping>
            <url-pattern>*.swc</url-pattern>
            </servlet-mapping>
            <servlet-mapping>
            <url-pattern>/flex-internal/*</url-pattern>
            </servlet-mapping>
            you'll also need to place the flex folder in the WEB-INF of your WAR. Instead the flex folder is your remote-config and services config file. The remote-config you put the java class you are to access and the protocol you'll use (we are using AMF here):
            <default-channels>
            <channel ref="my-amf"/>
            <!-- <channel ref="my-http"/> -->
            </default-channels>
            <destination adapter="java-object" id="RO">
            <properties>
            <source>com.simple.example.AJavaClass</source>
            <scope>session</scope>
            </properties>
            </destination>
            You'll need to adjust your service-config to point to your application server...
            <channel-definition id="my-amf" class="mx.messaging.channels.AMFChannel">
            <endpoint uri=" http://jboss.example.simple.com:8080/prefix/messagebroker/amf" class="flex.messaging.endpoints.AMFEndpoint"/>
            <properties>
            <polling-enabled>true</polling-enabled>
            </properties>
            </channel-definition>
            You may need to adjust the security on services-config accordingly. The mxml can then look like this:
            <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml">
            <mx:Script>
            <![CDATA[
            private function runRO(event:Event):void
            RO.addExclamationPoint(text1.text);
            private function roLoaded(evt:ResultEvent):void
            text1.text = evt.result as String;
            </mx:Script>
            <mx:VBox x="0" y="0" percentWidth="100" percentHeight="100">
            <mx:HDividedBox
            horizontalAlign="left"
            percentWidth="100"
            percentHeight="100"
            backgroundColor="#FFFFFF">
            <mx:TextInput id="text1" />
            <mx:Button label="go" click="runRO" />
            </mx:HDividedBox>
            </mx:VBox>
            <mx:RemoteObject id="RO" destination="RO" >
            <mx:method
            name="addExclamationPoint"
            result="roLoaded(event)"
            fault="mx.controls.Alert.show(event.fault.message, 'RO Error')"/>
            </mx:RemoteObject>
            </mx:Application>
            We then precompile the flex and place the swf in the root directory of the war. You then just wrap it all up in the WAR and place it on the application server. Then things just magically work.
            Unfortunately, there is no steadfast way to do this because of the multiple platforms this needs to be able to run on. But this is esstentially how we got ours to work. As for using it with CF if you google "Flex 2 RemoteObject CF" you'll get plenty of examples.
            • 3. Setting up RemoteObjects
              jsevlie Level 1
              Ok, so I figured it out.
              [1]
              I don't need to touch the "services-config.xml". I am using ColdFusion 7.0.2 which means that I can communicate with CFCs without any further modification.
              [2]
              This was the code that I was using to invoke my remote object:
              <mx:RemoteObject id="dashboardRPC"
              destination="ColdFusion"
              source="cfc.dashboard">
              </mx:RemoteObject>
              However, I came to find out that the "source" directory is actually off the webroot of the ColdFusion installation (for us, that's d:\cfusionmx7\wwwroot). However, our IIS server uses a different root for all of the actual web files (d:\web\wwwroot). So, here's where I thought the CFC should go:
              d:\web\wwwroot\cfc\dashboard.cfc
              However, according the current setup, it's supposed to go here:
              d:\cfusionmx7\wwwroot\cfc\dashboard.cfc
              I can, however, keep the cfc in the IIS directory as long as I use a CF Mapping and then change services-config.xml to allow CF to use mappings.
              I now have it working. Thank goodness.
